JetPack 4.64/L4t 32.7.4 Jetson xavier NX
Hi
I have a custom board based on DevKit p3668/p53509.I have to customize the L4T to support lontium lt6911uxc csi driver and dts,I already customised the same lt6911uxc driver and dts at jetson nano and it works.Now , I did the customise at platform jakku.I rebuild the kernel with the driver and also update the dts files.
Before changing the changes I flashed withn SDKManager the JetPack 4.6.4[l4T 32.7.4] and it boot ok and I also got the ubuntu screen well.
While I loaded the Image and dtb/dtbo I encounter failure with exception.I have a log file of the printing to console.
I see the following issues:
I see problems with Validating kernel and dtb, but it seems validation failed because the .sig not replaced.Anyway it print that it ignored.
I see that it failed to load ramdisk initrd.
The problem is that I changed extlinux.conf and editing with vi entered error in the name of initrd to /boot/initrD with cap letter D instead of initrd…
Here is a snapshot from the log (log is attached) at Line number 8750
I> Loading ramdisk from rootfs …
[0019.145] I> Loading ramdisk binary from rootfs …
[0019.150] I> rootfs path: /sdmmc_user/boot/initrD
This caused exception and panic with
[0019.343]HALT: spinning forever…
I want to ask how to recover from this situation that kernal is stuck due to error in extlinux.cont ?
I want to avoid flash from the SDKManger of the whole long process and build the customization again…
Is there a way to use recovery mode and flash just extlinuxconf or just the dtb and kernel? I have jetson with eMMC.
I attached the log
XAVIER_FAILED_ON_BOOT_DTB_AUTHENTIC.txt (406.8 KB)
Regards
Yehuda
Does the extlinux.conf have backup entry?
Hi
No.
The extlinux is as originally supplied at the jetpack 4.6.4 which the backup label is in comment.
I thought to use the flash script from sdkmanager in ~/nvidia/nvidia_sdk/jetpack_4.6.4_Linux_JETSON_XAVIER_NX_TARGETS/
Can the flash script flash the original file system and image and may resolve the extlinux wrong line
of initrD instead initrd?
regards
yehuda
Maybe try to backup the system image and reflash the device then to restore it.
