Jetson AGX Orin type-c does not support display output
I have a Kwumsy K2 keyboard connected to a jetson Orin using type-c. This keyboard input works fine, but the screen doesn’t work. Do I need to enable the display output function of type-c? what should i do
Orin does not support to output from usb port … Please use the DP port on the carrier board if this is devkit…
Is it because the hardware doesn’t support it or the driver doesn’t support it?
There is also this question, please help me to answer the following
From the beginning, jetson’s USB does not support display function. Neither hardware or software.
