My Orin Agx refused to boot after i ran sudo reboot in terminal. I wasn’t rebooting so i manually turned it off, tried starting back up and now its stuck in a phase of the fan spinning and not spinning. I don’t know if that indicates that it is trying to come on but stuck in some problem loop. Please help, i cant afford to Flash the board.
If you are in a state that you totally cannot tell whether the board is booting up or not, you should dump the serial console log from micro usb port.
Thank you, worked just fine. Rebooted from the serial console, plugged in my display and ready to go.
