Jetpack 5.0.2 : NULL VI channel received & VIFALC_TDSTATE
I am developing a driver which has been working Jetpack 5.0.2 in xavier
(1)Here is the dtsi:
mclk_khz = “27000”;
num_lanes = “4”;
tegra_sinterface = “serial_a”;
phy_mode = “DPHY”;
discontinuous_clk = “no”;
dpcm_enable = “false”;
cil_settletime = “0”;
dynamic_pixel_bit_depth = “16”;
csi_pixel_bit_depth = “16”;
mode_type = “yuv”;
pixel_phase = “uyvy”;
	active_w = "3840";
	active_h = "2160";
	readout_orientation = "0";
	line_length = "5000";
	inherent_gain = "1";
	mclk_multiplier = "2";
	pix_clk_hz = "300000000";
	serdes_pix_clk_hz = "300000000";
When i used this command:
v4l2-ctl --set-ctrl bypass_mode=0 --stream-mmap -d /dev/video0
and got following error :
[ 641.245393] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 641.245716] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 641.246577] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 641.246759] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 641.246992] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 641.247150] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 641.247671] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 641.248565] ------------[ cut here ]------------
and trace as follows:
kworker/0:1-15 [000] … 638.713532: rtcpu_vinotify_event: tstamp:20746020343 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:663856604256 data:0xcd9ce50010000000
kworker/0:1-15 [000] … 638.713536: rtcpu_vinotify_event: tstamp:20746020514 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:663856610048 data:0x0000000031000001
kworker/0:1-15 [000] … 638.713537: rtcpu_vinotify_event: tstamp:20746020706 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:663856672704 data:0xcd9ce20010000000
kworker/0:1-15 [000] … 638.713538: rtcpu_vinotify_event: tstamp:20746020869 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:663856678272 data:0x0000000031000002
vi-output, ox08-3520 [003] … 641.247415: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 10
v4l2-ctl-3518 [002] … 641.257460: tegra_channel_close: vi-output, ox08b40 30-0024
dmesg.txt (86.5 KB)
trace.txt (5.0 KB)
Looks like NVCSI/VI didn’t receive any validate data from the sensor.
May need to probe the MIPI signal to confirm.
