I understand that there is an issue with the GPIO assignments, which is 3499398 (GPIO configuration utility does not work as expected in Linux 5.10 kernel included in Jetpack 5.0 DP release).
I would like to confirm that the issue I am seeing is related to this. When I added our pinmux.dtsi file, generated from the NX spreadsheet my NX module wouldn’t boot. I removed many of the assignments, until the NX to booted. After getting the NX to boot, I did a “sudo grep gpio /sys/kernel/debug/gpio” and noticed the locations of the pins were different when compared with JetPack4.
My questions are:
Is this changed assignment due to the 3499398 issue:
If so, will the fix put the GPIO pins back to the same assignment as JetPack 4?
Does a changed GPIO assignment/error occur only when the macro TEGRA194_MAIN_GPIO is used?
Thanks for the feedback. I will look at the information you provided.
Could you answer the questions above. The reason is, I don’t understand what effect I will see as a result of the “GPIO configuration” issue. Is what I am seeing with the change in gpio “locations” the result of the GPIO configuration issue?
If I execute the following command: “sudo grep gpio /sys/kernel/debug/gpio”, here is what I am seeing:
In jetPack4 : gpio-480 (SPI1_SCK |gmsl1-enable ) out hi:
in JetPack5: gpio-484 (PY.00 |gmsl1-enable ) out hi
In the JetPack 5 gpio dump, PY.00 is correct, but the calculation shows the incorrect gpio number of 484. It should be 480.
yes, it follow the same process to change the pinmux configuration applied by the software.
please see-also developer guide, Pinmux Changes for reference, thanks
