Anyone have any luck getting a UVC Web Camera to work with Gstreamer on the Jetson Xavier?
I initially encountered issues with not getting any video when trying the imagenet-camera sample app within Jetson-Inference.
It seemed to be a gstreamer issue so I tried it separately, and here is the output.
nvidia@jetson-0423018055236:~$ gst-launch-1.0 v4l2src device="/dev/video0" ! “video/x-raw, width=640, height=480, format=(string)I420” ! xvimagesink -e
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
EOS on shutdown enabled – waiting for EOS after Error
Waiting for EOS…
Now I’m not sure that’s the correct pipeline. It was in the Jetson_Xavier_Accelerated_GStreamer_User_Guide.
The webcam works perfectly fine in Cheese.
A Logitech C920 works with cheese. I tried using guvcview, but this failed with SIGABRT.
Does
v4l2-ctl -d /dev/video0 --list-formats-ext
shows I420 640x480 as a supported mode ? You may also set framerate.
Yeah, I get the same result.
The C920 works with Cheese, and guvcview fails. I wanted to use QtCam, but apparently it doesn’t support 18.04
I added package “v4l-utils”, and this is the content:
# v4l2-ctl -d /dev/video0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'YUYV'
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.042s (24.000 fps)
Interval: Discrete 0.050s (20.000 fps)
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.100s (10.000 fps)
Interval: Discrete 0.133s (7.500 fps)
Interval: Discrete 0.200s (5.000 fps)
Size: Discrete 1920x1080
Size: Discrete 2304x1296
Interval: Discrete 0.500s (2.000 fps)
Size: Discrete 2304x1536
Index : 1
Pixel Format: 'H264' (compressed)
Index : 2
Pixel Format: 'MJPG' (compressed)
The actual error is D-Bus. It may be some sort of permissions setup issue, don’t know…the same libdbus-1.so.3 is used for both cheese and guvcview, though only cheese works without a D-Bus error. Basically cheese is the only camera app I know of right now which works, but I have not tried much.
So, for gstreamer you may use format YUY2 instead of I420.
Replacing I420 with YUY2 fixes the problem.
Thanks for your help.
This also fixes the problem with Jetson-Inference, and the Logitec C920 Camera.
See this thread
opened 01:28AM - 15 Sep 18 UTC
As I understand it jetson-inference supports the Jetson Xavier (with Jetpack 4.0 DP) as of the latest commit (81b84d7). But, when...
Could you please explain how did you do it?
Thanks in advance.
