Jetpack version not shown right on jtop
I’ve recently installed Jtop for resource monitoring using the command “$ sudo pip3 install -U jetson-stats”. My Jetson Nano board is supposed to have the jetpack version 4.6.1. Meanwhile, it is showing 4.6.4 at the top of the panel. What could be done to resolve this issue? Is it possible to install Jtop, particularly for version 4.6.1 ?
Hi rahulbeingrahul,
Are you using the devkit or custom board for Jetson Nano?
Could you share the result of the following command on your board?
$ cat /etc/nv_tegra_release
Do you have any requirement to stay at JP4.6.1 rather than updating to the latest JP4.6.4?
