Jetson nano 4GB A02 mcp2515 connect
Hello, I have version jetson nano 4GB A02 and am trying to use can by connecting mcp2515 but am new to this board and have been looking for multiple sources but have not even been able to connect. Can anyone explain this in detail?
Hi shehdgml13,
Are you using the devkit or custom board for Jetson Nano?
Before you try to port MCP2515 module on Jetson Nano, I would suggest you verifying SPI loopback test.
Please refer to the following thread for this.
Jetson Nano SPI Bus Not Working - #10 by KevinFFF
Hello
I’m using a jetson nano devkit A02. Also, the jetpack version is 4.6.1.
New to this board, I don’t know how to use MCP2515.
Can you explain it step by step?
Thank you.
Have you referred to above thread for the step-by-step guide to verify SPI loopback test already?
MCP2515 module uses SPI interface from Jetson device so that you have to verify SPI configurations all good first.
