There are times when an SSD connected via USB 3.0 is not recognized by the Jetson AGX Xavier.
This does not happen every time, but it occurs occasionally.
I have attached the dmesg log file from the system startup. dmesg.log (145.0 KB)
In this log file, the SSD was connected after the Jetson was powered on, and the logs related to the SSD start at line 1598.
Even when the SSD is connected to the Jetson at startup, the same issue may occur.
Additionally, once this issue occurs, the SSD will not be recognized no matter how many times it is reconnected, unless the system is restarted.
Sorry, it was Xavier, not Orin.
I’m not designing the board. I’m using ROSCUBE.
The output of the uname -r command is 4.9.253-rqx58g
Is there a problem with the ROSCUBE board design?
