Hi everyone,
I have just recently installed jetpack 4.2 on my Jetson TX2 board however when I try out to read the the Logitec C920 Camera i was not able to read it.
#include <iostream>
#include <opencv2//opencv.hpp>
#include <opencv2/videoio/videoio.hpp>
#include <opencv2/highgui/highgui.hpp>
#include <opencv2/imgproc/imgproc.hpp>
int main()
cv::VideoCapture cap(1);
if(!cap.isOpened()) {
std::cout<<"Failed to open camera."<<std::endl;
return (-1);
unsigned int width = cap.get(CV_CAP_PROP_FRAME_WIDTH);
unsigned int height = cap.get(CV_CAP_PROP_FRAME_HEIGHT);
unsigned int fps = cap.get(CV_CAP_PROP_FPS);
unsigned int pixels = width*height;
unsigned int format = cap.get(CV_CAP_PROP_FORMAT);
std::cout <<"Frame size : "<<width<<" x "<<height<<", "<<pixels<<" Pixels "<<fps<<" FPS"<<std::endl;
std::cout <<"Format : " << format <<std::endl;
cv::Mat frame_in;
cap.read(frame_in);
//imshow("image",frame_in);
cap.release();
return 0;
the result output is :
ian@jetsontx2:~/OpenCvExample/build$ ./cv_camera
Frame size : 176 x 144, 25344 Pixels 15 FPS
Format : 16
VIDIOC_STREAMON: Input/output error
Format : 16
VIDIOC_STREAMON: Protocol error
VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV
OpenCV Error: Unspecified error (GStreamer: unable to start pipeline
) in cvCaptureFromCAM_GStreamer, file /home/nvidia/build_opencv/opencv/modules/videoio/src/cap_gstreamer.cpp, line 887
VIDEOIO(cvCreateCapture_GStreamer(CV_CAP_GSTREAMER_V4L2, reinterpret_cast<char *>(index))): raised OpenCV exception:
/home/nvidia/build_opencv/opencv/modules/videoio/src/cap_gstreamer.cpp:887: error: (-2) GStreamer: unable to start pipeline
in function cvCaptureFromCAM_GStreamer
I really don’t understand the error as I can run this same code in the Jetson Nano.
ian@jetsontx2:~/OpenCvExample/build$ v4l2-ctl -d /dev/video1 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: ‘YUYV’
Interval: Discrete 0.050s (20.000 fps)
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.100s (10.000 fps)
Interval: Discrete 0.133s (7.500 fps)
Interval: Discrete 0.200s (5.000 fps)
Index : 1
Pixel Format: 'H264' (compressed)
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.042s (24.000 fps)
Index : 2
Pixel Format: 'MJPG' (compressed)
