Hi Team
I unable access jetpack 4.6 and not able flash my kit with Jetpack 4.6. I am able to downlaod Jetpack 4.6 SDK manager but when I login , it is showing "OOPS, No SDK managers found for your account ". But I am able to get other higher SDK managers. Kindly help me to resolve this issue.
I am downloading the SDK manager from the following the link.
What is the version of ubuntu on your host PC?
I am a little confused you your terms here. There is no " higher SDK managers" but only āhigher jetpack versionā.
Are you talking about jetpack version or āsdkmanager versionā? You should always use latest sdkmanager version but jetpack version could be old one.
Actually I installed SDK manager that comes for Jetpack 4.6 but It was throwing me error. that āNo SDKs available for you accountā. But when I use SDK manager of Jetpack 4.6.3 and higher version like 5.0 and above, SDK managers are available.
I am attaching the screenshot for your reference:
Sdkmanager download is over hereā¦
Hi @WayneWWW
Please refer to my previous reply, you will understand the problem. I have downloaded the SDK that is available from the above mentioned link itself.
Yes, I understand your problem. But your comment does not make sense.
Your link is downloading jetpack but not sdkmanager. Sdkmanger is just one version. Jetpack could be various.
If you really have a problem in sdkmanager, then you could directly download jetpack from similar website as what you shared too.
For example, jetpack4.5 page for jp4.5.
Just to clarify, sdkmanager has its own version too but that version only needs to update. We wonāt fallback sdkmanger version for older jetpack version.
Please let me know if you really understand my comment. If you cannot, please tell.
I need to confirm you are not using some old sdkmanager version here. For example, latest sdkmanager is already 1.9.2.xxx version. Your version seems still 1.6.1.xxx.
Ok let me explain clearly.
I installed SDK manager 1.6.1-8175 to install Jetpack 4.6. But their I am facing the problem. When I login to SDK manager it is showing me like āNo SDKs available for your accountā.
Yes, then your sdkmanager is out-of-date. Please upgrade your sdkmanager. Check the button on the upper right ācheck for updatesā.
Sdkmanager is just a tool for download jetpack. You donāt need to use a very old sdkmanager in order to download old jetpack versionā¦
Even latest 1.9.2 sdkmanager can support jetpack 4ā¦
I updated the SDK manager(to 1.9.2-10899) but I am not able to find Jetpack 4.6.
Kindly find the screenshot attached below for your reference.
Now start on command line with:
sdkmanager --archivedversions
Great ! I am able to find jetpack 4.6(rev. 3).
Thanks @WayneWWW and @linuxdev
