Hi, we are supplying the Xavier with external batteries and are currently only using a fuse solution. We are having problem with the xavier turning off. We found out that the xavier have a security measure when the voltage changes abruptly and therefore the cause of it turning off. Is it possible to neglect this with using some type of decoupling capacitor? if possible what size should these be? (farad) Or is there a better solution?
hello jacobkristians1,
you’ll need to check power-down requirements, please access Jetson AGX Xavier OEM Product Design Guide for reference,
you may check chapter-5 which describes the power specifications for the Jetson AGX Xavier Series module.
thanks
