Jetson nano Debug logs
i have a seeed board j1010, i connected a data logger with jetson nano debug uart logs under header j14. please help me out what happens to it .
PFA
DATA.TXT (793.2 KB)
This log looks totally out of order. Did you only boot one time or you boot multiple times?
My jetson nano was in truck. I dont know what has happened to it
2000-01-01 00:00:00: [ 1769.239240] soctherm: OC ALARM 0x00000001
Data logged to SD card: 2000-01-01 00:00:00: [ 1769.239240] soctherm: OC ALARM 0x00000001
2000-01-01 00:00:00: [0000.637] Bootloader DTB Load Address: 0x83000000
Data logged to SD card: 2000-01-01 00:00:00: [0000.637] Bootloader DTB Load Address: 0x83000000
2000-01-01 00:00:00: [0000.642] [0001.648] Config for emmc ddr50 mode completed
Data logged to SD card: 2000-01-01 00:00:00: [0000.642] [0001.648] Config for emmc ddr50 mode completed
2000-01-01 00:00:00: [00[0002.726] load_bmp_blob: panelresolution=1080 type=3
Data logged to SD card: 2000-01-01 00:00:00: [00[0002.726] load_bmp_blob: panelresolution=1080 type=3
2000-01-01 00:00:00: [0002003.716] Updated board info to DTB
Data logged to SD card: 2000-01-01 00:00:00: [0002003.716] Updated board info to DTB
2000-01-01 00:00:00: [0003.719] "display-bo 1  0
Data logged to SD card: 2000-01-01 00:00:00: [0003.719] "display-bo 1  0
2000-01-01 00:00:00: MMC: no card present
Data logged to SD card: 2000-01-01 00:00:00: MMC: no card present
2000-01-01 00:00:00: switch to partitions #0, OK
Data logged to SD card: 2000-01-01 00:00:00: switch to partitions #0, OK
2000-01-01 00:00:00: mmc0(part 0)2: Custom Header Config:
Data logged to SD card: 2000-01-01 00:00:00: mmc0(part 0)2: Custom Header Config:
2000-01-01 00:00:00: Retrieving file: /boot/initr
can you tell me now
I think the question here is what could you do for your board now?
Are you able to access it? Are you able to flash it?
You cannot even dump a clear log out and it seems you told us you are not able to access the board. I really wonder what could you do on your side?
No. I have shared some part of logs above, can u just take out of it anything ?
Your log is not even completed. Out of order and even not have useful info…
It is just like it printed first line, printed line 10000 then, and somehow it is back to print line 10 again. Not able to know what happened there…
This log totally cannot provide much help here.
If you expect some helps here, at least give out a clean log… just like how other users did…
