The issue starts at 72 second. At about that time it was no longer possible to connect. It did show up as hotspot on other devices but on connect it just timeouts. At 329 we connected monitor to get more info.
Also tried changing /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf to disable power saving - it didn’t work.
Another log just a network manager restart later where it happened again: [ 0.000000] Booting Linux on physical CPU 0x100[ 0.000000] Linux version - Pastebin.com - first part is the same as first log (first disconnect at 72), then another at about 2834. When monitor is plugged in (hdmi: plugged) then it just happened. So it can happen multiple times in one boot.
I am having the same issue. I have about 6 TX2 devices running JetPack 4.2 L4T 32.1 and I am trying to connect to a private network with static IP’s and they will just not connect. I’ve tried all variations of settings and know for a fact the subnet and gateway are correct. I’ve worked with our IT on this issue and it is still not working and is holding us back from critical development.
Please assist as its an issue with the JetPack driver from Nvidia it seems like for WIFI.
