Jetson Nano booting error after upgrade
To summarize all for Jetson Nano Jetpack 4.6.2 version:
Get 64GB pendrive and instal
  1. Get 1 random pendrive and install Ubuntu 18.04 image
  2. Enable UEFI option in the laptop and boot into Ubuntu
  3. Install full Ubuntu on another pendrive (64GB min)
  4. Run the full Ubuntu in the pendrive, search Nvidia SDK Manager and download it
  5. Enable universe in the “Software and Updates”
  6. Install the Nvidia SDK Manager through “sudo apt-get install sdkxxxx.deb”
  7. Start SDK Manager
  8. Connect the “Force Recovery” pin to GND
  9. Use a microUSB cable (with data line) and connect to the host pc (laptop)
    Power the Jetson Nano with Power adapter
  10. Choose Jetpack 4.6.2 and go to next step
  11. Wait for downloading, took me half day to complete it
  12. Before flashing, choose OEM Configuration to RUNTIME
  13. After flashing image, the Jetson Nano will boot up, connect to another display and complete the setup, connect to the WIFI same as the host pc(laptop)
  14. Check the connection information and record the ip address
  15. On the host pc, enter username, password, ip address
  16. Wait for flashing (1,2 hours)
  17. On the Jetson Nano, the boot location is on eMMC, only 16GB which is not enough
  18. Follow through the Youtube video attached above to format the pendrive, copy the rootf to the pendrive etc.
  19. change /boot/extlinux/extlinux.conf on the SD card/eMMC, and modify
  20. Reboot and its done
I hope this helps whoever using Jetson Nano in the future for newbie.
All my problem started with “sudo apt-get upgrade” and replaced some older version, it’s fun journey but I do not want to suffer this again. Once again thank for everyone helping me! Probably gonna post again as I expected there are more problem hidden which I not yet face.
I tried to do sudo apt-get upgrade again, and the same thing occurred, so I think there is something wrong with upgrade and I should not proceed with any upgrade?
I found a very similar case but I don’t understand how he proceeded to get to set those env, would you mind to take a look?
