HI, I use Jetson Nano Devkit
but, i made my custom L4T by referring NVIDIA Documantation
NVIDIA Docs
I have made modifications to the kernel and U-Boot, and the changes are as follows:
- U-Boot
- Disabling USB Support
- CONFIG_BOOTDELAY = 0
- Kernel
- Disable Real-time Clock
- Audio codec OFF (CONFIG_SND_SOC_TEGRA_ALT, CONFIG_SND_SOC …)
- Disable Console over UART (configuration file p3448-0000.conf to remove the specification console=ttyS0)
Jetson has successfully booted up, but the boot time has only decreased to around 1 second
Serial console log refers to the output of “dmesg”? I am attaching the output below.
May 31 18:03:46 ati-desktop kernel: [ 0.000000] Booting Linux on physical CPU 0x0
May 31 18:03:46 ati-desktop kernel: [ 0.000000] Linux version 4.9.253-tegra (root@haoun-900X3L) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #3 SMP PREEMPT Wed May 31 13:53:31 KST 2023
May 31 18:03:46 ati-desktop kernel: [ 0.000000] Boot CPU: AArch64 Processor [411fd071]
May 31 18:03:46 ati-desktop kernel: [ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
May 31 18:03:46 ati-desktop kernel: [ 0.000000] OF: fdt: - 80000000 , 3f800000
May 31 18:03:46 ati-desktop kernel: [ 0.000000] OF: fdt: - bfa00000 , 3fe00000
May 31 18:03:46 ati-desktop kernel: [ 0.000000] OF: fdt: - ffa00000 , 600000
May 31 18:03:46 ati-desktop kernel: [ 0.000000] Found tegra_fbmem: 00800000@92ca9000
May 31 18:03:46 ati-desktop kernel: [ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
May 31 18:03:46 ati-desktop kernel: [ 0.000000] bootconsole [uart8250] enabled
May 31 18:03:46 ati-desktop kernel: [ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
May 31 18:03:46 ati-desktop kernel: [ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
May 31 18:03:46 ati-desktop kernel: [ 0.000000] cma: Reserved 64 MiB at 0x00000000fb800000
May 31 18:03:46 ati-desktop kernel: [ 0.000000] On node 0 totalpages: 522752
May 31 18:03:46 ati-desktop kernel: [ 0.000000] DMA zone: 8192 pages used for memmap
May 31 18:03:46 ati-desktop kernel: [ 0.000000] DMA zone: 0 pages reserved
May 31 18:03:46 ati-desktop kernel: [ 0.000000] DMA zone: 522752 pages, LIFO batch:31
May 31 18:03:46 ati-desktop kernel: [ 0.000000] psci: probing for conduit method from DT.
May 31 18:03:46 ati-desktop kernel: [ 0.000000] psci: PSCIv1.0 detected in firmware.
May 31 18:03:46 ati-desktop kernel: [ 0.000000] psci: Using standard PSCI v0.2 function IDs
May 31 18:03:46 ati-desktop kernel: [ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
May 31 18:03:46 ati-desktop kernel: [ 0.000000] psci: SMC Calling Convention v1.1
May 31 18:03:46 ati-desktop kernel: [ 0.000000] percpu: Embedded 24 pages/cpu s57624 r8192 d32488 u98304
May 31 18:03:46 ati-desktop kernel: [ 0.000000] pcpu-alloc: s57624 r8192 d32488 u98304 alloc=24*4096
May 31 18:03:46 ati-desktop kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
May 31 18:03:46 ati-desktop kernel: [ 0.000000] CPU features: enabling workaround for ARM erratum 832075
May 31 18:03:46 ati-desktop kernel: [ 0.000000] Speculative Store Bypass Disable mitigation not required
May 31 18:03:46 ati-desktop kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 514560
May 31 18:03:46 ati-desktop kernel: [ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 core_edp_mv=1125 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92ca9000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
May 31 18:03:46 ati-desktop kernel: [ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
May 31 18:03:46 ati-desktop kernel: [ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
May 31 18:03:46 ati-desktop kernel: [ 0.000000] log_buf_len min size: 32768 bytes
May 31 18:03:46 ati-desktop kernel: [ 0.000000] log_buf_len: 131072 bytes
May 31 18:03:46 ati-desktop kernel: [ 0.000000] early log buf free: 30100(91%)
May 31 18:03:46 ati-desktop kernel: [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
May 31 18:03:46 ati-desktop kernel: [ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
May 31 18:03:46 ati-desktop kernel: [ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
May 31 18:03:46 ati-desktop kernel: [ 0.000000] Memory: 1940576K/2091008K available (15102K kernel code, 2664K rwdata, 5756K rodata, 7616K init, 610K bss, 84896K reserved, 65536K cma-reserved)
May 31 18:03:46 ati-desktop kernel: [ 0.000000] Virtual kernel memory layout:
May 31 18:03:46 ati-desktop kernel: [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
May 31 18:03:46 ati-desktop kernel: [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
May 31 18:03:46 ati-desktop kernel: [ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f40000 ( 15104 KB)
May 31 18:03:46 ati-desktop kernel: [ 0.000000] .rodata : 0xffffff8008f40000 - 0xffffff80094f0000 ( 5824 KB)
May 31 18:03:46 ati-desktop kernel: [ 0.000000] .init : 0xffffff80094f0000 - 0xffffff8009c60000 ( 7616 KB)
May 31 18:03:46 ati-desktop kernel: [ 0.000000] .data : 0xffffff8009c60000 - 0xffffff8009efa008 ( 2665 KB)
May 31 18:03:46 ati-desktop kernel: [ 0.000000] .bss : 0xffffff8009efa008 - 0xffffff8009f92874 ( 611 KB)
May 31 18:03:46 ati-desktop kernel: [ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
May 31 18:03:46 ati-desktop kernel: [ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
May 31 18:03:46 ati-desktop kernel: [ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
May 31 18:03:46 ati-desktop kernel: [ 0.000000] 0xffffffbf00000000 - 0xffffffbf02000000 ( 32 MB actual)
May 31 18:03:46 ati-desktop kernel: [ 0.000000] memory : 0xffffffc000000000 - 0xffffffc080000000 ( 2048 MB)
May 31 18:03:46 ati-desktop kernel: [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
May 31 18:03:46 ati-desktop kernel: [ 0.000000] Preemptible hierarchical RCU implementation.
May 31 18:03:46 ati-desktop kernel: [ 0.000000] Build-time adjustment of leaf fanout to 64.
May 31 18:03:46 ati-desktop kernel: [ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
May 31 18:03:46 ati-desktop kernel: [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
May 31 18:03:46 ati-desktop kernel: [ 0.000000] NR_IRQS:64 nr_irqs:64 0
May 31 18:03:46 ati-desktop kernel: [ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
May 31 18:03:46 ati-desktop kernel: [ 0.000000] t210 clock and reset probe
May 31 18:03:46 ati-desktop kernel: [ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
May 31 18:03:46 ati-desktop kernel: [ 0.000000] clk_cbus_recalc_rate: no gbus parent
May 31 18:03:46 ati-desktop kernel: [ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
May 31 18:03:46 ati-desktop kernel: [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
May 31 18:03:46 ati-desktop kernel: [ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
May 31 18:03:46 ati-desktop kernel: [ 0.001504] Console: colour dummy device 80x25
May 31 18:03:46 ati-desktop kernel: [ 0.001524] kmemleak: Kernel memory leak detector disabled
May 31 18:03:46 ati-desktop kernel: [ 0.001542] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
May 31 18:03:46 ati-desktop kernel: [ 0.001555] pid_max: default: 32768 minimum: 301
May 31 18:03:46 ati-desktop kernel: [ 0.002007] Security Framework initialized
May 31 18:03:46 ati-desktop kernel: [ 0.002230] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
May 31 18:03:46 ati-desktop kernel: [ 0.002237] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
May 31 18:03:46 ati-desktop kernel: [ 0.003364] ftrace: allocating 46198 entries in 181 pages
May 31 18:03:46 ati-desktop kernel: [ 0.169843] sched-energy: CPU device node has no sched-energy-costs
May 31 18:03:46 ati-desktop kernel: [ 0.169878] ASID allocator initialised with 65536 entries
May 31 18:03:46 ati-desktop kernel: [ 0.207770] tegra-id: chipid=22117.
May 31 18:03:46 ati-desktop kernel: [ 0.207784] tegra-id: opt_subrevision=0.
May 31 18:03:46 ati-desktop kernel: [ 0.207802] Tegra Speedo/IDDQ fuse revision 4
May 31 18:03:46 ati-desktop kernel: [ 0.207807] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
May 31 18:03:46 ati-desktop kernel: [ 0.207811] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
May 31 18:03:46 ati-desktop kernel: [ 0.207815] Tegra: CPU Speedo Value 2017, SoC Speedo Value 1927, GPU Speedo Value 2022
May 31 18:03:46 ati-desktop kernel: [ 0.207819] Tegra: CPU IDDQ Value 1660, SoC IDDQ Value 1844, GPU IDDQ Value 2220
May 31 18:03:46 ati-desktop kernel: [ 0.207841] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 0
May 31 18:03:46 ati-desktop kernel: [ 0.207855] DTS File Name: /home/haoun/Linux_for_Tegra/sources/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/batuu/kernel-dts/tegra210-p3448-0003-p3542-0000.dts
May 31 18:03:46 ati-desktop kernel: [ 0.207862] DTB Build time: May 31 2023 14:14:54
May 31 18:03:46 ati-desktop kernel: [ 0.257113] CPU1: Booted secondary processor [411fd071]
May 31 18:03:46 ati-desktop kernel: [ 0.289016] CPU2: Booted secondary processor [411fd071]
May 31 18:03:46 ati-desktop kernel: [ 0.320973] CPU3: Booted secondary processor [411fd071]
May 31 18:03:46 ati-desktop kernel: [ 0.321064] Brought up 4 CPUs
May 31 18:03:46 ati-desktop kernel: [ 0.321071] SMP: Total of 4 processors activated.
May 31 18:03:46 ati-desktop kernel: [ 0.321080] CPU features: detected feature: 32-bit EL0 Support
May 31 18:03:46 ati-desktop kernel: [ 0.321342] CPU: All CPU(s) started at EL2
May 31 18:03:46 ati-desktop kernel: [ 0.321359] alternatives: patching kernel code
May 31 18:03:46 ati-desktop kernel: [ 0.329042] devtmpfs: initialized
May 31 18:03:46 ati-desktop kernel: [ 0.365995] Initilizing CustomIPI irq domain
May 31 18:03:46 ati-desktop kernel: [ 0.366324] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
May 31 18:03:46 ati-desktop kernel: [ 0.366345] futex hash table entries: 1024 (order: 4, 65536 bytes)
May 31 18:03:46 ati-desktop kernel: [ 0.368130] pinctrl core: initialized pinctrl subsystem
May 31 18:03:46 ati-desktop kernel: [ 0.368597] OS set in device tree is not L4T.
May 31 18:03:46 ati-desktop kernel: [ 0.369011] regulator-dummy: no parameters
May 31 18:03:46 ati-desktop kernel: [ 0.369325] Initializing plugin-manager
May 31 18:03:46 ati-desktop kernel: [ 0.369462] Plugin module not found
May 31 18:03:46 ati-desktop kernel: [ 0.369804] node /plugin-manager/fragment@1 match with board >=3448-0003-400
May 31 18:03:46 ati-desktop kernel: [ 0.371000] node /plugin-manager/fragement@7 match with odm-data enable-pmic-wdt
May 31 18:03:46 ati-desktop kernel: [ 0.371216] node /plugin-manager/fragement@8 match with odm-data enable-pmic-wdt
May 31 18:03:46 ati-desktop kernel: [ 0.371688] node /plugin-manager/fragment@12 match with board >=3448-0003-400
May 31 18:03:46 ati-desktop kernel: [ 0.371957] node /plugin-manager/fragement@13 match with board >=3448-0003-400
May 31 18:03:46 ati-desktop kernel: [ 0.375627] NET: Registered protocol family 16
May 31 18:03:46 ati-desktop kernel: [ 0.376827] pstore: using zlib compression
May 31 18:03:46 ati-desktop kernel: [ 0.376861] console [pstore-1] enabled
May 31 18:03:46 ati-desktop kernel: [ 0.376865] pstore: Registered ramoops as persistent store backend
May 31 18:03:46 ati-desktop kernel: [ 0.376871] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
May 31 18:03:46 ati-desktop kernel: [ 0.393132] cpuidle: using governor menu
May 31 18:03:46 ati-desktop kernel: [ 0.396102] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
May 31 18:03:46 ati-desktop kernel: [ 0.397697] vdso: 2 pages (1 code @ ffffff8008f47000, 1 data @ ffffff8009c64000)
May 31 18:03:46 ati-desktop kernel: [ 0.397717] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
May 31 18:03:46 ati-desktop kernel: [ 0.401634] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
May 31 18:03:46 ati-desktop kernel: [ 0.403890] Serial: AMBA PL011 UART driver
May 31 18:03:46 ati-desktop kernel: [ 0.404446] tegra_powergate_init: DONE
May 31 18:03:46 ati-desktop kernel: [ 0.404463] DTS File Name: /home/haoun/Linux_for_Tegra/sources/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/batuu/kernel-dts/tegra210-p3448-0003-p3542-0000.dts
May 31 18:03:46 ati-desktop kernel: [ 0.404470] DTB Build time: May 31 2023 14:14:54
May 31 18:03:46 ati-desktop kernel: [ 0.406226] Tegra reboot handler registered.
May 31 18:03:46 ati-desktop kernel: [ 0.410726] iommu: Adding device tegra-carveouts to group 0
May 31 18:03:46 ati-desktop kernel: [ 0.410836] platform tegra-carveouts: domain=ffffffc078ae2258 allocates as[0]=ffffffc0784080a8
May 31 18:03:46 ati-desktop kernel: [ 0.411196] iommu: Adding device smmu_test to group 1
May 31 18:03:46 ati-desktop kernel: [ 0.411244] platform smmu_test: domain=ffffffc078ae2498 allocates as[0]=ffffffc078408110
May 31 18:03:46 ati-desktop kernel: [ 0.412081] mc: mapped MMIO address: 0xffffff8008041000 -> 0x70019000
May 31 18:03:46 ati-desktop kernel: [ 0.412145] mc: mapped MMIO address: 0xffffff8008067000 -> 0x7001c000
May 31 18:03:46 ati-desktop kernel: [ 0.412197] mc: mapped MMIO address: 0xffffff800807b000 -> 0x7001d000
May 31 18:03:46 ati-desktop kernel: [ 0.412206] nv-tegra-mc 70019000.mc: No mssnvlink node
May 31 18:03:46 ati-desktop kernel: [ 0.412239] mc-err: mcerr ops are set to t21x
May 31 18:03:46 ati-desktop kernel: [ 0.422983] iommu: Adding device 70090000.xusb to group 2
May 31 18:03:46 ati-desktop kernel: [ 0.423265] iommu: Adding device 70006000.serial to group 3
May 31 18:03:46 ati-desktop kernel: [ 0.423325] platform 70006000.serial: domain=ffffffc078492498 allocates as[0]=ffffffc078408178
May 31 18:03:46 ati-desktop kernel: [ 0.423772] iommu: Adding device 70006040.serial to group 4
May 31 18:03:46 ati-desktop kernel: [ 0.424038] iommu: Adding device 70006200.serial to group 5
May 31 18:03:46 ati-desktop kernel: [ 0.424252] iommu: Adding device sound to group 6
May 31 18:03:46 ati-desktop kernel: [ 0.424301] platform sound: domain=ffffffc0784929d8 allocates as[0]=ffffffc0784081e0
May 31 18:03:46 ati-desktop kernel: [ 0.424866] iommu: Adding device 7000d400.spi to group 7
May 31 18:03:46 ati-desktop kernel: [ 0.425169] iommu: Adding device 7000d600.spi to group 8
May 31 18:03:46 ati-desktop kernel: [ 0.425450] iommu: Adding device 70410000.spi to group 9
May 31 18:03:46 ati-desktop kernel: [ 0.425770] iommu: Adding device 50000000.host1x to group 10
May 31 18:03:46 ati-desktop kernel: [ 0.426040] iommu: Adding device 54080000.vi to group 11
May 31 18:03:46 ati-desktop kernel: [ 0.426425] iommu: Adding device 54600000.isp to group 12
May 31 18:03:46 ati-desktop kernel: [ 0.426718] iommu: Adding device 54680000.isp to group 13
May 31 18:03:46 ati-desktop kernel: [ 0.427002] iommu: Adding device tegradc.0 to group 14
May 31 18:03:46 ati-desktop kernel: [ 0.427054] platform tegradc.0: domain=ffffffc07849f918 allocates as[0]=ffffffc078408248
May 31 18:03:46 ati-desktop kernel: [ 0.431244] platform tegradc.0: IOVA linear map 0x0000000092ca9000(800000)
May 31 18:03:46 ati-desktop kernel: [ 0.431506] iommu: Adding device 54340000.vic to group 15
May 31 18:03:46 ati-desktop kernel: [ 0.431706] iommu: Adding device 544c0000.nvenc to group 16
May 31 18:03:46 ati-desktop kernel: [ 0.431902] iommu: Adding device 54500000.tsec to group 17
May 31 18:03:46 ati-desktop kernel: [ 0.432106] iommu: Adding device 54100000.tsecb to group 18
May 31 18:03:46 ati-desktop kernel: [ 0.432335] iommu: Adding device 54480000.nvdec to group 19
May 31 18:03:46 ati-desktop kernel: [ 0.432536] iommu: Adding device 54380000.nvjpg to group 20
May 31 18:03:46 ati-desktop kernel: [ 0.433318] iommu: Adding device 546c0000.i2c to group 21
May 31 18:03:46 ati-desktop kernel: [ 0.433657] iommu: Adding device 57000000.gpu to group 22
May 31 18:03:46 ati-desktop kernel: [ 0.433707] platform 57000000.gpu: domain=ffffffc0784ad798 allocates as[0]=ffffffc0784082b0
May 31 18:03:46 ati-desktop kernel: [ 0.433745] platform 57000000.gpu: domain=ffffffc0784ad798 allocates as[1]=ffffffc078408318
May 31 18:03:46 ati-desktop kernel: [ 0.433784] platform 57000000.gpu: domain=ffffffc0784ad798 allocates as[2]=ffffffc078408380
May 31 18:03:46 ati-desktop kernel: [ 0.433825] platform 57000000.gpu: domain=ffffffc0784ad798 allocates as[3]=ffffffc0784083e8
May 31 18:03:46 ati-desktop kernel: [ 0.434717] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
May 31 18:03:46 ati-desktop kernel: [ 0.434728] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
May 31 18:03:46 ati-desktop kernel: [ 0.434740] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
May 31 18:03:46 ati-desktop kernel: [ 0.434744] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
May 31 18:03:46 ati-desktop kernel: [ 0.434750] tegra-pmc: ### PMC reset status reg: 0x0
May 31 18:03:46 ati-desktop kernel: [ 0.485193] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
May 31 18:03:46 ati-desktop kernel: [ 0.485204] tegra-pmc: Clear bootloader IO dpd settings
May 31 18:03:46 ati-desktop kernel: [ 0.485222] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
May 31 18:03:46 ati-desktop kernel: [ 0.485281] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
May 31 18:03:46 ati-desktop kernel: [ 0.485566] iommu: Adding device 70012000.se to group 23
May 31 18:03:46 ati-desktop kernel: [ 0.486140] iommu: Adding device 1003000.pcie to group 24
May 31 18:03:46 ati-desktop kernel: [ 0.486197] platform 1003000.pcie: domain=ffffffc0784adf18 allocates as[0]=ffffffc078408450
May 31 18:03:46 ati-desktop kernel: [ 0.486649] iommu: Adding device 7000c000.i2c to group 25
May 31 18:03:46 ati-desktop kernel: [ 0.486909] iommu: Adding device 7000c400.i2c to group 26
May 31 18:03:46 ati-desktop kernel: [ 0.487199] iommu: Adding device 7000c500.i2c to group 27
May 31 18:03:46 ati-desktop kernel: [ 0.487460] iommu: Adding device 7000c700.i2c to group 28
May 31 18:03:46 ati-desktop kernel: [ 0.487713] iommu: Adding device 7000d000.i2c to group 29
May 31 18:03:46 ati-desktop kernel: [ 0.487960] iommu: Adding device 7000d100.i2c to group 30
May 31 18:03:46 ati-desktop kernel: [ 0.488256] iommu: Adding device sdhci-tegra.0 to group 31
May 31 18:03:46 ati-desktop kernel: [ 0.488302] platform sdhci-tegra.0: domain=ffffffc078526a98 allocates as[0]=ffffffc0784084b8
May 31 18:03:46 ati-desktop kernel: [ 0.489184] iommu: Adding device 700d0000.xudc to group 32
May 31 18:03:46 ati-desktop kernel: [ 0.492419] vdd-ac-bat: 5000 mV
May 31 18:03:46 ati-desktop kernel: [ 0.492842] vdd-5v0-sys: 5000 mV
May 31 18:03:46 ati-desktop kernel: [ 0.493548] vdd-5v0-hdmi: 5000 mV
May 31 18:03:46 ati-desktop kernel: [ 0.493989] vdd-5v0-hdmi: supplied by vdd-5v0-sys
May 31 18:03:46 ati-desktop kernel: [ 0.494239] vdd-1v8-sys: 1800 mV
May 31 18:03:46 ati-desktop kernel: [ 0.494613] vdd-fan: 5000 mV
May 31 18:03:46 ati-desktop kernel: [ 0.494826] vdd-fan: supplied by vdd-5v0-sys
May 31 18:03:46 ati-desktop kernel: [ 0.495082] vdd-usb-vbus: 5000 mV
May 31 18:03:46 ati-desktop kernel: [ 0.495310] vdd-usb-vbus: supplied by vdd-5v0-sys
May 31 18:03:46 ati-desktop kernel: [ 0.495662] vdd-usb-vbus2: 5000 mV
May 31 18:03:46 ati-desktop kernel: [ 0.525909] HugeTLB registered 2 MB page size, pre-allocated 0 pages
May 31 18:03:46 ati-desktop kernel: [ 0.528104] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
May 31 18:03:46 ati-desktop kernel: [ 0.529487] GPIO line 6 (system-suspend-gpio) hogged as output/high
May 31 18:03:46 ati-desktop kernel: [ 0.529527] GPIO line 151 (camera-control-output-low) hogged as output/low
May 31 18:03:46 ati-desktop kernel: [ 0.529930] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
May 31 18:03:46 ati-desktop kernel: [ 0.538132] eventlib_kernel: keventlib is initialized, test id: 0
May 31 18:03:46 ati-desktop kernel: [ 0.538486] SCSI subsystem initialized
May 31 18:03:46 ati-desktop kernel: [ 0.538697] libata version 3.00 loaded.
May 31 18:03:46 ati-desktop kernel: [ 0.538996] usbcore: registered new interface driver usbfs
May 31 18:03:46 ati-desktop kernel: [ 0.539058] usbcore: registered new interface driver hub
May 31 18:03:46 ati-desktop kernel: [ 0.539100] usbcore: registered new device driver usb
May 31 18:03:46 ati-desktop kernel: [ 0.543278] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
May 31 18:03:46 ati-desktop kernel: [ 0.549353] vdd-core: 600 <--> 1162 mV at 1125 mV
May 31 18:03:46 ati-desktop kernel: [ 0.550445] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
May 31 18:03:46 ati-desktop kernel: [ 0.550542] random: fast init done
May 31 18:03:46 ati-desktop kernel: [ 0.552328] vdd-ddr-1v1: 1150 mV
May 31 18:03:46 ati-desktop kernel: [ 0.556227] vdd-pre-reg-1v35: 1350 mV
May 31 18:03:46 ati-desktop kernel: [ 0.560232] vdd-1v8: 1800 mV
May 31 18:03:46 ati-desktop kernel: [ 0.564231] avdd-sys-1v2: 1200 mV
May 31 18:03:46 ati-desktop kernel: [ 0.568230] vdd-pex-1v0: 1050 mV
May 31 18:03:46 ati-desktop kernel: [ 0.568861] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
May 31 18:03:46 ati-desktop kernel: [ 0.569406] max77620-ldo3: at 3100 mV
May 31 18:03:46 ati-desktop kernel: [ 0.572231] vdd-rtc: 850 <--> 1100 mV at 1000 mV
May 31 18:03:46 ati-desktop kernel: [ 0.572805] max77620-ldo5: at 3100 mV
May 31 18:03:46 ati-desktop kernel: [ 0.576235] vddio-sdmmc3-ap: 1800 <--> 3300 mV at 2800 mV
May 31 18:03:46 ati-desktop kernel: [ 0.580227] avdd-1v05-pll: 1050 mV
May 31 18:03:46 ati-desktop kernel: [ 0.584231] avdd-io-hdmi-dp: 1050 mV
May 31 18:03:46 ati-desktop kernel: [ 0.586964] GPIO line 505 (spmic-default-output-high) hogged as output/high
May 31 18:03:46 ati-desktop kernel: [ 0.587251] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
May 31 18:03:46 ati-desktop kernel: [ 0.587537] max77620 4-003c: max77620 probe successful
May 31 18:03:46 ati-desktop kernel: [ 0.590273] media: Linux media interface: v0.10
May 31 18:03:46 ati-desktop kernel: [ 0.590332] Linux video capture interface: v2.00
May 31 18:03:46 ati-desktop kernel: [ 0.591250] pps_core: LinuxPPS API ver. 1 registered
May 31 18:03:46 ati-desktop kernel: [ 0.591255] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
May 31 18:03:46 ati-desktop kernel: [ 0.591286] PTP clock support registered
May 31 18:03:46 ati-desktop kernel: [ 0.594551] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
May 31 18:03:46 ati-desktop kernel: [ 0.595468] Advanced Linux Sound Architecture Driver Initialized.
May 31 18:03:46 ati-desktop kernel: [ 0.596134] Bluetooth: Core ver 2.22
May 31 18:03:46 ati-desktop kernel: [ 0.596190] NET: Registered protocol family 31
May 31 18:03:46 ati-desktop kernel: [ 0.596194] Bluetooth: HCI device and connection manager initialized
May 31 18:03:46 ati-desktop kernel: [ 0.596264] Bluetooth: HCI socket layer initialized
May 31 18:03:46 ati-desktop kernel: [ 0.596272] Bluetooth: L2CAP socket layer initialized
May 31 18:03:46 ati-desktop kernel: [ 0.596302] Bluetooth: SCO socket layer initialized
May 31 18:03:46 ati-desktop kernel: [ 0.598074] tegra210_dvfs: no clock found for sdmmc2_ddr
May 31 18:03:46 ati-desktop kernel: [ 0.598090] tegra210_dvfs: no clock found for sdmmc4_ddr
May 31 18:03:46 ati-desktop kernel: [ 0.598143] tegra210_dvfs: no clock found for sdmmc1_ddr
May 31 18:03:46 ati-desktop kernel: [ 0.598156] tegra210_dvfs: no clock found for sdmmc3_ddr
May 31 18:03:46 ati-desktop kernel: [ 0.601455] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
May 31 18:03:46 ati-desktop kernel: [ 0.602589] vdd-3v3-sys: 3300 mV
May 31 18:03:46 ati-desktop kernel: [ 0.602962] vdd-3v3-sys: supplied by vdd-5v0-sys
May 31 18:03:46 ati-desktop kernel: [ 0.603014] vdd-1v8-sys: supplied by vdd-3v3-sys
May 31 18:03:46 ati-desktop kernel: [ 0.604312] vdd-usb-vbus2: supplied by vdd-3v3-sys
May 31 18:03:46 ati-desktop kernel: [ 0.604711] vdd-3v3-sd: 3300 mV
May 31 18:03:46 ati-desktop kernel: [ 0.605079] vdd-3v3-sd: supplied by vdd-3v3-sys
May 31 18:03:46 ati-desktop kernel: [ 0.605831] avdd-io-edp-1v05: 1050 mV
May 31 18:03:46 ati-desktop kernel: [ 0.606178] avdd-io-edp-1v05: supplied by avdd-1v05-pll
May 31 18:03:46 ati-desktop kernel: [ 0.606345] vdd-usb-hub-en: 5000 mV
May 31 18:03:46 ati-desktop kernel: [ 0.606702] vdd-usb-hub-en: supplied by vdd-1v8-sys
May 31 18:03:46 ati-desktop kernel: [ 0.607803] camchar: rtcpu character device driver loaded
May 31 18:03:46 ati-desktop kernel: [ 0.608541] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
May 31 18:03:46 ati-desktop kernel: [ 0.610026] clocksource: Switched to clocksource arch_sys_counter
May 31 18:03:46 ati-desktop kernel: [ 0.650640] VFS: Disk quotas dquot_6.6.0
May 31 18:03:46 ati-desktop kernel: [ 0.650766] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
May 31 18:03:46 ati-desktop kernel: [ 0.651268] nvmap_heap_init: nvmap_heap_init: created heap block cache
May 31 18:03:46 ati-desktop kernel: [ 0.651756] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
May 31 18:03:46 ati-desktop kernel: [ 0.651767] nvmap_page_pool_init: Total RAM pages: 501528
May 31 18:03:46 ati-desktop kernel: [ 0.651773] nvmap_page_pool_init: nvmap page pool size: 62691 pages (244 MB)
May 31 18:03:46 ati-desktop kernel: [ 0.651902] nvmap_background_zero_thread: PP zeroing thread starting.
May 31 18:03:46 ati-desktop kernel: [ 0.652259] misc nvmap: iram :dma coherent mem declare 0x0000000040001000,258048
May 31 18:03:46 ati-desktop kernel: [ 0.652463] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
May 31 18:03:46 ati-desktop kernel: [ 0.661599] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
May 31 18:03:46 ati-desktop kernel: [ 0.662140] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
May 31 18:03:46 ati-desktop kernel: [ 0.662560] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
May 31 18:03:46 ati-desktop kernel: [ 0.662857] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
May 31 18:03:46 ati-desktop kernel: [ 0.663057] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
May 31 18:03:46 ati-desktop kernel: [ 0.663349] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
May 31 18:03:46 ati-desktop kernel: [ 0.663353] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
May 31 18:03:46 ati-desktop kernel: [ 0.663796] NET: Registered protocol family 2
May 31 18:03:46 ati-desktop kernel: [ 0.663970] IP idents hash table entries: 32768 (order: 6, 262144 bytes)
May 31 18:03:46 ati-desktop kernel: [ 0.665553] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
May 31 18:03:46 ati-desktop kernel: [ 0.665665] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
May 31 18:03:46 ati-desktop kernel: [ 0.665935] TCP: Hash tables configured (established 16384 bind 16384)
May 31 18:03:46 ati-desktop kernel: [ 0.666166] UDP hash table entries: 1024 (order: 3, 32768 bytes)
May 31 18:03:46 ati-desktop kernel: [ 0.666215] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
May 31 18:03:46 ati-desktop kernel: [ 0.666593] NET: Registered protocol family 1
May 31 18:03:46 ati-desktop kernel: [ 0.667224] RPC: Registered named UNIX socket transport module.
May 31 18:03:46 ati-desktop kernel: [ 0.667229] RPC: Registered udp transport module.
May 31 18:03:46 ati-desktop kernel: [ 0.667232] RPC: Registered tcp transport module.
May 31 18:03:46 ati-desktop kernel: [ 0.667236] RPC: Registered tcp NFSv4.1 backchannel transport module.
May 31 18:03:46 ati-desktop kernel: [ 0.667249] PCI: CLS 0 bytes, default 64
May 31 18:03:46 ati-desktop kernel: [ 0.667493] Trying to unpack rootfs image as initramfs...
May 31 18:03:46 ati-desktop kernel: [ 0.972683] Freeing initrd memory: 6988K
May 31 18:03:46 ati-desktop kernel: [ 0.982719] host1x 50000000.host1x: initialized
May 31 18:03:46 ati-desktop kernel: [ 0.984434] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
May 31 18:03:46 ati-desktop kernel: [ 0.987802] audit: initializing netlink subsys (disabled)
May 31 18:03:46 ati-desktop kernel: [ 0.987901] audit: type=2000 audit(0.839:1): initialized
May 31 18:03:46 ati-desktop kernel: [ 0.988691] workingset: timestamp_bits=46 max_order=19 bucket_order=0
May 31 18:03:46 ati-desktop kernel: [ 0.999041] squashfs: version 4.0 (2009/01/31) Phillip Lougher
May 31 18:03:46 ati-desktop kernel: [ 1.000502] ntfs: driver 2.1.32 [Flags: R/W].
May 31 18:03:46 ati-desktop kernel: [ 1.001318] 9p: Installing v9fs 9p2000 file system support
May 31 18:03:46 ati-desktop kernel: [ 1.004877] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
May 31 18:03:46 ati-desktop kernel: [ 1.004997] io scheduler noop registered
May 31 18:03:46 ati-desktop kernel: [ 1.005304] io scheduler cfq registered (default)
May 31 18:03:46 ati-desktop kernel: [ 1.008146] gic 702f9000.agic: GIC IRQ controller registered
May 31 18:03:46 ati-desktop kernel: [ 1.011444] iommu: Adding device 702ef000.adsp to group 33
May 31 18:03:46 ati-desktop kernel: [ 1.020417] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
May 31 18:03:46 ati-desktop kernel: [ 1.020566] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
May 31 18:03:46 ati-desktop kernel: [ 1.021204] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x7969411
May 31 18:03:46 ati-desktop kernel: [ 1.021213] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
May 31 18:03:46 ati-desktop kernel: [ 1.022924] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
May 31 18:03:46 ati-desktop kernel: [ 1.023027] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
May 31 18:03:46 ati-desktop kernel: [ 1.023129] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
May 31 18:03:46 ati-desktop kernel: [ 1.023320] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
May 31 18:03:46 ati-desktop kernel: [ 1.023411] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
May 31 18:03:46 ati-desktop kernel: [ 1.023504] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
May 31 18:03:46 ati-desktop kernel: [ 1.023592] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
May 31 18:03:46 ati-desktop kernel: [ 1.023688] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
May 31 18:03:46 ati-desktop kernel: [ 1.023774] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
May 31 18:03:46 ati-desktop kernel: [ 1.023865] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
May 31 18:03:46 ati-desktop kernel: [ 1.024450] tegra-xusb-padctl 7009f000.xusb_padctl: failed to setup XUSB ports: -517
May 31 18:03:46 ati-desktop kernel: [ 1.030839] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
May 31 18:03:46 ati-desktop kernel: [ 1.032502] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
May 31 18:03:46 ati-desktop kernel: [ 1.034446] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
May 31 18:03:46 ati-desktop kernel: [ 1.034481] tegra-pcie 1003000.pcie: PHY get deferred: -517
May 31 18:03:46 ati-desktop kernel: [ 1.034487] tegra-pcie 1003000.pcie: failed to get PHYs: -517
May 31 18:03:46 ati-desktop kernel: [ 1.035869] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
May 31 18:03:46 ati-desktop kernel: [ 1.036086] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
May 31 18:03:46 ati-desktop kernel: [ 1.036330] Adding domain tsec-pd to PM domain host1x-pd
May 31 18:03:46 ati-desktop kernel: [ 1.039091] tsec 54500000.tsec: initialized
May 31 18:03:46 ati-desktop kernel: [ 1.040466] tsec 54100000.tsecb: initialized
May 31 18:03:46 ati-desktop kernel: [ 1.041152] Adding domain nvdec-pd to PM domain host1x-pd
May 31 18:03:46 ati-desktop kernel: [ 1.044375] nvdec 54480000.nvdec: initialized
May 31 18:03:46 ati-desktop kernel: [ 1.045432] Adding domain vic03-pd to PM domain host1x-pd
May 31 18:03:46 ati-desktop kernel: [ 1.045622] Adding domain msenc-pd to PM domain host1x-pd
May 31 18:03:46 ati-desktop kernel: [ 1.045779] Adding domain nvjpg-pd to PM domain host1x-pd
May 31 18:03:46 ati-desktop kernel: [ 1.049647] falcon 54340000.vic: initialized
May 31 18:03:46 ati-desktop kernel: [ 1.050904] falcon 544c0000.nvenc: initialized
May 31 18:03:46 ati-desktop kernel: [ 1.052204] falcon 54380000.nvjpg: initialized
May 31 18:03:46 ati-desktop kernel: [ 1.056566] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=95
May 31 18:03:46 ati-desktop kernel: [ 1.056618] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
May 31 18:03:46 ati-desktop kernel: [ 1.056653] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
May 31 18:03:46 ati-desktop kernel: [ 1.056656] tegra_cec 70015000.tegra_cec: tegra_cec_init started
May 31 18:03:46 ati-desktop kernel: [ 1.056747] display board info: id 0x0, fab 0x0
May 31 18:03:46 ati-desktop kernel: [ 1.056804] generic_infoframe_type: 0x87
May 31 18:03:46 ati-desktop kernel: [ 1.056936] tegradc tegradc.0: DT parsed successfully
May 31 18:03:46 ati-desktop kernel: [ 1.056954] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
May 31 18:03:46 ati-desktop kernel: [ 1.056960] tegra_cec 70015000.tegra_cec: probed
May 31 18:03:46 ati-desktop kernel: [ 1.056980] tegradc tegradc.0: Display dc.ffffff800a940000 registered with id=0
May 31 18:03:46 ati-desktop kernel: [ 1.057551] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350781
May 31 18:03:46 ati-desktop kernel: [ 1.064790] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
May 31 18:03:46 ati-desktop kernel: [ 1.065800] tegradc tegradc.0: probed
May 31 18:03:46 ati-desktop kernel: [ 1.071495] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
May 31 18:03:46 ati-desktop kernel: [ 1.073019] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
May 31 18:03:46 ati-desktop kernel: [ 1.073028] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
May 31 18:03:46 ati-desktop kernel: [ 1.073480] kfuse 7000fc00.kfuse: initialized
May 31 18:03:46 ati-desktop kernel: [ 1.075125] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
May 31 18:03:46 ati-desktop kernel: [ 1.076060] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
May 31 18:03:46 ati-desktop kernel: [ 1.077636] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
May 31 18:03:46 ati-desktop kernel: [ 1.077657] vdd-cpu: 708 <--> 1322 mV at 708 mV
May 31 18:03:46 ati-desktop kernel: [ 1.078282] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
May 31 18:03:46 ati-desktop kernel: [ 1.080042] vdd-gpu: applied init 1000000uV constraint
May 31 18:03:46 ati-desktop kernel: [ 1.080052] vdd-gpu: 708 <--> 1323 mV at 997 mV
May 31 18:03:46 ati-desktop kernel: [ 1.080498] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
May 31 18:03:46 ati-desktop kernel: [ 1.085444] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
May 31 18:03:46 ati-desktop kernel: [ 1.085610] No Device Node present for smmu client: serial8250 !!
May 31 18:03:46 ati-desktop kernel: [ 1.085623] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
May 31 18:03:46 ati-desktop kernel: [ 1.085690] iommu: Adding device serial8250 to group 35
May 31 18:03:46 ati-desktop kernel: [ 1.089530] console [ttyS0] disabled
May 31 18:03:46 ati-desktop kernel: [ 1.089691] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
May 31 18:03:46 ati-desktop kernel: [ 1.089769] console [ttyS0] enabled
May 31 18:03:46 ati-desktop kernel: [ 1.089776] bootconsole [uart8250] disabled
May 31 18:03:46 ati-desktop kernel: [ 1.091102] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
May 31 18:03:46 ati-desktop kernel: [ 1.091544] serial-tegra 70006200.serial: RX in PIO mode
May 31 18:03:46 ati-desktop kernel: [ 1.091641] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
May 31 18:03:46 ati-desktop kernel: [ 1.092629] [drm] Initialized
May 31 18:03:46 ati-desktop kernel: [ 1.097660] Console: switching to colour frame buffer device 240x67
May 31 18:03:46 ati-desktop kernel: [ 1.097788] tegradc tegradc.0: fb registered
May 31 18:03:46 ati-desktop kernel: [ 1.104030] brd: module loaded
May 31 18:03:46 ati-desktop kernel: [ 1.105302] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
May 31 18:03:46 ati-desktop kernel: [ 1.105358] tegradc tegradc.0: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_75m_150m
May 31 18:03:46 ati-desktop kernel: [ 1.105905] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
May 31 18:03:46 ati-desktop kernel: [ 1.105916] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
May 31 18:03:46 ati-desktop kernel: [ 1.109887] loop: module loaded
May 31 18:03:46 ati-desktop kernel: [ 1.109981] tegra_profiler: version: 1.145, samples/io: 49/28
May 31 18:03:46 ati-desktop kernel: [ 1.110168] tegra_profiler: auth: init
May 31 18:03:46 ati-desktop kernel: [ 1.111523] THERMAL EST: found 2 subdevs
May 31 18:03:46 ati-desktop kernel: [ 1.111535] THERMAL EST num_resources: 0
May 31 18:03:46 ati-desktop kernel: [ 1.111543] [THERMAL EST subdev 0]
May 31 18:03:46 ati-desktop kernel: [ 1.111551] [THERMAL EST subdev 1]
May 31 18:03:46 ati-desktop kernel: [ 1.112019] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
May 31 18:03:46 ati-desktop kernel: [ 1.112022] THERMAL EST: thz register success.
May 31 18:03:46 ati-desktop kernel: [ 1.112202] THERMAL EST: end of probe, return err: 0
May 31 18:03:46 ati-desktop kernel: [ 1.113440] sd: No Scsi addr parsed to reserve index
May 31 18:03:46 ati-desktop kernel: [ 1.113487] hisi_sas: driver version v1.6
May 31 18:03:46 ati-desktop kernel: [ 1.118530] tegra-qspi 70410000.spi: Prod settings list not found
May 31 18:03:46 ati-desktop kernel: [ 1.119761] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
May 31 18:03:46 ati-desktop kernel: [ 1.119772] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
May 31 18:03:46 ati-desktop kernel: [ 1.122942] libphy: Fixed MDIO Bus: probed
May 31 18:03:46 ati-desktop kernel: [ 1.123722] tun: Universal TUN/TAP device driver, 1.6
May 31 18:03:46 ati-desktop kernel: [ 1.123728] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
May 31 18:03:46 ati-desktop kernel: [ 1.124722] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
May 31 18:03:46 ati-desktop kernel: [ 1.124732] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
May 31 18:03:46 ati-desktop kernel: [ 1.124793] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
May 31 18:03:46 ati-desktop kernel: [ 1.124798] igb: Copyright (c) 2007-2014 Intel Corporation.
May 31 18:03:46 ati-desktop kernel: [ 1.124847] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
May 31 18:03:46 ati-desktop kernel: [ 1.124852] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
May 31 18:03:46 ati-desktop kernel: [ 1.124901] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
May 31 18:03:46 ati-desktop kernel: [ 1.124904] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
May 31 18:03:46 ati-desktop kernel: [ 1.126337] PPP generic driver version 2.4.2
May 31 18:03:46 ati-desktop kernel: [ 1.126838] PPP BSD Compression module registered
May 31 18:03:46 ati-desktop kernel: [ 1.126848] PPP Deflate Compression module registered
May 31 18:03:46 ati-desktop kernel: [ 1.126890] PPP MPPE Compression module registered
May 31 18:03:46 ati-desktop kernel: [ 1.126898] NET: Registered protocol family 24
May 31 18:03:46 ati-desktop kernel: [ 1.126994] usbcore: registered new interface driver r8152
May 31 18:03:46 ati-desktop kernel: [ 1.127043] usbcore: registered new interface driver asix
May 31 18:03:46 ati-desktop kernel: [ 1.127102] usbcore: registered new interface driver ax88179_178a
May 31 18:03:46 ati-desktop kernel: [ 1.127146] usbcore: registered new interface driver cdc_ether
May 31 18:03:46 ati-desktop kernel: [ 1.127193] usbcore: registered new interface driver net1080
May 31 18:03:46 ati-desktop kernel: [ 1.127243] usbcore: registered new interface driver cdc_subset
May 31 18:03:46 ati-desktop kernel: [ 1.127283] usbcore: registered new interface driver zaurus
May 31 18:03:46 ati-desktop kernel: [ 1.127339] usbcore: registered new interface driver cdc_ncm
May 31 18:03:46 ati-desktop kernel: [ 1.127516] VFIO - User Level meta-driver version: 0.3
May 31 18:03:46 ati-desktop kernel: [ 1.128908] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
May 31 18:03:46 ati-desktop kernel: [ 1.128937] ehci-pci: EHCI PCI platform driver
May 31 18:03:46 ati-desktop kernel: [ 1.128987] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
May 31 18:03:46 ati-desktop kernel: [ 1.129000] ohci-pci: OHCI PCI platform driver
May 31 18:03:46 ati-desktop kernel: [ 1.129043] ohci-platform: OHCI generic platform driver
May 31 18:03:46 ati-desktop kernel: [ 1.130981] usbcore: registered new interface driver uas
May 31 18:03:46 ati-desktop kernel: [ 1.131114] usbcore: registered new interface driver usb-storage
May 31 18:03:46 ati-desktop kernel: [ 1.131242] usbcore: registered new interface driver usbserial
May 31 18:03:46 ati-desktop kernel: [ 1.132292] extcon-disp-state extcon:disp-state: cable 47 state 1
May 31 18:03:46 ati-desktop kernel: [ 1.132302] Extcon AUX1(HDMI) enable
May 31 18:03:46 ati-desktop kernel: [ 1.135443] mousedev: PS/2 mouse device common for all mice
May 31 18:03:46 ati-desktop kernel: [ 1.135535] usbcore: registered new interface driver xpad
May 31 18:03:46 ati-desktop kernel: [ 1.138222] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
May 31 18:03:46 ati-desktop kernel: [ 1.138260] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
May 31 18:03:46 ati-desktop kernel: [ 1.138755] i2c /dev entries driver
May 31 18:03:46 ati-desktop kernel: [ 1.140618] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
May 31 18:03:46 ati-desktop kernel: [ 1.163968] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
May 31 18:03:46 ati-desktop kernel: [ 1.164048] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
May 31 18:03:46 ati-desktop kernel: [ 1.171710] imx219 6-0010: board setup failed
May 31 18:03:46 ati-desktop kernel: [ 1.176164] imx219: probe of 6-0010 failed with error -121
May 31 18:03:46 ati-desktop kernel: [ 1.177431] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:1.0 pclk:148350781 146868084~161703244
May 31 18:03:46 ati-desktop kernel: [ 1.177489] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
May 31 18:03:46 ati-desktop kernel: [ 1.179787] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
May 31 18:03:46 ati-desktop kernel: [ 1.179792] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
May 31 18:03:46 ati-desktop kernel: [ 1.180103] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
May 31 18:03:46 ati-desktop kernel: [ 1.180116] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
May 31 18:03:46 ati-desktop kernel: [ 1.180125] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
May 31 18:03:46 ati-desktop kernel: [ 1.180258] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
May 31 18:03:46 ati-desktop kernel: [ 1.180269] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
May 31 18:03:46 ati-desktop kernel: [ 1.180276] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
May 31 18:03:46 ati-desktop kernel: [ 1.180425] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
May 31 18:03:46 ati-desktop kernel: [ 1.180435] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
May 31 18:03:46 ati-desktop kernel: [ 1.180441] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
May 31 18:03:46 ati-desktop kernel: [ 1.180633] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
May 31 18:03:46 ati-desktop kernel: [ 1.181229] tegra_aotag tegra-aotag: Registering sensor 0
May 31 18:03:46 ati-desktop kernel: [ 1.181276] tegra_aotag tegra-aotag: Invalid temp readout
May 31 18:03:46 ati-desktop kernel: [ 1.181297] tegra_aotag tegra-aotag: Invalid temp readout
May 31 18:03:46 ati-desktop kernel: [ 1.181314] tegra_aotag tegra-aotag: Bound to TZ : ID 0
May 31 18:03:46 ati-desktop kernel: [ 1.181323] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
May 31 18:03:46 ati-desktop kernel: [ 1.182265] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
May 31 18:03:46 ati-desktop kernel: [ 1.182281] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
May 31 18:03:46 ati-desktop kernel: [ 1.182437] tegra_aotag tegra-aotag: Invalid temp readout
May 31 18:03:46 ati-desktop kernel: [ 1.182460] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
May 31 18:03:46 ati-desktop kernel: [ 1.182876] parse_throttle_dt_data: Num cap clks = 6
May 31 18:03:46 ati-desktop kernel: [ 1.182881] parse_throttle_dt_data: clk=cclk_g type=2
May 31 18:03:46 ati-desktop kernel: [ 1.182889] parse_throttle_dt_data: clk=gpu type=4
May 31 18:03:46 ati-desktop kernel: [ 1.182913] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
May 31 18:03:46 ati-desktop kernel: [ 1.182935] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
May 31 18:03:46 ati-desktop kernel: [ 1.182960] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
May 31 18:03:46 ati-desktop kernel: [ 1.182964] parse_throttle_dt_data: clk=emc type=3
May 31 18:03:46 ati-desktop kernel: [ 1.183291] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
May 31 18:03:46 ati-desktop kernel: [ 1.183384] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
May 31 18:03:46 ati-desktop kernel: [ 1.183505] tegra_throttle_probe: probe successful. #cdevs=4
May 31 18:03:46 ati-desktop kernel: [ 1.184156] FAN dev name: pwm-fan
May 31 18:03:46 ati-desktop kernel: [ 1.184202] FAN:gpio request success.
May 31 18:03:46 ati-desktop kernel: [ 1.184251] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
May 31 18:03:46 ati-desktop kernel: [ 1.184493] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
May 31 18:03:46 ati-desktop kernel: [ 1.184614] pwm_fan_driver pwm-fan: fan tach request irq success
May 31 18:03:46 ati-desktop kernel: [ 1.184622] pwm_fan_driver pwm-fan: tach period: 1000
May 31 18:03:46 ati-desktop kernel: [ 1.184702] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
May 31 18:03:46 ati-desktop kernel: [ 1.184707] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
May 31 18:03:46 ati-desktop kernel: [ 1.184712] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
May 31 18:03:46 ati-desktop kernel: [ 1.184717] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
May 31 18:03:46 ati-desktop kernel: [ 1.184722] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
May 31 18:03:46 ati-desktop kernel: [ 1.184727] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
May 31 18:03:46 ati-desktop kernel: [ 1.184732] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
May 31 18:03:46 ati-desktop kernel: [ 1.184737] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
May 31 18:03:46 ati-desktop kernel: [ 1.184741] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
May 31 18:03:46 ati-desktop kernel: [ 1.184746] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
May 31 18:03:46 ati-desktop kernel: [ 1.187275] device-mapper: uevent: version 1.0.3
May 31 18:03:46 ati-desktop kernel: [ 1.187661] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
May 31 18:03:46 ati-desktop kernel: [ 1.190256] tegra210-cpufreq cpufreq: probe()...completed
May 31 18:03:46 ati-desktop kernel: [ 1.190976] sdhci: Secure Digital Host Controller Interface driver
May 31 18:03:46 ati-desktop kernel: [ 1.190979] sdhci: Copyright(c) Pierre Ossman
May 31 18:03:46 ati-desktop kernel: [ 1.190981] sdhci-pltfm: SDHCI platform and OF driver helper
May 31 18:03:46 ati-desktop kernel: [ 1.191452] sdhci-tegra sdhci-tegra.0: Got CD GPIO
May 31 18:03:46 ati-desktop kernel: [ 1.191815] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
May 31 18:03:46 ati-desktop kernel: [ 1.191942] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 298
May 31 18:03:46 ati-desktop kernel: [ 1.196847] tegra-se 70012000.se: tegra_se_probe: complete
May 31 18:03:46 ati-desktop kernel: [ 1.197327] hidraw: raw HID events driver (C) Jiri Kosina
May 31 18:03:46 ati-desktop kernel: [ 1.198471] usbcore: registered new interface driver usbhid
May 31 18:03:46 ati-desktop kernel: [ 1.198473] usbhid: USB HID core driver
May 31 18:03:46 ati-desktop kernel: [ 1.199411] tegra21x_actmon 6000c800.actmon: in actmon_register()...
May 31 18:03:46 ati-desktop kernel: [ 1.199626] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
May 31 18:03:46 ati-desktop kernel: [ 1.201590] nvpmodel: initialized successfully
May 31 18:03:46 ati-desktop kernel: [ 1.202695] usbcore: registered new interface driver snd-usb-audio
May 31 18:03:46 ati-desktop kernel: [ 1.202722] u32 classifier
May 31 18:03:46 ati-desktop kernel: [ 1.202724] Actions configured
May 31 18:03:46 ati-desktop kernel: [ 1.202798] Initializing XFRM netlink socket
May 31 18:03:46 ati-desktop kernel: [ 1.203511] NET: Registered protocol family 10
May 31 18:03:46 ati-desktop kernel: [ 1.204197] NET: Registered protocol family 17
May 31 18:03:46 ati-desktop kernel: [ 1.204209] NET: Registered protocol family 15
May 31 18:03:46 ati-desktop kernel: [ 1.204284] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
May 31 18:03:46 ati-desktop kernel: [ 1.204326] Bluetooth: RFCOMM socket layer initialized
May 31 18:03:46 ati-desktop kernel: [ 1.204335] Bluetooth: RFCOMM ver 1.11
May 31 18:03:46 ati-desktop kernel: [ 1.204341] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
May 31 18:03:46 ati-desktop kernel: [ 1.204346] Bluetooth: HIDP socket layer initialized
May 31 18:03:46 ati-desktop kernel: [ 1.204365] 9pnet: Installing 9P2000 support
May 31 18:03:46 ati-desktop kernel: [ 1.204401] Key type dns_resolver registered
May 31 18:03:46 ati-desktop kernel: [ 1.204724] Registered cp15_barrier emulation handler
May 31 18:03:46 ati-desktop kernel: [ 1.204731] Registered setend emulation handler
May 31 18:03:46 ati-desktop kernel: [ 1.208383] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
May 31 18:03:46 ati-desktop kernel: [ 1.208508] registered taskstats version 1
May 31 18:03:46 ati-desktop kernel: [ 1.209011] Adding domain ve2-pd to PM domain host1x-pd
May 31 18:03:46 ati-desktop kernel: [ 1.209261] Adding domain ve-pd to PM domain host1x-pd
May 31 18:03:46 ati-desktop kernel: [ 1.211308] isp 54600000.isp: initialized
May 31 18:03:46 ati-desktop kernel: [ 1.212269] isp 54680000.isp: initialized
May 31 18:03:46 ati-desktop kernel: [ 1.222483] last reset is due to power on reset
May 31 18:03:46 ati-desktop kernel: [ 1.222487] KERNEL: PMC reset status reg: 0x0
May 31 18:03:46 ati-desktop kernel: [ 1.222544] BL: PMC reset status reg: 0x0
May 31 18:03:46 ati-desktop kernel: [ 1.222547] BL: PMIC poweroff Event Recorder: 0x40
May 31 18:03:46 ati-desktop kernel: [ 1.223039] vdd-usb-vbus-en: 5000 mV
May 31 18:03:46 ati-desktop kernel: [ 1.223385] vdd-usb-vbus-en: supplied by vdd-5v0-sys
May 31 18:03:46 ati-desktop kernel: [ 1.224324] clk_cbus_recalc_rate: no gbus parent
May 31 18:03:46 ati-desktop kernel: [ 1.224329] clk_cbus_round_rate: no gbus parent
May 31 18:03:46 ati-desktop kernel: [ 1.224332] clk_cbus_round_rate: no gbus parent
May 31 18:03:46 ati-desktop kernel: [ 1.224339] clk_cbus_recalc_rate: no gbus parent
May 31 18:03:46 ati-desktop kernel: [ 1.224434] clk_cbus_recalc_rate: no gbus parent
May 31 18:03:46 ati-desktop kernel: [ 1.224438] clk_cbus_round_rate: no gbus parent
May 31 18:03:46 ati-desktop kernel: [ 1.224440] clk_cbus_round_rate: no gbus parent
May 31 18:03:46 ati-desktop kernel: [ 1.224444] clk_cbus_recalc_rate: no gbus parent
May 31 18:03:46 ati-desktop kernel: [ 1.225109] tegra_dvfs: GPU-cap: registered
May 31 18:03:46 ati-desktop kernel: [ 1.225174] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
May 31 18:03:46 ati-desktop kernel: [ 1.225177] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
May 31 18:03:46 ati-desktop kernel: [ 1.225180] tegra dvfs: vdd-gpu: nominal 1078mV, offset 708000uV, step 10000uV, scaling enabled
May 31 18:03:46 ati-desktop kernel: [ 1.226857] tegra_dvfs: vdd-gpu-vts: registered
May 31 18:03:46 ati-desktop kernel: [ 1.227002] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x7969411
May 31 18:03:46 ati-desktop kernel: [ 1.227006] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
May 31 18:03:46 ati-desktop kernel: [ 1.227714] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
May 31 18:03:46 ati-desktop kernel: [ 1.227775] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
May 31 18:03:46 ati-desktop kernel: [ 1.227840] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
May 31 18:03:46 ati-desktop kernel: [ 1.227944] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
May 31 18:03:46 ati-desktop kernel: [ 1.228002] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
May 31 18:03:46 ati-desktop kernel: [ 1.228058] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
May 31 18:03:46 ati-desktop kernel: [ 1.228116] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
May 31 18:03:46 ati-desktop kernel: [ 1.228170] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
May 31 18:03:46 ati-desktop kernel: [ 1.228226] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
May 31 18:03:46 ati-desktop kernel: [ 1.228281] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
May 31 18:03:46 ati-desktop kernel: [ 1.229582] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
May 31 18:03:46 ati-desktop kernel: [ 1.231602] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
May 31 18:03:46 ati-desktop kernel: [ 1.231723] tegra-pcie 1003000.pcie: PCIE: Enable power rails
May 31 18:03:46 ati-desktop kernel: [ 1.232369] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
May 31 18:03:46 ati-desktop kernel: [ 1.232384] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
May 31 18:03:46 ati-desktop kernel: [ 1.233407] tegra-xusb 70090000.xusb: extcon 0: ffffffc078b56c00 id
May 31 18:03:46 ati-desktop kernel: [ 1.234092] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
May 31 18:03:46 ati-desktop kernel: [ 1.234890] tegra-xudc-new 700d0000.xudc: device count: 1
May 31 18:03:46 ati-desktop kernel: [ 1.235901] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
May 31 18:03:46 ati-desktop kernel: [ 1.235908] tegra-xudc-new 700d0000.xudc: vbus state: 0
May 31 18:03:46 ati-desktop kernel: [ 1.236343] tegra-xudc-new 700d0000.xudc: entering ELPG
May 31 18:03:46 ati-desktop kernel: [ 1.236605] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
May 31 18:03:46 ati-desktop kernel: [ 1.236794] tegra-xusb 70090000.xusb: Firmware timestamp: 2020-07-31 09:33:12 UTC, Version: 50.26 release
May 31 18:03:46 ati-desktop kernel: [ 1.236819] tegra-xusb 70090000.xusb: xHCI Host Controller
May 31 18:03:46 ati-desktop kernel: [ 1.236831] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
May 31 18:03:46 ati-desktop kernel: [ 1.237546] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
May 31 18:03:46 ati-desktop kernel: [ 1.237572] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
May 31 18:03:46 ati-desktop kernel: [ 1.237817] tegra-xudc-new 700d0000.xudc: entering ELPG done
May 31 18:03:46 ati-desktop kernel: [ 1.238360] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
May 31 18:03:46 ati-desktop kernel: [ 1.238450] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
May 31 18:03:46 ati-desktop kernel: [ 1.238454] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
May 31 18:03:46 ati-desktop kernel: [ 1.238458] usb usb1: Product: xHCI Host Controller
May 31 18:03:46 ati-desktop kernel: [ 1.238461] usb usb1: Manufacturer: Linux 4.9.253-tegra xhci-hcd
May 31 18:03:46 ati-desktop kernel: [ 1.238464] usb usb1: SerialNumber: 70090000.xusb
May 31 18:03:46 ati-desktop kernel: [ 1.238850] hub 1-0:1.0: USB hub found
May 31 18:03:46 ati-desktop kernel: [ 1.238877] hub 1-0:1.0: 5 ports detected
May 31 18:03:46 ati-desktop kernel: [ 1.238919] input: gpio-keys as /devices/gpio-keys/input/input1
May 31 18:03:46 ati-desktop kernel: [ 1.239670] tegra-xusb 70090000.xusb: xHCI Host Controller
May 31 18:03:46 ati-desktop kernel: [ 1.239679] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
May 31 18:03:46 ati-desktop kernel: [ 1.239790] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
May 31 18:03:46 ati-desktop kernel: [ 1.239849] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
May 31 18:03:46 ati-desktop kernel: [ 1.239854] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
May 31 18:03:46 ati-desktop kernel: [ 1.239857] usb usb2: Product: xHCI Host Controller
May 31 18:03:46 ati-desktop kernel: [ 1.239860] usb usb2: Manufacturer: Linux 4.9.253-tegra xhci-hcd
May 31 18:03:46 ati-desktop kernel: [ 1.239863] usb usb2: SerialNumber: 70090000.xusb
May 31 18:03:46 ati-desktop kernel: [ 1.240107] vi 54080000.vi: vi_probe: ++
May 31 18:03:46 ati-desktop kernel: [ 1.240161] hub 2-0:1.0: USB hub found
May 31 18:03:46 ati-desktop kernel: [ 1.240186] hub 2-0:1.0: 4 ports detected
May 31 18:03:46 ati-desktop kernel: [ 1.240676] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
May 31 18:03:46 ati-desktop kernel: [ 1.240681] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
May 31 18:03:46 ati-desktop kernel: [ 1.243146] vi 54080000.vi: initialized
May 31 18:03:46 ati-desktop kernel: [ 1.245107] vi 54080000.vi: subdev nvcsi--1 bound
May 31 18:03:46 ati-desktop kernel: [ 1.245851] Disable partitions left on by BL
May 31 18:03:46 ati-desktop kernel: [ 1.245855] disb
May 31 18:03:46 ati-desktop kernel: [ 1.245896] bwmgr: missing cdev-type property
May 31 18:03:46 ati-desktop kernel: [ 1.245989] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
May 31 18:03:46 ati-desktop kernel: [ 1.245996] DRAM derating cdev registered.
May 31 18:03:46 ati-desktop kernel: [ 1.246137] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
May 31 18:03:46 ati-desktop kernel: [ 1.246951] ALSA device list:
May 31 18:03:46 ati-desktop kernel: [ 1.246955] #0: tegra-hda at 0x70038000 irq 81
May 31 18:03:46 ati-desktop kernel: [ 1.250001] Freeing unused kernel memory: 7616K
May 31 18:03:46 ati-desktop kernel: [ 1.265690] tegradc tegradc.0: blank - powerdown
May 31 18:03:46 ati-desktop kernel: [ 1.315212] extcon-disp-state extcon:disp-state: cable 47 state 0
May 31 18:03:46 ati-desktop kernel: [ 1.315214] Extcon AUX1(HDMI) disable
May 31 18:03:46 ati-desktop kernel: [ 1.343671] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
May 31 18:03:46 ati-desktop kernel: [ 1.343727] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 2
May 31 18:03:46 ati-desktop kernel: [ 1.344948] usb usb2: usb_suspend_both: status 0
May 31 18:03:46 ati-desktop kernel: [ 1.355163] tegradc tegradc.0: unblank
May 31 18:03:46 ati-desktop kernel: [ 1.366883] tegradc tegradc.0: nominal-pclk:181250000 parent:181248750 div:1.0 pclk:181248750 179437500~197562500
May 31 18:03:46 ati-desktop kernel: [ 1.366935] tegradc tegradc.0: hdmi: tmds rate:181250K prod-setting:prod_c_hdmi_150m_300m
May 31 18:03:46 ati-desktop kernel: [ 1.367946] tegradc tegradc.0: hdmi: get YCC quant from EDID.
May 31 18:03:46 ati-desktop kernel: [ 1.403021] extcon-disp-state extcon:disp-state: cable 47 state 1
May 31 18:03:46 ati-desktop kernel: [ 1.403023] Extcon AUX1(HDMI) enable
May 31 18:03:46 ati-desktop kernel: [ 1.419236] tegradc tegradc.0: sync windows ret = 246
May 31 18:03:46 ati-desktop kernel: [ 1.445081] extcon-disp-state extcon:disp-state: cable 51 state 1
May 31 18:03:46 ati-desktop kernel: [ 1.445084] Extcon HDMI: HPD enabled
May 31 18:03:46 ati-desktop kernel: [ 1.445095] tegradc tegradc.0: hdmi: plugged
May 31 18:03:46 ati-desktop kernel: [ 1.456106] mmc0: hw tuning done ...
May 31 18:03:46 ati-desktop kernel: [ 1.456142] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
May 31 18:03:46 ati-desktop kernel: [ 1.456595] mmcblk0: mmc0:aaaa SD64G 59.5 GiB
May 31 18:03:46 ati-desktop kernel: [ 1.462374] mmcblk0: p1
May 31 18:03:46 ati-desktop kernel: [ 1.519695] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
May 31 18:03:46 ati-desktop kernel: [ 1.670705] tegra-pcie 1003000.pcie: link 0 down, retrying
May 31 18:03:46 ati-desktop kernel: [ 1.746345] ip_tables: (C) 2000-2006 Netfilter Core Team
May 31 18:03:46 ati-desktop kernel: [ 1.758745] cgroup: cgroup2: unknown option "nsdelegate"
May 31 18:03:46 ati-desktop kernel: [ 2.040305] random: systemd: uninitialized urandom read (16 bytes read)
May 31 18:03:46 ati-desktop kernel: [ 2.040556] random: systemd: uninitialized urandom read (16 bytes read)
May 31 18:03:46 ati-desktop kernel: [ 2.042180] random: systemd: uninitialized urandom read (16 bytes read)
May 31 18:03:46 ati-desktop kernel: [ 2.066170] tegra_cec 70015000.tegra_cec: physical address: 20:00.
May 31 18:03:46 ati-desktop kernel: [ 2.088127] tegra-pcie 1003000.pcie: link 0 down, retrying
May 31 18:03:46 ati-desktop kernel: [ 2.105521] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
May 31 18:03:46 ati-desktop kernel: [ 2.268919] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
May 31 18:03:46 ati-desktop kernel: [ 2.318515] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
May 31 18:03:46 ati-desktop kernel: [ 2.339220] usb 2-1: New USB device found, idVendor=0bc2, idProduct=ab18
May 31 18:03:46 ati-desktop kernel: [ 2.339227] usb 2-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1
May 31 18:03:46 ati-desktop kernel: [ 2.339231] usb 2-1: Product: PS4 Game Drive
May 31 18:03:46 ati-desktop kernel: [ 2.339235] usb 2-1: Manufacturer: Seagate
May 31 18:03:46 ati-desktop kernel: [ 2.339238] usb 2-1: SerialNumber: NZ0LY4LF
May 31 18:03:46 ati-desktop kernel: [ 2.347803] scsi host0: uas
May 31 18:03:46 ati-desktop kernel: [ 2.349268] scsi 0:0:0:0: Direct-Access Seagate PS4 Game Drive 0304 PQ: 0 ANSI: 6
May 31 18:03:46 ati-desktop kernel: [ 2.393373] sd 0:0:0:0: [sda] 3907029167 512-byte logical blocks: (2.00 TB/1.82 TiB)
May 31 18:03:46 ati-desktop kernel: [ 2.401251] sd 0:0:0:0: [sda] 2048-byte physical blocks
May 31 18:03:46 ati-desktop kernel: [ 2.458065] usb 1-3: new high-speed USB device number 3 using tegra-xusb
May 31 18:03:46 ati-desktop kernel: [ 2.478483] usb 1-3: New USB device found, idVendor=1a40, idProduct=0801
May 31 18:03:46 ati-desktop kernel: [ 2.478489] usb 1-3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
May 31 18:03:46 ati-desktop kernel: [ 2.478493] usb 1-3: Product: USB 2.0 Hub
May 31 18:03:46 ati-desktop kernel: [ 2.479408] hub 1-3:1.0: USB hub found
May 31 18:03:46 ati-desktop kernel: [ 2.479485] hub 1-3:1.0: 4 ports detected
May 31 18:03:46 ati-desktop kernel: [ 2.480450] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
May 31 18:03:46 ati-desktop kernel: [ 2.524054] tegra-pcie 1003000.pcie: link 0 down, retrying
May 31 18:03:46 ati-desktop kernel: [ 2.526048] tegra-pcie 1003000.pcie: link 0 down, ignoring
May 31 18:03:46 ati-desktop kernel: [ 2.552582] Adding 4194300k swap on /swapfile. Priority:-1 extents:6 across:6258684k SS
May 31 18:03:46 ati-desktop kernel: [ 2.631487] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
May 31 18:03:46 ati-desktop kernel: [ 2.631494] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
May 31 18:03:46 ati-desktop kernel: [ 2.631498] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
May 31 18:03:46 ati-desktop kernel: [ 2.631503] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
May 31 18:03:46 ati-desktop kernel: [ 2.631508] pci_bus 0000:00: root bus resource [bus 00-ff]
May 31 18:03:46 ati-desktop kernel: [ 2.631532] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
May 31 18:03:46 ati-desktop kernel: [ 2.631609] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
May 31 18:03:46 ati-desktop kernel: [ 2.631760] iommu: Adding device 0000:00:02.0 to group 36
May 31 18:03:46 ati-desktop kernel: [ 2.631840] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
May 31 18:03:46 ati-desktop kernel: [ 2.631968] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
May 31 18:03:46 ati-desktop kernel: [ 2.631993] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
May 31 18:03:46 ati-desktop kernel: [ 2.632023] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
May 31 18:03:46 ati-desktop kernel: [ 2.632043] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
May 31 18:03:46 ati-desktop kernel: [ 2.632206] pci 0000:01:00.0: supports D1 D2
May 31 18:03:46 ati-desktop kernel: [ 2.632209] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
May 31 18:03:46 ati-desktop kernel: [ 2.632382] iommu: Adding device 0000:01:00.0 to group 37
May 31 18:03:46 ati-desktop kernel: [ 2.642130] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
May 31 18:03:46 ati-desktop kernel: [ 2.642161] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
May 31 18:03:46 ati-desktop kernel: [ 2.642166] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
May 31 18:03:46 ati-desktop kernel: [ 2.642174] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
May 31 18:03:46 ati-desktop kernel: [ 2.642192] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
May 31 18:03:46 ati-desktop kernel: [ 2.642209] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
May 31 18:03:46 ati-desktop kernel: [ 2.642217] pci 0000:00:02.0: PCI bridge to [bus 01]
May 31 18:03:46 ati-desktop kernel: [ 2.642221] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
May 31 18:03:46 ati-desktop kernel: [ 2.642227] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
May 31 18:03:46 ati-desktop kernel: [ 2.642540] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
May 31 18:03:46 ati-desktop kernel: [ 2.642545] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
May 31 18:03:46 ati-desktop kernel: [ 2.642550] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
May 31 18:03:46 ati-desktop kernel: [ 2.642641] aer 0000:00:02.0:pcie002: service driver aer loaded
May 31 18:03:46 ati-desktop kernel: [ 2.642832] r8168 0000:01:00.0: enabling device (0000 -> 0003)
May 31 18:03:46 ati-desktop kernel: [ 2.642849] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
May 31 18:03:46 ati-desktop kernel: [ 2.656892] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
May 31 18:03:46 ati-desktop kernel: [ 2.656963] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 48:b0:2d:2e:1f:f3 from device tree
May 31 18:03:46 ati-desktop kernel: [ 2.657457] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
May 31 18:03:46 ati-desktop kernel: [ 2.657474] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@realtek.com>
May 31 18:03:46 ati-desktop kernel: [ 2.657474] This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
May 31 18:03:46 ati-desktop kernel: [ 2.657474] This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
May 31 18:03:46 ati-desktop kernel: [ 2.766147] usb 1-3.2: new high-speed USB device number 4 using tegra-xusb
May 31 18:03:46 ati-desktop kernel: [ 2.801682] usb 1-3.2: New USB device found, idVendor=0e8d, idProduct=7610
May 31 18:03:46 ati-desktop kernel: [ 2.801690] usb 1-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
May 31 18:03:46 ati-desktop kernel: [ 2.801694] usb 1-3.2: Product: WiFi
May 31 18:03:46 ati-desktop kernel: [ 2.801698] usb 1-3.2: Manufacturer: MediaTek
May 31 18:03:46 ati-desktop kernel: [ 2.801701] usb 1-3.2: SerialNumber: 1.0
May 31 18:03:47 ati-desktop kernel: [ 2.943252] using random self ethernet address
May 31 18:03:47 ati-desktop kernel: [ 2.949007] using random host ethernet address
May 31 18:03:47 ati-desktop kernel: [ 3.278032] random: crng init done
May 31 18:03:47 ati-desktop kernel: [ 3.281431] random: 7 urandom warning(s) missed due to ratelimiting
May 31 18:03:47 ati-desktop kernel: [ 3.377369] sd 0:0:0:0: [sda] Write Protect is off
May 31 18:03:47 ati-desktop kernel: [ 3.382270] sd 0:0:0:0: [sda] Mode Sense: 4f 00 00 00
May 31 18:03:47 ati-desktop kernel: [ 3.382659] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
May 31 18:03:47 ati-desktop kernel: [ 3.392373] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of physical block size (2048 bytes)
May 31 18:03:47 ati-desktop kernel: [ 3.476922] sda: sda1 sda2
May 31 18:03:47 ati-desktop kernel: [ 3.479114] sd 0:0:0:0: [sda] Attached SCSI disk
May 31 18:03:47 ati-desktop kernel: [ 3.722057] usb 1-3.1: new high-speed USB device number 5 using tegra-xusb
May 31 18:03:47 ati-desktop kernel: [ 3.743821] usb 1-3.1: New USB device found, idVendor=2109, idProduct=2817
May 31 18:03:47 ati-desktop kernel: [ 3.743827] usb 1-3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
May 31 18:03:47 ati-desktop kernel: [ 3.743831] usb 1-3.1: Product: USB2.0 Hub
May 31 18:03:47 ati-desktop kernel: [ 3.743835] usb 1-3.1: Manufacturer: VIA Labs, Inc.
May 31 18:03:47 ati-desktop kernel: [ 3.744856] hub 1-3.1:1.0: USB hub found
May 31 18:03:47 ati-desktop kernel: [ 3.745057] hub 1-3.1:1.0: 4 ports detected
May 31 18:03:47 ati-desktop kernel: [ 3.842236] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
May 31 18:03:47 ati-desktop kernel: [ 3.842259] cpu-throttle-alert cooling device registered.
May 31 18:03:47 ati-desktop kernel: [ 3.842665] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
May 31 18:03:47 ati-desktop kernel: [ 3.842683] gpu-throttle-alert cooling device registered.
May 31 18:03:47 ati-desktop kernel: [ 3.842993] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
May 31 18:03:47 ati-desktop kernel: [ 3.843007] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
May 31 18:03:47 ati-desktop kernel: [ 3.843024] hot-surface-alert cooling device registered.
May 31 18:03:48 ati-desktop kernel: [ 4.069086] Mass Storage Function, version: 2009/09/11
May 31 18:03:48 ati-desktop kernel: [ 4.069091] LUN: removable file: (no medium)
May 31 18:03:48 ati-desktop kernel: [ 4.076397] using random self ethernet address
May 31 18:03:48 ati-desktop kernel: [ 4.081070] using random host ethernet address
May 31 18:03:48 ati-desktop kernel: [ 4.210064] tegra_cec 70015000.tegra_cec: timeout in tegra_cec_native_write_l:172.
May 31 18:03:48 ati-desktop kernel: [ 4.217867] tegra_cec 70015000.tegra_cec: Sent <Text View On> res: -62.
May 31 18:03:48 ati-desktop kernel: [ 4.226886] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
May 31 18:03:48 ati-desktop kernel: [ 4.228803] rndis0: HOST MAC 46:7a:d0:5f:5c:80
May 31 18:03:48 ati-desktop kernel: [ 4.229184] rndis0: MAC 46:7a:d0:5f:5c:81
May 31 18:03:48 ati-desktop kernel: [ 4.229778] usb0: HOST MAC 46:7a:d0:5f:5c:82
May 31 18:03:48 ati-desktop kernel: [ 4.229804] usb0: MAC 46:7a:d0:5f:5c:83
May 31 18:03:48 ati-desktop kernel: [ 4.229823] tegra-xudc-new 700d0000.xudc: exiting ELPG
May 31 18:03:48 ati-desktop kernel: [ 4.233261] tegra-xudc-new 700d0000.xudc: exiting ELPG done
May 31 18:03:48 ati-desktop kernel: [ 4.233274] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
May 31 18:03:48 ati-desktop kernel: [ 4.236309] tegra-xudc-new 700d0000.xudc: entering ELPG
May 31 18:03:48 ati-desktop kernel: [ 4.236561] tegra-xudc-new 700d0000.xudc: entering ELPG done
May 31 18:03:48 ati-desktop kernel: [ 4.236569] tegra-xudc-new 700d0000.xudc: exiting ELPG
May 31 18:03:48 ati-desktop kernel: [ 4.237100] tegra-xudc-new 700d0000.xudc: exiting ELPG done
May 31 18:03:48 ati-desktop kernel: [ 4.237113] tegra-xudc-new 700d0000.xudc: entering ELPG
May 31 18:03:48 ati-desktop kernel: [ 4.237323] tegra-xudc-new 700d0000.xudc: entering ELPG done
May 31 18:03:48 ati-desktop kernel: [ 4.237653] l4tbr0: port 1(rndis0) entered blocking state
May 31 18:03:48 ati-desktop kernel: [ 4.237657] l4tbr0: port 1(rndis0) entered disabled state
May 31 18:03:48 ati-desktop kernel: [ 4.237819] device rndis0 entered promiscuous mode
May 31 18:03:48 ati-desktop kernel: [ 4.244022] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
May 31 18:03:48 ati-desktop kernel: [ 4.249384] l4tbr0: port 2(usb0) entered blocking state
May 31 18:03:48 ati-desktop kernel: [ 4.249388] l4tbr0: port 2(usb0) entered disabled state
May 31 18:03:48 ati-desktop kernel: [ 4.249844] device usb0 entered promiscuous mode
May 31 18:03:48 ati-desktop kernel: [ 4.255648] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
May 31 18:03:48 ati-desktop kernel: [ 4.594768] r8168 0000:01:00.0 enp1s0: renamed from eth0
May 31 18:03:48 ati-desktop kernel: [ 4.622068] usb 1-3.1.3: new low-speed USB device number 6 using tegra-xusb
May 31 18:03:48 ati-desktop kernel: [ 4.648793] usb 1-3.1.3: New USB device found, idVendor=0e6a, idProduct=02c0
May 31 18:03:48 ati-desktop kernel: [ 4.648798] usb 1-3.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
May 31 18:03:48 ati-desktop kernel: [ 4.648801] usb 1-3.1.3: Product: PS/2+USB Keyboard
May 31 18:03:48 ati-desktop kernel: [ 4.648803] usb 1-3.1.3: Manufacturer: dakai
May 31 18:03:48 ati-desktop kernel: [ 4.653608] input: dakai PS/2+USB Keyboard as /devices/70090000.xusb/usb1/1-3/1-3.1/1-3.1.3/1-3.1.3:1.0/0003:0E6A:02C0.0001/input/input2
May 31 18:03:48 ati-desktop kernel: [ 4.710787] hid-generic 0003:0E6A:02C0.0001: input,hidraw0: USB HID v1.11 Keyboard [dakai PS/2+USB Keyboard] on usb-70090000.xusb-3.1.3/input0
May 31 18:03:48 ati-desktop kernel: [ 4.717638] input: dakai PS/2+USB Keyboard as /devices/70090000.xusb/usb1/1-3/1-3.1/1-3.1.3/1-3.1.3:1.1/0003:0E6A:02C0.0002/input/input3
May 31 18:03:48 ati-desktop kernel: [ 4.774341] hid-generic 0003:0E6A:02C0.0002: input,hidraw1: USB HID v1.11 Keyboard [dakai PS/2+USB Keyboard] on usb-70090000.xusb-3.1.3/input1
May 31 18:03:48 ati-desktop kernel: [ 4.902058] usb 1-3.1.4: new high-speed USB device number 7 using tegra-xusb
May 31 18:03:48 ati-desktop kernel: [ 4.925354] usb 1-3.1.4: New USB device found, idVendor=05e3, idProduct=0749
May 31 18:03:48 ati-desktop kernel: [ 4.925361] usb 1-3.1.4: New USB device strings: Mfr=3, Product=4, SerialNumber=2
May 31 18:03:48 ati-desktop kernel: [ 4.925365] usb 1-3.1.4: Product: USB3.0 Card Reader
May 31 18:03:48 ati-desktop kernel: [ 4.925368] usb 1-3.1.4: Manufacturer: Generic
May 31 18:03:48 ati-desktop kernel: [ 4.925372] usb 1-3.1.4: SerialNumber: 000000001532
May 31 18:03:48 ati-desktop kernel: [ 4.926525] usb-storage 1-3.1.4:1.0: USB Mass Storage device detected
May 31 18:03:48 ati-desktop kernel: [ 4.934601] scsi host1: usb-storage 1-3.1.4:1.0
May 31 18:03:49 ati-desktop kernel: [ 5.048165] IPv6: ADDRCONF(NETDEV_UP): enp1s0: link is not ready
May 31 18:03:49 ati-desktop kernel: [ 5.058509] enp1s0: 0xffffff800d3a5000, 48:b0:2d:2e:1f:f3, IRQ 404
May 31 18:03:49 ati-desktop kernel: [ 5.132608] IPv6: ADDRCONF(NETDEV_UP): enp1s0: link is not ready
May 31 18:03:49 ati-desktop kernel: [ 5.214755] zram: Added device: zram0
May 31 18:03:49 ati-desktop kernel: [ 5.218950] zram: Added device: zram1
May 31 18:03:49 ati-desktop kernel: [ 5.222763] zram: Added device: zram2
May 31 18:03:49 ati-desktop kernel: [ 5.224144] zram: Added device: zram3
May 31 18:03:49 ati-desktop kernel: [ 5.255780] zram0: detected capacity change from 0 to 258654208
May 31 18:03:49 ati-desktop kernel: [ 5.313944] Adding 252588k swap on /dev/zram0. Priority:5 extents:1 across:252588k SS
May 31 18:03:49 ati-desktop kernel: [ 5.322876] zram1: detected capacity change from 0 to 258654208
May 31 18:03:49 ati-desktop kernel: [ 5.337190] Adding 252588k swap on /dev/zram1. Priority:5 extents:1 across:252588k SS
May 31 18:03:49 ati-desktop kernel: [ 5.340208] zram2: detected capacity change from 0 to 258654208
May 31 18:03:49 ati-desktop kernel: [ 5.359486] Adding 252588k swap on /dev/zram2. Priority:5 extents:1 across:252588k SS
May 31 18:03:49 ati-desktop kernel: [ 5.368108] zram3: detected capacity change from 0 to 258654208
May 31 18:03:49 ati-desktop kernel: [ 5.388523] Adding 252588k swap on /dev/zram3. Priority:5 extents:1 across:252588k SS
May 31 18:03:50 ati-desktop kernel: [ 5.939307] scsi 1:0:0:0: Direct-Access Generic STORAGE DEVICE 1532 PQ: 0 ANSI: 6
May 31 18:03:50 ati-desktop kernel: [ 5.949569] sd 1:0:0:0: [sdb] Attached SCSI removable disk
May 31 18:03:50 ati-desktop kernel: [ 6.078082] usb 1-3.1.2: new full-speed USB device number 8 using tegra-xusb
May 31 18:03:50 ati-desktop kernel: [ 6.099736] usb 1-3.1.2: New USB device found, idVendor=060b, idProduct=2323
May 31 18:03:50 ati-desktop kernel: [ 6.099744] usb 1-3.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
May 31 18:03:50 ati-desktop kernel: [ 6.099748] usb 1-3.1.2: Product: NMouse4k S-Auto
May 31 18:03:50 ati-desktop kernel: [ 6.099752] usb 1-3.1.2: Manufacturer: Skydigital
May 31 18:03:50 ati-desktop kernel: [ 6.102208] input: Skydigital NMouse4k S-Auto as /devices/70090000.xusb/usb1/1-3/1-3.1/1-3.1.2/1-3.1.2:1.0/0003:060B:2323.0003/input/input4
May 31 18:03:50 ati-desktop kernel: [ 6.102551] hid-generic 0003:060B:2323.0003: input,hidraw2: USB HID v1.10 Mouse [Skydigital NMouse4k S-Auto] on usb-70090000.xusb-3.1.2/input0
May 31 18:03:50 ati-desktop kernel: [ 6.103688] input: Skydigital NMouse4k S-Auto as /devices/70090000.xusb/usb1/1-3/1-3.1/1-3.1.2/1-3.1.2:1.1/0003:060B:2323.0004/input/input5
May 31 18:03:50 ati-desktop kernel: [ 6.104635] hid-generic 0003:060B:2323.0004: input,hidraw3: USB HID v1.10 Device [Skydigital NMouse4k S-Auto] on usb-70090000.xusb-3.1.2/input1
May 31 18:03:50 ati-desktop kernel: [ 6.380731] mt7610u_sta: loading out-of-tree module taints kernel.
May 31 18:03:50 ati-desktop kernel: [ 6.419398] rtusb init rt2870 --->
May 31 18:03:50 ati-desktop kernel: [ 6.419735]
May 31 18:03:50 ati-desktop kernel: [ 6.419735] === pAd = ffffff800f142000, size = 895688 ===
May 31 18:03:50 ati-desktop kernel: [ 6.420281] <-- RTMPAllocTxRxRingMemory, Status=0
May 31 18:03:50 ati-desktop kernel: [ 6.420489] <-- RTMPAllocAdapterBlock, Status=0
May 31 18:03:50 ati-desktop kernel: [ 6.420619] ==>RT65xx_WLAN_ChipOnOff(): OnOff:1, Reset= 0, pAd->WlanFunCtrl:0x0, Reg-WlanFunCtrl=0xff000002
May 31 18:03:50 ati-desktop kernel: [ 6.421491] MCUType = 2
May 31 18:03:50 ati-desktop kernel: [ 6.421695] NVM is EFUSE
May 31 18:03:50 ati-desktop kernel: [ 6.421698] Endpoint(8) is for In-band Command
May 31 18:03:50 ati-desktop kernel: [ 6.421701] Endpoint(4) is for WMM0 AC0
May 31 18:03:50 ati-desktop kernel: [ 6.421704] Endpoint(5) is for WMM0 AC1
May 31 18:03:50 ati-desktop kernel: [ 6.421707] Endpoint(6) is for WMM0 AC2
May 31 18:03:50 ati-desktop kernel: [ 6.421710] Endpoint(7) is for WMM0 AC3
May 31 18:03:50 ati-desktop kernel: [ 6.421712] Endpoint(9) is for WMM1 AC0
May 31 18:03:50 ati-desktop kernel: [ 6.421715] Endpoint(84) is for Data-In
May 31 18:03:50 ati-desktop kernel: [ 6.421717] Endpoint(85) is for Command Rsp
May 31 18:03:50 ati-desktop kernel: [ 6.421882] 80211> RFICType = 3
May 31 18:03:50 ati-desktop kernel: [ 6.421887] 80211> Number of channel = 44
May 31 18:03:50 ati-desktop kernel: [ 6.421890] 80211> Number of rate = 12
May 31 18:03:50 ati-desktop kernel: [ 6.421892] 80211> CurTxPower = 0 dBm
May 31 18:03:50 ati-desktop kernel: [ 6.421896] 80211> TxStream = 0
May 31 18:03:50 ati-desktop kernel: [ 6.422083] crda> requlation requestion by core:
May 31 18:03:50 ati-desktop kernel: [ 6.422086] 00
May 31 18:03:50 ati-desktop kernel: [ 6.422237] 80211> CFG80211_Register
May 31 18:03:50 ati-desktop kernel: [ 6.422613] 80211> CFG80211_OpsTxPwrGet ==>
May 31 18:03:50 ati-desktop kernel: [ 6.423811] 80211> CFG80211_OpsTxPwrGet ==>
May 31 18:03:50 ati-desktop kernel: [ 6.429826] usbcore: registered new interface driver rt2870
May 31 18:03:51 ati-desktop kernel: [ 7.543733] Bridge firewalling registered
May 31 18:03:51 ati-desktop kernel: [ 7.733184] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
May 31 18:03:51 ati-desktop kernel: [ 7.879930] tegradc tegradc.0: unblank
May 31 18:03:52 ati-desktop kernel: [ 8.044263] Netfilter messages via NETLINK v0.30.
May 31 18:03:52 ati-desktop kernel: [ 8.047075] ctnetlink v0.93: registering with nfnetlink.
May 31 18:03:52 ati-desktop kernel: [ 8.253744] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
May 31 18:03:53 ati-desktop kernel: [ 9.653020] fuse init (API version 7.26)
May 31 18:03:55 ati-desktop kernel: [ 11.513143] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
May 31 18:03:55 ati-desktop kernel: [ 11.513154] Bluetooth: BNEP socket layer initialized
May 31 18:03:57 ati-desktop kernel: [ 13.093486] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
