Using v4l2-ctrl --list-formats-ext
, the CSI cameras are RG10
and the UVC are YUYV
although I’m capturing in MJPG
Using v4l2-compliance
, I get the following:
CSI:
v4l2-compliance -d /dev/video0
v4l2-compliance SHA : not available
Driver Info:
Driver name : tegra-video
Card type : vi-output, imx219 7-0010
Bus info : platform:54080000.vi:0
Driver version: 4.9.201
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Compliance test for device /dev/video0 (not using libv4l2):
Required ioctls:
test VIDIOC_QUERYCAP: OK
Allow for multiple opens:
test second video open: OK
test VIDIOC_G/S_PRIORITY: OK
test for unlimited opens: OK
Debug ioctls:
test VIDIOC_DBG_G/S_REGISTER: OK (Not Supported)
test VIDIOC_LOG_STATUS: OK
Input ioctls:
test VIDIOC_G/S_TUNER/ENUM_FREQ_BANDS: OK (Not Supported)
test VIDIOC_G/S_FREQUENCY: OK (Not Supported)
test VIDIOC_S_HW_FREQ_SEEK: OK (Not Supported)
test VIDIOC_ENUMAUDIO: OK (Not Supported)
test VIDIOC_G/S/ENUMINPUT: OK
test VIDIOC_G/S_AUDIO: OK (Not Supported)
Inputs: 1 Audio Inputs: 0 Tuners: 0
Output ioctls:
test VIDIOC_G/S_MODULATOR: OK (Not Supported)
test VIDIOC_ENUMAUDOUT: OK (Not Supported)
test VIDIOC_G/S/ENUMOUTPUT: OK (Not Supported)
test VIDIOC_G/S_AUDOUT: OK (Not Supported)
Outputs: 0 Audio Outputs: 0 Modulators: 0
Input/Output configuration ioctls:
test VIDIOC_ENUM/G/S/QUERY_STD: OK (Not Supported)
test VIDIOC_ENUM/G/S/QUERY_DV_TIMINGS: OK (Not Supported)
test VIDIOC_DV_TIMINGS_CAP: OK (Not Supported)
test VIDIOC_G/S_EDID: OK (Not Supported)
Test input 0:
Control ioctls:
test VIDIOC_QUERY_EXT_CTRL/QUERYMENU: OK
test VIDIOC_QUERYCTRL: OK
test VIDIOC_G/S_CTRL: OK
test VIDIOC_G/S/TRY_EXT_CTRLS: OK
test VIDIOC_(UN)SUBSCRIBE_EVENT/DQEVENT: OK
test VIDIOC_G/S_JPEGCOMP: OK (Not Supported)
Standard Controls: 1 Private Controls: 17
Format ioctls:
test VIDIOC_ENUM_FMT/FRAMESIZES/FRAMEINTERVALS: OK
fail: v4l2-test-formats.cpp(1184): ret && node->has_frmintervals
test VIDIOC_G/S_PARM: FAIL
test VIDIOC_G_FBUF: OK (Not Supported)
test VIDIOC_G_FMT: OK
test VIDIOC_TRY_FMT: OK
test VIDIOC_S_FMT: OK
test VIDIOC_G_SLICED_VBI_CAP: OK (Not Supported)
test Cropping: OK (Not Supported)
test Composing: OK (Not Supported)
test Scaling: OK (Not Supported)
Codec ioctls:
test VIDIOC_(TRY_)ENCODER_CMD: OK (Not Supported)
test VIDIOC_G_ENC_INDEX: OK (Not Supported)
test VIDIOC_(TRY_)DECODER_CMD: OK (Not Supported)
Buffer ioctls:
test VIDIOC_REQBUFS/CREATE_BUFS/QUERYBUF: OK
test VIDIOC_EXPBUF: OK
Test input 0:
Total: 43, Succeeded: 42, Failed: 1, Warnings: 0
UVC:
v4l2-compliance -d /dev/video3
Driver Info:
Driver name : uvcvideo
Card type : USB 2.0 Camera
Bus info : usb-70090000.xusb-2.4
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Video Capture
Streaming
Extended Pix Format
Compliance test for device /dev/video3 (not using libv4l2):
Required ioctls:
Debug ioctls:
test VIDIOC_LOG_STATUS: OK (Not Supported)
Input ioctls:
Output ioctls:
Test input 0:
Control ioctls:
fail: v4l2-test-controls.cpp(214): missing control class for class 00980000
fail: v4l2-test-controls.cpp(251): missing control class for class 009a0000
test VIDIOC_QUERY_EXT_CTRL/QUERYMENU: FAIL
warn: v4l2-test-controls.cpp(434): s_ctrl returned EIO
warn: v4l2-test-controls.cpp(671): s_ext_ctrls returned EIO
warn: v4l2-test-controls.cpp(695): g_ext_ctrls(0) invalid error_idx 0
warn: v4l2-test-controls.cpp(740): s_ext_ctrls returned EIO
warn: v4l2-test-controls.cpp(756): error_idx should be equal to count
warn: v4l2-test-controls.cpp(774): error_idx should be equal to count
Standard Controls: 14 Private Controls: 0
Format ioctls:
warn: v4l2-test-formats.cpp(1216): S_PARM is supported but doesn't report V4L2_CAP_TIMEPERFRAME
fail: v4l2-test-formats.cpp(1140): node->has_frmintervals && !cap->capability
warn: v4l2-test-formats.cpp(887): Could not set fmt2
Codec ioctls:
Buffer ioctls:
Test input 0:
Total: 43, Succeeded: 41, Failed: 2, Warnings: 11
