I set
ODMDATA=“gbe-uphy-config-0,hsstp-lane-map-3,hsio-uphy-config-16,nvhs-uphy-config-0”;
How do I confirm that the machine is working under Configuration #2 ???
I set
After changing to Configuration #2 , the Type C port “J39” which is above the power connector only has USB2 availability.
You can plug in a USB3 device, but only USB2 is available.
For example, I plug in a USB3 external ssd, but only USB2.1(480Mb/s) is available.
