hi,Jetson :
Recently, I encountered some problems when using Jetson AGX Orin Series. I hope you can help me check;
1, we use the HDMI display, after powering on, from the display Angle can normally see the Nvidia logo, and then normal boot after printing some log, the display will not respond (display prompt no video signal);
2, we use the serial port to print log information, log, the last printed information is shown in the appendix at the end of the article;
3, I looked up the relevant solution, said to use the serial port to send instructions to configure, but I tried, no effect; Is there any error in the sent instruction? Or can we provide configuration instructions to send?
4, try a lot of methods, and then don’t know how to deal with the next step;
【 Note: 1. We use the self-designed carrier board to connect Jetson AGX Orin, because it is difficult to fix the supporting carrier board after connecting to PCIE, but the K5 and H8 pins are not connected to flash, is it affected by this? 2, I also found a way to change the device tree, need to change the DP to the default HDMI output, do not know if this is the case?
The following is the last few lines of the log information printed over the serial port:
[14.000505] nvidia: loading out-of-tree module taints kernel.
[14.043504] rt5640 8-001c: Device with ID register 0xffff54da is not RT5640/39
[14.216841] ucsi_ccg 1-0008: i2c_transfer failed-121
[14.222791] ucsi_ccg 1-0008: ucsi_ccg_init failed-121
[14.223561] ucsi_ccg: probe of 1-0008 failed with error-121
[15.739192] CPU8: shutdown
[15.951904] CPU9: shutdown
[16.099472] CPU10: shutdown
[16.224789] IRQ 124: no longer affine to CPU11
[16.230854] CPU11: shutdown
[18.047545] Aquantia AQR113C 6810,000. ethernet:00: aqr107_wait_reset_complete failed: -110
[34.117729] Please complete system configuration setup on the serial port provided by Jetson’s USB device mode connection. e.g. /dev/ttyUSBx where x can 0, 1, 2 etc.
There seems to be a problem with the USB port
HDMI seems having problem as you said.
Ethernet looks like problem too.
There is actually no problem with the boot itself, as the boot process will be waiting over there for the first boot time, please set the user account to continue to the boot process
Which situation do you want to deal with in this topic? Usually, one topic only deal with one issue.
以下是启动最后的log:
[ 18.047545] Aquantia AQR113C 6810000.ethernet:00: aqr107_wait_reset_complete failed: -110
[ 34.117729] Please complete system configuration setup on the serial port provided by Jetson’s USB device mode connection. e.g. /dev/ttyUSBx where x can 0, 1, 2 etc.
e[1;24re[4le)0e[me(Be[1;24re[He[Je[1;1HSystem Configuratione[9;12H鈹屸攢鈹€鈹€鈹€鈹?License For Customer Use of NVIDIA Software 鈹溾攢鈹€鈹€鈹€鈹€鈹?[10;12H鈹?[56C鈹?[11;12H鈹?Welcome to Jetson Initial Configuratione[16C鈹?[12;12H鈹?[56C鈹?[13;12H鈹?[25Ce[7me[27Ce[me(B鈹?[14;12H鈹?[56C鈹?[15;12H鈹斺攢鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹€鈹?[13;39H
