I am trying to use my MLX90614-DCI temperature sensor with Jetson Nano Developer Kit (4GB). I connected the VIN pin of the sensor to 5V of Jetson nano, the GND pin to GND, the SCL pin to 5, the SDA pin to 3 but when I run the i2cdetect -y -r 1
command on the terminal, Jetson does not see the sensor. I even put a 10K pull up resistor to system but did not worked. What can I do, does anyone have any advice?
Hi i_konak,
Sorry for the late response, have you managed to get the temperature sensor working?
