Jetson AGX Orion is booting up with no display
I was trying to install Pytorch which works on CUDA. Initially, I had jetpack 5.1 and cudatool kit 11.4 version on ubuntu20.04. Then I installed cudatool kit 12.2 then on reboot the display was gone. I am not sure which caused the issue. How to work around this situation so that I can make it work as normal?
I need help ASAP.
Could you share how do you install the CUDA 12 on the Jetson Orin.
Currently, there are two way available:
1. Setup with JetPack 6
2. Use CUDA Compatibility feature:
Follow the instructions listed below:
