I work with a Jetson TX2 to do autonomous robotic (f1tenth). I recently upgraded JetPack to 4.6 and I can’t compile some ROS packages (cartographer ros and hector slam) since that because of a segmentation fault error. After some research I found that topic : Error when trying to compile on nvidia xavier AGX. Hence I tried to upgrade gcc and g++ to 8.4 and I tried to increase the stack size with ulimit but without success.
Then, I discovered this topic : Jetpack 4.6: Maximum stacksize limited to 1024 causing stackoverflow in gcc. I am pretty sure that it’s my problem. Hence, is it possible to change the stack size with this Nvidia limit ? I have already tried ulimit -s unlimited
, ulimit -s xxxx
and sudo bash -c "ulimit -s xxxx"
but either I have an error or it does nothing.
Thanks !
