I am using a Jetson AGX Orin device and it is Configuration #1 mode and I need to switch to Configuration #2 mode. Where do I switch it from?
“Table 6 4 shows the supported UPHY mapping for USB 3.2, PCIe, UFS and MGBE. Only one of
the three supported configurations can be used in a design. No mixing or matching of
interfaces between the configurations is supported”
How do I switch to Configuration #2?
Check the adaptation guide which is inside the l4t developer guide.
Thank you so much, dear WayneWWW
I have successfully replaced the Configuration #2
