JTOP variables not found
Hello ! Im in grear trouble
I have installed jetson-stats==3.0.0 everything is working fine jtop command jetson_config command all is working fine but i encountered below error which im unable to debug
Please help me how to remove this error
Please try sudo tegrastats. You should see identical information as shown in JTOP.
Hi @aymen.baig
I suggest installing the latest version of jetson-stats with all the latest fixes and updates.
PLEASE NOTE: If you are working python instead of python3 use pip instead of pip3
You can quickly do with:
sudo pip3 install -U jetson-stats
If you need exactly this version, I suggest reinstalling with the following command:
sudo pip3 install --no-cache-dir jetson-stats==3.0.0
If this error is there after reboot, try to remove the file manually located in:
sudo rm /etc/profile.d/jetson_env.sh
I followed all the suggestions above but error is still there
What’s your JetPack version?
Nano devkit or custom carrier board?
