12V battery powered abnormal shutdown
Xavier上采用12V20A的电池供电,当跑起检测程序时,系统关机。用19V的原装适配器供电没问题。可能是什么原因,该如何排查
Hi 2489024013,
Welcome to Jetson and Embedded System forum, please be sure to open issue in English manner, below is the translation by Google:
Xavier is powered by a 12V20A battery. When the test program is started, the system shuts down. It is no problem to use the 19V original adapter for power supply. What could be the cause and how to troubleshoot
The Xavier is powered by a 12V20A battery.After starting the Object Detection API program, the system will shut down.Using the 19V original adapter power supply is no problem.What are the possible causes and how can they be resolved
Power must be stable. If the cables are too low of a gauge, or if cables are too long, then this might occur. If the power connector itself has too much resistance, then this too might be a problem.
https://www.google.com/search?source=hp&ei=CTYeXpj-MNSktQb0jYioBw&q=translate+english+to+mandarin&oq=translate+english+to+mandarin&gs_l=psy-ab.3…0l10.10850.15173…15546…1.0…1.264.1949.27j2j1…0…1…gws-wiz…0i131.2r2Av-JSxD0&ved=0ahUKEwjYprzgh4TnAhVUUs0KHfQGAnUQ4dUDCAc&uact=5
电源必须稳定。如果电缆的线规太低或电缆太长,则可能会发生这种情况。如果电源连接器本身的电阻太大,那么这也可能是一个问题。
Diànyuán bìxū wěndìng. Rúguǒ diànlǎn de xiàn guī tài dī huò diànlǎn tài zhǎng, zé kěnéng huì fāshēng zhè zhǒng qíngkuàng. Rúguǒ diànyuán liánjiē qì běnshēn de diànzǔ tài dà, nàme zhè yě kěnéng shì yīgè wèntí.
The resistance of the power supply terminal is 0.2 ohms, the peak current is 3A, and the power supply voltage fluctuation is less than 0.3V.
I could not tell you if that is too much of a variation, but this does seem like a bit high on resistance. Someone else may be able to say if the 0.3V fluctuation is too much, but keep in mind that the time span over which this fluctuation occurs is also important (0.3V over a minute is far different than 0.3V over 100 micro seconds).
Thank you, the internal resistance of the system power meter is too large, it has been resolved!
