Alright, back to hardware. I just reflashed from scratch, didn’t install anything (except updates provided by ubuntu software update), then enabled hotspot. Worked fine once, then on restart I have the same issue. The Jetson is still plugged in the devkit. Now I’m stumped. I can replicate the same hardware issue on two Jetsons?
Is there a test I can do to be certain it is a hardware issue? Or what hw issue specifically? Because dmesg just tells me it turns on, then turns off. No errors or anything.
Edit: This is dmesg from the very beginning just in case it maybe shows something before:
[code][ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38-tegra (root@TX1-DEV) (gcc version 4.8.5 (GCC) ) #1 SMP PREEMPT Mon Apr 23 16:30:32 EDT 2018
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options ‘’)
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 2052096
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519680 pages, LIFO batch:31
[ 0.000000] Normal zone: 23968 pages used for memmap
[ 0.000000] Normal zone: 1532416 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f6666000 s31360 r8192 d30080 u69632
[ 0.000000] pcpu-alloc: s31360 r8192 d30080 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2019936
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2.1 androidboot.serialno=0320717049015 bl_prof_dataptr=0x10000@0x277040000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7976724K/8208384K available (11192K kernel code, 1806K rwdata, 5772K rodata, 1164K init, 690K bss, 166124K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
0xffffffbdc2000000 - 0xffffffbdc9da0000 ( 125 MB actual)
fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
memory : 0xffffffc000000000 - 0xffffffc1f6800000 ( 8040 MB)
.init : 0xffffffc001112000 - 0xffffffc001235000 ( 1164 KB)
.text : 0xffffffc000080000 - 0xffffffc001112000 ( 16968 KB)
.data : 0xffffffc001257000 - 0xffffffc00141aa30 ( 1807 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009415] Console: colour dummy device 80x25
[ 0.014074] console [tty0] enabled
[ 0.017630] bootconsole [uart0] disabled
[ 0.021734] kmemleak: Kernel memory leak detector disabled
[ 0.021746] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.021757] pid_max: default: 32768 minimum: 301
[ 0.021805] Security Framework initialized
[ 0.021842] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.021852] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022234] Initializing cgroup subsys io
[ 0.022246] Initializing cgroup subsys memory
[ 0.022263] Initializing cgroup subsys devices
[ 0.022273] Initializing cgroup subsys freezer
[ 0.022282] Initializing cgroup subsys net_cls
[ 0.022291] Initializing cgroup subsys perf_event
[ 0.022301] Initializing cgroup subsys net_prio
[ 0.022311] Initializing cgroup subsys pids
[ 0.022319] Initializing cgroup subsys debug
[ 0.022458] CPU0 ipc=752
[ 0.022468] CPU1 ipc=1024
[ 0.022476] CPU2 ipc=1024
[ 0.022485] CPU3 ipc=752
[ 0.022495] CPU4 ipc=752
[ 0.022504] CPU5 ipc=752
[ 0.022544] ASID allocator initialised with 65536 entries
[ 0.044577] tegra-id: chipid=21817.
[ 0.044596] tegra-id: opt_subrevision=1.
[ 0.044609] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.045038] DTS File Name: tegra186-tx2-cti-ASG001-USB3.dts
[ 0.045051] DTB Build time: Apr 23 2018 16:59:49
[ 0.062386] CPU1: Booted secondary processor [4e0f0030]
[ 0.073940] CPU2: Booted secondary processor [4e0f0030]
[ 0.085603] CPU3: Booted secondary processor [411fd073]
[ 0.097622] CPU4: Booted secondary processor [411fd073]
[ 0.109623] CPU5: Booted secondary processor [411fd073]
[ 0.109688] Brought up 6 CPUs
[ 0.109746] SMP: Total of 6 processors activated.
[ 0.109759] CPU: All CPU(s) started at EL2
[ 0.110236] devtmpfs: initialized
[ 0.128565] Initilizing CustomIPI irq domain
[ 0.128754] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.129533] pinctrl core: initialized pinctrl subsystem
[ 0.129727] OS set in device tree is not L4T.
[ 0.129918] regulator-dummy: no parameters
[ 0.130024] Initializing plugin-manager
[ 0.130076] Plugin module not found
[ 0.130467] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.130770] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt
[ 0.131342] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt
[ 0.132457] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[ 0.132785] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[ 0.133040] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[ 0.133257] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[ 0.133853] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[ 0.134095] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3310-1000-800
[ 0.134306] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[ 0.134553] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[ 0.135826] Adding domain adsp-pd to PM domain ape-pd
[ 0.137430] NET: Registered protocol family 16
[ 0.139469] console [pstore-1] enabled
[ 0.139482] pstore: Registered ramoops as persistent store backend
[ 0.139495] ramoops: attached 0x200000@0x277080000, ecc: 0/0
[ 0.145606] cpuidle: using governor ladder
[ 0.153603] cpuidle: using governor menu
[ 0.154442] bpmp: waiting for handshake
[ 0.154457] bpmp: handshake completed
[ 0.154499] bpmp: synchronizing channels
[ 0.154523] bpmp: channels synchronized
[ 0.154534] bpmp: mail init ok
[ 0.154875] vdso: 2 pages (1 code @ ffffffc00125d000, 1 data @ ffffffc00125c000)
[ 0.154909] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.155859] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.157283] tegra_powergate_init: DONE
[ 0.157304] DTS File Name: tegra186-tx2-cti-ASG001-USB3.dts
[ 0.157318] DTB Build time: Apr 23 2018 16:59:49
[ 0.158176] Tegra reboot handler registered.
[ 0.158771] Registering Tegra186 clocks (this may take a while)…done
[ 0.160072] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.160089] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.160103] arm-smmu 12000000.iommu: stage 1 translation
[ 0.160116] arm-smmu 12000000.iommu: stage 2 translation
[ 0.160129] arm-smmu 12000000.iommu: nested translation
[ 0.160144] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.160163] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.160183] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.160198] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.160212] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.195710] arm-smmu 12000000.iommu: registered 67 master devices
[ 0.197899] iommu: Adding device 3460000.sdhci to group 0
[ 0.198343] iommu: Adding device 3400000.sdhci to group 1
[ 0.199631] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.199897] iommu: Adding device 3160000.i2c to group 3
[ 0.200135] iommu: Adding device c240000.i2c to group 4
[ 0.200346] iommu: Adding device 3180000.i2c to group 5
[ 0.200553] iommu: Adding device 3190000.i2c to group 6
[ 0.200823] iommu: Adding device 31b0000.i2c to group 7
[ 0.201031] iommu: Adding device 31c0000.i2c to group 8
[ 0.201248] iommu: Adding device c250000.i2c to group 9
[ 0.201458] iommu: Adding device 31e0000.i2c to group 10
[ 0.202613] iommu: Adding device 3210000.spi to group 11
[ 0.202817] iommu: Adding device c260000.spi to group 12
[ 0.203026] iommu: Adding device 3240000.spi to group 13
[ 0.203512] iommu: Adding device 3100000.serial to group 14
[ 0.203724] iommu: Adding device 3110000.serial to group 15
[ 0.203947] iommu: Adding device c280000.serial to group 16
[ 0.204153] iommu: Adding device 3130000.serial to group 17
[ 0.205045] iommu: Adding device 2490000.ether_qos to group 18
[ 0.205413] iommu: Adding device b000000.rtcpu to group 19
[ 0.205717] iommu: Adding device c1a0000.aon to group 20
[ 0.206326] Wake73 for irq=42
[ 0.206512] iommu: Adding device smmu_test to group 21
[ 0.206862] mc: mapped MMIO address: 0xffffff8000560000 → 0x2c10000
[ 0.206885] mc: mapped MMIO address: 0xffffff8000640000 → 0x2c20000
[ 0.206904] mc: mapped MMIO address: 0xffffff8000660000 → 0x2c30000
[ 0.206924] mc: mapped MMIO address: 0xffffff8000fa0000 → 0x2c40000
[ 0.206944] mc: mapped MMIO address: 0xffffff8000fc0000 → 0x2c50000
[ 0.206964] mc-err: Set intmask: 0xf3140
[ 0.207106] ecc-err: dram ecc disabled-MC_ECC_CONTROL:0x0000000c
[ 0.207650] Wake76 for irq=199
[ 0.207664] Wake77 for irq=199
[ 0.207674] Wake78 for irq=199
[ 0.207684] Wake79 for irq=199
[ 0.207694] Wake80 for irq=199
[ 0.207703] Wake81 for irq=199
[ 0.207713] Wake82 for irq=199
[ 0.207782] iommu: Adding device 3530000.xhci to group 22
[ 0.208021] iommu: Adding device 3550000.xudc to group 23
[ 0.208520] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.208537] tegra-pmc: ### PMC reset source: Software reset
[ 0.208549] tegra-pmc: ### PMC reset level: L1
[ 0.208559] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.208697] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.208716] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.208821] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.208837] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.209140] iommu: Adding device 13e10000.host1x to group 24
[ 0.209289] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[ 0.209441] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[ 0.209608] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[ 0.209759] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[ 0.209909] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[ 0.210067] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[ 0.210213] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[ 0.210364] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[ 0.210649] iommu: Adding device 150c0000.nvcsi to group 33
[ 0.211017] iommu: Adding device 15700000.vi to group 34
[ 0.211228] iommu: Adding device 15600000.isp to group 35
[ 0.211449] iommu: Adding device 15210000.nvdisplay to group 36
[ 0.211578] iommu: Adding device 15340000.vic to group 37
[ 0.211704] iommu: Adding device 154c0000.nvenc to group 38
[ 0.211843] iommu: Adding device 15480000.nvdec to group 39
[ 0.212064] iommu: Adding device 15380000.nvjpg to group 40
[ 0.212189] iommu: Adding device 15500000.tsec to group 41
[ 0.212316] iommu: Adding device 15100000.tsecb to group 42
[ 0.212772] iommu: Adding device 15810000.se to group 43
[ 0.212897] iommu: Adding device 15820000.se to group 44
[ 0.213014] iommu: Adding device 15830000.se to group 45
[ 0.213144] iommu: Adding device 15840000.se to group 46
[ 0.213491] iommu: Adding device 17000000.gp10b to group 47
[ 0.214700] tegra-reset 5000000.clock: registered 193 resets.
[ 0.218214] iommu: Adding device d000000.bpmp to group 48
[ 0.218618] bpmp: ping status is 0
[ 0.218779] bpmp d000000.bpmp: firmware tag is 83385b61e34297b2f37e76e0cd1ff81e
[ 0.219249] bpmp d000000.bpmp: probe ok
[ 0.222073] iommu: Adding device 2600000.dma to group 49
[ 0.223075] GPIO line 334 (e3325-sdio-rst) hogged as output/high
[ 0.223135] GPIO line 332 (e3325-lane0-mux) hogged as output/low
[ 0.223189] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.223259] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 0.223313] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 0.223371] GPIO line 461 (cam0-rst) hogged as output/low
[ 0.223443] GPIO line 456 (cam0-pwdn) hogged as output/low
[ 0.223551] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 0.225405] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.225511] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 0.226471] iommu: Adding device 10003000.pcie-controller to group 50
[ 0.226808] iommu: Adding device sound to group 51
[ 0.228623] iommu: Adding device 3510000.hda to group 52
[ 0.229769] iommu: Adding device adsp_audio to group 53
[ 0.231133] iommu: Adding device 2993000.adsp to group 54
[ 0.241451] vdd-ac-bat: 5000 mV
[ 0.243823] vdd-1v8-ap: 1800 mV
[ 0.264387] SCSI subsystem initialized
[ 0.264552] libata version 3.00 loaded.
[ 0.264735] usbcore: registered new interface driver usbfs
[ 0.264800] usbcore: registered new interface driver hub
[ 0.264920] usbcore: registered new device driver usb
[ 0.277888] media: Linux media interface: v0.10
[ 0.277987] Linux video capture interface: v2.00
[ 0.282007] pps_core: LinuxPPS API ver. 1 registered
[ 0.282038] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.282116] PTP clock support registered
[ 0.283079] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.283156] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.284649] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.286778] GPIO line 253 (spmic_gpio_input_5) hogged as input
[ 0.286970] GPIO line 254 (spmic_gpio_input_6) hogged as input
[ 0.287098] gpiochip_add_data: registered GPIOs 248 to 255 on device: max77620-gpio
[ 0.294566] vddio-ddr: at 1125 mV
[ 0.298407] avdd_dsi_csi: 1200 mV
[ 0.302401] vdd-1v8: 1800 mV
[ 0.306400] vdd-3v3-sys: 3300 mV
[ 0.307247] spmic-ldo0: at 1800 mV
[ 0.308043] spmic-ldo1: at 800 mV
[ 0.310402] vddio-3v3: 3300 mV
[ 0.311056] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.313630] vdd-rtc: at 800 mV
[ 0.314186] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 0.317627] spmic-ldo6: at 1500 mV
[ 0.321627] vdd-pex-1v05: 1000 mV
[ 0.322182] dvdd-pex: 1000 mV
[ 0.322465] max77620 4-003c: max77620 probe successful
[ 0.322710] Advanced Linux Sound Architecture Driver Initialized.
[ 0.323685] en-vdd-sd: 3300 mV
[ 0.323829] en-vdd-cam: 1800 mV
[ 0.323946] vdd-hdmi: 5000 mV
[ 0.324121] vdd-usb0-5v: 5000 mV
[ 0.324285] vdd-usb1-5v: 5000 mV
[ 0.324401] en-vdd-ts-1v8: 1800 mV
[ 0.324524] en-vdd-ts-hv-3v3: 3300 mV
[ 0.324634] en-vdd-disp-3v3: 3300 mV
[ 0.324747] en-mdm-pwr-3v7: 3700 mV
[ 0.324861] en-vdd-disp-1v8: 1800 mV
[ 0.324971] en-vdd-cam-hv-2v8: 2800 mV
[ 0.325078] en-vdd-cam-1v2: 1200 mV
[ 0.325196] vdd-fan: 5000 mV
[ 0.325303] vdd-3v3: 3300 mV
[ 0.325413] dis-vdd-1v2: 1200 mV
[ 0.325519] en-vdd-vcm-2v8: 2800 mV
[ 0.325641] vdd-usb2-5v: 5000 mV
[ 0.325761] vdd-sys-bl: 3300 mV
[ 0.325871] en-vdd-sys: 1200 mV
[ 0.329056] extcon-gpio-states external-connection:extcon@1: Cable state 0
[ 0.329459] clocksource: Switched to clocksource arch_sys_counter
[ 0.349031] tegra-pcie 10003000.pcie-controller: 2x1, 1x1, 1x1 configuration
[ 0.349487] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.349711] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 0.350182] nvmap_page_pool_init: Total RAM pages: 2010565
[ 0.350201] nvmap_page_pool_init: nvmap page pool size: 251320 pages (981 MB)
[ 0.350281] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.350911] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 0.351319] tegra-pcie 10003000.pcie-controller: probing port 0, using 2 lanes
[ 0.353475] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 0.355180] Wake76 for irq=199
[ 0.355194] Wake77 for irq=199
[ 0.355206] Wake78 for irq=199
[ 0.355216] Wake79 for irq=199
[ 0.355227] Wake80 for irq=199
[ 0.355237] Wake81 for irq=199
[ 0.355248] Wake82 for irq=199
[ 0.356016] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.356201] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.356520] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.356595] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.356737] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.356878] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.357013] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.357308] isomgr_init(): iso emc max clk=1866000KHz
[ 0.357321] isomgr_init(): max_iso_bw=26870400KB
[ 0.357399] NET: Registered protocol family 2
[ 0.357754] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.357976] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.358269] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.358327] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.358381] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.358547] NET: Registered protocol family 1
[ 0.358746] RPC: Registered named UNIX socket transport module.
[ 0.358761] RPC: Registered udp transport module.
[ 0.358772] RPC: Registered tcp transport module.
[ 0.358783] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.358857] PCI: CLS 0 bytes, default 128
[ 0.358950] Trying to unpack rootfs image as initramfs…
[ 0.371435] host1x 13e10000.host1x: initialized
[ 0.372211] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.374430] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.374530] audit: initializing netlink subsys (disabled)
[ 0.374561] audit: type=2000 audit(0.364:1): initialized
[ 0.379803] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.381682] io scheduler noop registered
[ 0.381792] io scheduler cfq registered (default)
[ 0.384332] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.385508] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.386561] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.387599] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.390304] tsec 15500000.tsec: initialized
[ 0.391346] tsec 15100000.tsecb: initialized
[ 0.392953] nvdec 15480000.nvdec: initialized
[ 0.395736] falcon 15340000.vic: initialized
[ 0.396723] falcon 154c0000.nvenc: initialized
[ 0.397773] falcon 15380000.nvjpg: initialized
[ 0.398474] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.398970] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.399466] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.399958] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.400452] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.400955] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.401464] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.401969] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.403042] DC OR NODE connected to /host1x/sor1
[ 0.403160] generic_infoframe_type: 0x87
[ 0.403168] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.403254] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.403269] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.403285] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1000000, vi_iso_bw=1500000, max_bw=3916800
[ 0.403297] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registered with id=0
[ 0.410399] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.410421] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.410438] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.410495] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 0.410511] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 0.410899] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.412608] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.412805] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range
[ 0.412936] kfuse 3830000.kfuse: initialized
[ 0.414061] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.414459] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.416352] console [ttyS0] disabled
[ 0.416399] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[ 0.448266] tegradc 15210000.nvdisplay: probed
[ 0.778874] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 1.182960] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 1.587058] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 1.589073] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 1.991291] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 2.395625] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 2.480285] console [ttyS0] enabled
[ 2.482386] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.483458] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 2.483713] serial-tegra 3130000.serial: RX in PIO mode
[ 2.484648] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[ 2.494738] Console: switching to colour frame buffer device 240x67
[ 2.496105] brd: module loaded
[ 2.501264] loop: module loaded
[ 2.501522] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.501526] nct1008_nct72 7-004c: starting parse dt
[ 2.501603] nct1008_nct72 7-004c: success parsing dt
[ 2.501722] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.568824] tmp451: Enabled overheat logging at 104.00C
[ 2.568918] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.570759] THERMAL EST: found 3 subdevs
[ 2.570762] THERMAL EST num_resources: 0
[ 2.570764] [THERMAL EST subdev 0]
[ 2.570767] [THERMAL EST subdev 1]
[ 2.570770] [THERMAL EST subdev 2]
[ 2.570987] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 2.570988] THERMAL EST: thz register success.
[ 2.571064] THERMAL EST: end of probe, return err: 0
[ 2.571070] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 2.571107] tegra_profiler: Branch: Dev
[ 2.571108] tegra_profiler: Version: 1.117
[ 2.571110] tegra_profiler: Samples version: 41
[ 2.571111] tegra_profiler: IO version: 22
[ 2.571114] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.571117] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.571119] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.571121] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 0, pmu ver: 0x1
[ 2.571123] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.571125] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 0, pmu ver: 0x1
[ 2.571127] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.571128] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.571130] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.571132] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.571134] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.571135] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.571260] tegra_profiler: auth: init
[ 2.573782] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 2.573789] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 2.574407] scsi host0: tegra_ahci
[ 2.574629] scsi host1: tegra_ahci
[ 2.574746] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[ 2.574748] ata2: DUMMY
[ 2.575442] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.575771] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.576070] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.576667] tun: Universal TUN/TAP device driver, 1.6
[ 2.576669] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 2.576793] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.576794] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.576820] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.576821] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.577522] PPP generic driver version 2.4.2
[ 2.577612] PPP BSD Compression module registered
[ 2.577615] PPP Deflate Compression module registered
[ 2.577627] PPP MPPE Compression module registered
[ 2.577634] NET: Registered protocol family 24
[ 2.577671] usbcore: registered new interface driver r8152
[ 2.577696] usbcore: registered new interface driver asix
[ 2.577723] usbcore: registered new interface driver ax88179_178a
[ 2.577744] usbcore: registered new interface driver cdc_ether
[ 2.577770] usbcore: registered new interface driver smsc75xx
[ 2.577790] usbcore: registered new interface driver net1080
[ 2.577810] usbcore: registered new interface driver cdc_subset
[ 2.577838] usbcore: registered new interface driver zaurus
[ 2.577883] usbcore: registered new interface driver cdc_ncm
[ 2.578064] Wake76 for irq=199
[ 2.578066] Wake77 for irq=199
[ 2.578067] Wake78 for irq=199
[ 2.578068] Wake79 for irq=199
[ 2.578069] Wake80 for irq=199
[ 2.578070] Wake81 for irq=199
[ 2.578071] Wake82 for irq=199
[ 2.578116] tegra-xotg xotg: usb2 phy is not available yet
[ 2.578559] usbcore: registered new interface driver cdc_acm
[ 2.578560] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.578592] usbcore: registered new interface driver usb-storage
[ 2.578647] usbcore: registered new interface driver usbserial
[ 2.578666] usbcore: registered new interface driver cp210x
[ 2.578681] usbserial: USB Serial support registered for cp210x
[ 2.578700] usbcore: registered new interface driver ftdi_sio
[ 2.578715] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.578734] usbcore: registered new interface driver option
[ 2.578747] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.578775] usbcore: registered new interface driver pl2303
[ 2.578787] usbserial: USB Serial support registered for pl2303
[ 2.579026] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.580701] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b 8c 43 d4
[ 2.581124] libphy: dwc_phy: probed
[ 2.581476] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.650610] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 2.710394] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.712591] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.712603] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.712735] i2c /dev entries driver
[ 2.713500] [OV5693]: probing v4l2 sensor.
[ 2.718579] tegra-i2c 3160000.i2c: no acknowledge from address 0x36
[ 2.718738] ov5693_write_reg:i2c write failed, 100 = 1
[ 2.718877] tegra-i2c 3160000.i2c: no acknowledge from address 0x36
[ 2.719024] ov5693_write_reg:i2c write failed, 100 = 0
[ 2.764516] tegra-i2c 3160000.i2c: no acknowledge from address 0x36
[ 2.764677] regmap_util_write_table_8:regmap_util_write_table:-121
[ 2.764677] ov5693 0-0036: could not read otp bank
[ 2.766832] ov5693 0-0036: Error -121 reading otp data
[ 2.766892] ov5693: probe of 0-0036 failed with error -121
[ 2.766973] gspca_main: v2.14.0 registered
[ 2.767016] usbcore: registered new interface driver gspca_zc3xx
[ 2.767287] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 2.769041] FAN dev name: pwm-fan
[ 2.769079] FAN:gpio request success.
[ 2.769084] FAN: can’t find tach_gpio
[ 2.769102] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 2.769252] pwm_fan_driver pwm-fan: got pwm for fan
[ 2.769255] pwm_fan_driver pwm-fan: tach period: 1000
[ 2.769520] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 2.769523] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 2.769526] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 2.769530] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 2.769532] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 2.769535] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 2.769538] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 2.769541] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 2.769544] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 2.769547] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 2.770284] device-mapper: uevent: version 1.0.3
[ 2.770454] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.770824] sdhci: Secure Digital Host Controller Interface driver
[ 2.770825] sdhci: Copyright(c) Pierre Ossman
[ 2.770830] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.771064] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 2.771317] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 2.771528] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 2.774687] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 2.774839] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.776420] usbcore: registered new interface driver usbhid
[ 2.776423] usbhid: USB HID core driver
[ 2.779294] nvadsp 2993000.adsp: in probe()…
[ 2.780500] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 2.780536] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 2.780763] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 2.784013] Denver: backdoor interface is NOT available.
[ 2.797438] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 2.799455] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 2.799465] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 2.800144] coresight-tmc 8030000.etf: TMC initialized
[ 2.807214] coresight-tmc 8050000.etr: TMC initialized
[ 2.807669] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 2.808252] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 2.808747] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 2.809221] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[ 2.809703] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 2.810434] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 2.811063] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 2.811666] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 2.812290] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 2.812320] Module initialized successfully
[ 2.816049] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[ 2.817464] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.817621] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ 2.817744] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 2.817913] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[ 2.818046] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 2.818325] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 2.818374] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 2.818420] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[ 2.818460] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[ 2.818499] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[ 2.818564] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[ 2.818603] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[ 2.818744] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ 2.818746] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 2.819382] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[ 2.819385] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
[ 2.819387] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[ 2.819389] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
[ 2.819392] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
[ 2.819394] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[ 2.819395] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[ 2.819424] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[ 2.825729] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 2.826489] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 2.826589] camchar: rtcpu character device driver loaded
[ 2.830523] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 2.830813] register_ari_mca_banks: Registered MCA ROC:IOB
[ 2.830957] register_ari_mca_banks: Registered MCA ROC:CCE
[ 2.831413] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 2.831441] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 2.831467] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 2.831497] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 2.831522] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 2.831547] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 2.831572] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 2.831599] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 2.831623] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 2.831649] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 2.831674] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 2.831702] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 2.831728] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 2.831754] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 2.831778] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 2.831828] **** A57 ECC: Enabled
[ 2.831830] tegra18_a57_serr_init: on CPU 3 a A57 Core
[ 2.831984] parse_throttle_dt_data: Num cap clks = 4
[ 2.831987] parse_throttle_dt_data: clk=mcpu type=1
[ 2.831988] parse_throttle_dt_data: clk=bcpu type=2
[ 2.831994] parse_throttle_dt_data: clk=gpu type=4
[ 2.831996] parse_throttle_dt_data: clk=emc type=3
[ 2.832529] tegra_throttle_probe: probe successful. #cdevs=4
[ 2.832625] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 2.835775] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 2.836909] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 2.853449] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.853666] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 2.853713] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 2.853784] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 2.853812] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
[ 2.854042] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 2.889469] ata1: SATA link down (SStatus 0 SControl 300)
[ 2.891468] mmc0: MAN_BKOPS_EN bit is not set
[ 2.897517] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.898828] mmc0: Skipping tuning since strobe enabled
[ 2.906358] mmc0: periodic cache flush enabled
[ 2.906366] mmc0: new HS400 MMC card at address 0001
[ 2.906677] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 2.906839] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 2.907019] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 2.907181] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 2.908493] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29
[ 2.949959] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 3.148629] mmc1 tuning done saved tap delay=20
[ 3.148641] mmc1: hw tuning done …
[ 3.148655] mmc1: tuning_window[0]: 0xffffffff
[ 3.148667] mmc1: tuning_window[1]: 0xffffe3ff
[ 3.148710] mmc1: tuning_window[2]: 0xfc7fffff
[ 3.148717] mmc1: tuning_window[3]: 0x7fffffff
[ 3.148723] mmc1: tuning_window[4]: 0x0
[ 3.148729] mmc1: tuning_window[5]: 0x0
[ 3.148735] mmc1: tuning_window[6]: 0x0
[ 3.148740] mmc1: tuning_window[7]: 0x0
[ 3.148772] sdhci: Tap value: 20 | Trim value: 5
[ 3.148776] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 3.155673] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.155722] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 4.315873] tegradc 15210000.nvdisplay: fb registered
[ 4.322447] PD DISP0 index2 UP
[ 4.327868] PD DISP1 index3 UP
[ 4.332251] PD DISP2 index4 UP
[ 4.338287] Parent Clock set for DC plld2
[ 4.347402] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 4.374754] tegra-se-nvhost 15810000.se: initialized
[ 4.382237] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 4.390661] tegra-se-nvhost 15820000.se: initialized
[ 4.398036] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 4.406491] tegra-se-nvhost 15830000.se: initialized
[ 4.413589] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 4.422048] tegra-se-nvhost 15840000.se: initialized
[ 4.429361] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 4.441196] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 4.452949] cpufreq: platform driver Initialization: pass
[ 4.460016] tegra_cluster_clk e090000.cluster_clk_priv: in probe()…
[ 4.468079] tegra_cluster_clk e090000.cluster_clk_priv: passed
[ 4.475605] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 4.486678] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 4.497449] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2cc095
[ 4.505942] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 4.505967] tegradc 15210000.nvdisplay: blank - normal
[ 4.507205] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 4.507363] tegradc 15210000.nvdisplay: blank - powerdown
[ 4.507945] tegra186-padctl 3520000.pinctrl: Missing OC pin 0 pinctrl state vbus_en0_sfio_tristate: -19
[ 4.508814] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 4.509243] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not supported
[ 4.511160] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 4.511324] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 4.512584] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered
[ 4.512592] Tachometer driver initialized with pulse_per_rev: 2 and win_len: 2
[ 4.516032] tegra210_adsp_audio_platform_probe: platform probe started
[ 4.528075] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec1
[ 4.528504] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[ 4.529038] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[ 4.529623] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1
[ 4.530420] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[ 4.530426] tegra210-adsp adsp_audio: adma channel page address dt entry not found
[ 4.530429] tegra210-adsp adsp_audio: using adma channel page 0
[ 4.531366] tegra210_adsp_audio_platform_probe probe successfull.
[ 4.531373] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 4.531572] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 4.545130] OPE platform probe
[ 4.545236] OPE platform probe successful
[ 4.562217] PD DISP2 index4 DOWN
[ 4.562332] PD DISP1 index3 DOWN
[ 4.562457] PD DISP0 index2 DOWN
[ 4.568957] tegradc 15210000.nvdisplay: unblank
[ 4.568978] PD DISP0 index2 UP
[ 4.570033] PD DISP1 index3 UP
[ 4.570133] PD DISP2 index4 UP
[ 4.571703] Parent Clock set for DC plld2
[ 4.573245] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 4.579779] random: nonblocking pool is initialized
[ 4.642812] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 4.642921] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 4.643027] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 4.643153] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 4.643251] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 4.643351] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 4.643472] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 4.643568] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 4.643688] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 4.643788] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 4.643891] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 4.644000] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 4.644104] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 4.644221] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 4.644336] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 4.644435] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 4.644539] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 4.644660] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 4.644780] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 4.644885] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 4.649822] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 <-> ADSP PCM1 mapping ok
[ 4.649956] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 <-> ADSP PCM2 mapping ok
[ 4.649999] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[ 4.650030] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[ 4.688965] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input2
[ 4.689672] tegra-snd-t186ref-mobile-rt565x sound: codec-dai “dit-hifi” registered
[ 4.689676] tegra-snd-t186ref-mobile-rt565x sound: This is a dummy codec
[ 4.690327] GACT probability NOT on
[ 4.690338] Mirror/redirect action on
[ 4.690351] u32 classifier
[ 4.690352] Actions configured
[ 4.690392] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 4.691069] IPVS: Registered protocols ()
[ 4.691099] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 4.691176] IPVS: Creating netns size=1424 id=0
[ 4.691204] IPVS: ipvs loaded.
[ 4.691211] IPVS: [rr] scheduler registered.
[ 4.691301] ipip: IPv4 over IPv4 tunneling driver
[ 4.691641] Initializing XFRM netlink socket
[ 4.691983] NET: Registered protocol family 10
[ 4.692680] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 4.692739] NET: Registered protocol family 17
[ 4.692774] NET: Registered protocol family 15
[ 4.692813] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 4.692819] 8021q: 802.1Q VLAN Support v1.8
[ 4.693130] Registered cp15_barrier emulation handler
[ 4.693150] Registered setend emulation handler
[ 4.694943] registered taskstats version 1
[ 4.698240] isp 15600000.isp: initialized
[ 4.701922] nvcsi 150c0000.nvcsi: initialized
[ 4.701932] nvcsi 150c0000.nvcsi: No csi port info
[ 4.701934] nvcsi 150c0000.nvcsi: No bus width info
[ 4.701941] nvcsi 150c0000.nvcsi: No csi port info
[ 4.701943] nvcsi 150c0000.nvcsi: No bus width info
[ 4.701950] nvcsi 150c0000.nvcsi: No csi port info
[ 4.701952] nvcsi 150c0000.nvcsi: No bus width info
[ 4.701958] nvcsi 150c0000.nvcsi: No csi port info
[ 4.701960] nvcsi 150c0000.nvcsi: No bus width info
[ 4.701978] nvcsi 150c0000.nvcsi: No csi port info
[ 4.701980] nvcsi 150c0000.nvcsi: No bus width info
[ 4.702700] Wake76 for irq=199
[ 4.702702] Wake77 for irq=199
[ 4.702702] Wake78 for irq=199
[ 4.702703] Wake79 for irq=199
[ 4.702704] Wake80 for irq=199
[ 4.702704] Wake81 for irq=199
[ 4.702705] Wake82 for irq=199
[ 4.702965] xhci-tegra 3530000.xhci: UTMI port 0 has OTG_CAP
[ 4.702967] xhci-tegra 3530000.xhci: No USB3 port has OTG_CAP
[ 4.704055] spi-tegra114 3210000.spi: Static pin configuration used
[ 4.704184] xhci-tegra 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 4.704186] xhci-tegra 3530000.xhci: Falling back to user helper
[ 4.704616] spi-tegra114 c260000.spi: Static pin configuration used
[ 4.705112] spi-tegra114 3240000.spi: Static pin configuration used
[ 4.705678] tegra-xotg xotg: OTG rev:0200, ADP:0, SRP:1, HNP:1, RSP:0
[ 4.705711] tegra-xotg xotg: update_id_state: ID floating
[ 4.705716] tegra-xotg xotg: update_vbus_state: VBUS not detected
[ 4.705729] tegra-xotg xotg: Nvidia XUSB OTG Controller
[ 4.707082] tegra-xotg xotg: otg: gadget gadget registered
[ 4.707084] tegra-xotg xotg: set gadget otg_caps from OTG controller
[ 4.707085] tegra-xotg xotg: otg: host not registered yet
[ 4.707087] tegra-xotg xotg: otg: start OTG finite state machine
[ 4.707122] tegra-xudc-new 3550000.xudc: entering ELPG
[ 4.707415] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 4.708208] input: gpio-keys as /devices/gpio-keys/input/input3
[ 4.741650] tegra_rtc c2a0000.rtc: setting system clock to 2018-05-27 13:11:00 UTC (1527426660)
[ 4.771493] bpmp: mounted debugfs mirror
[ 4.771949] [dram-timers] DRAM derating cdev registered.
[ 4.776020] spmic-ldo0: disabling
[ 4.776217] spmic-ldo1: disabling
[ 4.776405] en-vdd-sd: disabling
[ 4.776408] vdd-usb0-5v: disabling
[ 4.776409] vdd-usb1-5v: disabling
[ 4.776415] vdd-3v3: disabling
[ 4.776418] en-vdd-vcm-2v8: disabling
[ 4.776420] vdd-sys-bl: disabling
[ 4.782690] ALSA device list:
[ 4.782692] #0: tegra-hda at 0x3518000 irq 400
[ 4.782693] #1: tegra-snd-t186ref-mobile-rt565x
[ 4.783930] tegra-vi4 15700000.vi: initialized
[ 4.785142] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi-4 bound
[ 4.785146] tegra-vi4 15700000.vi: all channel register failed
[ 6.485042] tegradc 15210000.nvdisplay: hdmi: plugged
[ 6.489889] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.489902] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 6.490862] devtmpfs: mounted
[ 6.491154] Freeing unused kernel memory: 1164K (ffffffc001112000 - ffffffc001235000)
[ 6.491177] Freeing alternatives memory: 96K (ffffffc001235000 - ffffffc00124d000)
[ 6.500402] btb inv war enabled
[ 6.553246] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 6.573351] systemd[1]: Detected architecture arm64.
[ 6.589958] systemd[1]: Set hostname to .
[ 6.719894] systemd[1]: Listening on udev Control Socket.
[ 6.728944] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 6.739155] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 6.749066] systemd[1]: Listening on Syslog Socket.
[ 6.757677] systemd[1]: Reached target Encrypted Volumes.
[ 6.766907] systemd[1]: Reached target User and Group Name Lookups.
[ 6.777356] systemd[1]: Listening on Journal Audit Socket.
[ 6.787886] systemd[1]: Listening on udev Kernel Socket.
[ 6.796919] systemd[1]: Created slice User and Session Slice.
[ 6.806193] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 6.816708] systemd[1]: Created slice System Slice.
[ 6.824889] systemd[1]: Reached target Slices.
[ 6.832638] systemd[1]: Listening on Journal Socket.
[ 6.845879] systemd[1]: Starting Create list of required static device nodes for the current kernel…
[ 6.860216] systemd[1]: Started Braille Device Support.
[ 6.870886] systemd[1]: Starting Set console keymap…
[ 6.881748] systemd[1]: Mounting POSIX Message Queue File System…
[ 6.892946] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 6.898624] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 6.910507] systemd[1]: Reached target Remote File Systems (Pre).
[ 6.919971] systemd[1]: Reached target Remote File Systems.
[ 6.932626] systemd[1]: Starting Load Kernel Modules…
[ 6.941858] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.952984] systemd[1]: Starting Journal Service…
[ 6.963138] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
[ 6.977546] systemd[1]: Reached target Swap.
[ 6.985768] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.997301] systemd[1]: Listening on LVM2 poll daemon socket.
[ 7.008287] systemd[1]: Mounting Debug File System…
[ 7.017849] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 7.031630] systemd[1]: Mounted Debug File System.
[ 7.040484] systemd[1]: Mounted POSIX Message Queue File System.
[ 7.050528] systemd[1]: Started Journal Service.
[ 7.209345] systemd-journald[293]: Received request to flush runtime journal from PID 1
[ 7.396559] xhci-tegra 3530000.xhci: cannot find firmware…retry after 1 second
[ 7.543607] dhd_module_init in
[ 7.573220] tegra_net_perf_init: cannot get wifi sclk
[ 7.599265] found wifi platform device bcmdhd_wlan
[ 7.600226] wifi_platform_get_country_code_map: could not get country_code_map
[ 7.600228] wifi_plat_dev_drv_probe:platform country code map is not available
[ 7.600241] Power-up adapter ‘DHD generic adapter’
[ 7.600245] wifi_platform_set_power = 1
[ 7.801475] wifi_platform_bus_enumerate device present 1
[ 7.821884] wifi_platform_bus_enumerate device present 0
[ 7.832419] F1 signature read @0x18000000=0x17214354
[ 7.872870] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 7.886171] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 7.895367] wifi_platform_prealloc: failed to alloc static mem section 7
[ 7.905951] wifi_platform_get_mac_addr
[ 7.916212] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 7.916678] wl_create_event_handler(): thread:wl_event_handler:257 started
[ 7.916707] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc1e0da1a70
[ 7.926950] dhd_attach(): thread:dhd_watchdog_thread:258 started
[ 7.927218] dhd_attach(): thread:dhd_dpc:25a started
[ 7.927271] dhd_attach(): thread:dhd_rxf:25b started
[ 7.927277] dhd_deferred_work_init: work queue initialized
[ 7.928810] Dongle Host Driver, version 1.201.82 (r)
Compiled in drivers/net/wireless/bcmdhd on Apr 23 2018 at 16:32:00
[ 7.929130] tegra_sysfs_register
[ 7.929158] Register interface [wlan0] MAC: 00:04:4b:8c:43:d2
[ 7.929161] dhd_prot_ioctl : bus is down. we have nothing to do
[ 7.929256] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 20
[ 7.930306] wifi_platform_set_power = 0
[ 8.343444] using random self ethernet address
[ 8.350387] using random host ethernet address
[ 8.382375] Mass Storage Function, version: 2009/09/11
[ 8.389800] LUN: removable file: (no medium)
[ 8.400307] using random self ethernet address
[ 8.407125] using random host ethernet address
[ 8.414030] xhci-tegra 3530000.xhci: Firmware timestamp: 2017-12-07 10:50:08 UTC, Version: 55.09 release
[ 8.426151] usb0: HOST MAC 06:dd:33:b4:ad:d7
[ 8.427700] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 8.427714] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 1
[ 8.428923] xhci-tegra 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00010810
[ 8.428949] xhci-tegra 3530000.xhci: irq 59, io mem 0x03530000
[ 8.429041] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 8.429043] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.429045] usb usb1: Product: xHCI Host Controller
[ 8.429047] usb usb1: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 8.429048] usb usb1: SerialNumber: 3530000.xhci
[ 8.430010] hub 1-0:1.0: USB hub found
[ 8.430032] hub 1-0:1.0: 4 ports detected
[ 8.446387] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 8.446394] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 2
[ 8.446501] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 8.446503] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.446505] usb usb2: Product: xHCI Host Controller
[ 8.446507] usb usb2: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 8.446509] usb usb2: SerialNumber: 3530000.xhci
[ 8.446759] hub 2-0:1.0: USB hub found
[ 8.446778] hub 2-0:1.0: 3 ports detected
[ 8.447133] tegra-xotg xotg: otg: host 3530000.xhci registered
[ 8.597342] usb0: MAC 5a:59:23:de:2a:f6
[ 8.597923] usb1: HOST MAC 8a:42:48:62:68:af
[ 8.597960] usb1: MAC 6e:d1:20:2a:e0:50
[ 8.597980] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 8.598832] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 8.598849] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 8.598877] tegra-xudc-new 3550000.xudc: entering ELPG
[ 8.599192] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 8.599230] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 8.599866] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 8.599881] tegra-xudc-new 3550000.xudc: entering ELPG
[ 8.600194] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 8.621930] device usb0 entered promiscuous mode
[ 8.626019] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 8.629677] device usb1 entered promiscuous mode
[ 8.633011] IPv6: ADDRCONF(NETDEV_UP): usb1: link is not ready
[ 8.633014] l4tbr0: port 2(usb1) entered forwarding state
[ 8.633024] l4tbr0: port 2(usb1) entered forwarding state
[ 8.749449] usb 1-2: new high-speed USB device number 2 using xhci-tegra
[ 8.758559] usb 2-1: new SuperSpeed USB device number 2 using xhci-tegra
[ 8.774334] usb 2-1: New USB device found, idVendor=0424, idProduct=5744
[ 8.784764] usb 2-1: New USB device strings: Mfr=2, Product=3, SerialNumber=0
[ 8.784767] usb 2-1: Product: USB5744
[ 8.784768] usb 2-1: Manufacturer: Microchip Tech
[ 8.785351] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 8.787649] hub 2-1:1.0: USB hub found
[ 8.788019] hub 2-1:1.0: 2 ports detected
[ 8.886553] usb 1-2: New USB device found, idVendor=0424, idProduct=2744
[ 8.895219] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.904376] usb 1-2: Product: USB2744
[ 8.904387] usb 1-2: Manufacturer: Microchip Tech
[ 8.905210] hub 1-2:1.0: USB hub found
[ 8.905271] hub 1-2:1.0: 4 ports detected
[ 9.177459] usb 1-2.1: new high-speed USB device number 3 using xhci-tegra
[ 9.199863] IPVS: Creating netns size=1424 id=1
[ 9.253758] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 9.262260]
[ 9.283810] wl_android_wifi_on in
[ 9.283814] wifi_platform_set_power = 1
[ 9.301923] usb 1-2.1: New USB device found, idVendor=2357, idProduct=010d
[ 9.310880] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 9.320102] usb 1-2.1: Product: 802.11n NIC
[ 9.326644] usb 1-2.1: Manufacturer: Realtek
[ 9.331272] gk20a 17000000.gp10b: railgate is disabled.
[ 9.341694] usb 1-2.1: SerialNumber: 123456
[ 9.342522] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 9.429466] usb 1-2.2: new full-speed USB device number 4 using xhci-tegra
[ 9.442478] tegradc 15210000.nvdisplay: blank - powerdown
[ 9.511423] PD DISP2 index4 DOWN
[ 9.511514] PD DISP1 index3 DOWN
[ 9.511596] PD DISP0 index2 DOWN
[ 9.527690] tegradc 15210000.nvdisplay: unblank
[ 9.527702] PD DISP0 index2 UP
[ 9.528607] PD DISP1 index3 UP
[ 9.528690] PD DISP2 index4 UP
[ 9.530047] Parent Clock set for DC plld2
[ 9.531424] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 9.547608] usb 1-2.2: New USB device found, idVendor=045e, idProduct=07b2
[ 9.547611] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.547613] usb 1-2.2: Product: Microsoft® 2.4GHz Transceiver v8.0
[ 9.547614] usb 1-2.2: Manufacturer: Microsoft
[ 9.552930] input: Microsoft Microsoft® 2.4GHz Transceiver v8.0 as /devices/3530000.xhci/usb1/1-2/1-2.2/1-2.2:1.0/0003:045E:07B2.0001/input/input4
[ 9.554059] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 9.606153] hid-generic 0003:045E:07B2.0001: input,hidraw0: USB HID v1.11 Keyboard [Microsoft Microsoft® 2.4GHz Transceiver v8.0] on usb-3530000.xhci-2.2/input0
[ 9.612064] input: Microsoft Microsoft® 2.4GHz Transceiver v8.0 as /devices/3530000.xhci/usb1/1-2/1-2.2/1-2.2:1.1/0003:045E:07B2.0002/input/input5
[ 9.612510] hid-generic 0003:045E:07B2.0002: input,hidraw1: USB HID v1.11 Mouse [Microsoft Microsoft® 2.4GHz Transceiver v8.0] on usb-3530000.xhci-2.2/input1
[ 9.621970] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 20
[ 9.622992] F1 signature read @0x18000000=0x17214354
[ 9.629921] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 9.630798] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 9.630947] input: Microsoft Microsoft® 2.4GHz Transceiver v8.0 as /devices/3530000.xhci/usb1/1-2/1-2.2/1-2.2:1.2/0003:045E:07B2.0003/input/input6
[ 9.686585] hid-generic 0003:045E:07B2.0003: input,hidraw2: USB HID v1.11 Device [Microsoft Microsoft® 2.4GHz Transceiver v8.0] on usb-3530000.xhci-2.2/input2
[ 9.739638] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 9.781788] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 9.782022] Enabling wake69
[ 9.782942] wifi_platform_get_mac_addr
[ 9.783879] Firmware up: op_mode=0x0002, MAC=00:04:4b:8c:43:d2
[ 9.788939] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 9.792016] Firmware version = wl0: Dec 12 2017 15:09:35 version 7.35.221.34 (r679642) FWID 01-e35dbe99
[ 9.794277] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 9.794456] tegra_sysfs_on
[ 9.851262] l4tbr0: port 2(usb1) entered disabled state
[ 9.871871] cfg80211: World regulatory domain updated:
[ 9.871876] cfg80211: DFS Master region: unset
[ 9.871876] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 9.871881] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.871883] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.871885] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.871888] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 9.871891] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 9.871893] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 9.871895] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.871897] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 9.882955] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.885560] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.012355] CFG80211-ERROR) __wl_cfg80211_scan : Invalid Scan Command at SoftAP mode
[ 10.012358] CFG80211-ERROR) wl_cfg80211_scan : scan error (-22)
[ 10.049581] CFG80211-ERROR) wl_cfg80211_del_station : Disconnect STA : ff:ff:ff:ff:ff:ff scb_val.val 3
[ 10.065579] CFG80211-ERROR) wl_cfg80211_set_channel : netdev_ifidx(5), chan_type(1) target channel(36)
[ 10.110361] _dhd_wlfc_mac_entry_update():1733, entry(32)
[ 10.197718] dhd_ndo_add_ip: ndo ip addr add failed, retcode = -23
[ 10.197723] dhd_inet6_work_handler: Adding host ip for NDO failed -23
[ 10.220946] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 10.559507] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 5
[ 10.559514] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work ignore firmware MBOX_CMD_DEC_SSPI_CLOCK request
[ 10.921038] dhd_ndo_remove_ip: ndo ip addr remove failed, retcode = -23
[ 10.921045] dhd_i
