On Jetpack 4.6, during compilation of our code we ran into some stackoverflow segfaults when compiling with gcc. After lots of debugging we found that the file /etc/security/limits.conf was no longer the default one from ubuntu18.04. In this file you changed the stacksizes to 1024 while the default is 8192.
Why is this? And if we change this back to the default, will it cause issues for us?
l4t: release: set stacksize to 1 MBytes
Our driver should declare less stacksize requirement to reserve memory
usage if the app is calling mlockall() for the consideration of
performance.
The current stacksize is 8M
Bug 3282372
diff --git a/rfs/etc/systemd/nvfb.sh b/rfs/etc/systemd/nvfb.sh
index 7d5dacb..69c27b2 100755
--- a/rfs/etc/systemd/nvfb.sh
+++ b/rfs/etc/systemd/nvfb.sh
@@ -1,7 +1,7 @@
#!/bin/bash
-# Copyright (c) 2016-2020, NVIDIA CORPORATION. All rights reserved.
+# Copyright (c) 2016-2021, NVIDIA CORPORATION. All rights reserved.
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions
@@ -47,6 +47,16 @@ if [ -e "/lib/systemd/system/ssh.service" ]; then
done
fi
+# Set default stacksize to 1 MBytes
+ echo "nvidia hard stack 1024"
+ echo "nvidia soft stack 1024"
+ echo "ubuntu hard stack 1024"
+ echo "ubuntu soft stack 1024"
+ echo "root hard stack 1024"
+ echo "root soft stack 1024"
+} >> "/etc/security/limits.conf"
I know ‘mlockall’ is a kernel API (aka system-call). What I wonder and ask is : why did Nvidia change the ‘ulimit -s’ value. Does it make some nvidia-provided binary (which one ?) work better or impact less the rest of the system ?
Could those libraries (which ones, precisely ?) implement the ulimit themselves inside their code, instead of applying such a general “fix”. That “fix” is like using a hammer to kill a fly.
