Try to start with new jetpack7.2 iso struck with same step again and again
[ 8.614935] pci 0008:00:00.0: bridge window [mem 0x3528000000-0x35280fffff]: assigned
[ 8.615931] pci 0008:00:00.0: bridge window [io 0x300000-0x300fff]: assigned
[ 8.616790] pci 0008:01:00.0: BAR 4 [mem 0x3528000000-0x3528003fff 64bit]: assigned
[ 8.626832] pci 0008:01:00.0: BAR 2 [mem 0x3528004000-0x3528004fff 64bit]: assigned
[ 8.635038] pci 0008:01:00.0: BAR 0 [io 0x300000-0x3000ff]: assigned
[ 8.638918] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[ 8.644181] pci 0008:00:00.0: bridge window [io 0x300000-0x300fff]
[ 8.653181] pci 0008:00:00.0: bridge window [mem 0x3528000000-0x35280fffff]
[ 8.658953] pci_bus 0008:00: resource 4 [mem 0x3240000000-0x3527ffffff pref]
[ 8.664748] pci_bus 0008:00: resource 5 [mem 0x3528000000-0x352fffffff]
[ 8.674004] pci_bus 0008:00: resource 6 [io 0x300000-0x3fffff]
[ 8.678378] pci_bus 0008:01: resource 0 [io 0x300000-0x300fff]
[ 8.683768] pci_bus 0008:01: resource 1 [mem 0x3528000000-0x35280fffff]
[ 8.690393] pcieport 0008:00:00.0: Adding to iommu group 7
[ 8.698255] pcieport 0008:00:00.0: PME: Signaling with IRQ 198
[ 8.703261] pcieport 0008:00:00.0: AER: enabled with IRQ 198
[ 8.710173] r8168 0008:01:00.0: Adding to iommu group 7
[ 8.712313] r8168 Gigabit Ethernet driver 8.053.00-NAPI loaded
[ 8.718794] r8168 0008:01:00.0: enabling device (0000 → 0003)
[ 8.743294] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 8.744961] r8168 0008:01:00.0 enP8p1s0: renamed from eth0
[ 8.748003] r8168 Copyright (C) 2024 Realtek NIC software team nicfae@realtek.com
[ 8.748003] This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
[ 8.748003] This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
[ 16.351430] tegra186-emc 2c60000.external-memory-controller: sync_state() pending due to 3510000.hda
[ 16.352474] tegra-mc 2c00000.memory-controller: sync_state() pending due to 3510000.hda
[ 16.353313] tegra186-emc 2c60000.external-memory-controller: sync_state() pending due to 3550000.usb
[ 16.354137] tegra-mc 2c00000.memory-controller: sync_state() pending due to 3550000.usb
[ 16.354936] tegra186-emc 2c60000.external-memory-controller: sync_state() pending due to 13e00000.host1x
[ 16.355768] tegra-mc 2c00000.memory-controller: sync_state() pending due to 13e00000.host1x
[ 16.356575] tegra186-emc 2c60000.external-memory-controller: sync_state() pending due to 17000000.gpu
[ 16.357396] tegra-mc 2c00000.memory-controller: sync_state() pending due to 17000000.gpu
[ 16.358212] tegra186-emc 2c60000.external-memory-controller: sync_state() pending due to 13800000.display
[ 16.359064] tegra-mc 2c00000.memory-controller: sync_state() pending due to 13800000.display
[ 16.359883] tegra186-emc 2c60000.external-memory-controller: sync_state() pending due to bc00000.rtcpu
[ 16.360723] tegra-mc 2c00000.memory-controller: sync_state() pending due to bc00000.rtcpu
[ 16.366195] tegra186-emc 2c60000.external-memory-controller: sync_state() pending due to 2900800.ahub
[ 16.375456] tegra-mc 2c00000.memory-controller: sync_state() pending due to 2900800.ahub
why is this stop to same this step again in middle of booting after i will select install on NVMe.
what is the solution of this
What was the previous jetpack version before installing the jp7.2 ISO? And could you share full log?
previous version is 36.4.3
current version is 39.2.0
But now I have installed JetPack version 7.2 on the SD card. However, I only get this error when I change to the SSD. Actually, I need to do it on the SSD, but while I am able to install it on the SD card, it gets stuck exactly at this step whenever I use the SSD. I don’t know what the problem is. As attached in the previous image, it gets stuck and stands at that spot. After some time, it shows some error and then goes to the shell. I don’t know the solution for this issue. Please help me with this.
If you want to quick method to bypass all of these errors, then using another Ubuntu host PC to flash your Jetson with sdkmanager would definitely work.
what is the step by step process to change sd card to ssd by terminals?
i did’t have any linux device.
What are you trying to do here? From what I could tell from the limited info you shared, you could only fallback to jp6 for now. JP7.2 installation seems not possible.
If you want to check jp7.2 situation, I could tell you how to gather correct log first. Those screenshots or partial logs you shared didn’t cover all the info.
Your firmware version does not match 39.2 . On your splash screen, it says 36.4.3 which indicates that it is for JetPack 6.2
i update the version by press y when booting
The firmware did not update according to the splash screen.
Would like to get more information.
  1. Your Orin Nano module is with SD card slot(p3767-0005), and you flash rootfs to SD storage?
  2. In the ISO installation, you would like to switch rootfs from SD storage to NVMe SSD storage?
Since you mention SD card and NVMe SSD, it is uncertain which one you are using. Please advise. We would expect the storage interface of rootfs unchanged before and after ISO installation.
Please try the steps to upgrade QSPI to r39.2:
[Jetson AGX Orin] Boot loop after Jetson ISO r39.2 installation – L4TLauncher: Unable to locate L4T Support protocol: Not Found - #9 by DaneLLL
