I’m using Jetson Orin AGX device right now, my cuda version is 11.4, torch version is 2.4.1, I’m using conda virtual environment python==3.8, I’m trying to run the model of llama2-7b with this device, but found that he keeps running on the cpu, but I wanted to put it on the gpu, tested it and found torch.cuda.is_available() Returns false, so it can’t be put on the GPU, is there any way to fix it!
Any suggestions could be helpful!
Please install the PyTorch package that has been built with CUDA support.
You can find the package in the topic below:
