I have a quad monitor setup, and recently purchased/installed a Quadro P2200 (to replace my GTX 770s, one of which died). The main problem I’m having is that on screen lock, or even logging off, after one minute instead of sleeping (as it used to do), it actually “disconnects” so when I move the mouse to wake it up, it has to reconnect again. I’ve already tried uninstalling and reinstalling drivers - and it initially worked as normal, but then reverted to disconnecting. After much research and tinkering, my partner and I figured out that the problem is with the drivers - specifically the Production Branch driver 471.68, which causes the display to power cycle reset and I nearly almost lost my local drive! The ‘New Feature’ driver works, except now I can’t get the NVIDIA Control Panel to open. Any help/suggestions would be greatly appreciated, thanks so much in advance!
Related topics
Topic | Replies | Views | Activity | |
Can't wake up from suspend with Quadro M1200 / nvidia-driver-515.65.01 | 5 | 688 | October 13, 2022 | |
System Freezes (Kernel Panic) When Displays Shut Down - Linux 32-bit RHEL 5 VM Using Quadro P4000 | 3 | 794 | December 22, 2017 | |
Display not waking up after powersave | 1 | 1174 | December 7, 2015 | |
issues with 430.x series + 4k Dell monitor , screen turns off | 32 | 2021 | October 12, 2021 | |
Unable to Remotely Connect to Workstations with Nvidia Quadro P4000 GPUs Installed when Monitor in Sleep Mode or Powered Off | 0 | 96 | August 20, 2024 | |
Displayport woes on Quadro K620/P620 | 5 | 3622 | March 4, 2019 | |
Screen freezes randomly on Nvidia Quadro P2000, driver 470.63.01 | 0 | 709 | August 17, 2021 | |
Nvidia quadro display hangs | 0 | 1241 | March 11, 2013 | |
Potential driver problem with Quadro M4000 graphics card under Linux Fedora 22 | 0 | 1411 | April 12, 2016 | |
470 series driver on GTX 860M disconnects/forgets the internal laptop display when X is started | 11 | 561 | September 15, 2022 |
