Jatson AGX Thor使用uart5接口时报dma错
Jatson AGX Thor sdk 7.2.1
Issue Description:
我们使用uart5接口,接了一个GNSS模块,在cat uart5时报错了,怀疑时DMA申请时的问题。
日志:
nvidia@EATHA06:~$ sudo stty -F /dev/ttyAMA5
speed 9600 baud; line = 0;
-brkint -imaxbel
nvidia@EATHA06:~$ sudo stty -F /dev/ttyAMA5 speed 460800
9600
speed 460800 baud; line = 0;
-brkint -imaxbel
nvidia@EATHA06:~$ cat /dev/ttyAMA5
cat: /dev/ttyAMA5: Permission denied
nvidia@EATHA06:~$ sudo cat /dev/ttyAMA5
[ 118.954198] tegra-gpcdma 8400000.dma-controller: GPCDMA CH11 mc slave error
[ 118.954282] tegra-mc 8108020000.memory-controller: gpcdmaw: non-secure write @0x0000fffffffff000: EMEM address decode error (EMEM decode erro[ 118.959979] tegra-mc 8108020000.memory-controller: gpcdmaw: non-secure write @0x0000fffffffff000: EMEM address decode error (EMEM decode error)
[ 118.972970] tegra-mc 8108020000.memory-controller: gpcdmaw: non-secure write @0x0000fffffffff000: EMEM address decode error (EMEM decode error)
[ 118.985779] tegra-gpcdma 8400000.dma-controller: GPCDMA CH21 mc slave error
[ 118.992758] uart-pl011 810c510000.serial: unable to pause DMA transfer
[ 118.999501] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[ 119.010715] tegra-mc 8108020000.memory-controller: gpcdmar: non-secure read @0x0000fffffffff000: EMEM address decode error (EMEM decode error[ 119.023128] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[ 119.953973] tegra-mc 8108020000.memory-controller: gpcdmaw: non-secure write @0x0000fffffffff000: EMEM address decode error (EMEM decode error)
[ 119.954104] tegra-mc 8108020000.memory-controller: gpcdmaw: non-secure write @0x0000fffffffff000: EMEM address decode error (EMEM decode erro[ 119.965667] tegra-mc 8108020000.memory-controller: gpcdmaw: non-secure write @0x0000fffffffff000: EMEM address decode error (EMEM decode error)
[ 119.980897] uart-pl011 810c510000.serial: unable to pause DMA transfer
[ 119.985358] tegra-mc 8108020000.memory-controller: gpcdmar: non-secure read @0x0000fffffffff000: EMEM address decode error (EMEM decode error)
[ 119.998112] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[ 120.013588] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[ 120.024667] tegra-mc 8108020000.memory-controller: gpcdmar: non-secure read @0x0000fffffffff000: EMEM address decode error (EMEM decode error[ 120.954007] tegra-mc 8108020000.memory-controller: gpcdmaw: non-secure write @0x0000fffffffff000: EMEM address decode error (EMEM decode error)
[ 120.954891] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[ 120.963982] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[ 120.975142] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[ 120.992751] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[ 121.003788] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
$GNRMC,091827.0,60,112,34,07,44
[ 121.954926] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[ 122.399024] tegra-mc 8108020000.memory-controller: No interrupt in HUB/HUBC
[ 122.405962] tegra-mc 8108020000.memory-controller: No interrupt in HUB/HUBC
[ 122.412924] tegra-mc 8108020000.memory-controller: No interrupt in HUB/HUBC
[ 122.419054] ttyAMA ttyAMA5: 3 input overrun(s)
[ 122.424963] tegra-mc 8108020000.memory-controller: No interrupt in HUB/HUBC
Hi haiteng.wang,
Please check if you hit the similar issue as 7.2 uart5 issue - #13 by KevinFFF.
