Cannot reboot Jetson Orin AGX on JetPack 6.0
A few days ago, I started using an AGX Orin that had JetPack 6.0 installed. I could not get OpenCV and PyTorch to run on the GPU so I followed the instructions (link) and
tried installing each of these wheels: https://developer.download.nvidia.com/compute/redist/jp/v60dp/pytorch/
I tried upgrading the version of cuda and rebooted, and since I cannot boot the Jetson.
I’ve read Jetson Orin AGX refused to reboot after running sudo reboot but I do not have another PC with Ubuntu handy to reboot from the serial console.
The initial screen starts up and then the display goes to a power saving mode. I’ve followed AGX Orin Recovery Boot, without luck.
Thank you very much.
Nothing you can do without an x86 host.
It’s required for flashing.
