I have a Jetson Nano development kit and I need to install Ubuntu 20.04 on it. Is it possible to install it? I´ve seen that the Jetpack 5.0 should come with Ubuntu 20.04 but i´m unsure if the Jetpack supports the Jetson Nano dev kit.
Thanks in advance!
There are different Nanos…the original Nano, TX2 Nano, the Xavier Nano, and Orin Nano. If you have the original Nano (the least expensive one), then the answer is “no”, as it cannot use an L4T release greater than R32.x (which is Ubuntu 18.04). The listing of L4T releases can be seen here (L4T is just the name of Ubuntu after NVIDIA drivers are added):
https://developer.nvidia.com/linux-tegra
