Jetson AGX Xavier stuck in the boot loop after do-release-upgrade
Later update from the SDKmanager did not yield in better result.
What is the best way to make the device usable, I do not need to recover the data.
Jetsons terminal spits this. Than it drops a ton of new lines and reboots.
cp: not writing through dangling symlink ‘etc/resolv.conf’
6.319893] cgroup: cgroup2: unknown option “nsdelegate”
7.125866] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
7.126136] squashfs: SQUASHFS error: unable to read xattr id index table
[FAILED] Failed to start RPC bind portmap service. [FAILED] Failed to start RPC bind portmap service.
[ 7.807465] iwlwifi 0003:01:00.0: Direct firmware load for iwlwifi-8265-26.ucode failed with error -2 [ 7.807701] iwlwifi 0003:01:00.0: Falling back to user helper
8.492067] iwlwifi 0003:01:00.0: Direct firmware load for iwlwifi-8265-25.ucode failed with error -2 8.492071] iwlwifi 0003:01:00.0: Falling back to user helper
8.529662] iwlwifi 0003:01:00.0: Direct firmware load for iwlwifi-8265-24.ucode failed with error -2 8.529665] iwlwifi 0003:01:00.0: Falling back to user helper
8.531749] iwlwifi 0003:01:00.0: Direct firmware load for iwlwifi-8265-23.ucode failed with error -2 8.531753] iwlwifi 0003:01:00.0: Falling back to user helper
8.695701] thermal thermal_zone8: failed to read out thermal zone (-5)
What is your target JP version?
Is your host a native ubuntu?
Is your Xavier NX using a dev kit?
Hi, thanks for the response.
I tried flashing the latest one, 6.1 or so.
Host is native Ubuntu 22.04.
Flashing was attempted after do-release-upgrade on Jetson.
do-release-upgrade resulted in the bootloop, Flashing over the sdkmanager did not change the situation.
Can’t answer if Xavier used the dev kit, it did say it was on Ubuntu 18.
Xavier NX only supports JP5.x/JP4.x
Please refer to
Thanks, I will give it a shot.
One more thing SDK Manager when Product Category is Jetson,
System Configuration: Host Machine Ubuntu 22.04 and with Target Hardware selected it gives No SDKs available for installation.
Does that indicate any issues?
Oh it seems that I need to downgrade the host machine to flash 5.1…
You could download the bsp and rootfs and flash manually in your ubuntu 22.04
JP5.1.5?
Intention was to go with the latest possible, so I guess JP5.1.5 it is.
Please download Driver Package (BSP) and Sample Root Filesystem from the Jetson Linux | NVIDIA Developer.
And follow the Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation to flash your device.
