Isaac Sim 4.5 Issues List
Isaac Sim Version
4.5.0
Operating System
Ubuntu 22.04
GPU Information
  • Model: GeForce RTX 3090
  • Driver Version: 555.42.06
Topic Description
Detailed Description
Related Issues
Additional Context
I refereed to [isaacsim.simulation_app] Isaac Sim Kit Helpers — Isaac Sim . This document shows “open_usd” option is enable. But I cannot use the option. When would the document update ?
It seems that the environment was broken during the process of installing ROS 2. I’m currently investigating at what stage it broke.
There are too many changes, so isn’t it all written together somewhere?
This is additional information about the action graph.
After trying the docker image nvcr.io/nvidia/isaac-sim:4.5.0, I found that the action graph was also broken in the tutorial python file. Therefore, it seems that the current Isaac Sim 4.5 cannot correctly process the action graph in standalone scripts.
./python.sh standalone_examples/tutorials/getting_started.py
./isaac-sim.sh --allow-root
Let’s use this topic to address the action graph issue. I haven’t encountered this problem when running the Isaac Sim Full application through the Isaac Sim Selector. Could you please confirm if you experienced the same behavior on your end?
Thank you for your response.
I’m using Isaac Sim with docker.
I can launch Isaac Sim with the below settings.
cd /isaac-sim/
./isaac-sim.selector.sh --allow-root
If I start it via the selector as you say, it seems that there are no problems.
When starting an Isaac Sim application in a Docker container, how do you encounter this issue? Could you please provide more details about the steps you’re taking and any error messages you receive? This information will help us better understand the problem and provide more effective assistance
I launched the container with below script.
#!/bin/bash
xhost +local:
docker run --name isaac-sim --entrypoint bash -it --gpus all -e "ACCEPT_EULA=Y" --rm --network=host --privileged \
    -v ~/docker/isaac-sim/cache/kit:/isaac-sim/kit/cache/Kit:rw \
    -v ~/docker/isaac-sim/cache/ov:/root/.cache/ov:rw \
    -v ~/docker/isaac-sim/cache/pip:/root/.cache/pip:rw \
    -v ~/docker/isaac-sim/cache/glcache:/root/.cache/nvidia/GLCache:rw \
    -v ~/docker/isaac-sim/cache/computecache:/root/.nv/ComputeCache:rw \
    -v ~/docker/isaac-sim/logs:/root/.nvidia-omniverse/logs:rw \
    -v ~/docker/isaac-sim/data:/root/.local/share/ov/data:rw \
    -v ~/docker/isaac-sim/documents:/root/Documents:rw \
    --env="DISPLAY" \
    -v $HOME/.Xauthority:/root/.Xauthority:rw \
    -v /tmp/.X11-unix:/tmp/.X11-unix \
The execution logs for each command are as follows.
# ./python.sh standalone_examples/tutorials/getting_started.py
Starting kit application with the following args:  ['/isaac-sim/exts/isaacsim.simulation_app/isaacsim/simulation_app/simulation_app.py', '/isaac-sim/apps/isaacsim.exp.base.python.kit', '--/app/tokens/exe-path=/isaac-sim/kit', '--/persistent/app/viewport/displayOptions=3094', '--/rtx/materialDb/syncLoads=True', '--/rtx/hydra/materialSyncLoads=True', '--/omni.kit.plugin/syncUsdLoads=True', '--/app/renderer/resolution/width=1280', '--/app/renderer/resolution/height=720', '--/app/window/width=1440', '--/app/window/height=900', '--/renderer/multiGpu/enabled=True', '--/app/fastShutdown=True', '--/app/installSignalHandlers=0', '--ext-folder', '/isaac-sim/exts', '--ext-folder', '/isaac-sim/apps', '--/physics/cudaDevice=0', '--portable', '--allow-root']
Passing the following args to the base kit application:  []
[Info] [carb] Logging to file: /isaac-sim/kit/logs/Kit/Isaac-Sim Python/4.5/kit_20250313_152312.log
2025-03-13 15:23:12 [0ms] [Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn't available.
[0.052s] [ext: omni.kit.async_engine-0.0.1] startup
[0.742s] [ext: omni.metrics.core-0.0.1] startup
[0.742s] [ext: omni.client.lib-1.0.0] startup
[0.769s] [ext: omni.blobkey-1.1.2] startup
[0.770s] [ext: omni.stats-1.0.1] startup
[0.771s] [ext: omni.datastore-0.0.0] startup
[0.776s] [ext: omni.client-1.2.2] startup
[0.781s] [ext: omni.ujitso.default-1.0.0] startup
[0.782s] [ext: omni.hsscclient-1.1.1] startup
2025-03-13 15:23:12 [768ms] [Warning] [omni.datastore] OmniHub is inaccessible
[0.786s] [ext: omni.gpu_foundation.shadercache.vulkan-1.0.0] startup
[0.795s] [ext: omni.assets.plugins-0.0.0] startup
[0.796s] [ext: omni.gpu_foundation-0.0.0] startup
[0.804s] [ext: carb.windowing.plugins-1.0.0] startup
2025-03-13 15:23:13 [1,318ms] [Warning] [carb.windowing-glfw.gamepad] Joystick with unknown remapping detected (will be ignored):  Sony Interactive Entertainment DualSense Wireless Controller Touchpad [030000004c050000e60c000011810000]
2025-03-13 15:23:13 [1,318ms] [Warning] [carb.windowing-glfw.gamepad] Joystick with unknown remapping detected (will be ignored):  ELECOM ELECOM TrackBall Mouse Consumer Control [030000006e050000f900000011010000]
2025-03-13 15:23:13 [1,318ms] [Warning] [carb.windowing-glfw.gamepad] Joystick with unknown remapping detected (will be ignored):  SteelSeries SteelSeries GameDAC [03000000381000008012000011010000]
2025-03-13 15:23:13 [1,318ms] [Warning] [carb.windowing-glfw.gamepad] Joystick with unknown remapping detected (will be ignored):  Logitech USB Receiver Consumer Control [030000006d04000048c5000011010000]
2025-03-13 15:23:13 [1,318ms] [Warning] [carb.windowing-glfw.gamepad] Joystick with unknown remapping detected (will be ignored):  Logitech USB Receiver [030000006d04000048c5000011010000]
[1.334s] [ext: omni.kit.renderer.init-0.0.0] startup
| Driver Version: 555.42.06     | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | Bus-ID    |            |
| 0   | NVIDIA GeForce RTX 3090          | Yes: 0 |     | 24822   MB | 10de      | 0          |
|     |                                  |        |     |            | 2204      | 63c31080.. |
|     |                                  |        |     |            | b         |            |
| OS: 22.04.5 LTS (Jammy Jellyfish) ubuntu, Version: 22.04.5, Kernel: 6.5.0-15-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12101004 (1.21.1.4)
| Processor: AMD Ryzen 9 5950X 16-Core Processor
| Cores: 16 | Logical Cores: 32
| Total Memory (MB): 64211 | Free Memory: 58369
| Total Page/Swap (MB): 2048 | Free Page/Swap: 0
2025-03-13 15:23:14 [2,234ms] [Warning] [gpu.foundation.plugin] IOMMU is enabled.
[2.448s] [ext: omni.kit.pipapi-0.0.0] startup
[2.452s] [ext: omni.kit.pip_archive-0.0.0] startup
[2.452s] [ext: omni.pip.compute-1.4.5] startup
[2.453s] [ext: omni.materialx.libs-1.0.6] startup
[2.462s] [ext: omni.kit.telemetry-0.5.1] startup
[2.494s] [ext: omni.pip.cloud-1.1.7] startup
[2.508s] [ext: omni.isaac.core_archive-2.3.3] startup
[2.509s] [ext: omni.usd.config-1.0.5] startup
[2.514s] [ext: omni.gpucompute.plugins-0.0.0] startup
[2.515s] [ext: omni.usd.libs-1.0.1] startup
[2.576s] [ext: omni.isaac.ml_archive-2.1.2] startup
[2.577s] [ext: omni.mdl-55.0.1] startup
[2.701s] [ext: omni.iray.libs-0.0.0] startup
[2.706s] [ext: omni.mdl.neuraylib-0.2.10] startup
[2.710s] [ext: omni.kit.usd.mdl-1.0.7] startup
[2.817s] [ext: omni.kit.loop-isaac-1.2.1] startup
[2.818s] [ext: omni.kit.test-1.1.2] startup
[3.026s] [ext: omni.appwindow-1.1.9] startup
[3.948s] [ext: omni.kit.renderer.core-1.0.2] startup
[8.449s] [ext: omni.kit.renderer.capture-0.0.0] startup
[8.453s] [ext: omni.kit.renderer.imgui-1.0.2] startup
[8.516s] [ext: omni.ui-2.26.5] startup
[8.530s] [ext: omni.kit.mainwindow-1.0.3] startup
[8.532s] [ext: carb.audio-0.1.0] startup
[8.536s] [ext: omni.uiaudio-1.0.0] startup
[8.537s] [ext: omni.kit.uiapp-0.0.0] startup
[8.537s] [ext: omni.usd.schema.metrics.assembler-106.5.0] startup
[8.544s] [ext: omni.usd.schema.anim-0.0.0] startup
[8.564s] [ext: omni.usd.schema.isaac-3.0.2] startup
[8.564s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[8.566s] [ext: omni.usd.schema.physx-106.5.7] startup
[8.593s] [ext: omni.usd.schema.audio-0.0.0] startup
[8.597s] [ext: omni.usd.schema.semantics-0.0.0] startup
[8.599s] [ext: omni.usd_resolver-1.0.0] startup
[8.603s] [ext: usdrt.scenegraph-7.5.1] startup
[8.643s] [ext: omni.kit.actions.core-1.0.0] startup
[8.646s] [ext: omni.timeline-1.0.11] startup
[8.648s] [ext: omni.usd.core-1.4.2] startup
[8.651s] [ext: omni.resourcemonitor-107.0.0] startup
[8.653s] [ext: omni.activity.core-1.0.1] startup
[8.655s] [ext: omni.kit.audiodeviceenum-1.0.1] startup
[8.657s] [ext: omni.hydra.usdrt_delegate-7.5.1] startup
[8.665s] [ext: omni.graph.exec-0.9.4] startup
[8.665s] [ext: omni.kit.window.popup_dialog-2.0.24] startup
[8.674s] [ext: omni.kit.exec.core-0.13.4] startup
[8.677s] [ext: omni.kit.widget.nucleus_connector-1.1.10] startup
[8.684s] [ext: omni.kit.usd_undo-0.1.8] startup
[8.685s] [ext: omni.kit.commands-1.4.9] startup
[8.695s] [ext: omni.hydra.scene_delegate-0.3.3] startup
[8.698s] [ext: omni.usd-1.12.4] startup
[8.774s] [ext: omni.kit.asset_converter-2.8.3] startup
[8.789s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[8.794s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[8.800s] [ext: omni.usd.schema.forcefield-106.5.7] startup
[8.805s] [ext: isaacsim.robot.schema-3.1.2] startup
[8.812s] [ext: omni.inspect-1.0.1] startup
[8.814s] [ext: omni.kit.notification_manager-1.0.9] startup
[8.818s] [ext: omni.graph.core-2.181.8] startup
[8.820s] [ext: isaacsim.core.deprecation_manager-0.2.2] startup
[8.822s] [ext: omni.index.libs-380600.1777.0] startup
[8.822s] [ext: omni.ujitso.processor.texture-1.0.0] startup
[8.823s] [ext: omni.index-1.0.1] startup
[8.824s] [ext: omni.kit.widget.path_field-2.0.11] startup
[8.828s] [ext: omni.volume-0.5.0] startup
[8.833s] [ext: omni.ujitso.client-0.0.0] startup
[8.833s] [ext: omni.hydra.rtx.shadercache.vulkan-1.0.0] startup
[8.834s] [ext: omni.kit.widget.browser_bar-2.0.10] startup
[8.837s] [ext: omni.kit.clipboard-1.0.5] startup
[8.838s] [ext: omni.hydra.rtx-1.0.0] startup
2025-03-13 15:23:20 [8,828ms] [Warning] [omni.log] Source: omni.hydra was already registered.
[8.855s] [ext: omni.kit.viewport.registry-104.0.6] startup
[8.857s] [ext: omni.kit.helper.file_utils-0.1.9] startup
[8.861s] [ext: omni.kit.widget.options_menu-1.1.6] startup
[8.870s] [ext: omni.kit.menu.core-1.1.2] startup
[8.873s] [ext: omni.kit.widget.filebrowser-2.10.52] startup
[8.897s] [ext: omni.ui.scene-1.11.2] startup
[8.901s] [ext: omni.kit.widget.options_button-1.0.3] startup
[8.902s] [ext: omni.kit.widget.context_menu-1.2.4] startup
[8.907s] [ext: omni.kit.viewport.legacy_gizmos-1.0.16] startup
[8.909s] [ext: omni.kit.usd.layers-2.2.0] startup
[8.933s] [ext: omni.kit.window.filepicker-2.11.7] startup
[8.995s] [ext: omni.kit.hydra_texture-1.4.0] startup
[8.999s] [ext: omni.kit.viewport.scene_camera_model-1.0.5] startup
[9.003s] [ext: omni.kit.context_menu-1.8.3] startup
[9.011s] [ext: omni.kit.window.file_importer-1.1.14] startup
[9.015s] [ext: omni.kit.menu.utils-1.7.7] startup
[9.042s] [ext: omni.kit.widget.viewport-107.0.7] startup
[9.059s] [ext: omni.kit.window.drop_support-1.0.4] startup
[9.060s] [ext: omni.kit.raycast.query-1.0.5] startup
[9.064s] [ext: omni.kit.material.library-1.5.15] startup
[9.088s] [ext: omni.hydra.engine.stats-1.0.3] startup
[9.090s] [ext: omni.kit.viewport.window-107.0.8] startup
[9.131s] [ext: omni.warp.core-1.5.0] startup
[9.382s] [ext: omni.kit.viewport.utility-1.0.18] startup
[9.387s] [ext: omni.kit.hotkeys.core-1.3.10] startup
[9.388s] [ext: omni.kit.widget.prompt-1.0.7] startup
[9.390s] [ext: omni.kit.usd.collect-2.2.22] startup
[9.400s] [ext: omni.kit.window.content_browser_registry-0.0.6] startup
[9.402s] [ext: omni.graph.tools-1.79.1] startup
[9.503s] [ext: omni.kit.window.file_exporter-1.0.31] startup
[9.506s] [ext: omni.kit.stage_template.core-1.1.22] startup
[9.508s] [ext: omni.graph.image.core-0.6.0] startup
[9.509s] [ext: omni.graph.action_core-1.1.7] startup
[9.512s] [ext: omni.graph-1.140.2] startup
[9.622s] [ext: omni.kit.window.file-1.3.57] startup
[9.635s] [ext: omni.kit.widget.filter-1.1.4] startup
[9.638s] [ext: omni.graph.image.nodes-1.3.0] startup
[9.640s] [ext: omni.graph.action_nodes-1.40.1] startup
[9.644s] [ext: omni.kit.window.content_browser-2.10.3] startup
[9.676s] [ext: omni.kvdb-106.5.7] startup
[9.704s] [ext: omni.graph.action-1.120.0] startup
[9.708s] [ext: omni.kit.tool.collect-2.2.16] startup
[9.732s] [ext: omni.graph.nodes-1.162.1] startup
[9.764s] [ext: omni.kit.widget.searchfield-1.1.8] startup
[9.815s] [ext: omni.localcache-106.5.7] startup
[9.820s] [ext: omni.convexdecomposition-106.5.7] startup
[9.869s] [ext: omni.kit.widget.stage_icons-1.0.6] startup
[9.876s] [ext: omni.kit.widget.stage-2.11.6] startup
[9.930s] [ext: omni.usdphysics-106.5.7] startup
[9.932s] [ext: omni.physx.foundation-106.5.7] startup
[9.934s] [ext: omni.physics.tensors-106.5.7] startup
[9.952s] [ext: omni.kit.window.stage-2.5.11] startup
[9.958s] [ext: omni.kit.property.adapter.core-1.0.2] startup
[9.963s] [ext: omni.physx.cooking-106.5.7] startup
[9.969s] [ext: omni.kit.widget.zoombar-1.0.5] startup
[9.972s] [ext: omni.kit.widget.highlight_label-1.0.3] startup
[9.974s] [ext: omni.kit.property.adapter.usd-1.0.2] startup
[9.977s] [ext: omni.kit.property.adapter.fabric-1.0.3] startup
[9.982s] [ext: omni.physx-106.5.7] startup
[9.996s] [ext: omni.kit.browser.core-2.3.11] startup
[10.011s] [ext: omni.kit.window.property-1.11.5] startup
[10.020s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[10.021s] [ext: omni.kit.property.usd-4.2.16] startup
[10.078s] [ext: omni.physx.tensors-106.5.7] startup
[10.083s] [ext: omni.kit.menu.stage-1.2.5] startup
[10.085s] [ext: omni.kit.browser.folder.core-1.10.1] startup
[10.105s] [ext: omni.warp-1.5.0] startup
[10.122s] [ext: isaacsim.examples.browser-0.1.8] startup
[10.131s] [ext: omni.physx.stageupdate-106.5.7] startup
[10.137s] [ext: omni.kit.numpy.common-0.1.2] startup
[10.139s] [ext: isaacsim.core.version-2.0.2] startup
[10.157s] [ext: omni.isaac.dynamic_control-1.3.15] startup
2025-03-13 15:23:22 [10,152ms] [Warning] [omni.isaac.dynamic_control] omni.isaac.dynamic_control is deprecated as of Isaac Sim 4.5. No action is needed from end-users.
[10.170s] [ext: isaacsim.storage.native-1.0.6] startup
[10.178s] [ext: omni.kit.menu.create-1.0.17] startup
[10.186s] [ext: isaacsim.core.utils-2.2.8] startup
[10.216s] [ext: omni.kit.widget.searchable_combobox-1.0.6] startup
[10.231s] [ext: omni.kit.primitive.mesh-1.0.17] startup
[10.275s] [ext: isaacsim.core.simulation_manager-0.3.3] startup
[12.550s] [ext: omni.kit.scripting-106.5.2] startup
[12.567s] [ext: omni.kit.stage_templates-1.2.6] startup
[12.574s] [ext: isaacsim.core.prims-0.3.7] startup
[12.657s] [ext: isaacsim.replicator.behavior-1.0.8] startup
[12.660s] [ext: isaacsim.core.api-4.2.16] startup
[12.706s] [ext: omni.ui_query-1.1.7] startup
[12.711s] [ext: omni.kit.manipulator.viewport-107.0.1] startup
[12.714s] [ext: omni.kit.ui_test-1.3.3] startup
[12.721s] [ext: omni.kit.window.extensions-1.4.25] startup
[12.752s] [ext: omni.graph.visualization.nodes-2.1.1] startup
[12.760s] [ext: omni.kit.tool.asset_importer-2.12.2] startup
[12.801s] [ext: isaacsim.gui.components-1.0.9] startup
[12.826s] [ext: omni.kit.widget.settings-1.2.2] startup
[12.839s] [ext: omni.kit.widget.graph-1.12.17] startup
[12.871s] [ext: omni.kit.window.preferences-1.7.0] startup
[12.892s] [ext: omni.kit.graph.delegate.default-1.2.2] startup
[12.893s] [ext: omni.kit.viewport.menubar.core-107.1.2] startup
[12.932s] [ext: omni.kit.widget.material_preview-1.0.16] startup
[12.938s] [ext: omni.kit.graph.usd.commands-1.3.1] startup
[12.941s] [ext: omni.kit.graph.editor.core-1.5.3] startup
[12.953s] [ext: omni.syntheticdata-0.6.10] startup
[13.027s] [ext: omni.kit.window.material_graph-1.8.19] startup
[13.139s] [ext: omni.graph.scriptnode-1.40.1] startup
[13.143s] [ext: isaacsim.core.cloner-1.3.4] startup
[13.149s] [ext: omni.replicator.core-1.11.35] startup
Warp 1.5.0 initialized:
   CUDA Toolkit 11.8, Driver 12.5
   Devices:
     "cpu"      : "x86_64"
     "cuda:0"   : "NVIDIA GeForce RTX 3090" (24 GiB, sm_86, mempool enabled)
   Kernel cache:
     /root/.cache/warp/1.5.0
2025-03-13 15:23:25 [13,316ms] [Warning] [omni.replicator.core.scripts.extension] No material configuration file, adding configuration to material settings directly.
[13.334s] [ext: omni.isaac.cloner-1.0.2] startup
2025-03-13 15:23:25 [13,321ms] [Warning] [omni.isaac.cloner] omni.isaac.cloner has been deprecated in favor of isaacsim.core.cloner. Please update your code accordingly.
[13.337s] [ext: isaacsim.core.nodes-2.1.4] startup
[13.352s] [ext: isaacsim.asset.importer.urdf-2.3.10] startup
[13.642s] [ext: omni.isaac.core-4.0.3] startup
2025-03-13 15:23:25 [13,642ms] [Warning] [omni.isaac.core.physics_context.physics_context] omni.isaac.core.physics_context.physics_context has been deprecated in favor of isaacsim.core.api.physics_context.physics_context. Please update your code accordingly.
2025-03-13 15:23:25 [13,652ms] [Warning] [omni.isaac.core.simulation_context.simulation_context] omni.isaac.core.simulation_context.simulation_context has been deprecated in favor of isaacsim.core.api.simulation_context.simulation_context. Please update your code accordingly.
2025-03-13 15:23:25 [13,661ms] [Warning] [omni.isaac.core.world.world] omni.isaac.core.world.world has been deprecated in favor of isaacsim.core.api.world.world. Please update your code accordingly.
2025-03-13 15:23:25 [13,661ms] [Warning] [omni.isaac.core] omni.isaac.core has been deprecated in favor of isaacsim.core.api. Please update your code accordingly.
[13.677s] [ext: omni.isaac.core_nodes-2.0.2] startup
2025-03-13 15:23:25 [13,674ms] [Warning] [omni.isaac.core_nodes] omni.isaac.core_nodes has been deprecated in favor of isaacsim.core.nodes. Please update your code accordingly.
[13.690s] [ext: omni.anim.curve.core-1.2.0] startup
[13.759s] [ext: isaacsim.robot_motion.lula-4.0.4] startup
[13.783s] [ext: isaacsim.asset.importer.mjcf-2.3.3] startup
[13.820s] [ext: isaacsim.robot_motion.motion_generation-8.0.6] startup
[13.918s] [ext: isaacsim.asset.browser-1.3.4] startup
[14.177s] [ext: isaacsim.robot.surface_gripper-2.0.6] startup
[14.182s] [ext: omni.kit.selection-0.1.5] startup
[14.188s] [ext: isaacsim.robot_motion.lula_test_widget-1.0.5] startup
[14.199s] [ext: omni.isaac.assets_check-0.3.9] startup
2025-03-13 15:23:26 [14,192ms] [Warning] [omni.isaac.assets_check] omni.isaac.assets_check has been deprecated in favor of isaacsim.asset.browser. Please update your code accordingly.
[14.207s] [ext: isaacsim.robot.manipulators-3.0.4] startup
[14.216s] [ext: isaacsim.sensors.physics-0.3.5] startup
[14.235s] [ext: isaacsim.gui.menu-2.0.9] startup
[14.270s] [ext: omni.isaac.lula_test_widget-1.0.2] startup
2025-03-13 15:23:26 [14,257ms] [Warning] [omni.isaac.lula_test_widget] omni.isaac.lula_test_widget has been deprecated in favor of isaacsim.robot_motion.lula_test_widget. Please update your code accordingly.
[14.273s] [ext: omni.sensors.nv.common-2.5.0-coreapi] startup
[14.285s] [ext: omni.isaac.manipulators-3.0.3] startup
2025-03-13 15:23:26 [14,270ms] [Warning] [omni.isaac.manipulators] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-03-13 15:23:26 [14,271ms] [Warning] [omni.isaac.manipulators.controllers] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-03-13 15:23:26 [14,271ms] [Warning] [omni.isaac.manipulators.controllers.pick_place_controller] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-03-13 15:23:26 [14,273ms] [Warning] [omni.isaac.manipulators.controllers.stacking_controller] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-03-13 15:23:26 [14,274ms] [Warning] [omni.isaac.manipulators.grippers] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-03-13 15:23:26 [14,274ms] [Warning] [omni.isaac.manipulators.grippers.gripper] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-03-13 15:23:26 [14,274ms] [Warning] [omni.isaac.manipulators.grippers.parallel_gripper] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-03-13 15:23:26 [14,274ms] [Warning] [omni.isaac.manipulators.grippers.surface_gripper] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-03-13 15:23:26 [14,275ms] [Warning] [omni.isaac.manipulators.manipulators] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-03-13 15:23:26 [14,275ms] [Warning] [omni.isaac.manipulators.manipulators.single_manipulator] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
[14.291s] [ext: isaacsim.robot.policy.examples-4.0.3] startup
[14.294s] [ext: omni.isaac.menu-1.0.2] startup
2025-03-13 15:23:26 [14,280ms] [Warning] [omni.isaac.menu] omni.isaac.menu has been deprecated in favor of isaacsim.gui.menu. Please update your code accordingly.
[14.296s] [ext: omni.isaac.motion_generation-8.0.2] startup
2025-03-13 15:23:26 [14,284ms] [Warning] [omni.isaac.motion_generation] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:23:26 [14,284ms] [Warning] [omni.isaac.motion_generation.articulation_kinematics_solver] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:23:26 [14,284ms] [Warning] [omni.isaac.motion_generation.articulation_motion_policy] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:23:26 [14,285ms] [Warning] [omni.isaac.motion_generation.articulation_trajectory] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:23:26 [14,285ms] [Warning] [omni.isaac.motion_generation.kinematics_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:23:26 [14,285ms] [Warning] [omni.isaac.motion_generation.lula] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:23:26 [14,285ms] [Warning] [omni.isaac.motion_generation.lula.kinematics] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:23:26 [14,286ms] [Warning] [omni.isaac.motion_generation.lula.motion_policies] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:23:26 [14,286ms] [Warning] [omni.isaac.motion_generation.lula.path_planners] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:23:26 [14,286ms] [Warning] [omni.isaac.motion_generation.lula.trajectory_generator] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:23:26 [14,287ms] [Warning] [omni.isaac.motion_generation.motion_policy_controller] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:23:26 [14,287ms] [Warning] [omni.isaac.motion_generation.motion_policy_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:23:26 [14,287ms] [Warning] [omni.isaac.motion_generation.path_planner_visualizer] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:23:26 [14,287ms] [Warning] [omni.isaac.motion_generation.path_planning_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:23:26 [14,288ms] [Warning] [omni.isaac.motion_generation.trajectory] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:23:26 [14,288ms] [Warning] [omni.isaac.motion_generation.world_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
[14.304s] [ext: omni.sensors.nv.materials-1.4.0-coreapi] startup
[14.307s] [ext: omni.isaac.nucleus-1.0.3] startup
2025-03-13 15:23:26 [14,292ms] [Warning] [omni.isaac.nucleus] omni.isaac.nucleus has been deprecated in favor of isaacsim.storage.native. Please update your code accordingly.
2025-03-13 15:23:26 [14,293ms] [Warning] [omni.isaac.nucleus.nucleus] omni.isaac.nucleus.nucleus has been deprecated in favor of isaacsim.storage.native. Please update your code accordingly.
[14.308s] [ext: omni.isaac.quadruped-3.0.2] startup
2025-03-13 15:23:26 [14,294ms] [Warning] [omni.isaac.quadruped] omni.isaac.quadruped has been deprecated in favor of isaacsim.robot.policy.examples. Please update your code accordingly.
[14.309s] [ext: omni.kit.manipulator.selector-1.1.1] startup
[14.314s] [ext: omni.sensors.nv.wpm-2.4.0-coreapi] startup
[14.317s] [ext: omni.sensors.nv.lidar-2.6.3-coreapi] startup
[14.322s] [ext: omni.sensors.nv.ids-1.4.0-coreapi] startup
[14.326s] [ext: isaacsim.robot.manipulators.examples-1.0.3] startup
[14.328s] [ext: isaacsim.util.debug_draw-2.0.2] startup
[14.332s] [ext: omni.sensors.tiled-0.0.6] startup
[14.334s] [ext: omni.sensors.nv.radar-2.6.1-coreapi] startup
[14.340s] [ext: omni.kit.widget.toolbar-1.7.3] startup
[14.360s] [ext: omni.kit.manipulator.transform-106.0.1] startup
[14.379s] [ext: isaacsim.sensors.physx-2.2.4] startup
[14.388s] [ext: isaacsim.sensors.rtx-13.6.3] startup
[14.399s] [ext: isaacsim.sensors.camera-0.2.9] startup
[14.420s] [ext: isaacsim.cortex.framework-1.0.2] startup
[14.426s] [ext: omni.kit.manipulator.tool.snap-1.5.12] startup
[14.457s] [ext: omni.isaac.range_sensor-4.0.2] startup
[14.460s] [ext: omni.isaac.surface_gripper-2.0.2] startup
2025-03-13 15:23:26 [14,446ms] [Warning] [omni.isaac.surface_gripper] omni.isaac.surface_gripper has been deprecated in favor of isaacsim.robot.surface_gripper. Please update your code accordingly.
[14.462s] [ext: omni.isaac.sensor-13.0.3] startup
2025-03-13 15:23:26 [14,448ms] [Warning] [omni.isaac.sensor] omni.isaac.sensor has been deprecated in favor of isaacsim.sensors.camera, isaacsim.sensors.physics, isaacsim.sensors.physx, and isaacsim.sensors.rtx. Please update your code accordingly.
2025-03-13 15:23:26 [14,448ms] [Warning] [omni.isaac.sensor.camera] omni.isaac.sensor.camera has been deprecated in favor of isaacsim.sensors.camera.camera. Please update your code accordingly.
2025-03-13 15:23:26 [14,449ms] [Warning] [omni.isaac.sensor.camera_view] omni.isaac.sensor.camera_view has been deprecated in favor of isaacsim.sensors.camera.camera_view. Please update your code accordingly.
2025-03-13 15:23:26 [14,449ms] [Warning] [omni.isaac.sensor.commands] omni.isaac.sensor.commands has been deprecated in favor of isaacsim.sensors.physics.commands, isaacsim.sensors.physx.commands, and isaacsim.sensors.rtx.commands. Please update your code accordingly.
2025-03-13 15:23:26 [14,449ms] [Warning] [omni.isaac.sensor.contact_sensor] omni.isaac.sensor.contact_sensor has been deprecated in favor of isaacsim.sensors.physics.contact_sensor. Please update your code accordingly.
2025-03-13 15:23:26 [14,449ms] [Warning] [omni.isaac.sensor.imu_sensor] omni.isaac.sensor.imu_sensor has been deprecated in favor of isaacsim.sensors.physics.imu_sensor. Please update your code accordingly.
2025-03-13 15:23:26 [14,450ms] [Warning] [omni.isaac.sensor.lidar_rtx] omni.isaac.sensor.lidar_rtx has been deprecated in favor of isaacsim.sensors.rtx.lidar_rtx. Please update your code accordingly.
2025-03-13 15:23:26 [14,450ms] [Warning] [omni.isaac.sensor.rotating_lidar_physX] omni.isaac.sensor.imu_sensor has been deprecated in favor of isaacsim.sensors.physix.rotating_lidar_physX. Please update your code accordingly.
2025-03-13 15:23:26 [14,451ms] [Warning] [omni.isaac.sensor.scripts.samples.contact_sensor] omni.isaac.sensor.scripts.samples.contact_sensor has been deprecated in favor of isaacsim.sensors.physics.scripts.samples.contact_sensor. Please update your code accordingly.
2025-03-13 15:23:26 [14,451ms] [Warning] [omni.isaac.sensor.scripts.samples.imu_sensor] omni.isaac.sensor.scripts.samples.imu_sensor has been deprecated in favor of isaacsim.sensors.physics.scripts.samples.imu_sensor. Please update your code accordingly.
2025-03-13 15:23:26 [14,451ms] [Warning] [omni.isaac.sensor.scripts.samples.lightbeam_sensor] omni.isaac.sensor.scripts.samples.lightbeam_sensor has been deprecated in favor of isaacsim.sensors.physx.scripts.samples.lightbeam_sensor. Please update your code accordingly.
[14.467s] [ext: omni.isaac.cortex-1.0.2] startup
2025-03-13 15:23:26 [14,454ms] [Warning] [omni.isaac.cortex] omni.isaac.cortex has been deprecated in favor of isaacsim.cortex.framework. Please update your code accordingly.
[14.470s] [ext: omni.kit.viewport.manipulator.transform-107.0.4] startup
[14.482s] [ext: omni.debugdraw-0.1.3] startup
[14.486s] [ext: omni.isaac.universal_robots-1.0.2] startup
2025-03-13 15:23:26 [14,471ms] [Warning] [omni.isaac.universal_robots] omni.isaac.universal_robots has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
2025-03-13 15:23:26 [14,472ms] [Warning] [omni.isaac.universal_robots.kinematics_solver] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
2025-03-13 15:23:26 [14,473ms] [Warning] [omni.isaac.universal_robots.ur10] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
[14.489s] [ext: omni.isaac.utils-2.0.2] startup
[14.492s] [ext: omni.kit.manipulator.prim.core-107.0.7] startup
[14.513s] [ext: omni.fabric.commands-1.1.5] startup
[14.525s] [ext: omni.kit.manipulator.selection-106.0.1] startup
[14.529s] [ext: omni.kit.viewport.actions-107.0.0] startup
[14.538s] [ext: omni.kit.manipulator.prim.usd-107.0.3] startup
[14.541s] [ext: omni.kit.manipulator.prim.fabric-107.0.4] startup
[14.546s] [ext: isaacsim.cortex.behaviors-2.0.3] startup
[14.548s] [ext: omni.kit.widget.layers-1.8.2] startup
[14.593s] [ext: omni.kit.viewport.menubar.display-107.0.3] startup
[14.598s] [ext: omni.kit.manipulator.prim-107.0.0] startup
[14.599s] [ext: omni.isaac.cortex.sample_behaviors-2.0.2] startup
2025-03-13 15:23:26 [14,584ms] [Warning] [omni.isaac.cortex.sample_behaviors] omni.isaac.cortex.sample_behaviors has been deprecated in favor of isaacsim.cortex.behaviors. Please update your code accordingly.
[14.599s] [ext: omni.graph.ui_nodes-1.40.1] startup
[14.604s] [ext: omni.usdphysics.ui-106.5.7] startup
[14.682s] [ext: omni.physx.commands-106.5.7] startup
[14.723s] [ext: omni.kit.property.camera-1.0.9] startup
[14.738s] [ext: omni.hydra.scene_api-0.1.2] startup
[14.746s] [ext: omni.kit.property.geometry-1.3.3] startup
[14.768s] [ext: omni.kit.property.light-1.0.11] startup
[14.776s] [ext: omni.physx.ui-106.5.7] startup
[14.873s] [ext: omni.kit.property.material-1.10.17] startup
[14.894s] [ext: omni.kit.property.render-1.1.3] startup
[14.898s] [ext: omni.kit.property.transform-1.5.10] startup
[14.916s] [ext: omni.kit.property.audio-1.0.16] startup
[14.921s] [ext: isaacsim.gui.property-1.0.4] startup
[14.927s] [ext: omni.physx.demos-106.5.7] startup
[15.016s] [ext: omni.kit.property.physx-106.5.7] startup
[15.078s] [ext: omni.isaac.lula-4.0.2] startup
2025-03-13 15:23:27 [15,065ms] [Warning] [omni.isaac.lula] omni.isaac.lula has been deprecated in favor of isaacsim.robot_motion.lula. Please update your code accordingly.
[15.081s] [ext: omni.kit.property.bundle-1.3.2] startup
[15.084s] [ext: omni.kit.property.isaac-1.0.2] startup
2025-03-13 15:23:27 [15,070ms] [Warning] [omni.kit.property.isaac] omni.kit.property.isaac has been deprecated in favor of isaacsim.gui.property. Please update your code accordingly.
2025-03-13 15:23:27 [15,071ms] [Warning] [omni.kit.property.isaac.widgets] omni.kit.property.isaac.widgets has been deprecated in favor of isaacsim.gui.property.widgets. Please update your code accordingly.
[15.087s] [ext: omni.physx.vehicle-106.5.7] startup
[15.150s] [ext: omni.kit.viewport.menubar.camera-107.0.2] startup
[15.167s] [ext: omni.kit.viewport.menubar.lighting-106.0.2] startup
[15.177s] [ext: omni.kit.viewport.menubar.render-107.0.8] startup
[15.186s] [ext: omni.kit.viewport.menubar.settings-107.0.3] startup
[15.201s] [ext: omni.kit.window.console-0.2.14] startup
[15.214s] [ext: omni.physx.camera-106.5.7] startup
[15.226s] [ext: omni.kit.window.toolbar-1.6.2] startup
[15.232s] [ext: omni.isaac.version-2.0.2] startup
2025-03-13 15:23:27 [15,218ms] [Warning] [omni.isaac.version] omni.isaac.version has been deprecated in favor of isaacsim.core.version. Please update your code accordingly.
[15.234s] [ext: isaacsim.robot.wheeled_robots-4.0.3] startup
[15.249s] [ext: omni.physx.cct-106.5.7] startup
[15.272s] [ext: omni.physx.graph-106.5.7] startup
[15.312s] [ext: isaacsim.replicator.writers-1.0.1] startup
[15.576s] [ext: omni.physx.supportui-106.5.7] startup
[15.641s] [ext: omni.physx.telemetry-106.5.7] startup
[15.647s] [ext: omni.isaac.wheeled_robots-3.0.3] startup
2025-03-13 15:23:27 [15,632ms] [Warning] [omni.isaac.wheeled_robots] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-03-13 15:23:27 [15,633ms] [Warning] [omni.isaac.wheeled_robots.controllers] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-03-13 15:23:27 [15,633ms] [Warning] [omni.isaac.wheeled_robots.controllers.ackermann_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-03-13 15:23:27 [15,633ms] [Warning] [omni.isaac.wheeled_robots.controllers.differential_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-03-13 15:23:27 [15,634ms] [Warning] [omni.isaac.wheeled_robots.controllers.holonomic_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-03-13 15:23:27 [15,634ms] [Warning] [omni.isaac.wheeled_robots.controllers.quintic_path_planner] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-03-13 15:23:27 [15,634ms] [Warning] [omni.isaac.wheeled_robots.controllers.stanley_control] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-03-13 15:23:27 [15,634ms] [Warning] [omni.isaac.wheeled_robots.controllers.wheel_base_pose_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-03-13 15:23:27 [15,635ms] [Warning] [omni.isaac.wheeled_robots.impl] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-03-13 15:23:27 [15,635ms] [Warning] [omni.isaac.wheeled_robots.robots] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-03-13 15:23:27 [15,635ms] [Warning] [omni.isaac.wheeled_robots.robots.holonomic_robot_usd_setup] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-03-13 15:23:27 [15,636ms] [Warning] [omni.isaac.wheeled_robots.robots.wheeled_robot] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
[15.651s] [ext: omni.isaac.franka-1.0.2] startup
2025-03-13 15:23:27 [15,638ms] [Warning] [omni.isaac.franka] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
2025-03-13 15:23:27 [15,639ms] [Warning] [omni.isaac.franka.franka] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
2025-03-13 15:23:27 [15,640ms] [Warning] [omni.isaac.franka.kinematics_solver] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
[15.656s] [ext: isaacsim.replicator.domain_randomization-1.0.2] startup
[15.664s] [ext: isaacsim.replicator.examples-1.1.2] startup
[15.668s] [ext: omni.kit.window.status_bar-0.1.7] startup
[15.677s] [ext: omni.rtx.window.settings-0.6.17] startup
[15.714s] [ext: omni.usd.metrics.assembler-106.5.0] startup
[15.729s] [ext: omni.physx.bundle-106.5.7] startup
[15.730s] [ext: isaacsim.app.about-2.0.7] startup
[15.737s] [ext: omni.replicator.isaac-2.0.3] startup
2025-03-13 15:23:27 [15,724ms] [Warning] [omni.replicator.isaac] omni.replicator.isaac has been deprecated in favor of isaacsim.replicator.domain_randomization, isaacsim.replicator.examples, isaacsim.replicator.writers. Please update your code accordingly.
[15.740s] [ext: omni.replicator.replicator_yaml-2.0.10] startup
[15.789s] [ext: omni.rtx.settings.core-0.6.3] startup
[15.812s] [ext: omni.usd.metrics.assembler.ui-106.5.0] startup
[15.823s] [ext: isaacsim.simulation_app-2.4.2] startup
[15.824s] [ext: omni.isaac.window.about-2.0.2] startup
2025-03-13 15:23:27 [15,809ms] [Warning] [omni.isaac.window.about] omni.isaac.window.about has been deprecated in favor of isaacsim.app.about. Please update your code accordingly.
2025-03-13 15:23:27 [15,810ms] [Warning] [omni.isaac.window.about.about] omni.isaac.window.about.about has been deprecated in favor of isaacsim.app.about.about. Please update your code accordingly.
[15.825s] [ext: semantics.schema.editor-0.3.10] startup
[15.832s] [ext: omni.kit.ui.actions-1.0.2] startup
[15.835s] [ext: semantics.schema.property-1.0.5] startup
[15.838s] [ext: omni.kit.manipulator.camera-106.0.3] startup
[15.855s] [ext: omni.isaac.kit-2.0.3] startup
2025-03-13 15:23:27 [15,840ms] [Warning] [omni.isaac.kit] omni.isaac.kit has been deprecated in favor of isaacsim.simulation_app. Please update your code accordingly.
[15.855s] [ext: omni.isaac.asset_browser-1.0.2] startup
2025-03-13 15:23:27 [15,841ms] [Warning] [omni.isaac.asset_browser] omni.isaac.asset_browser has been deprecated in favor of isaacsim.asset.browser. Please update your code accordingly.
[15.857s] [ext: isaacsim.core.throttling-2.0.2] startup
[15.859s] [ext: omni.kit.menu.common-1.1.9] startup
[15.862s] [ext: isaacsim.exp.base-4.5.0] startup
[15.863s] [ext: isaacsim.exp.base.python-4.5.0] startup
[15.864s] Simulation App Starting
[16.212s] app ready
2025-03-13 15:23:28 [16,217ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit buffer size 7374781440
2025-03-13 15:23:28 [16,217ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : valid false, within: false
2025-03-13 15:23:28 [16,217ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : decrement: 167690, decrement size: 7301033856
2025-03-13 15:23:28 [16,217ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : New limit 9748724 (slope: 439, intercept: 13179904)
2025-03-13 15:23:28 [16,217ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit buffer size 4287352704
2025-03-13 15:23:28 [16,217ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : valid true, within: true
2025-03-13 15:23:29 [17,082ms] [Warning] [omni.usd-abi.plugin] No setting was found for '/rtx-defaults-transient/meshlights/forceDisable'
2025-03-13 15:23:29 [17,417ms] [Warning] [omni.usd-abi.plugin] No setting was found for '/rtx-defaults/post/dlss/execMode'
# ./isaac-sim.sh --allow-root
Loading user config located at: '/root/.local/share/ov/data/Kit/Isaac-Sim Full/4.5/user.config.json'
[Info] [carb] Logging to file: /root/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/4.5/kit_20250313_152045.log
[0.407s] [ext: omni.kit.async_engine-0.0.1] startup
[1.149s] [ext: omni.metrics.core-0.0.1] startup
[1.150s] [ext: omni.client.lib-1.0.0] startup
[1.177s] [ext: omni.blobkey-1.1.2] startup
[1.177s] [ext: omni.stats-1.0.1] startup
[1.178s] [ext: omni.datastore-0.0.0] startup
[1.183s] [ext: omni.client-1.2.2] startup
[1.188s] [ext: omni.ujitso.default-1.0.0] startup
[1.190s] [ext: omni.hsscclient-1.1.1] startup
2025-03-13 15:20:46 [1,167ms] [Warning] [omni.datastore] OmniHub is inaccessible
[1.193s] [ext: omni.gpu_foundation.shadercache.vulkan-1.0.0] startup
[1.202s] [ext: omni.assets.plugins-0.0.0] startup
[1.204s] [ext: omni.gpu_foundation-0.0.0] startup
[1.211s] [ext: carb.windowing.plugins-1.0.0] startup
2025-03-13 15:20:46 [1,631ms] [Warning] [carb.windowing-glfw.gamepad] Joystick with unknown remapping detected (will be ignored):  Sony Interactive Entertainment DualSense Wireless Controller Touchpad [030000004c050000e60c000011810000]
2025-03-13 15:20:46 [1,631ms] [Warning] [carb.windowing-glfw.gamepad] Joystick with unknown remapping detected (will be ignored):  ELECOM ELECOM TrackBall Mouse Consumer Control [030000006e050000f900000011010000]
2025-03-13 15:20:46 [1,631ms] [Warning] [carb.windowing-glfw.gamepad] Joystick with unknown remapping detected (will be ignored):  SteelSeries SteelSeries GameDAC [03000000381000008012000011010000]
2025-03-13 15:20:46 [1,631ms] [Warning] [carb.windowing-glfw.gamepad] Joystick with unknown remapping detected (will be ignored):  Logitech USB Receiver Consumer Control [030000006d04000048c5000011010000]
2025-03-13 15:20:46 [1,631ms] [Warning] [carb.windowing-glfw.gamepad] Joystick with unknown remapping detected (will be ignored):  Logitech USB Receiver [030000006d04000048c5000011010000]
[1.655s] [ext: omni.kit.renderer.init-0.0.0] startup
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | Bus-ID    |            |
|     |                                  |        |     |            | 2204      | 63c31080.. |
|     |                                  |        |     |            | b         |            |
| Total Memory (MB): 64211 | Free Memory: 58443
2025-03-13 15:20:47 [2,494ms] [Warning] [gpu.foundation.plugin] IOMMU is enabled.
[2.719s] [ext: omni.kit.pipapi-0.0.0] startup
[2.723s] [ext: omni.kit.pip_archive-0.0.0] startup
[2.724s] [ext: omni.pip.compute-1.4.5] startup
[2.724s] [ext: omni.pip.cloud-1.1.7] startup
[2.738s] [ext: omni.isaac.core_archive-2.3.3] startup
[2.738s] [ext: omni.materialx.libs-1.0.6] startup
[2.747s] [ext: omni.isaac.ml_archive-2.1.2] startup
[2.747s] [ext: omni.usd.config-1.0.5] startup
[2.753s] [ext: omni.gpucompute.plugins-0.0.0] startup
[2.753s] [ext: omni.usd.libs-1.0.1] startup
[2.812s] [ext: omni.kit.telemetry-0.5.1] startup
[2.845s] [ext: omni.mdl-55.0.1] startup
[2.973s] [ext: omni.iray.libs-0.0.0] startup
[2.978s] [ext: omni.mdl.neuraylib-0.2.10] startup
[2.982s] [ext: omni.kit.usd.mdl-1.0.7] startup
[3.092s] [ext: omni.kit.loop-isaac-1.2.1] startup
[3.094s] [ext: omni.kit.test-1.1.2] startup
[3.317s] [ext: omni.appwindow-1.1.9] startup
[4.142s] [ext: omni.kit.renderer.core-1.0.2] startup
[8.737s] [ext: omni.kit.renderer.capture-0.0.0] startup
[8.741s] [ext: omni.kit.renderer.imgui-1.0.2] startup
[8.801s] [ext: omni.ui-2.26.5] startup
[8.815s] [ext: omni.kit.mainwindow-1.0.3] startup
[8.817s] [ext: carb.audio-0.1.0] startup
[8.821s] [ext: omni.uiaudio-1.0.0] startup
[8.822s] [ext: omni.kit.uiapp-0.0.0] startup
[8.822s] [ext: omni.usd.schema.metrics.assembler-106.5.0] startup
[8.828s] [ext: omni.usd.schema.semantics-0.0.0] startup
[8.831s] [ext: omni.usd.schema.audio-0.0.0] startup
[8.834s] [ext: isaacsim.robot.schema-3.1.2] startup
[8.842s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[8.847s] [ext: omni.anim.graph.schema-106.5.0] startup
[8.852s] [ext: omni.usd.schema.anim-0.0.0] startup
[8.870s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[8.873s] [ext: omni.usd_resolver-1.0.0] startup
[8.876s] [ext: omni.kit.window.popup_dialog-2.0.24] startup
[8.885s] [ext: usdrt.scenegraph-7.5.1] startup
[8.922s] [ext: omni.timeline-1.0.11] startup
[8.924s] [ext: omni.usd.core-1.4.2] startup
[8.926s] [ext: omni.resourcemonitor-107.0.0] startup
[8.929s] [ext: omni.activity.core-1.0.1] startup
[8.930s] [ext: omni.kit.widget.nucleus_connector-1.1.10] startup
[8.937s] [ext: omni.hydra.usdrt_delegate-7.5.1] startup
[8.945s] [ext: omni.kit.actions.core-1.0.0] startup
[8.949s] [ext: omni.graph.exec-0.9.4] startup
[8.949s] [ext: omni.kit.commands-1.4.9] startup
[8.958s] [ext: omni.kit.usd_undo-0.1.8] startup
[8.959s] [ext: omni.kit.exec.core-0.13.4] startup
[8.962s] [ext: omni.kit.audiodeviceenum-1.0.1] startup
[8.963s] [ext: omni.hydra.scene_delegate-0.3.3] startup
[8.967s] [ext: omni.usd-1.12.4] startup
[9.040s] [ext: omni.inspect-1.0.1] startup
[9.041s] [ext: omni.kit.notification_manager-1.0.9] startup
[9.046s] [ext: omni.graph.core-2.181.8] startup
[9.049s] [ext: isaacsim.core.deprecation_manager-0.2.2] startup
[9.053s] [ext: omni.usd.schema.forcefield-106.5.7] startup
[9.063s] [ext: omni.kit.asset_converter-2.8.3] startup
[9.081s] [ext: omni.usd.schema.isaac-3.0.2] startup
[9.081s] [ext: omni.anim.navigation.schema-106.4.0] startup
[9.084s] [ext: omni.usd.schema.scene.visualization-2.0.2] startup
[9.086s] [ext: omni.usd.schema.physx-106.5.7] startup
[9.107s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[9.111s] [ext: omni.kit.property.adapter.core-1.0.2] startup
[9.114s] [ext: omni.kit.property.adapter.usd-1.0.2] startup
[9.117s] [ext: omni.kit.property.adapter.fabric-1.0.3] startup
[9.121s] [ext: omni.kit.widget.nucleus_info-1.0.2] startup
[9.123s] [ext: omni.kit.helper.file_utils-0.1.9] startup
[9.126s] [ext: omni.kit.widget.path_field-2.0.11] startup
[9.130s] [ext: omni.kit.search_core-1.0.6] startup
[9.132s] [ext: omni.kit.widget.filebrowser-2.10.52] startup
[9.154s] [ext: omni.kit.widget.options_menu-1.1.6] startup
[9.163s] [ext: omni.kit.widget.browser_bar-2.0.10] startup
[9.166s] [ext: omni.graph.tools-1.79.1] startup
[9.265s] [ext: omni.kit.widget.search_delegate-1.0.6] startup
[9.269s] [ext: omni.kit.widget.options_button-1.0.3] startup
[9.270s] [ext: omni.kit.clipboard-1.0.5] startup
[9.271s] [ext: omni.graph-1.140.2] startup
[9.599s] [ext: omni.kit.menu.core-1.1.2] startup
[9.603s] [ext: omni.kit.collaboration.telemetry-1.0.0] startup
[9.605s] [ext: omni.kit.widget.context_menu-1.2.4] startup
[9.609s] [ext: omni.kit.collaboration.channel_manager-1.0.12] startup
[9.614s] [ext: omni.ui.scene-1.11.2] startup
[9.618s] [ext: omni.kit.widget.versioning-1.4.9] startup
[9.627s] [ext: omni.kit.usd.layers-2.2.0] startup
[9.651s] [ext: omni.kit.window.filepicker-2.11.7] startup
[9.710s] [ext: omni.kit.widget.filter-1.1.4] startup
[9.713s] [ext: omni.kit.hotkeys.core-1.3.10] startup
[9.724s] [ext: omni.kit.context_menu-1.8.3] startup
[9.732s] [ext: omni.kit.window.file_importer-1.1.14] startup
[9.737s] [ext: omni.kit.window.file_exporter-1.0.31] startup
[9.741s] [ext: omni.kit.widget.searchfield-1.1.8] startup
[9.747s] [ext: omni.kit.stage_template.core-1.1.22] startup
[9.749s] [ext: omni.kit.widget.stage-2.11.6] startup
[9.787s] [ext: omni.hydra.engine.stats-1.0.3] startup
[9.790s] [ext: omni.kit.widget.highlight_label-1.0.3] startup
[9.793s] [ext: omni.kit.window.file-1.3.57] startup
[9.806s] [ext: omni.ujitso.processor.texture-1.0.0] startup
[9.807s] [ext: omni.index.libs-380600.1777.0] startup
[9.807s] [ext: omni.volume-0.5.0] startup
[9.812s] [ext: omni.ujitso.client-0.0.0] startup
[9.813s] [ext: omni.index-1.0.1] startup
[9.813s] [ext: omni.hydra.rtx.shadercache.vulkan-1.0.0] startup
[9.815s] [ext: omni.kit.window.content_browser_registry-0.0.6] startup
[9.817s] [ext: omni.hydra.rtx-1.0.0] startup
2025-03-13 15:20:55 [9,798ms] [Warning] [omni.log] Source: omni.hydra was already registered.
[9.833s] [ext: omni.kit.viewport.registry-104.0.6] startup
[9.835s] [ext: omni.kit.viewport.legacy_gizmos-1.0.16] startup
[9.837s] [ext: omni.kit.raycast.query-1.0.5] startup
[9.842s] [ext: omni.kit.viewport.scene_camera_model-1.0.5] startup
[9.846s] [ext: omni.kit.hydra_texture-1.4.0] startup
[9.849s] [ext: omni.kit.menu.utils-1.7.7] startup
[9.868s] [ext: omni.kit.window.drop_support-1.0.4] startup
[9.870s] [ext: omni.kit.widget.viewport-107.0.7] startup
[9.886s] [ext: omni.kit.material.library-1.5.15] startup
[9.909s] [ext: omni.convexdecomposition-106.5.7] startup
[9.913s] [ext: omni.kit.viewport.window-107.0.8] startup
[9.951s] [ext: omni.kit.window.property-1.11.5] startup
[9.960s] [ext: omni.kit.window.content_browser-2.10.3] startup
[9.983s] [ext: omni.kit.widget.searchable_combobox-1.0.6] startup
[9.988s] [ext: omni.kit.widget.prompt-1.0.7] startup
[9.992s] [ext: omni.kit.widget.settings-1.2.2] startup
[10.002s] [ext: omni.kit.widget.live_session_management.ui-1.0.1] startup
[10.012s] [ext: omni.kit.collaboration.presence_layer-1.0.9] startup
[10.024s] [ext: omni.usdphysics-106.5.7] startup
[10.027s] [ext: omni.kvdb-106.5.7] startup
[10.029s] [ext: omni.kit.window.preferences-1.7.0] startup
[10.048s] [ext: omni.physx.foundation-106.5.7] startup
[10.051s] [ext: omni.localcache-106.5.7] startup
[10.053s] [ext: omni.kit.widget.live_session_management-1.2.20] startup
[10.062s] [ext: omni.physx.cooking-106.5.7] startup
[10.069s] [ext: omni.kit.viewport.utility-1.0.18] startup
[10.074s] [ext: omni.kit.property.usd-4.2.16] startup
[10.131s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[10.134s] [ext: omni.physx-106.5.7] startup
[10.148s] [ext: omni.ui_query-1.1.7] startup
[10.152s] [ext: omni.kit.window.extensions-1.4.25] startup
[10.181s] [ext: omni.graph.action_core-1.1.7] startup
[10.184s] [ext: isaacsim.core.version-2.0.2] startup
[10.187s] [ext: omni.graph.ui-1.91.0] startup
[10.243s] [ext: omni.physx.stageupdate-106.5.7] startup
[10.250s] [ext: omni.kit.numpy.common-0.1.2] startup
[10.252s] [ext: isaacsim.storage.native-1.0.6] startup
[10.257s] [ext: omni.graph.action_nodes-1.40.1] startup
[10.261s] [ext: omni.isaac.dynamic_control-1.3.15] startup
2025-03-13 15:20:55 [10,248ms] [Warning] [omni.isaac.dynamic_control] omni.isaac.dynamic_control is deprecated as of Isaac Sim 4.5. No action is needed from end-users.
[10.273s] [ext: omni.kit.window.cursor-1.1.4] startup
[10.277s] [ext: omni.graph.image.core-0.6.0] startup
[10.278s] [ext: omni.physics.tensors-106.5.7] startup
[10.299s] [ext: omni.warp.core-1.5.0] startup
[10.599s] [ext: omni.graph.image.nodes-1.3.0] startup
[10.601s] [ext: omni.physx.tensors-106.5.7] startup
[10.606s] [ext: isaacsim.core.utils-2.2.8] startup
[10.610s] [ext: omni.graph.action-1.120.0] startup
[10.612s] [ext: omni.kit.viewport.menubar.core-107.1.2] startup
[10.650s] [ext: omni.graph.nodes-1.162.1] startup
[10.659s] [ext: isaacsim.core.simulation_manager-0.3.3] startup
[12.809s] [ext: omni.kit.widget.graph-1.12.17] startup
[12.841s] [ext: omni.kit.manipulator.viewport-107.0.1] startup
[12.844s] [ext: omni.warp-1.5.0] startup
[12.861s] [ext: omni.syntheticdata-0.6.10] startup
[12.980s] [ext: isaacsim.core.prims-0.3.7] startup
[13.180s] [ext: omni.kit.graph.delegate.default-1.2.2] startup
[13.189s] [ext: omni.graph.visualization.nodes-2.1.1] startup
[13.204s] [ext: omni.kit.widget.stage_icons-1.0.6] startup
[13.209s] [ext: omni.kit.graph.usd.commands-1.3.1] startup
[13.213s] [ext: omni.kit.graph.editor.core-1.5.3] startup
[13.237s] [ext: omni.kit.widget.material_preview-1.0.16] startup
[13.244s] [ext: omni.kit.primitive.mesh-1.0.17] startup
[13.258s] [ext: omni.kit.window.stage-2.5.11] startup
[13.264s] [ext: omni.kit.ui_test-1.3.3] startup
[13.270s] [ext: omni.kit.window.material_graph-1.8.19] startup
[13.349s] [ext: omni.kit.stage_templates-1.2.6] startup
[13.357s] [ext: omni.kit.menu.stage-1.2.5] startup
[13.360s] [ext: omni.graph.scriptnode-1.40.1] startup
[13.363s] [ext: isaacsim.gui.components-1.0.9] startup
[13.397s] [ext: isaacsim.core.api-4.2.16] startup
[13.444s] [ext: omni.replicator.core-1.11.35] startup
   Devices:
     "cpu"      : "x86_64"
   Kernel cache:
2025-03-13 15:20:58 [13,596ms] [Warning] [omni.replicator.core.scripts.extension] No material configuration file, adding configuration to material settings directly.
[13.622s] [ext: isaacsim.robot_motion.lula-4.0.4] startup
[13.635s] [ext: isaacsim.robot.surface_gripper-2.0.6] startup
[13.646s] [ext: isaacsim.core.nodes-2.1.4] startup
[13.673s] [ext: omni.kit.widget.zoombar-1.0.5] startup
[13.682s] [ext: isaacsim.robot_motion.motion_generation-8.0.6] startup
[13.799s] [ext: isaacsim.robot.manipulators-3.0.4] startup
[13.866s] [ext: omni.kit.usd.collect-2.2.22] startup
[13.913s] [ext: omni.kit.browser.core-2.3.11] startup
[14.011s] [ext: isaacsim.robot.manipulators.examples-1.0.3] startup
[14.027s] [ext: omni.kit.tool.collect-2.2.16] startup
[14.086s] [ext: omni.kit.browser.folder.core-1.10.1] startup
[14.178s] [ext: isaacsim.cortex.framework-1.0.2] startup
[14.188s] [ext: isaacsim.examples.browser-0.1.8] startup
[14.231s] [ext: isaacsim.cortex.behaviors-2.0.3] startup
[14.235s] [ext: isaacsim.sensors.physics-0.3.5] startup
[14.276s] [ext: omni.kit.menu.create-1.0.17] startup
[14.290s] [ext: isaacsim.robot.policy.examples-4.0.3] startup
[14.309s] [ext: omni.kit.scripting-106.5.2] startup
[14.357s] [ext: isaacsim.robot.wheeled_robots-4.0.3] startup
[14.404s] [ext: isaacsim.examples.extension-2.0.6] startup
[14.419s] [ext: isaacsim.replicator.behavior-1.0.8] startup
[14.438s] [ext: isaacsim.examples.interactive-4.4.8] startup
[14.603s] [ext: isaacsim.sensors.physics.examples-0.1.4] startup
[14.618s] [ext: isaacsim.replicator.behavior.ui-1.0.1] startup
[14.636s] [ext: isaacsim.sensors.camera-0.2.9] startup
[14.653s] [ext: isaacsim.robot.manipulators.ui-2.1.4] startup
[14.662s] [ext: isaacsim.sensors.camera.ui-0.1.4] startup
[15.433s] [ext: omni.debugdraw-0.1.3] startup
[15.439s] [ext: omni.kit.widget.toolbar-1.7.3] startup
[15.457s] [ext: omni.kit.manipulator.transform-106.0.1] startup
[15.476s] [ext: omni.anim.navigation.core-106.4.0] startup
[15.483s] [ext: omni.kit.manipulator.tool.snap-1.5.12] startup
[15.496s] [ext: omni.kit.manipulator.selector-1.1.1] startup
[15.499s] [ext: omni.anim.navigation.recast-106.4.0] startup
[15.502s] [ext: omni.kit.viewport.manipulator.transform-107.0.4] startup
[15.508s] [ext: omni.kit.widget.imageview-1.0.3] startup
[15.509s] [ext: omni.kit.graph.delegate.modern-1.10.8] startup
[15.520s] [ext: omni.kit.graph.widget.variables-2.1.0] startup
[15.525s] [ext: omni.fabric.commands-1.1.5] startup
[15.537s] [ext: omni.kit.manipulator.prim.core-107.0.7] startup
[15.557s] [ext: omni.kit.window.quicksearch-2.4.4] startup
[15.566s] [ext: omni.anim.shared.core-106.0.2] startup
[15.571s] [ext: omni.sensors.nv.common-2.5.0-coreapi] startup
[15.585s] [ext: omni.kit.actions.window-1.1.1] startup
[15.610s] [ext: omni.kit.manipulator.prim.fabric-107.0.4] startup
[15.615s] [ext: omni.graph.window.core-1.130.1] startup
[15.669s] [ext: omni.kit.manipulator.prim.usd-107.0.3] startup
[15.673s] [ext: omni.sensors.nv.materials-1.4.0-coreapi] startup
[15.677s] [ext: omni.kit.hotkeys.window-1.4.8] startup
[15.695s] [ext: omni.kit.viewport.actions-107.0.0] startup
[15.703s] [ext: omni.graph.window.action-1.40.0] startup
[15.712s] [ext: omni.kit.manipulator.prim-107.0.0] startup
[15.713s] [ext: omni.sensors.nv.ids-1.4.0-coreapi] startup
[15.717s] [ext: isaacsim.util.debug_draw-2.0.2] startup
[15.722s] [ext: omni.kit.viewport.menubar.display-107.0.3] startup
[15.728s] [ext: omni.kit.manipulator.selection-106.0.1] startup
[15.732s] [ext: omni.mdl.usd_converter-1.0.24] startup
[15.752s] [ext: omni.sensors.nv.wpm-2.4.0-coreapi] startup
[15.755s] [ext: omni.sensors.tiled-0.0.6] startup
[15.757s] [ext: omni.sensors.nv.radar-2.6.1-coreapi] startup
[15.763s] [ext: omni.sensors.nv.lidar-2.6.3-coreapi] startup
[15.768s] [ext: isaacsim.asset.importer.heightmap-2.0.3] startup
[15.774s] [ext: isaacsim.sensors.rtx-13.6.3] startup
[15.783s] [ext: omni.kit.widget.layers-1.8.2] startup
[15.848s] [ext: omni.physx.commands-106.5.7] startup
[15.865s] [ext: omni.usdphysics.ui-106.5.7] startup
[15.917s] [ext: omni.kit.stage.mdl_converter-1.0.7] startup
[15.958s] [ext: omni.isaac.block_world-2.0.2] startup
2025-03-13 15:21:01 [15,936ms] [Warning] [omni.isaac.block_world] ['omni.isaac.block_world'] has been deprecated in favor of ['isaacsim.asset.importer.heightmap']. Please update your code accordingly.
[15.961s] [ext: isaacsim.sensors.rtx.ui-0.1.2] startup
2025-03-13 15:21:01 [15,940ms] [Warning] [isaacsim.sensors.rtx.ui.extension] config_dir_path /isaac-sim/exts/isaacsim.sensors.rtx/data/lidar_configs
[16.461s] [ext: isaacsim.sensors.physics.ui-0.1.2] startup
[16.467s] [ext: omni.physx.ui-106.5.7] startup
[16.563s] [ext: omni.usd.metrics.assembler-106.5.0] startup
[16.570s] [ext: omni.importer.onshape-0.8.1] startup
[16.589s] [ext: isaacsim.robot_setup.gain_tuner-2.0.3] startup
[16.606s] [ext: omni.usd.metrics.assembler.physics-106.5.0] startup
[16.613s] [ext: isaacsim.util.camera_inspector-1.0.4] startup
[16.619s] [ext: omni.isaac.gain_tuner-2.0.2] startup
[16.621s] [ext: isaacsim.robot_setup.grasp_editor-2.0.5] startup
[16.637s] [ext: isaacsim.asset.gen.omap-2.0.8] startup
[16.649s] [ext: omni.anim.curve.core-1.2.0] startup
[16.698s] [ext: isaacsim.robot.surface_gripper.ui-2.1.1] startup
[16.703s] [ext: omni.isaac.grasp_editor-2.0.2] startup
[16.704s] [ext: omni.isaac.occupancy_map-2.0.3] startup
2025-03-13 15:21:01 [16,683ms] [Warning] [omni.isaac.occupancy_map] omni.isaac.occupancy_map has been deprecated in favor of isaacsim.asset.gen.omap. Please update your code accordingly.
[16.707s] [ext: omni.anim.curve.ui-1.4.0] startup
[16.736s] [ext: isaacsim.util.merge_mesh-2.0.6] startup
[16.756s] [ext: isaacsim.robot_setup.assembler-2.1.5] startup
[16.779s] [ext: omni.anim.curve.bundle-1.2.3] startup
[16.781s] [ext: isaacsim.robot_setup.xrdf_editor-3.1.5] startup
[16.798s] [ext: omni.isaac.robot_assembler-2.0.2] startup
[16.799s] [ext: isaacsim.replicator.scene_blox-1.0.2] startup
[16.801s] [ext: omni.isaac.robot_description_editor-3.0.2] startup
[16.802s] [ext: isaacsim.replicator.synthetic_recorder-2.2.3] startup
[16.816s] [ext: isaacsim.core.throttling-2.0.2] startup
[16.822s] [ext: omni.isaac.scene_blox-1.0.2] startup
2025-03-13 15:21:02 [16,800ms] [Warning] [omni.isaac.scene_blox] omni.isaac.scene_blox has been deprecated in favor of isaacsim.replicator.scene_blox. Please update your code accordingly.
[16.824s] [ext: omni.graph.ui_nodes-1.40.1] startup
[16.832s] [ext: omni.isaac.synthetic_recorder-2.0.2] startup
2025-03-13 15:21:02 [16,810ms] [Warning] [omni.isaac.synthetic_recorder] omni.isaac.synthetic_recorder has been deprecated in favor of isaacsim.replicator.synthetic_recorder. Please update your code accordingly.
[16.834s] [ext: omni.isaac.throttling-2.0.2] startup
2025-03-13 15:21:02 [16,813ms] [Warning] [omni.isaac.throttling] omni.isaac.throttling has been deprecated in favor of isaacsim.core.throttling. Please update your code accordingly.
2025-03-13 15:21:02 [16,814ms] [Warning] [omni.isaac.throttling.throttling] omni.isaac.throttling.throttling has been deprecated in favor of isaacsim.core.throttling.extension. Please update your code accordingly.
[16.838s] [ext: omni.kit.browser.asset-1.3.11] startup
[16.855s] [ext: omni.graph.bundle.action-2.20.0] startup
[16.859s] [ext: omni.isaac.cortex.sample_behaviors-2.0.2] startup
2025-03-13 15:21:02 [16,838ms] [Warning] [omni.isaac.cortex] omni.isaac.cortex has been deprecated in favor of isaacsim.cortex.framework. Please update your code accordingly.
2025-03-13 15:21:02 [16,839ms] [Warning] [omni.isaac.cortex.sample_behaviors] omni.isaac.cortex.sample_behaviors has been deprecated in favor of isaacsim.cortex.behaviors. Please update your code accordingly.
[16.863s] [ext: omni.kit.core.collection-0.2.0] startup
[16.872s] [ext: omni.kit.mesh.raycast-105.4.0] startup
[16.877s] [ext: omni.kit.preferences.animation-1.2.0] startup
[16.910s] [ext: omni.graph.window.generic-1.40.0] startup
[16.930s] [ext: omni.kit.property.collection-0.2.0] startup
[16.939s] [ext: omni.kit.property.layer-1.1.8] startup
[16.960s] [ext: omni.kit.search.files-1.0.4] startup
[16.967s] [ext: omni.kit.stage.copypaste-1.2.2] startup
[16.982s] [ext: omni.kit.window.title-1.1.5] startup
[16.990s] [ext: omni.isaac.extension_templates-2.0.2] startup
2025-03-13 15:21:02 [16,969ms] [Warning] [omni.isaac.extension_templates] omni.isaac.extension_templates has been deprecated in favor of isaacsim.examples.extension. Please update your code accordingly.
[16.993s] [ext: omni.kit.stage_column.variant-1.0.13] startup
[17.008s] [ext: omni.kit.stagerecorder.core-105.0.5] startup
[17.015s] [ext: omni.kit.tool.remove_unused.core-0.1.2] startup
[17.020s] [ext: omni.kit.browser.material-1.6.0] startup
[17.034s] [ext: omni.kit.property.material-1.10.17] startup
[17.075s] [ext: omni.kit.stagerecorder.ui-105.0.6] startup
[17.089s] [ext: omni.kit.widgets.custom-1.0.9] startup
[17.139s] [ext: omni.kit.usdz_export-1.0.7] startup
[17.147s] [ext: omni.kit.window.material-1.6.2] startup
[17.177s] [ext: omni.kit.stagerecorder.bundle-105.0.2] startup
[17.178s] [ext: omni.kit.variant.editor-106.1.1] startup
[17.253s] [ext: omni.kit.thumbnails.usd-1.0.9] startup
[17.400s] [ext: omni.kit.tool.asset_exporter-1.6.2] startup
[17.411s] [ext: omni.kit.tool.remove_unused.controller-0.1.3] startup
[17.417s] [ext: omni.kit.usda_edit-1.1.14] startup
[17.444s] [ext: omni.kit.variant.presenter-107.0.0] startup
[17.460s] [ext: omni.kit.viewport.menubar.camera-107.0.2] startup
[17.486s] [ext: omni.kit.manipulator.camera-106.0.3] startup
[17.509s] [ext: omni.kit.viewport.menubar.settings-107.0.3] startup
[17.531s] [ext: omni.kit.viewport.menubar.render-107.0.8] startup
[17.546s] [ext: omni.rtx.window.settings-0.6.17] startup
[17.563s] [ext: isaacsim.asset.gen.omap.ui-2.0.4] startup
[17.576s] [ext: omni.scene.optimizer.core-106.1.10] startup
[17.659s] [ext: omni.kit.widget.live-2.1.8] startup
[17.666s] [ext: omni.kit.viewport.bundle-104.0.1] startup
[17.667s] [ext: omni.kit.viewport.rtx-104.0.1] startup
[17.667s] [ext: omni.isaac.occupancy_map.ui-2.0.3] startup
2025-03-13 15:21:02 [17,645ms] [Warning] [omni.isaac.occupancy_map.ui] omni.isaac.occupancy_map.ui has been deprecated in favor of isaacsim.asset.gen.omap.ui. Please update your code accordingly.
[17.675s] [ext: omni.kit.converter.common-503.2.1] startup
[17.734s] [ext: omni.kit.viewport_widgets_manager-1.0.8] startup
[17.741s] [ext: omni.kit.widget.cache_indicator-3.0.1] startup
2025-03-13 15:21:02 [17,718ms] [Warning] [omni.kit.pipapi.pipapi] extension omni.kit.widget.cache_indicator-3.0.1 has a [python.pipapi] entry, but use_online_index=true is not set. It doesn't do anything and can be removed.
[17.916s] [ext: omni.isaac.physics_inspector-0.1.7] startup
2025-03-13 15:21:03 [17,895ms] [Warning] [omni.isaac.physics_inspector] omni.isaac.physics_inspector has been deprecated.Replaced by Physics Visualization tools
[17.919s] [ext: isaacsim.util.physics-1.1.2] startup
[17.930s] [ext: omni.kit.converter.dgn_core-503.3.2] startup
[17.994s] [ext: omni.kit.tool.asset_importer-2.12.2] startup
[17.995s] [ext: omni.kit.converter.hoops_core-504.4.1] startup
[18.007s] [ext: omni.kit.window.script_editor-1.7.8] startup
[18.015s] [ext: omni.kit.window.usd_paths-1.0.7] startup
[18.021s] [ext: isaacsim.asset.browser-1.3.4] startup
[18.144s] [ext: omni.simready.explorer-1.1.1] startup
[18.188s] [ext: isaacsim.core.cloner-1.3.4] startup
[18.194s] [ext: omni.kit.converter.dgn-503.3.1] startup
[18.207s] [ext: omni.kit.converter.hoops-504.4.3] startup
[18.213s] [ext: isaacsim.asset.importer.mjcf-2.3.3] startup
[18.233s] [ext: isaacsim.asset.importer.urdf-2.3.10] startup
[18.293s] [ext: omni.isaac.asset_browser-1.0.2] startup
2025-03-13 15:21:03 [18,272ms] [Warning] [omni.isaac.asset_browser] omni.isaac.asset_browser has been deprecated in favor of isaacsim.asset.browser. Please update your code accordingly.
[18.296s] [ext: omni.isaac.assets_check-0.3.9] startup
2025-03-13 15:21:03 [18,275ms] [Warning] [omni.isaac.assets_check] omni.isaac.assets_check has been deprecated in favor of isaacsim.asset.browser. Please update your code accordingly.
[18.299s] [ext: omni.isaac.cloner-1.0.2] startup
2025-03-13 15:21:03 [18,277ms] [Warning] [omni.isaac.cloner] omni.isaac.cloner has been deprecated in favor of isaacsim.core.cloner. Please update your code accordingly.
[18.302s] [ext: omni.kit.widget.calendar-1.0.8] startup
[18.316s] [ext: omni.kit.selection-0.1.5] startup
[18.322s] [ext: omni.isaac.core-4.0.3] startup
2025-03-13 15:21:03 [18,302ms] [Warning] [omni.isaac.core.physics_context.physics_context] omni.isaac.core.physics_context.physics_context has been deprecated in favor of isaacsim.core.api.physics_context.physics_context. Please update your code accordingly.
2025-03-13 15:21:03 [18,304ms] [Warning] [omni.isaac.core.simulation_context.simulation_context] omni.isaac.core.simulation_context.simulation_context has been deprecated in favor of isaacsim.core.api.simulation_context.simulation_context. Please update your code accordingly.
2025-03-13 15:21:03 [18,306ms] [Warning] [omni.isaac.core.world.world] omni.isaac.core.world.world has been deprecated in favor of isaacsim.core.api.world.world. Please update your code accordingly.
2025-03-13 15:21:03 [18,306ms] [Warning] [omni.isaac.core] omni.isaac.core has been deprecated in favor of isaacsim.core.api. Please update your code accordingly.
[18.330s] [ext: isaacsim.simulation_app-2.4.2] startup
[18.336s] [ext: omni.isaac.core_nodes-2.0.2] startup
2025-03-13 15:21:03 [18,317ms] [Warning] [omni.isaac.core_nodes] omni.isaac.core_nodes has been deprecated in favor of isaacsim.core.nodes. Please update your code accordingly.
[18.341s] [ext: omni.isaac.cortex-1.0.2] startup
[18.343s] [ext: isaacsim.robot_motion.lula_test_widget-1.0.5] startup
[18.355s] [ext: omni.kit.widget.extended_searchfield-1.0.29] startup
[18.404s] [ext: isaacsim.gui.menu-2.0.9] startup
[18.444s] [ext: omni.isaac.franka-1.0.2] startup
2025-03-13 15:21:03 [18,423ms] [Warning] [omni.isaac.franka] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
2025-03-13 15:21:03 [18,424ms] [Warning] [omni.isaac.franka.franka] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
2025-03-13 15:21:03 [18,425ms] [Warning] [omni.isaac.franka.kinematics_solver] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
[18.449s] [ext: omni.isaac.kit-2.0.3] startup
2025-03-13 15:21:03 [18,430ms] [Warning] [omni.isaac.kit] omni.isaac.kit has been deprecated in favor of isaacsim.simulation_app. Please update your code accordingly.
[18.454s] [ext: omni.isaac.lula-4.0.2] startup
2025-03-13 15:21:03 [18,434ms] [Warning] [omni.isaac.lula] omni.isaac.lula has been deprecated in favor of isaacsim.robot_motion.lula. Please update your code accordingly.
[18.458s] [ext: isaacsim.sensors.physx-2.2.4] startup
[18.474s] [ext: omni.isaac.lula_test_widget-1.0.2] startup
2025-03-13 15:21:03 [18,453ms] [Warning] [omni.isaac.lula_test_widget] omni.isaac.lula_test_widget has been deprecated in favor of isaacsim.robot_motion.lula_test_widget. Please update your code accordingly.
[18.478s] [ext: omni.isaac.manipulators-3.0.3] startup
2025-03-13 15:21:03 [18,458ms] [Warning] [omni.isaac.manipulators] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-03-13 15:21:03 [18,459ms] [Warning] [omni.isaac.manipulators.controllers] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-03-13 15:21:03 [18,460ms] [Warning] [omni.isaac.manipulators.controllers.pick_place_controller] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-03-13 15:21:03 [18,462ms] [Warning] [omni.isaac.manipulators.controllers.stacking_controller] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-03-13 15:21:03 [18,463ms] [Warning] [omni.isaac.manipulators.grippers] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-03-13 15:21:03 [18,465ms] [Warning] [omni.isaac.manipulators.grippers.gripper] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-03-13 15:21:03 [18,465ms] [Warning] [omni.isaac.manipulators.grippers.parallel_gripper] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-03-13 15:21:03 [18,466ms] [Warning] [omni.isaac.manipulators.grippers.surface_gripper] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-03-13 15:21:03 [18,475ms] [Warning] [omni.isaac.manipulators.manipulators] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-03-13 15:21:03 [18,475ms] [Warning] [omni.isaac.manipulators.manipulators.single_manipulator] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
[18.502s] [ext: omni.isaac.menu-1.0.2] startup
2025-03-13 15:21:03 [18,482ms] [Warning] [omni.isaac.menu] omni.isaac.menu has been deprecated in favor of isaacsim.gui.menu. Please update your code accordingly.
[18.506s] [ext: omni.isaac.motion_generation-8.0.2] startup
2025-03-13 15:21:03 [18,485ms] [Warning] [omni.isaac.motion_generation] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:21:03 [18,486ms] [Warning] [omni.isaac.motion_generation.articulation_kinematics_solver] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:21:03 [18,487ms] [Warning] [omni.isaac.motion_generation.articulation_motion_policy] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:21:03 [18,488ms] [Warning] [omni.isaac.motion_generation.articulation_trajectory] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:21:03 [18,490ms] [Warning] [omni.isaac.motion_generation.kinematics_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:21:03 [18,499ms] [Warning] [omni.isaac.motion_generation.lula] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:21:03 [18,502ms] [Warning] [omni.isaac.motion_generation.lula.kinematics] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:21:03 [18,508ms] [Warning] [omni.isaac.motion_generation.lula.motion_policies] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:21:03 [18,509ms] [Warning] [omni.isaac.motion_generation.lula.path_planners] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:21:03 [18,510ms] [Warning] [omni.isaac.motion_generation.lula.trajectory_generator] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:21:03 [18,512ms] [Warning] [omni.isaac.motion_generation.motion_policy_controller] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:21:03 [18,519ms] [Warning] [omni.isaac.motion_generation.motion_policy_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:21:03 [18,520ms] [Warning] [omni.isaac.motion_generation.path_planner_visualizer] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:21:03 [18,521ms] [Warning] [omni.isaac.motion_generation.path_planning_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:21:03 [18,521ms] [Warning] [omni.isaac.motion_generation.trajectory] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-03-13 15:21:03 [18,522ms] [Warning] [omni.isaac.motion_generation.world_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
[18.546s] [ext: omni.isaac.nucleus-1.0.3] startup
2025-03-13 15:21:03 [18,528ms] [Warning] [omni.isaac.nucleus] omni.isaac.nucleus has been deprecated in favor of isaacsim.storage.native. Please update your code accordingly.
2025-03-13 15:21:03 [18,535ms] [Warning] [omni.isaac.nucleus.nucleus] omni.isaac.nucleus.nucleus has been deprecated in favor of isaacsim.storage.native. Please update your code accordingly.
[18.559s] [ext: omni.isaac.quadruped-3.0.2] startup
2025-03-13 15:21:03 [18,542ms] [Warning] [omni.isaac.quadruped] omni.isaac.quadruped has been deprecated in favor of isaacsim.robot.policy.examples. Please update your code accordingly.
[18.567s] [ext: omni.isaac.range_sensor-4.0.2] startup
[18.572s] [ext: omni.isaac.sensor-13.0.3] startup
2025-03-13 15:21:03 [18,550ms] [Warning] [omni.isaac.sensor] omni.isaac.sensor has been deprecated in favor of isaacsim.sensors.camera, isaacsim.sensors.physics, isaacsim.sensors.physx, and isaacsim.sensors.rtx. Please update your code accordingly.
2025-03-13 15:21:03 [18,550ms] [Warning] [omni.isaac.sensor.camera] omni.isaac.sensor.camera has been deprecated in favor of isaacsim.sensors.camera.camera. Please update your code accordingly.
2025-03-13 15:21:03 [18,554ms] [Warning] [omni.isaac.sensor.camera_view] omni.isaac.sensor.camera_view has been deprecated in favor of isaacsim.sensors.camera.camera_view. Please update your code accordingly.
2025-03-13 15:21:03 [18,555ms] [Warning] [omni.isaac.sensor.commands] omni.isaac.sensor.commands has been deprecated in favor of isaacsim.sensors.physics.commands, isaacsim.sensors.physx.commands, and isaacsim.sensors.rtx.commands. Please update your code accordingly.
2025-03-13 15:21:03 [18,562ms] [Warning] [omni.isaac.sensor.contact_sensor] omni.isaac.sensor.contact_sensor has been deprecated in favor of isaacsim.sensors.physics.contact_sensor. Please update your code accordingly.
2025-03-13 15:21:03 [18,565ms] [Warning] [omni.isaac.sensor.imu_sensor] omni.isaac.sensor.imu_sensor has been deprecated in favor of isaacsim.sensors.physics.imu_sensor. Please update your code accordingly.
2025-03-13 15:21:03 [18,568ms] [Warning] [omni.isaac.sensor.lidar_rtx] omni.isaac.sensor.lidar_rtx has been deprecated in favor of isaacsim.sensors.rtx.lidar_rtx. Please update your code accordingly.
2025-03-13 15:21:03 [18,568ms] [Warning] [omni.isaac.sensor.rotating_lidar_physX] omni.isaac.sensor.imu_sensor has been deprecated in favor of isaacsim.sensors.physix.rotating_lidar_physX. Please update your code accordingly.
2025-03-13 15:21:03 [18,571ms] [Warning] [omni.isaac.sensor.scripts.samples.contact_sensor] omni.isaac.sensor.scripts.samples.contact_sensor has been deprecated in favor of isaacsim.sensors.physics.scripts.samples.contact_sensor. Please update your code accordingly.
2025-03-13 15:21:03 [18,575ms] [Warning] [omni.isaac.sensor.scripts.samples.imu_sensor] omni.isaac.sensor.scripts.samples.imu_sensor has been deprecated in favor of isaacsim.sensors.physics.scripts.samples.imu_sensor. Please update your code accordingly.
2025-03-13 15:21:03 [18,576ms] [Warning] [omni.isaac.sensor.scripts.samples.lightbeam_sensor] omni.isaac.sensor.scripts.samples.lightbeam_sensor has been deprecated in favor of isaacsim.sensors.physx.scripts.samples.lightbeam_sensor. Please update your code accordingly.
[18.600s] [ext: omni.isaac.surface_gripper-2.0.2] startup
2025-03-13 15:21:03 [18,581ms] [Warning] [omni.isaac.surface_gripper] omni.isaac.surface_gripper has been deprecated in favor of isaacsim.robot.surface_gripper. Please update your code accordingly.
[18.605s] [ext: omni.isaac.universal_robots-1.0.2] startup
2025-03-13 15:21:03 [18,588ms] [Warning] [omni.isaac.universal_robots] omni.isaac.universal_robots has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
2025-03-13 15:21:03 [18,591ms] [Warning] [omni.isaac.universal_robots.kinematics_solver] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
2025-03-13 15:21:03 [18,595ms] [Warning] [omni.isaac.universal_robots.ur10] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
[18.619s] [ext: omni.isaac.utils-2.0.2] startup
[18.625s] [ext: omni.kit.property.audio-1.0.16] startup
[18.632s] [ext: omni.kit.property.camera-1.0.9] startup
[18.650s] [ext: omni.hydra.scene_api-0.1.2] startup
[18.659s] [ext: omni.kit.property.physx-106.5.7] startup
[18.767s] [ext: omni.physx.demos-106.5.7] startup
[19.346s] [ext: omni.kit.property.geometry-1.3.3] startup
[19.356s] [ext: isaacsim.app.about-2.0.7] startup
[19.360s] [ext: omni.kit.property.light-1.0.11] startup
[19.363s] [ext: omni.kit.property.render-1.1.3] startup
[19.366s] [ext: omni.kit.property.transform-1.5.10] startup
[19.387s] [ext: omni.isaac.version-2.0.2] startup
2025-03-13 15:21:04 [19,364ms] [Warning] [omni.isaac.version] omni.isaac.version has been deprecated in favor of isaacsim.core.version. Please update your code accordingly.
[19.388s] [ext: omni.physx.vehicle-106.5.7] startup
[19.450s] [ext: omni.isaac.wheeled_robots-3.0.3] startup
2025-03-13 15:21:04 [19,428ms] [Warning] [omni.isaac.wheeled_robots] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-03-13 15:21:04 [19,428ms] [Warning] [omni.isaac.wheeled_robots.controllers] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-03-13 15:21:04 [19,429ms] [Warning] [omni.isaac.wheeled_robots.controllers.ackermann_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-03-13 15:21:04 [19,429ms] [Warning] [omni.isaac.wheeled_robots.controllers.differential_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-03-13 15:21:04 [19,429ms] [Warning] [omni.isaac.wheeled_robots.controllers.holonomic_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-03-13 15:21:04 [19,430ms] [Warning] [omni.isaac.wheeled_robots.controllers.quintic_path_planner] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-03-13 15:21:04 [19,430ms] [Warning] [omni.isaac.wheeled_robots.controllers.stanley_control] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-03-13 15:21:04 [19,430ms] [Warning] [omni.isaac.wheeled_robots.controllers.wheel_base_pose_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-03-13 15:21:04 [19,430ms] [Warning] [omni.isaac.wheeled_robots.impl] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-03-13 15:21:04 [19,431ms] [Warning] [omni.isaac.wheeled_robots.robots] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-03-13 15:21:04 [19,431ms] [Warning] [omni.isaac.wheeled_robots.robots.holonomic_robot_usd_setup] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-03-13 15:21:04 [19,431ms] [Warning] [omni.isaac.wheeled_robots.robots.wheeled_robot] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
[19.455s] [ext: omni.isaac.window.about-2.0.2] startup
2025-03-13 15:21:04 [19,434ms] [Warning] [omni.isaac.window.about] omni.isaac.window.about has been deprecated in favor of isaacsim.app.about. Please update your code accordingly.
2025-03-13 15:21:04 [19,435ms] [Warning] [omni.isaac.window.about.about] omni.isaac.window.about.about has been deprecated in favor of isaacsim.app.about.about. Please update your code accordingly.
[19.459s] [ext: isaacsim.sensors.physx.examples-2.2.4] startup
[19.466s] [ext: omni.kit.stage_column.payload-2.0.0] startup
[19.473s] [ext: omni.kit.property.bundle-1.3.2] startup
[19.476s] [ext: isaacsim.replicator.domain_randomization-1.0.2] startup
[19.483s] [ext: omni.physx.camera-106.5.7] startup
[19.505s] [ext: omni.kit.window.toolbar-1.6.2] startup
[19.515s] [ext: omni.kit.widget.timeline-105.0.1] startup
[19.538s] [ext: omni.isaac.range_sensor.examples-2.0.3] startup
2025-03-13 15:21:04 [19,518ms] [Warning] [omni.isaac.range_sensor.examples] omni.isaac.range_sensor.examples has been deprecated in favor of isaacsim.sensors.physx.examples. Please update your code accordingly.
2025-03-13 15:21:04 [19,521ms] [Warning] [omni.isaac.range_sensor.examples.lidar_info] omni.isaac.range_sensor.examples.lidar_info has been deprecated in favor of isaacsim.sensors.physx.examples.lidar_info. Please update your code accordingly.
2025-03-13 15:21:04 [19,521ms] [Warning] [omni.isaac.range_sensor.examples.generic_info] omni.isaac.range_sensor.examples.generic_info has been deprecated in favor of isaacsim.sensors.physx.examples.generic_info. Please update your code accordingly.
[19.545s] [ext: isaacsim.replicator.writers-1.0.1] startup
[19.605s] [ext: isaacsim.gui.property-1.0.4] startup
[19.616s] [ext: omni.physx.cct-106.5.7] startup
[19.653s] [ext: omni.physx.graph-106.5.7] startup
[19.687s] [ext: omni.physx.supportui-106.5.7] startup
[19.724s] [ext: omni.physx.telemetry-106.5.7] startup
[19.729s] [ext: isaacsim.replicator.examples-1.1.2] startup
[19.732s] [ext: omni.kit.property.isaac-1.0.2] startup
2025-03-13 15:21:04 [19,712ms] [Warning] [omni.kit.property.isaac] omni.kit.property.isaac has been deprecated in favor of isaacsim.gui.property. Please update your code accordingly.
2025-03-13 15:21:04 [19,713ms] [Warning] [omni.kit.property.isaac.widgets] omni.kit.property.isaac.widgets has been deprecated in favor of isaacsim.gui.property.widgets. Please update your code accordingly.
[19.737s] [ext: omni.kit.viewport.menubar.lighting-106.0.2] startup
[19.759s] [ext: omni.kit.window.console-0.2.14] startup
[19.778s] [ext: omni.kit.window.status_bar-0.1.7] startup
[19.782s] [ext: omni.kit.widget.collection-0.1.18] startup
[19.793s] [ext: omni.physx.bundle-106.5.7] startup
[19.794s] [ext: omni.replicator.isaac-2.0.3] startup
2025-03-13 15:21:05 [19,771ms] [Warning] [omni.replicator.isaac] omni.replicator.isaac has been deprecated in favor of isaacsim.replicator.domain_randomization, isaacsim.replicator.examples, isaacsim.replicator.writers. Please update your code accordingly.
[19.795s] [ext: omni.replicator.replicator_yaml-2.0.10] startup
[19.807s] [ext: omni.rtx.settings.core-0.6.3] startup
[19.828s] [ext: omni.kit.converter.jt_core-503.2.2] startup
[19.846s] [ext: omni.usd.metrics.assembler.ui-106.5.0] startup
[19.855s] [ext: omni.kit.window.collection-0.2.0] startup
[19.859s] [ext: isaacsim.sensors.physx.ui-2.2.1] startup
[19.862s] [ext: semantics.schema.editor-0.3.10] startup
[19.869s] [ext: omni.kit.ui.actions-1.0.2] startup
[19.872s] [ext: semantics.schema.property-1.0.5] startup
[19.876s] [ext: omni.kit.converter.jt-503.2.2] startup
[19.879s] [ext: omni.kit.quicklayout-1.0.8] startup
[19.882s] [ext: omni.kit.window.commands-0.2.7] startup
[19.887s] [ext: omni.isaac.range_sensor.ui-2.0.2] startup
2025-03-13 15:21:05 [19,864ms] [Warning] [omni.isaac.range_sensor.ui] omni.isaac.range_sensor.ui has been deprecated in favor of isaacsim.sensors.physx.ui. Please update your code accordingly.
2025-03-13 15:21:05 [19,865ms] [Warning] [omni.isaac.range_sensor.ui.menu] omni.isaac.range_sensor.ui.menu has been deprecated in favor of isaacsim.sensors.physx.ui.menu. Please update your code accordingly.
[19.889s] [ext: isaacsim.robot.wheeled_robots.ui-2.1.5] startup
[19.893s] [ext: omni.kit.menu.common-1.1.9] startup
[19.897s] [ext: isaacsim.exp.base-4.5.0] startup
[19.898s] [ext: omni.kit.converter.cad-202.2.0] startup
[19.898s] [ext: omni.kit.window.stats-0.1.7] startup
[19.901s] [ext: isaacsim.app.setup-1.3.5] startup
[19.903s] Isaac Sim Full Version: 4.5.0-rc.36
[19.903s] [ext: omni.kit.profiler.window-2.3.1] startup
[19.926s] [ext: isaacsim.exp.full-4.5.0] startup
[20.243s] [ext: isaacsim.ros2.bridge-4.1.15] startup
2025-03-13 15:21:05 [20,237ms] [Warning] [isaacsim.ros2.bridge.scripts.extension] ROS_DISTRO env var not found, Please source Humble, before enabling this extension
[20.261s] Using backup internal ROS2 humble distro
Checking to see if RMW can be loaded:
failed to get symbol 'rmw_init_options_init' due to Environment variable 'AMENT_PREFIX_PATH' is not set or empty, at /workspace/humble_ws/src/rmw_implementation/src/functions.cpp:171, at /workspace/humble_ws/src/rcl/rcl/src/rcl/init_options.c:75
RMW was not loaded
[20.271s] To use the internal libraries included with the extension please set the following environment variables to use with FastDDS (default) or CycloneDDS (ROS2 Humble only):
RMW_IMPLEMENTATION=rmw_fastrtps_cpp
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/isaac-sim/exts/isaacsim.ros2.bridge/humble/lib
OR
RMW_IMPLEMENTATION=rmw_cyclonedds_cpp
Before starting Isaac Sim
2025-03-13 15:21:05 [20,247ms] [Error] [isaacsim.ros2.bridge.scripts.extension] ROS2 Bridge startup failed
[20.292s] [ext: isaacsim.ros2.bridge-4.1.15] shutdown
2025-03-13 15:21:06 [20,754ms] [Warning] [omni.ext._impl._internal] isaacsim.ros2.bridge-4.1.15 -> <class 'isaacsim.ros2.bridge.scripts.samples.ros_moveit_sample.Extension'>: extension object is still alive, something holds a reference on it. References: ["[0]:type: <class 'method'>, id: 139958318113792", "[1]:type: <class 'method'>, id: 139957259338368"]
2025-03-13 15:21:06 [21,015ms] [Warning] [omni.ext._impl._internal] isaacsim.ros2.bridge-4.1.15 -> <class 'isaacsim.ros2.bridge.scripts.samples.ros_waypoint_follower_sample.Extension'>: extension object is still alive, something holds a reference on it. References: ["[0]:type: <class 'method'>, id: 139959641154432", "[1]:type: <class 'method'>, id: 139957263478016"]
2025-03-13 15:21:06 [21,054ms] [Warning] [omni.ext._impl._internal] isaacsim.ros2.bridge-4.1.15 -> <class 'isaacsim.ros2.bridge.scripts.samples.ros_samples.Extension'>: extension object is still alive, something holds a reference on it. References: ["[0]:type: <class 'method'>, id: 139957259261888", "[1]:type: <class 'method'>, id: 139957259269568", "[2]:type: <class 'method'>, id: 139959641181888", "[3]:type: <class 'method'>, id: 139957246743360", "[4]:type: <class 'method'>, id: 139959641193088", '[*] ...']
[21.419s] [ext: omni.kit.registry.nucleus-0.0.0] startup
[21.828s] app ready
2025-03-13 15:21:07 [21,837ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit buffer size 7374781440
2025-03-13 15:21:07 [21,837ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : valid false, within: false
2025-03-13 15:21:07 [21,837ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : decrement: 167690, decrement size: 7301033856
2025-03-13 15:21:07 [21,837ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : New limit 9748724 (slope: 439, intercept: 13179904)
2025-03-13 15:21:07 [21,837ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit buffer size 4287352704
2025-03-13 15:21:07 [21,837ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : valid true, within: true
2025-03-13 15:21:07 [21,975ms] [Warning] [omni.usd-abi.plugin] No setting was found for '/rtx-defaults-transient/meshlights/forceDisable'
2025-03-13 15:21:07 [22,030ms] [Warning] [omni.usd-abi.plugin] No setting was found for '/rtx-defaults/post/dlss/execMode'
2025-03-13 15:21:09 [24,427ms] [Warning] [omni.kit.widget.cache_indicator.utils] No library_root key valid path in omniverse.toml
2025-03-13 15:21:09 [24,428ms] [Warning] [omni.kit.widget.cache_indicator.utils] No library_root key valid path in omniverse.toml
[24.467s] Isaac Sim Full App is loaded.
2025-03-13 15:21:09 [24,618ms] [Warning] [omni.kit.widget.cache_indicator.utils] No library_root key valid path in omniverse.toml
isaac-sim.sh works fine, but ActionGraph is not loaded even in the sample for those using python.sh.
Hi. I believe this difference is expected and is not related to a container.
The python.sh uses the isaacsim.exp.base.python.kit while the Selector runs the full Isaac Sim kit file which is isaacsim.exp.full.kit. The actiongraph extension is only loaded in the Full kit file.
You can try add any additional extensions that you need in the .kit file or use command line flags to enable extensions.
Thanks for your reply.
It worked with Isaac Sim 4.2, but does that mean that the correct thing to do with Isaac Sim 4.5 is to not include the extension in python.sh?
If you don’t clearly indicate the changes from previous versions, I think it will become very difficult to continue using Isaac Sim.
Is there a quick start or tutorial guide on how to launch the isaacsim.exp.full.kit in a Python script for Isaac Sim 4.5.0?
It is recommended to initiate the process by adding the required extensions to the isaacsim.exp.base.python.kit experience kit file.
Is it referring to adding the required extensions directly into the isaacsim.exp.base.python.kit file? Is there any reference documentation or tutorial for this?
[package]
description = "A trimmed down app for use with python samples"
title = "Isaac Sim Python"
version = "4.5.0"
keywords = ["experience", "app", "usd", "isaacsim"] # That makes it browsable in UI with "experience" filter
[dependencies]
"isaacsim.exp.base" = {}
[settings.app]
name = "Isaac-Sim Python"
version = "4.5.0"
settings.persistent = false       # settings reset on each run with this app
window.title = "Isaac Sim Python"
vulkan = true # Explicitly enable Vulkan (on by default on Linux, off by default on Windows)
[settings.app.exts.folders]
    "${app}/../exts",
    "${app}/../extscache",
    "${app}/../extsPhysics",
    "${app}/../extsUser",
    "${app}/../extsDeprecated",
[settings.exts."omni.kit.registry.nucleus"]
registries = [
	{ name = "kit/default", url = "https://ovextensionsprod.blob.core.windows.net/exts/kit/prod/106/shared" },
	{ name = "kit/sdk", url = "https://ovextensionsprod.blob.core.windows.net/exts/kit/prod/sdk/${kit_version_short}/${kit_git_hash}" },
	{ name = "kit/community", url = "https://dw290v42wisod.cloudfront.net/exts/kit/community" },
I was able to add the necessary extensions to the standalone script and get the action graph to work.
import sys
import time
import signal
from isaacsim import SimulationApp
from distutils.util import strtobool
real_frame_per_second = 0.0
internal_frame_per_second = 60.0
time_steps_per_second = 360
kit = None
is_processing = False
def scheduler(signum, frame):
    global kit
    global is_processing
    if is_processing == False:
        is_processing = True
        kit.update()
def main():
    global kit
    args = sys.argv
    usd_path = args[1]
    if len(args) >= 3:
        internal_frame_per_second = float(args[2])
    if len(args) >= 4:
        time_steps_per_second = float(args[3])
    if len(args) >= 5:
        real_frame_per_second = float(args[4])
    else:
        real_frame_per_second = internal_frame_per_second
    is_headless_mode = False
    if len(args) >= 6:
        is_headless_mode = bool(strtobool(args[5]))
    # URDF import, configuration and simulation sample
    if is_headless_mode:
        kit = SimulationApp({"renderer": "RayTracedLighting", "headless": True, "hide_ui": False, "open_usd": usd_path})
    else:
        kit = SimulationApp({"renderer": "RayTracedLighting", "headless": False, "open_usd": usd_path})
    import omni
    from isaacsim.core.utils.extensions import enable_extension, disable_extension
    from isaacsim.core.api import SimulationContext, World
    enable_extension("omni.isaac.repl")
    kit.update()
    enable_extension("omni.kit.scripting")
    kit.update()
    enable_extension("omni.graph.bundle.action")
    kit.update()
    enable_extension("omni.graph.visualization.nodes")
    kit.update()
    enable_extension("omni.graph.window.action")
    kit.update()
    enable_extension("omni.graph.window.generic")
    kit.update()
    enable_extension("isaacsim.ros2.bridge")
        kit.update()
        enable_extension("omni.isaac.sim.headless.native")
    my_world = World(stage_units_in_meters = 1.0, physics_dt = 1.0 / internal_frame_per_second, rendering_dt = 1.0 / internal_frame_per_second)
    import omni.kit.commands
    from pxr import Sdf, Gf, UsdPhysics, PhysxSchema
        omni.usd.get_context().open_stage(usd_path)
    # Get stage handle
    stage_handle = omni.usd.get_context().get_stage()
    # Enable physics
    scene = UsdPhysics.Scene.Define(stage_handle, Sdf.Path("/physicsScene"))
    # Set gravity
    scene.CreateGravityDirectionAttr().Set(Gf.Vec3f(0.0, 0.0, -1.0))
    scene.CreateGravityMagnitudeAttr().Set(9.81)
    # Set solver settings
    PhysxSchema.PhysxSceneAPI.Apply(stage_handle.GetPrimAtPath("/physicsScene"))
    physxSceneAPI = PhysxSchema.PhysxSceneAPI.Get(stage_handle, "/physicsScene")
    physxSceneAPI.CreateEnableCCDAttr(True)
    physxSceneAPI.CreateEnableStabilizationAttr(True)
    physxSceneAPI.CreateEnableGPUDynamicsAttr(False)
    physxSceneAPI.CreateBroadphaseTypeAttr("MBP")
    # Refer to https://forums.developer.nvidia.com/t/wheeled-robot-incorrect-behavior/245133
    #physxSceneAPI.CreateSolverTypeAttr("TGS")
    physxSceneAPI.CreateSolverTypeAttr("PGS")
    physxSceneAPI.CreateTimeStepsPerSecondAttr(time_steps_per_second)
    # Start simulation
    #omni.timeline.get_timeline_interface().play()
    signal.signal(signal.SIGALRM, scheduler)
    signal.setitimer(signal.ITIMER_REAL, 1/real_frame_per_second, 1/real_frame_per_second)
    try:
        while True:
            time.sleep(1)
    except KeyboardInterrupt:
        # Shutdown and exit
        omni.timeline.get_timeline_interface().stop()
        kit.close()
if __name__ == '__main__':
    main()
However, there are still issues with the USD not being loaded at startup and the URDF importer automatically rewriting the USD.
Hi the same open_stage(usd) issue occurs to me. Did you find out what happened?
It may help to create a new topic for your specific issue and include a link to this thread for background, since your particular case may need independent troubleshooting and better visibility.
