Hello NVIDIA team,
I’m trying to install JetPack 7.2 (L4T 39.2) on a Jetson Orin Nano Developer Kit using the new Jetson ISO installer, but the installation consistently fails.
Before I spend more time debugging, I’d like to confirm whether this is a known issue or whether I’m missing something.
Hardware
Device: Jetson Orin Nano Developer Kit
Firmware: Updated to JetPack 7.2 generation firmware (accepted the firmware update prompt by pressing Y during installation)
Installer ISO:jetsoninstaller-r39.2.0-2026-06-01-23-53-13-arm64.iso
Installer media:HP 128GB USB flash drive
Target device:SanDisk USB SSD
What I have already verified
Official NVIDIA ISO downloaded.
ISO flashed multiple times using Balena Etcher.
Tried three different installer USB drives.
“Check disc for defects” reports no errors.
Firmware update prompt appeared and I pressed Y.
Installer boots correctly.
Target USB SSD is detected correctly.
Installation starts successfully.
Installation path
Boot Jetson ISO.
Select Install on USB.
Choose the SanDisk USB SSD as the installation target.
Installation proceeds normally.
Failure occurs during Curtin/Subiquity installation.
Errors observed
Error 1
TypeError: ‘NoneType’ object is not iterable
Subiquity traceback points into:
apply_autoinstall_config
convert_autoinstall_config
filesystem.py
Error 2
CurtinInstallError
followed by
Unexpected error while running command
Error 3
modprobe: FATAL: Module bcache not found in directory /lib/modules/6.8.12-1021-tegra
This appears during Curtin storage processing.
Additional observations
After the installer fails:
/target is empty.
Mounting the target filesystem manually also shows that no operating system has been installed.
The traceback occurs after Curtin begins processing the storage configuration.
Documentation question
The JetPack 7.2 Quick Start Guide lists only:
microSD
NVMe SSD
as target storage prerequisites.
However, the installer itself clearly provides an Install on USB option.
Is installing Jetson Linux onto a USB SSD officially supported on JetPack 7.2 for the Jetson Orin Nano Developer Kit?
If USB installation is supported, could this be a known installer bug?
If USB installation is not currently supported, could the documentation or installer UI be updated to make that clear?
Thank you for your help.
