USB devices not recognized
Hi everybody, i have a problem with mi Jetson AGX, sometimes when it boots up it doesn’t recognize any port, lsusb command doesn’t show any device also usb-devices, I check the system with dmesg --follow command and unplug and then plug the device I try to connect but dmesg doesn’t show anything, it is like all the usb ports dissapeared. If I turn off and on the device the usb start working, I think it is a random event but it is no desired for my application, what could it be? Thanks.
You can share the dmesg when error happened.
My dmesg file looks like this but when the error happens none of these USB messages appears:
[ 0.000000] Kernel command line: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix=_b boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4
[ 0.994491] usbcore: registered new interface driver usbfs
[ 0.994551] usbcore: registered new interface driver hub
[ 0.994701] usbcore: registered new device driver usb
[ 1.061355] vdd-usb-3v3: at 3300 mV
[ 1.853740] usbcore: registered new interface driver r8152
[ 1.853778] usbcore: registered new interface driver asix
[ 1.853810] usbcore: registered new interface driver ax88179_178a
[ 1.853839] usbcore: registered new interface driver cdc_ether
[ 1.853866] usbcore: registered new interface driver net1080
[ 1.853920] usbcore: registered new interface driver cdc_subset
[ 1.853948] usbcore: registered new interface driver zaurus
[ 1.853983] usbcore: registered new interface driver cdc_ncm
[ 1.855288] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.855350] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.860784] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 1.860817] tegra-xusb 3610000.xhci: USB3 port 2 has OTG_CAP
[ 1.867213] usbcore: registered new interface driver uas
[ 1.867267] usbcore: registered new interface driver usb-storage
[ 1.867355] usbcore: registered new interface driver usbserial
[ 1.883709] usbcore: registered new interface driver xpad
[ 2.061695] usbcore: registered new interface driver usbhid
[ 2.061698] usbhid: USB HID core driver
[ 2.083643] usbcore: registered new interface driver snd-usb-audio
[ 5.092373] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 5.092379] tegra-xusb 3610000.xhci: USB3 port 2 has OTG_CAP
[ 5.095574] tegra-xusb 3610000.xhci: extcon 0: ffffffc7d7152c00 id
[ 5.098501] tegra-xusb 3610000.xhci: Firmware timestamp: 2019-07-24 05:47:34 UTC, Version: 60.06 release
[ 5.098528] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 5.098539] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 5.099169] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 5.099196] tegra-xusb 3610000.xhci: irq 474, io mem 0x03610000
[ 5.099345] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.099362] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.099365] usb usb1: Product: xHCI Host Controller
[ 5.099369] usb usb1: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 5.099372] usb usb1: SerialNumber: 3610000.xhci
[ 5.099792] hub 1-0:1.0: USB hub found
[ 5.100064] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 5.100071] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 5.100077] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 5.100194] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 5.100198] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.100201] usb usb2: Product: xHCI Host Controller
[ 5.100204] usb usb2: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 5.100207] usb usb2: SerialNumber: 3610000.xhci
[ 5.100472] hub 2-0:1.0: USB hub found
[ 5.101045] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 5.101050] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 5.203895] usb usb2: usb_suspend_both: status 0
[ 5.435553] usb 1-1: new high-speed USB device number 2 using tegra-xusb
[ 5.456810] usb 1-1: New USB device found, idVendor=8086, idProduct=0b5c
[ 5.456816] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.456820] usb 1-1: Product: Intel(R) RealSense™ Depth Camera 455
[ 5.456823] usb 1-1: Manufacturer: Intel(R) RealSense™ Depth Camera 455
[ 7.022113] input: Intel(R) RealSense™ Depth Ca as /devices/3610000.xhci/usb1/1-1/1-1:1.0/input/input6
[ 7.024622] usbcore: registered new interface driver uvcvideo
[ 7.024627] USB Video Class driver (1.1.1)
[ 7.290676] usb0: HOST MAC d2:16:38:2b:c3:86
[ 7.290709] usb0: MAC d2:16:38:2b:c3:87
[ 7.310663] l4tbr0: port 2(usb0) entered blocking state
[ 7.310669] l4tbr0: port 2(usb0) entered disabled state
[ 7.311280] device usb0 entered promiscuous mode
[ 7.316535] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 8.017594] tegra-xusb 3610000.xhci: WARN Set TR Deq Ptr cmd failed due to incorrect slot or ep state.
[ 8.227609] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 8.249700] usb 1-3: New USB device found, idVendor=8087, idProduct=0025
[ 8.249712] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 8.433135] usbcore: registered new interface driver btusb
Please just share me the whole dmesg.
This is the dmesg, I am trying to reproduce the problem of the usb because it happens randomly.
dmesg.txt (75.3 KB)
Finally, this is the dmesg when the AGX doesn’t recognize the usb, this happened after a shutdown and disconnection from electrical power.
dmesg_fail.txt (70.1 KB)
Do you have any peripheral connected on the board that is using i2c? For example, the camera.
I use a Intel RealSense D455 as camera, from GPIO I use pin 16 as digital input (1 or 0), 18 and 37 (connected to a led) as digital output.
Can you remove those gpios and see if the issue is still there? According to your dmesg, the situation is somehow i2c is not able read the usb PD firmware and cause usb controller is not up.
Search ucsi keywords in the log will find out what I am talking about.
Hi, WayneWWW, I though it was resolved removing all GPIOS as you proposed, but today I lost Ethernet access, using ifconfig -a gives on eth0 interface a device interrup 41 message, AGX doesn’t have anything on GPIOS.
Trying cat /proc/interrupts gives:
41: 2 0 0 0 0 0 0 0 GICv2 226 Level ether_qos.common_irq
It’s a Xavier AGX 16GB, module P2888-0001, board P2822-0000 with Jetpack 4.5.1.
Thank you
Please file a new topic for this. We only deal with usb for the original topic.
