Continuing the discussion from Jetpack5.0.2 Xavier pcie endpoint mode network:
I have the same error
I already disable networkmanager on both machines.Ping still fails。
Your situation is basically the same as mine, disabling network management did not solve the problem, I solved it in this way: 1.
I made the board for PCIE connection according to “NVIDIA Jetson AGX Xavier PCIe Endpoint Design Guidelines (DA-09357)”, because the cable I bought online did not meet the requirements.
2. Replaced the 12V10A power adapter, I used 19V1A power adapter before, which may cause unknown problem due to insufficient power supply.
Then I successfully connected to the network on the following connections.
Although my connection #2 is now having problems again, Had success : )
oh,Thank you for your advice.
