Jetpack missing
Hello, I am currently using a Jetson Orin Nano 16GB version and have encountered the following issues:
The development board was originally running JetPack 6.0. I upgraded it to JetPack 7.2 using a USB flash drive. The system boots up normally, and I have installed the CUDA toolkit. I would like to achieve higher power limits and GPU frequencies, but I am running into the following problems:
When I use jetson_release to check the JetPack version, it shows as “missing.” However, when I run dpkg -l | grep -E "nvidia-(jetpack|l4t-core)", it does show that the system has it installed. Then, when I use jetson_clocks to lock the frequency, jtop shows that the GPU frequency is only 918 MHz — which is the same frequency as on JetPack 6.0.
After that, I checked the power limits and found that the maximum is only 25W — the 40W option does not appear.
To be honest, this is quite puzzling, and I haven’t been able to find the cause. That’s why I’m posting this thread — to ask for your help.
Thank you for your assistance. If the issue can be resolved, I would be extremely grateful, as it would be a huge help to me.
。。。 I reinstalled jtop, and now it can’t detect the GPU.
We cannot reproduce the issue.
Please try to reflash the device.
Guys, after a whole day of research and experimentation, I finally flashed my Jetson Orin NX into Super mode — the power limit and GPU frequency cap now reach 40W and 1.2 GHz respectively. However, the issue of jtop failing to detect the JetPack version still remains unsolved.
First off, the goal has been achieved. Now let me walk you through how to upgrade the dev kit to Super mode in detail.
First, you need to confirm the current version on your board. You can do this by opening jtop and checking the top-left corner to see whether the version string ends with “Super” or not.
Step 1: If you have an Orin NX or Orin Nano — regardless of whether it’s the 8GB or 16GB version — you need to flash it to JetPack 6.2 using SDK Manager. However, note that when flashing with SDK Manager, after the image download completes, a dialog will pop up with an option in the bottom-right corner where you can choose to select or skip.
Could you please tell me how to install jtop to display the JetPack version?
thank you
Have you run below commands?
sudo apt update
sudo apt install nvidia-jetpack
I have completed and executed the aforementioned commands, and everything appears to be working correctly for CUDA, TensorRT, and OpenCV; however, jtop was installed via pip.
