Using the toolbox MINGW64 Bash command
docker-machine ssh default
then docker …run hello-world
`docker: Error while pulling image: Get https://index.docker.io/v1/repositories/library/hello-world/images: x509: certificate signed by unknown authority.`
Get the same error when running the same command with the MINGW64 Bash command line.
Also get the same error using MINGW64 with docker login and enter my userID and password:
$ docker login
Login with your Docker ID to push and pull images from Docker Hub. If you don't have a Docker ID, head over to https://hub.docker.com to create one.
Username: ****
Password: ****
Error response from daemon: Get https://index.docker.io/v1/users/: x509: certificate signed by unknown authority
This is a new install on Windows 7 Enterprise. No proxy or VPN being used. My docker versions are below:
Client:
Version: 1.12.2
API version: 1.24
Go version: go1.6.3
Git commit: bb80604
Built: Tue Oct 11 17:00:50 2016
OS/Arch: windows/amd64
Server:
Version: 1.12.3
API version: 1.24
Go version: go1.6.3
Git commit: 6b644ec
Built: Wed Oct 26 23:26:11 2016
OS/Arch: linux/amd64
Here is the docker.log
/usr/local/bin/docker daemon -D -g "/var/lib/docker" -H unix:// -H tcp://0.0.0.0:2376
--label provider=virtualbox
--tlsverify --tlscacert=/var/lib/boot2docker/ca.pem --tlscert=/var/lib/boot2docker/server.pem --tlskey=/var/lib/boot2docker/server-key.pem -s aufs >> "/var/lib/boot2docker/docker.log"
time="2016-12-02T17:40:30.744686465Z" level=debug msg="Trusting 1 certs"
time="2016-12-02T17:40:30.744757096Z" level=debug msg="docker group found. gid: 100"
time="2016-12-02T17:40:30.744773618Z" level=debug msg="Listener created for HTTP on unix (/var/run/docker.sock)"
time="2016-12-02T17:40:30.745164208Z" level=debug msg="Listener created for HTTP on tcp (0.0.0.0:2376)"
time="2016-12-02T17:40:30.749858087Z" level=info msg="libcontainerd: new containerd process, pid: 1403"
time="2016-12-02T17:40:30.751232622Z" level=debug msg="libcontainerd: containerd connection state change: TRANSIENT_FAILURE"
time="2016-12-02T17:40:30.754248386Z" level=debug msg="containerd: read past events" count=0
time="2016-12-02T17:40:30.754312675Z" level=debug msg="containerd: supervisor running" cpus=1 memory=995 runtime=docker-runc runtimeArgs=[] stateDir="/var/run/docker/libcontainerd/containerd"
time="2016-12-02T17:40:30.754433105Z" level=debug msg="containerd: grpc api on /var/run/docker/libcontainerd/docker-containerd.sock"
time="2016-12-02T17:40:31.752647725Z" level=debug msg="Using default logging driver json-file"
time="2016-12-02T17:40:31.752690751Z" level=debug msg="Golang's threads limit set to 6840"
time="2016-12-02T17:40:31.752721505Z" level=debug msg="[graphdriver] trying provided driver \"aufs\""
time="2016-12-02T17:40:31.756491840Z" level=debug msg="Using graph driver aufs"
time="2016-12-02T17:40:31.756755448Z" level=debug msg="Max Concurrent Downloads: 3"
time="2016-12-02T17:40:31.756769285Z" level=debug msg="Max Concurrent Uploads: 5"
time="2016-12-02T17:40:31.758545195Z" level=info msg="Graph migration to content-addressability took 0.00 seconds"
time="2016-12-02T17:40:31.758669664Z" level=warning msg="Your kernel does not support cgroup blkio weight"
time="2016-12-02T17:40:31.758682044Z" level=warning msg="Your kernel does not support cgroup blkio weight_device"
time="2016-12-02T17:40:31.758984336Z" level=debug msg="Option DefaultDriver: bridge"
time="2016-12-02T17:40:31.758994250Z" level=debug msg="Option DefaultNetwork: bridge"
time="2016-12-02T17:40:31.764196394Z" level=debug msg="Fail to initialize firewalld: Failed to connect to D-Bus system bus: dial unix /var/run/dbus/system_bus_socket: connect: no such file or directory, using raw iptables instead"
time="2016-12-02T17:40:31.764892490Z" level=debug msg="/usr/local/sbin/iptables, [--wait --version]"
time="2016-12-02T17:40:31.765543798Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -D PREROUTING -m addrtype --dst-type LOCAL -j DOCKER]"
time="2016-12-02T17:40:31.772927899Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -D OUTPUT -m addrtype --dst-type LOCAL ! --dst 127.0.0.0/8 -j DOCKER]"
time="2016-12-02T17:40:31.773677414Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -D OUTPUT -m addrtype --dst-type LOCAL -j DOCKER]"
time="2016-12-02T17:40:31.774327019Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -D PREROUTING]"
time="2016-12-02T17:40:31.774928100Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -D OUTPUT]"
time="2016-12-02T17:40:31.775544188Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -F DOCKER]"
time="2016-12-02T17:40:31.776085017Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -X DOCKER]"
time="2016-12-02T17:40:31.776626424Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t filter -F DOCKER]"
time="2016-12-02T17:40:31.777206016Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t filter -X DOCKER]"
time="2016-12-02T17:40:31.777755328Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t filter -F DOCKER-ISOLATION]"
time="2016-12-02T17:40:31.778304247Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t filter -X DOCKER-ISOLATION]"
time="2016-12-02T17:40:31.778845101Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -n -L DOCKER]"
time="2016-12-02T17:40:31.779393672Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -N DOCKER]"
time="2016-12-02T17:40:31.779994206Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t filter -n -L DOCKER]"
time="2016-12-02T17:40:31.780561001Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t filter -N DOCKER]"
time="2016-12-02T17:40:31.781207318Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t filter -n -L DOCKER-ISOLATION]"
time="2016-12-02T17:40:31.781791215Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t filter -N DOCKER-ISOLATION]"
time="2016-12-02T17:40:31.782346071Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t filter -C DOCKER-ISOLATION -j RETURN]"
time="2016-12-02T17:40:31.783018224Z" level=debug msg="/usr/local/sbin/iptables, [--wait -I DOCKER-ISOLATION -j RETURN]"
time="2016-12-02T17:40:31.787270767Z" level=warning msg="Could not load necessary modules for IPSEC rules: Running modprobe xfrm_user failed with message: `modprobe: module xfrm_user not found in modules.dep`, error: exit status 1"
time="2016-12-02T17:40:31.787346607Z" level=debug msg="Did not find any interface with name docker0: Link not found"
time="2016-12-02T17:40:31.789910140Z" level=debug msg="Setting bridge mac address to 02:42:0d:c5:90:dc"
time="2016-12-02T17:40:31.789997612Z" level=debug msg="Assigning address to bridge interface docker0: 172.17.0.1/16"
time="2016-12-02T17:40:31.790053336Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -C POSTROUTING -s 172.17.0.0/16 ! -o docker0 -j MASQUERADE]"
time="2016-12-02T17:40:31.790895486Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -I POSTROUTING -s 172.17.0.0/16 ! -o docker0 -j MASQUERADE]"
time="2016-12-02T17:40:31.793281905Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -C DOCKER -i docker0 -j RETURN]"
time="2016-12-02T17:40:31.793927677Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -I DOCKER -i docker0 -j RETURN]"
time="2016-12-02T17:40:31.794558636Z" level=debug msg="/usr/local/sbin/iptables, [--wait -D FORWARD -i docker0 -o docker0 -j DROP]"
time="2016-12-02T17:40:31.795173446Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t filter -C FORWARD -i docker0 -o docker0 -j ACCEPT]"
time="2016-12-02T17:40:31.795764807Z" level=debug msg="/usr/local/sbin/iptables, [--wait -I FORWARD -i docker0 -o docker0 -j ACCEPT]"
time="2016-12-02T17:40:31.796351001Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t filter -C FORWARD -i docker0 ! -o docker0 -j ACCEPT]"
time="2016-12-02T17:40:31.796938536Z" level=debug msg="/usr/local/sbin/iptables, [--wait -I FORWARD -i docker0 ! -o docker0 -j ACCEPT]"
time="2016-12-02T17:40:31.797557497Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t filter -C FORWARD -o docker0 -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT]"
time="2016-12-02T17:40:31.798218826Z" level=debug msg="/usr/local/sbin/iptables, [--wait -I FORWARD -o docker0 -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT]"
time="2016-12-02T17:40:31.798875539Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -C PREROUTING -m addrtype --dst-type LOCAL -j DOCKER]"
time="2016-12-02T17:40:31.799561268Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -A PREROUTING -m addrtype --dst-type LOCAL -j DOCKER]"
time="2016-12-02T17:40:31.800206353Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -C OUTPUT -m addrtype --dst-type LOCAL -j DOCKER ! --dst 127.0.0.0/8]"
time="2016-12-02T17:40:31.800845743Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -A OUTPUT -m addrtype --dst-type LOCAL -j DOCKER ! --dst 127.0.0.0/8]"
time="2016-12-02T17:40:31.801556457Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t filter -C FORWARD -o docker0 -j DOCKER]"
time="2016-12-02T17:40:31.802147116Z" level=debug msg="/usr/local/sbin/iptables, [--wait -I FORWARD -o docker0 -j DOCKER]"
time="2016-12-02T17:40:31.802737882Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t filter -C FORWARD -j DOCKER-ISOLATION]"
time="2016-12-02T17:40:31.803331101Z" level=debug msg="/usr/local/sbin/iptables, [--wait -I FORWARD -j DOCKER-ISOLATION]"
time="2016-12-02T17:40:31.804007143Z" level=debug msg="Network (769a472) restored"
time="2016-12-02T17:40:31.817909885Z" level=debug msg="Allocating IPv4 pools for network bridge (769a4727f21c2c93bc5ab0d73b2221bf589b61d72286703044df82dff4404bdb)"
time="2016-12-02T17:40:31.817936450Z" level=debug msg="RequestPool(LocalDefault, 172.17.0.0/16, , map[], false)"
time="2016-12-02T17:40:31.817963419Z" level=debug msg="RequestAddress(LocalDefault/172.17.0.0/16, 172.17.0.1, map[RequestAddressType:com.docker.network.gateway])"
time="2016-12-02T17:40:31.818944639Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -C POSTROUTING -s 172.17.0.0/16 ! -o docker0 -j MASQUERADE]"
time="2016-12-02T17:40:31.819794283Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -D POSTROUTING -s 172.17.0.0/16 ! -o docker0 -j MASQUERADE]"
time="2016-12-02T17:40:31.820419933Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -C DOCKER -i docker0 -j RETURN]"
time="2016-12-02T17:40:31.821095012Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -D DOCKER -i docker0 -j RETURN]"
time="2016-12-02T17:40:31.821706584Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t filter -C FORWARD -i docker0 -o docker0 -j ACCEPT]"
time="2016-12-02T17:40:31.822306310Z" level=debug msg="/usr/local/sbin/iptables, [--wait -D FORWARD -i docker0 -o docker0 -j ACCEPT]"
time="2016-12-02T17:40:31.822917846Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t filter -C FORWARD -i docker0 ! -o docker0 -j ACCEPT]"
time="2016-12-02T17:40:31.823555089Z" level=debug msg="/usr/local/sbin/iptables, [--wait -D FORWARD -i docker0 ! -o docker0 -j ACCEPT]"
time="2016-12-02T17:40:31.824172614Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t filter -C FORWARD -o docker0 -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT]"
time="2016-12-02T17:40:31.824865567Z" level=debug msg="/usr/local/sbin/iptables, [--wait -D FORWARD -o docker0 -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT]"
time="2016-12-02T17:40:31.825579043Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t filter -C FORWARD -o docker0 -j DOCKER]"
time="2016-12-02T17:40:31.826190711Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t filter -C FORWARD -o docker0 -j DOCKER]"
time="2016-12-02T17:40:31.826793517Z" level=debug msg="/usr/local/sbin/iptables, [--wait -D FORWARD -o docker0 -j DOCKER]"
time="2016-12-02T17:40:31.827856201Z" level=debug msg="releasing IPv4 pools from network bridge (769a4727f21c2c93bc5ab0d73b2221bf589b61d72286703044df82dff4404bdb)"
time="2016-12-02T17:40:31.827873323Z" level=debug msg="ReleaseAddress(LocalDefault/172.17.0.0/16, 172.17.0.1)"
time="2016-12-02T17:40:31.827889444Z" level=debug msg="ReleasePool(LocalDefault/172.17.0.0/16)"
time="2016-12-02T17:40:31.829420991Z" level=info msg="Default bridge (docker0) is assigned with an IP address 172.17.0.0/16. Daemon option --bip can be used to set a preferred IP address"
time="2016-12-02T17:40:31.829449564Z" level=debug msg="Allocating IPv4 pools for network bridge (df4bd823534e55e46fab6700e94d5e3728ae40f7cdf6e4ce9fb523f4ef6a84d6)"
time="2016-12-02T17:40:31.829461383Z" level=debug msg="RequestPool(LocalDefault, 172.17.0.0/16, , map[], false)"
time="2016-12-02T17:40:31.829480436Z" level=debug msg="RequestAddress(LocalDefault/172.17.0.0/16, 172.17.0.1, map[RequestAddressType:com.docker.network.gateway])"
time="2016-12-02T17:40:31.829604904Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -C POSTROUTING -s 172.17.0.0/16 ! -o docker0 -j MASQUERADE]"
time="2016-12-02T17:40:31.830263211Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -I POSTROUTING -s 172.17.0.0/16 ! -o docker0 -j MASQUERADE]"
time="2016-12-02T17:40:31.830897081Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -C DOCKER -i docker0 -j RETURN]"
time="2016-12-02T17:40:31.831580401Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -I DOCKER -i docker0 -j RETURN]"
time="2016-12-02T17:40:31.832186563Z" level=debug msg="/usr/local/sbin/iptables, [--wait -D FORWARD -i docker0 -o docker0 -j DROP]"
time="2016-12-02T17:40:31.832832277Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t filter -C FORWARD -i docker0 -o docker0 -j ACCEPT]"
time="2016-12-02T17:40:31.833438658Z" level=debug msg="/usr/local/sbin/iptables, [--wait -I FORWARD -i docker0 -o docker0 -j ACCEPT]"
time="2016-12-02T17:40:31.834113557Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t filter -C FORWARD -i docker0 ! -o docker0 -j ACCEPT]"
time="2016-12-02T17:40:31.834778734Z" level=debug msg="/usr/local/sbin/iptables, [--wait -I FORWARD -i docker0 ! -o docker0 -j ACCEPT]"
time="2016-12-02T17:40:31.835383516Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t filter -C FORWARD -o docker0 -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT]"
time="2016-12-02T17:40:31.836099155Z" level=debug msg="/usr/local/sbin/iptables, [--wait -I FORWARD -o docker0 -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT]"
time="2016-12-02T17:40:31.836963236Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -C PREROUTING -m addrtype --dst-type LOCAL -j DOCKER]"
time="2016-12-02T17:40:31.837678997Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -C PREROUTING -m addrtype --dst-type LOCAL -j DOCKER]"
time="2016-12-02T17:40:31.838404700Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -C OUTPUT -m addrtype --dst-type LOCAL -j DOCKER ! --dst 127.0.0.0/8]"
time="2016-12-02T17:40:31.839196159Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t nat -C OUTPUT -m addrtype --dst-type LOCAL -j DOCKER ! --dst 127.0.0.0/8]"
time="2016-12-02T17:40:31.839951001Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t filter -C FORWARD -o docker0 -j DOCKER]"
time="2016-12-02T17:40:31.840701682Z" level=debug msg="/usr/local/sbin/iptables, [--wait -I FORWARD -o docker0 -j DOCKER]"
time="2016-12-02T17:40:31.841384288Z" level=debug msg="/usr/local/sbin/iptables, [--wait -t filter -C FORWARD -j DOCKER-ISOLATION]"
time="2016-12-02T17:40:31.842035782Z" level=debug msg="/usr/local/sbin/iptables, [--wait -D FORWARD -j DOCKER-ISOLATION]"
time="2016-12-02T17:40:31.842667948Z" level=debug msg="/usr/local/sbin/iptables, [--wait -I FORWARD -j DOCKER-ISOLATION]"
time="2016-12-02T17:40:31.844980088Z" level=info msg="Daemon has completed initialization"
time="2016-12-02T17:40:31.845016496Z" level=info msg="Docker daemon" commit=6b644ec graphdriver=aufs version=1.12.3
time="2016-12-02T17:40:31.845082732Z" level=debug msg="Registering routers"
time="2016-12-02T17:40:31.845090452Z" level=debug msg="Registering HEAD, /containers/{name:.*}/archive"
time="2016-12-02T17:40:31.845196210Z" level=debug msg="Registering GET, /containers/json"
time="2016-12-02T17:40:31.845249996Z" level=debug msg="Registering GET, /containers/{name:.*}/export"
time="2016-12-02T17:40:31.845332988Z" level=debug msg="Registering GET, /containers/{name:.*}/changes"
time="2016-12-02T17:40:31.845405539Z" level=debug msg="Registering GET, /containers/{name:.*}/json"
time="2016-12-02T17:40:31.845461108Z" level=debug msg="Registering GET, /containers/{name:.*}/top"
time="2016-12-02T17:40:31.845590507Z" level=debug msg="Registering GET, /containers/{name:.*}/logs"
time="2016-12-02T17:40:31.845654350Z" level=debug msg="Registering GET, /containers/{name:.*}/stats"
time="2016-12-02T17:40:31.845718392Z" level=debug msg="Registering GET, /containers/{name:.*}/attach/ws"
time="2016-12-02T17:40:31.845782209Z" level=debug msg="Registering GET, /exec/{id:.*}/json"
time="2016-12-02T17:40:31.845841816Z" level=debug msg="Registering GET, /containers/{name:.*}/archive"
time="2016-12-02T17:40:31.845906266Z" level=debug msg="Registering POST, /containers/create"
time="2016-12-02T17:40:31.845956564Z" level=debug msg="Registering POST, /containers/{name:.*}/kill"
time="2016-12-02T17:40:31.846072344Z" level=debug msg="Registering POST, /containers/{name:.*}/pause"
time="2016-12-02T17:40:31.846142240Z" level=debug msg="Registering POST, /containers/{name:.*}/unpause"
time="2016-12-02T17:40:31.846203895Z" level=debug msg="Registering POST, /containers/{name:.*}/restart"
time="2016-12-02T17:40:31.846274390Z" level=debug msg="Registering POST, /containers/{name:.*}/start"
time="2016-12-02T17:40:31.846335739Z" level=debug msg="Registering POST, /containers/{name:.*}/stop"
time="2016-12-02T17:40:31.846397909Z" level=debug msg="Registering POST, /containers/{name:.*}/wait"
time="2016-12-02T17:40:31.846455319Z" level=debug msg="Registering POST, /containers/{name:.*}/resize"
time="2016-12-02T17:40:31.846581902Z" level=debug msg="Registering POST, /containers/{name:.*}/attach"
time="2016-12-02T17:40:31.846648077Z" level=debug msg="Registering POST, /containers/{name:.*}/copy"
time="2016-12-02T17:40:31.846703368Z" level=debug msg="Registering POST, /containers/{name:.*}/exec"
time="2016-12-02T17:40:31.846757547Z" level=debug msg="Registering POST, /exec/{name:.*}/start"
time="2016-12-02T17:40:31.855298945Z" level=debug msg="Registering POST, /exec/{name:.*}/resize"
time="2016-12-02T17:40:31.855476145Z" level=debug msg="Registering POST, /containers/{name:.*}/rename"
time="2016-12-02T17:40:31.855680517Z" level=debug msg="Registering POST, /containers/{name:.*}/update"
time="2016-12-02T17:40:31.855823007Z" level=debug msg="Registering PUT, /containers/{name:.*}/archive"
time="2016-12-02T17:40:31.855965910Z" level=debug msg="Registering DELETE, /containers/{name:.*}"
time="2016-12-02T17:40:31.856156286Z" level=debug msg="Registering GET, /images/json"
time="2016-12-02T17:40:31.856248747Z" level=debug msg="Registering GET, /images/search"
time="2016-12-02T17:40:31.856338764Z" level=debug msg="Registering GET, /images/get"
time="2016-12-02T17:40:31.856428471Z" level=debug msg="Registering GET, /images/{name:.*}/get"
time="2016-12-02T17:40:31.856609363Z" level=debug msg="Registering GET, /images/{name:.*}/history"
time="2016-12-02T17:40:31.856737561Z" level=debug msg="Registering GET, /images/{name:.*}/json"
time="2016-12-02T17:40:31.856858547Z" level=debug msg="Registering POST, /commit"
time="2016-12-02T17:40:31.856932825Z" level=debug msg="Registering POST, /images/load"
time="2016-12-02T17:40:31.857067111Z" level=debug msg="Registering POST, /images/create"
time="2016-12-02T17:40:31.857171220Z" level=debug msg="Registering POST, /images/{name:.*}/push"
time="2016-12-02T17:40:31.857289494Z" level=debug msg="Registering POST, /images/{name:.*}/tag"
time="2016-12-02T17:40:31.857408848Z" level=debug msg="Registering DELETE, /images/{name:.*}"
time="2016-12-02T17:40:31.857600539Z" level=debug msg="Registering OPTIONS, /{anyroute:.*}"
time="2016-12-02T17:40:31.857700202Z" level=debug msg="Registering GET, /_ping"
time="2016-12-02T17:40:31.857773927Z" level=debug msg="Registering GET, /events"
time="2016-12-02T17:40:31.857843765Z" level=debug msg="Registering GET, /info"
time="2016-12-02T17:40:31.857908064Z" level=debug msg="Registering GET, /version"
time="2016-12-02T17:40:31.858001946Z" level=debug msg="Registering POST, /auth"
time="2016-12-02T17:40:31.858134328Z" level=debug msg="Registering GET, /volumes"
time="2016-12-02T17:40:31.858215934Z" level=debug msg="Registering GET, /volumes/{name:.*}"
time="2016-12-02T17:40:31.858338159Z" level=debug msg="Registering POST, /volumes/create"
time="2016-12-02T17:40:31.858435864Z" level=debug msg="Registering DELETE, /volumes/{name:.*}"
time="2016-12-02T17:40:31.858623798Z" level=debug msg="Registering POST, /build"
time="2016-12-02T17:40:31.858699227Z" level=debug msg="Registering POST, /swarm/init"
time="2016-12-02T17:40:31.858782830Z" level=debug msg="Registering POST, /swarm/join"
time="2016-12-02T17:40:31.858882884Z" level=debug msg="Registering POST, /swarm/leave"
time="2016-12-02T17:40:31.858975348Z" level=debug msg="Registering GET, /swarm"
time="2016-12-02T17:40:31.859090616Z" level=debug msg="Registering POST, /swarm/update"
time="2016-12-02T17:40:31.859185927Z" level=debug msg="Registering GET, /services"
time="2016-12-02T17:40:31.859271129Z" level=debug msg="Registering GET, /services/{id:.*}"
time="2016-12-02T17:40:31.859392667Z" level=debug msg="Registering POST, /services/create"
time="2016-12-02T17:40:31.859498568Z" level=debug msg="Registering POST, /services/{id:.*}/update"
time="2016-12-02T17:40:31.860487935Z" level=debug msg="Registering DELETE, /services/{id:.*}"
time="2016-12-02T17:40:31.860600622Z" level=debug msg="Registering GET, /nodes"
time="2016-12-02T17:40:31.860638114Z" level=debug msg="Registering GET, /nodes/{id:.*}"
time="2016-12-02T17:40:31.860689203Z" level=debug msg="Registering DELETE, /nodes/{id:.*}"
time="2016-12-02T17:40:31.860739964Z" level=debug msg="Registering POST, /nodes/{id:.*}/update"
time="2016-12-02T17:40:31.860791527Z" level=debug msg="Registering GET, /tasks"
time="2016-12-02T17:40:31.860823214Z" level=debug msg="Registering GET, /tasks/{id:.*}"
time="2016-12-02T17:40:31.860872242Z" level=debug msg="Registering GET, /networks"
time="2016-12-02T17:40:31.860907071Z" level=debug msg="Registering GET, /networks/{id:.*}"
time="2016-12-02T17:40:31.860959816Z" level=debug msg="Registering POST, /networks/create"
time="2016-12-02T17:40:31.861000434Z" level=debug msg="Registering POST, /networks/{id:.*}/connect"
time="2016-12-02T17:40:31.861149382Z" level=debug msg="Registering POST, /networks/{id:.*}/disconnect"
time="2016-12-02T17:40:31.861212449Z" level=debug msg="Registering DELETE, /networks/{id:.*}"
time="2016-12-02T17:40:31.861470361Z" level=info msg="API listen on [::]:2376"
time="2016-12-02T17:40:31.861560675Z" level=info msg="API listen on /var/run/docker.sock"
time="2016-12-02T17:40:33.751508859Z" level=debug msg="libcontainerd: containerd connection state change: READY"
time="2016-12-02T17:40:47.157118325Z" level=debug msg="Calling POST /v1.24/containers/create"
time="2016-12-02T17:40:47.157318825Z" level=debug msg="form data: {\"AttachStderr\":true,\"AttachStdin\":false,\"AttachStdout\":true,\"Cmd\":null,\"Domainname\":\"\",\"Entrypoint\":null,\"Env\":[],\"HostConfig\":{\"AutoRemove\":false,\"Bind
time="2016-12-02T17:40:47.157354807Z" level=debug msg="Client and server don't have the same version (client: 1.12.2, server: 1.12.3)"
time="2016-12-02T17:40:47.158018832Z" level=error msg="Handler for POST /v1.24/containers/create returned error: No such image: hello-world:latest"
time="2016-12-02T17:40:47.168659719Z" level=debug msg="Calling GET /v1.24/info"
time="2016-12-02T17:40:47.168702458Z" level=debug msg="Client and server don't have the same version (client: 1.12.2, server: 1.12.3)"
time="2016-12-02T17:40:47.175273487Z" level=debug msg="Calling POST /v1.24/images/create?fromImage=hello-world&tag=latest"
time="2016-12-02T17:40:47.175301389Z" level=debug msg="Client and server don't have the same version (client: 1.12.2, server: 1.12.3)"
time="2016-12-02T17:40:47.175394394Z" level=debug msg="Trying to pull hello-world from https://registry-1.docker.io v2"
time="2016-12-02T17:40:47.267928949Z" level=warning msg="Error getting v2 registry: Get https://registry-1.docker.io/v2/: x509: certificate signed by unknown authority"
time="2016-12-02T17:40:47.267962791Z" level=error msg="Attempting next endpoint for pull after error: Get https://registry-1.docker.io/v2/: x509: certificate signed by unknown authority"
time="2016-12-02T17:40:47.267980757Z" level=debug msg="Trying to pull hello-world from https://index.docker.io v1"
time="2016-12-02T17:40:47.268000661Z" level=debug msg="hostDir: /etc/docker/certs.d/docker.io"
time="2016-12-02T17:40:47.268523687Z" level=debug msg="[registry] Calling GET https://index.docker.io/v1/repositories/library/hello-world/images"
time="2016-12-02T17:40:47.343322233Z" level=error msg="Not continuing with pull after error: Error while pulling image: Get https://index.docker.io/v1/repositories/library/hello-world/images: x509: certificate signed by unknown authority"
Ok here is what I don't understand, you can see in the beginning of the log it is using 0.0.0.0:2376 for the docker VM. When I run `docker-machine ls` I see this:
$ docker-machine ls
NAME ACTIVE DRIVER STATE URL SWARM DOCKER ERRORS
default * virtualbox Running tcp://192.168.99.100:2376 v1.12.3
According [boot2docker](https://github.com/boot2docker/boot2docker) you are suppose to use hostname however it looks like two different IP addresses are being used. What should be used?
