Hi.
There are some issues with static mac and vxlan in Cumulus with bcm lib.
When adding a static mac into an access port with vxlan,
it is added into kernel, but not added into asic.
But it is correctly added into kernel and asic, if the vlan-id is trunk, or the port is bond (static or dynamic).
Tested on Cumulus Linux 4.3.0 with bcm asic (Trident2 and Tomahawk)
Test config with trunk
auto vni13101
iface vni13101
bridge-access 3101
vxlan-id 13101auto swp1
iface swp1
bridge-vids 3101auto bridge
iface bridge
mtu 9100
bridge-ports swp1 swp3 vni13101
bridge-mcsnoop no
bridge-stp off
bridge-vids 3101
bridge-vlan-aware yes
post-up bridge fdb replace 00:11:12:13:14:15 dev swp1 master static vlan 3101 sticky
# net show bridge mac vlan 3101
VLAN Master Interface MAC TunnelDest State Flags LastSeen
3101 bridge swp1 00:11:12:13:14:15 static sticky 00:09:52
3101 bridge swp1 dc:2c:6e:09:a9:0b 00:00:07
# /usr/lib/cumulus/bcmcmd l2 show
mac=dc:2c:6e:09:a9:0b vlan=1 GPORT=0x1 modid=0 port=1/xe0
mac=00:11:12:13:14:15 vlan=28673 GPORT=0x80000002 port=0x80000002(vxlan) Static
mac=dc:2c:6e:09:a9:0b vlan=28673 GPORT=0x80000002 port=0x80000002(vxlan)
mac 00:11:12:13:14:15 presents in the kernel and in the asic
And here is a test config with access vlan
auto vni13101
iface vni13101
bridge-access 3101
iface swp1
bridge-access 3101auto bridge
iface bridge
mtu 9100
bridge-ports swp1 vni13101
bridge-mcsnoop no
bridge-stp off
bridge-vids 3101
3101 bridge swp1 00:11:12:13:14:15 static sticky 00:00:13
3101 bridge swp1 dc:2c:6e:09:a9:0b 00:00:16
mac=dc:2c:6e:09:a9:0b vlan=3101 GPORT=0x1 modid=0 port=1/xe0 Hit
mac=dc:2c:6e:09:a9:0b vlan=28673 GPORT=0x80000002 port=0x80000002(vxlan) Hit
mac 00:11:12:13:14:15 presents only in kernel, but not installed into asic.
As a solution, a single port static bond could be.
auto vni13101
iface vni13101
bridge-access 3101
iface swp1auto bond1
iface bond1
bridge-access 3101
bond-slaves swp1
bond-mode balance-xor
iface bridge
mtu 9100
bridge-ports bond1 vni13101
bridge-mcsnoop no
bridge-stp off
bridge-vids 3101
post-up bridge fdb replace 00:11:12:13:14:15 dev bond1 master static vlan 3101 sticky
3101 bridge bond1 00:11:12:13:14:15 static sticky 00:01:37
3101 bridge bond1 dc:2c:6e:09:a9:0b 00:00:07
