Jetpack 3.3 OpenCV error No CUDA support (The library is compiled without CUDA support)
I’m attempting to build/run some code I inherited on a TX2 board with Jetpack 3.3. I get the following run-time message:
I didn’t build OpenCV–simply installed via the Jetpack installer.
Do I need to rebuild OpenCV? Is there something else that could be wrong?
Mike
Not checked last JetPack version, but previously opencv3 package included in JetPack had no CUDA nor gstreamer support.
You can build and install your own version. You can look at these links:
[url]https://github.com/AastaNV/JEP/blob/master/script/install_opencv3.4.0.sh[/url]
[url]https://github.com/jetsonhacks/buildOpenCVTX2[/url]
[url]https://jkjung-avt.github.io/opencv3-on-tx2/[/url]
[url]https://github.com/econsystems/opencv[/url]
It sounds like I’m rebuilding OpenCV. Thanks for the links…
Mike
