Jetcam cant read realsense image. open OpenCV | GStreamer warning: Cannot query video position: status=0, value=-1, duration=-1
hi, i get some problem of transfer image from realsense to jetson nano. i can run on python to get usb image from this code.
# create video sources & outputs
input = videoSource(args.input, argv=sys.argv)
output = videoOutput(args.output, argv=sys.argv)
# process frames until EOS or the user exits
while True:
    # capture the next image
    img = input.Capture()
    if img is None: # timeout
        continue
i think this is same as usb to send the image to jetson nano,i select /dev/video4 that can run RGB image.
but when i use jupyter to use this code
ls -Itrh /dev/video*
/dev/video0  /dev/video1  /dev/video2  /dev/video3  /dev/video4  /dev/video5
from jetcam.usb_camera import USBCamera
camera = USBCamera(width=640, height=480, capture_width=640, capture_height=480, capture_device=4)
[ WARN:0] global /home/ubuntu/build_opencv/opencv/modules/videoio/src/cap_gstreamer.cpp (1100) open OpenCV | GStreamer warning: Cannot query video position: status=0, value=-1, duration=-1
I got this warning and can’t not show the image. so is the jetcam function problem or just some seting i set wrong. i want to use this camera because i want to get depth information. logical 270 can’t get this information.
Please try the samples:
V4l2src using OpenCV Gstreamer is not working in Jetson Xavier NX - #3 by DaneLLL
If this sample works, you can refer to it and check why your sample does not work properly.
I can see the image from your sample but there is some information and same warning. General configuration
for OpenCV 4.5.4 =====================================
  Version control:               4.5.4-8-g3e4c170df4
  Platform:
    Timestamp:                   2022-01-18T10:01:01Z
    Host:                        Linux 5.10.65-tegra aarch64
    CMake:                       3.16.3
    CMake generator:             Unix Makefiles
    CMake build tool:            /usr/bin/make
    Configuration:               Release
  CPU/HW features:
    Baseline:                    NEON FP16
  C/C++:
    Built as dynamic libs?:      YES
    C++ standard:                11
    C++ Compiler:                /usr/bin/c++  (ver 9.3.0)
    C++ flags (Release):         -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Wsuggest-override -Wno-delete-non-virtual-dtor -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fvisibility=hidden -fvisibility-inlines-hidden -O3 -DNDEBUG  -DNDEBUG
    C++ flags (Debug):           -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Wsuggest-override -Wno-delete-non-virtual-dtor -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fvisibility=hidden -fvisibility-inlines-hidden -g  -O0 -DDEBUG -D_DEBUG
    C Compiler:                  /usr/bin/cc
    C flags (Release):           -fsigned-char -W -Wall -Werror=return-type -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fvisibility=hidden -O3 -DNDEBUG  -DNDEBUG
    C flags (Debug):             -fsigned-char -W -Wall -Werror=return-type -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fvisibility=hidden -g  -O0 -DDEBUG -D_DEBUG
    Linker flags (Release):      -Wl,--gc-sections -Wl,--as-needed
    Linker flags (Debug):        -Wl,--gc-sections -Wl,--as-needed
    ccache:                      NO
    Precompiled headers:         NO
    Extra dependencies:          dl m pthread rt
    3rdparty dependencies:
  OpenCV modules:
    To be built:                 calib3d core dnn features2d flann gapi highgui imgcodecs imgproc ml objdetect photo python2 python3 stitching ts video videoio
    Disabled:                    world
    Disabled by dependency:      -
    Unavailable:                 java
    Applications:                tests perf_tests examples apps
    Documentation:               NO
    Non-free algorithms:         NO
  GUI:                           GTK2
    GTK+:                        YES (ver 2.24.32)
      GThread :                  YES (ver 2.64.6)
      GtkGlExt:                  NO
  Media I/O:
    ZLib:                        /usr/lib/aarch64-linux-gnu/libz.so (ver 1.2.11)
    JPEG:                        /usr/lib/aarch64-linux-gnu/libjpeg.so (ver 80)
    WEBP:                        build (ver encoder: 0x020f)
    PNG:                         /usr/lib/aarch64-linux-gnu/libpng.so (ver 1.6.37)
    TIFF:                        /usr/lib/aarch64-linux-gnu/libtiff.so (ver 42 / 4.1.0)
    JPEG 2000:                   build (ver 2.4.0)
    HDR:                         YES
    SUNRASTER:                   YES
    PXM:                         YES
    PFM:                         YES
  Video I/O:
    FFMPEG:                      YES
      avcodec:                   YES (58.54.100)
      avformat:                  YES (58.29.100)
      avutil:                    YES (56.31.100)
      swscale:                   YES (5.5.100)
      avresample:                YES (4.0.0)
    GStreamer:                   YES (1.16.2)
    v4l/v4l2:                    YES (linux/videodev2.h)
  Parallel framework:            TBB (ver 2020.1 interface 11101)
  Trace:                         YES (with Intel ITT)
  Other third-party libraries:
    Lapack:                      NO
    Eigen:                       YES (ver 3.3.7)
    Custom HAL:                  YES (carotene (ver 0.0.1))
    Protobuf:                    build (3.5.1)
  Python 2:
    Interpreter:                 /usr/bin/python2.7 (ver 2.7.18)
    Libraries:                   /usr/lib/aarch64-linux-gnu/libpython2.7.so (ver 2.7.18)
    numpy:                       /usr/lib/python2.7/dist-packages/numpy/core/include (ver 1.16.5)
    install path:                lib/python2.7/dist-packages/cv2/python-2.7
  Python 3:
    Interpreter:                 /usr/bin/python3 (ver 3.8.10)
    Libraries:                   /usr/lib/aarch64-linux-gnu/libpython3.8.so (ver 3.8.10)
    numpy:                       /usr/lib/python3/dist-packages/numpy/core/include (ver 1.17.4)
    install path:                lib/python3.8/dist-packages/cv2/python-3.8
  Python (for build):            /usr/bin/python2.7
  Java:
    ant:                         NO
    JNI:                         NO
    Java wrappers:               NO
    Java tests:                  NO
  Install to:                    /usr
but i cant receive any image showed from this code on jupyter lab
camera = USBCamera(width=640, height=480, capture_width=640, capture_height=480, capture_device=5)
image = camera.read()
print(image.shape)
print(camera.value.shape)
import ipywidgets
from IPython.display import display
from jetcam.utils import bgr8_to_jpeg
image_widget = ipywidgets.Image(format='jpeg')
image_widget.value = bgr8_to_jpeg(image)
display(image_widget)
output:
Image(value=b'\xff\xd8\xff\xe0\x00\x10JFIF\x00\x01\x01\x00\x00\x01\x00\x01\x00\x00\xff\xdb\x00C\x00\x02\x01\x0…
i dont know why i can run your sample to read on CV2 but can’t read for image_widget but there are only value no image
