Hello, thank you for taking the time to read my inquiry. We are planning to use Jetson AGX orin modules to design a controller and plan to customize a carrier based on the Jetson AGX Orin Developer Kit. We would like to remove the PD controller (CYPD4226-40LQXIT). So So what I want to inquire about: can I install DRIVE using the USB3.1 interface under SDK manager instead of using the TYPE-C interface?
Welcome to the NVIDIA Developer forums! Your topic will be better served in the Jetson category.
I will move this over for visibility.
Cheers,
Tom
Assume you are asking about flash over USBSS, please refer to this Flashing Support — Jetson Linux Developer Guide documentation
