I am running into an issue with the UART on the jetson nano. I am attempting to connect it to a raspberry pi 2 model B through a navio+ shield. when I connect it, whether or not I am actually trying to communicate over the UARt, the jetson begins to glitch out and eventually shuts off. As far as I can tell, everything is connected correctly and at the same voltage level.
