Jetson Nano GPU driver compiling
It looks like driver from this kernel overlay conflicting with the driver from the kernel itself
kernel-4.9/drivers/media/platform/vivid conflicting with nvidia/media/platform/tegra-vivid
Maybe download the source from the download center to start in a clean folder to confirm again.
Good afternoon, ShaneCCC! I found the reason of all my problems. The reason is - make ignores my defconfig and write there a lot of extra options and now I cannot find where is it appears.
For example - I add to my own defconfig option CONFIG_DEBUG_FS=n then I made make ARCH=arm64 O=$TEGRA_KERNEL_OUT my_defconfig and checked .config - it is right - there is the option CONFIG_DEBUG_FS=n. Then I made make ARCH=arm64 O=$TEGRA_KERNEL_OUT -j20 Image and I received an error while it compiling some code that I don’t need. I checked .config again and discovered that there is: CONFIG_DEBUG_FS=y. Why? Maybe Nvidia makefiles somewhere rewriting .config and I don’t know this?
Please, help me. I hope - there is the last problem that I encountering while trying to build your kernel :)
Also my defconfig has 500 entries but .config has 5000 so it means that somewhere and somewhat rewriting this…
I have such defconfig (trying to minimize it as possible):
CONFIG_LOCALVERSION_AUTO=y
CONFIG_SYSVIPC=y
CONFIG_POSIX_MQUEUE=y
CONFIG_AUDIT=y
CONFIG_NO_HZ=y
CONFIG_HIGH_RES_TIMERS=y
CONFIG_IRQ_TIME_ACCOUNTING=y
CONFIG_BSD_PROCESS_ACCT=y
CONFIG_BSD_PROCESS_ACCT_V3=y
CONFIG_TASKSTATS=y
CONFIG_TASK_DELAY_ACCT=y
CONFIG_TASK_XACCT=y
CONFIG_TASK_IO_ACCOUNTING=y
CONFIG_IKCONFIG=y
CONFIG_IKCONFIG_PROC=y
CONFIG_LOG_BUF_SHIFT=15
CONFIG_LOG_CPU_MAX_BUF_SHIFT=15
CONFIG_CGROUPS=y
#CONFIG_CGROUP_DEBUG=y
CONFIG_CGROUP_FREEZER=y
CONFIG_CGROUP_PIDS=y
CONFIG_CGROUP_DEVICE=y
CONFIG_CPUSETS=y
CONFIG_CGROUP_CPUACCT=y
CONFIG_MEMCG=y
CONFIG_MEMCG_SWAP=y
CONFIG_BLK_CGROUP=y
CONFIG_CGROUP_SCHED=y
CONFIG_CFS_BANDWIDTH=y
CONFIG_CGROUP_HUGETLB=y
CONFIG_CGROUP_PERF=y
CONFIG_NAMESPACES=y
CONFIG_USER_NS=y
CONFIG_BLK_DEV_INITRD=y
CONFIG_KALLSYMS_ALL=y
CONFIG_EMBEDDED=y
# CONFIG_COMPAT_BRK is not set
CONFIG_PROFILING=y
CONFIG_JUMP_LABEL=y
CONFIG_ARCH_MMAP_RND_COMPAT_BITS=16
CONFIG_MODULES=y
CONFIG_MODULE_UNLOAD=y
CONFIG_MODVERSIONS=y
CONFIG_BLK_DEV_THROTTLING=y
CONFIG_PARTITION_ADVANCED=y
# CONFIG_IOSCHED_DEADLINE is not set
CONFIG_ARCH_TEGRA=y
CONFIG_PCI=y
CONFIG_PCIEPORTBUS=y
CONFIG_PCIEASPM_POWERSAVE=y
#CONFIG_PCI_STUB=m
CONFIG_PCI_IOV=y
CONFIG_PCIE_TEGRA=y
CONFIG_PCIE_TEGRA_EP=y
CONFIG_PCI_TEGRA=y
CONFIG_PCI_ENDPOINT=y
CONFIG_PCI_ENDPOINT_CONFIGFS=y
CONFIG_PCIE_EPF_NV_TEST=y
CONFIG_PCIE_EPF_TEGRA_VNET=y
# CONFIG_ARM64_ERRATUM_843419 is not set
CONFIG_SCHED_MC=y
CONFIG_PREEMPT=y
###CONFIG_MEMORY_HOTPLUG=y
###CONFIG_MEMORY_HOTPLUG_DEFAULT_ONLINE=y
###CONFIG_MEMORY_HOTREMOVE=y
CONFIG_HMM_MIRROR=y
CONFIG_KSM=y
CONFIG_TRANSPARENT_HUGEPAGE=y
CONFIG_CMA=y
CONFIG_ZSMALLOC=y
CONFIG_ZONE_DEVICE=y
CONFIG_DEVICE_PRIVATE=y
CONFIG_SECCOMP=y
CONFIG_KEXEC=y
# CONFIG_UNMAP_KERNEL_AT_EL0 is not set
CONFIG_ARMV8_DEPRECATED=y
CONFIG_SWP_EMULATION=y
CONFIG_CP15_BARRIER_EMULATION=y
CONFIG_SETEND_EMULATION=y
CONFIG_ARM64_SW_TTBR0_PAN=y
# CONFIG_ARM64_HW_AFDBM is not set
CONFIG_ARM64_LSE_ATOMICS=y
# CONFIG_ARM64_VHE is not set
CONFIG_RANDOMIZE_BASE=y
# CONFIG_EFI is not set
# CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set
#CONFIG_BINFMT_MISC=m
CONFIG_COMPAT=y
#CONFIG_PM_DEBUG=y
#CONFIG_PM_ADVANCED_DEBUG=y
CONFIG_CPU_IDLE=y
CONFIG_ARM_CPUIDLE=y
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_STAT=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=y
CONFIG_CPU_FREQ_GOV_USERSPACE=y
CONFIG_CPU_FREQ_GOV_ONDEMAND=y
CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
CONFIG_CPU_FREQ_GOV_INTERACTIVE=y
CONFIG_CPU_FREQ_GOV_SCHEDUTIL=y
CONFIG_TASK_WEIGHT=y
CONFIG_NET=y
CONFIG_PACKET=y
CONFIG_UNIX=y
CONFIG_XFRM_USER=y
CONFIG_NET_KEY=y
CONFIG_INET=y
###CONFIG_IP_MULTICAST=y
###CONFIG_IP_ADVANCED_ROUTER=y
###CONFIG_IP_MULTIPLE_TABLES=y
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_IP_PNP_BOOTP=y
#CONFIG_INET_ESP=m
###CONFIG_IPV6_ROUTER_PREF=y
###CONFIG_IPV6_ROUTE_INFO=y
###CONFIG_IPV6_OPTIMISTIC_DAD=y
#CONFIG_INET6_AH=m
#CONFIG_INET6_ESP=m
#CONFIG_INET6_IPCOMP=m
#CONFIG_IPV6_MIP6=m
#CONFIG_INET6_XFRM_MODE_TRANSPORT=m
#CONFIG_INET6_XFRM_MODE_TUNNEL=m
#CONFIG_INET6_XFRM_MODE_BEET=m
#CONFIG_IPV6_SIT=m
#CONFIG_IPV6_TUNNEL=m
###CONFIG_IPV6_MULTIPLE_TABLES=y
# CONFIG_ANDROID_PARANOID_NETWORK is not set
###CONFIG_NETFILTER=y
#CONFIG_NETFILTER_NETLINK_ACCT=m
#CONFIG_NF_CONNTRACK=m
#CONFIG_NF_CONNTRACK_EVENTS=y
#CONFIG_NF_CT_PROTO_DCCP=m
#CONFIG_NF_CT_PROTO_SCTP=m
#CONFIG_NF_CT_PROTO_UDPLITE=m
#CONFIG_NF_CONNTRACK_AMANDA=m
#CONFIG_NF_CONNTRACK_FTP=m
#CONFIG_NF_CONNTRACK_H323=m
#CONFIG_NF_CONNTRACK_IRC=m
#CONFIG_NF_CONNTRACK_NETBIOS_NS=m
#CONFIG_NF_CONNTRACK_PPTP=m
#CONFIG_NF_CONNTRACK_SANE=m
#CONFIG_NF_CONNTRACK_SIP=m
#CONFIG_NF_CONNTRACK_TFTP=m
#CONFIG_NF_CT_NETLINK=m
#CONFIG_NETFILTER_XT_TARGET_CHECKSUM=m
#CONFIG_NETFILTER_XT_TARGET_CLASSIFY=m
#CONFIG_NETFILTER_XT_TARGET_CONNMARK=m
#CONFIG_NETFILTER_XT_TARGET_IDLETIMER=m
#CONFIG_NETFILTER_XT_TARGET_LOG=m
#CONFIG_NETFILTER_XT_TARGET_MARK=m
#CONFIG_NETFILTER_XT_TARGET_NFLOG=m
#CONFIG_NETFILTER_XT_TARGET_NFQUEUE=m
#CONFIG_NETFILTER_XT_TARGET_TPROXY=m
#CONFIG_NETFILTER_XT_TARGET_TRACE=m
#CONFIG_NETFILTER_XT_TARGET_TCPMSS=m
#CONFIG_NETFILTER_XT_MATCH_ADDRTYPE=m
#CONFIG_NETFILTER_XT_MATCH_COMMENT=m
#CONFIG_NETFILTER_XT_MATCH_CONNBYTES=m
#CONFIG_NETFILTER_XT_MATCH_CONNLIMIT=m
#CONFIG_NETFILTER_XT_MATCH_CONNMARK=m
#CONFIG_NETFILTER_XT_MATCH_CONNTRACK=m
#CONFIG_NETFILTER_XT_MATCH_HASHLIMIT=m
#CONFIG_NETFILTER_XT_MATCH_HELPER=m
#CONFIG_NETFILTER_XT_MATCH_IPRANGE=m
#CONFIG_NETFILTER_XT_MATCH_IPVS=m
#CONFIG_NETFILTER_XT_MATCH_LENGTH=m
#CONFIG_NETFILTER_XT_MATCH_LIMIT=m
#CONFIG_NETFILTER_XT_MATCH_MAC=m
#CONFIG_NETFILTER_XT_MATCH_MARK=m
#CONFIG_NETFILTER_XT_MATCH_MULTIPORT=m
#CONFIG_NETFILTER_XT_MATCH_OWNER=m
#CONFIG_NETFILTER_XT_MATCH_POLICY=m
#CONFIG_NETFILTER_XT_MATCH_PHYSDEV=m
#CONFIG_NETFILTER_XT_MATCH_PKTTYPE=m
#CONFIG_NETFILTER_XT_MATCH_QUOTA=m
#CONFIG_NETFILTER_XT_MATCH_QUOTA2=m
#CONFIG_NETFILTER_XT_MATCH_RECENT=m
#CONFIG_NETFILTER_XT_MATCH_SOCKET=m
#CONFIG_NETFILTER_XT_MATCH_STATE=m
#CONFIG_NETFILTER_XT_MATCH_STATISTIC=m
#CONFIG_NETFILTER_XT_MATCH_STRING=m
#CONFIG_NETFILTER_XT_MATCH_TIME=m
#CONFIG_NETFILTER_XT_MATCH_U32=m
#CONFIG_IP_VS=m
CONFIG_IP_VS_PROTO_TCP=y
CONFIG_IP_VS_PROTO_UDP=y
#CONFIG_IP_VS_RR=m
#CONFIG_IP_VS_NFCT=y
#CONFIG_NF_CONNTRACK_IPV4=m
#CONFIG_IP_NF_IPTABLES=m
#CONFIG_IP_NF_MATCH_AH=m
#CONFIG_IP_NF_MATCH_ECN=m
#CONFIG_IP_NF_MATCH_RPFILTER=m
#CONFIG_IP_NF_MATCH_TTL=m
#CONFIG_IP_NF_FILTER=m
#CONFIG_IP_NF_TARGET_REJECT=m
#CONFIG_IP_NF_NAT=m
#CONFIG_IP_NF_TARGET_MASQUERADE=m
#CONFIG_IP_NF_TARGET_REDIRECT=m
#CONFIG_IP_NF_MANGLE=m
#CONFIG_IP_NF_RAW=m
#CONFIG_IP_NF_ARPTABLES=m
#CONFIG_IP_NF_ARPFILTER=m
#CONFIG_IP_NF_ARP_MANGLE=m
#CONFIG_NF_CONNTRACK_IPV6=m
#CONFIG_IP6_NF_IPTABLES=m
#CONFIG_IP6_NF_FILTER=m
#CONFIG_IP6_NF_TARGET_REJECT=m
#CONFIG_IP6_NF_MANGLE=m
#CONFIG_IP6_NF_RAW=m
#CONFIG_IP6_NF_NAT=m
#CONFIG_IP6_NF_TARGET_MASQUERADE=m
#CONFIG_BRIDGE=y
#CONFIG_BRIDGE_VLAN_FILTERING=y
#CONFIG_VLAN_8021Q=m
#CONFIG_VLAN_8021Q_GVRP=y
#CONFIG_VLAN_8021Q_MVRP=y
###CONFIG_NET_SCHED=y
###CONFIG_NET_SCH_HTB=y
###CONFIG_NET_CLS_U32=y
###CONFIG_NET_CLS_CGROUP=y
###CONFIG_NET_EMATCH=y
###CONFIG_NET_EMATCH_U32=y
###CONFIG_NET_CLS_ACT=y
###CONFIG_DNS_RESOLVER=y
###CONFIG_NET_L3_MASTER_DEV=y
###CONFIG_CGROUP_NET_PRIO=y
###CONFIG_BPF_JIT=y
#CONFIG_CAN=m
#CONFIG_CAN_VCAN=m
#CONFIG_CAN_SLCAN=m
#CONFIG_CAN_C_CAN=m
#CONFIG_CAN_CC770=m
#CONFIG_CAN_CC770_ISA=m
#CONFIG_CAN_CC770_PLATFORM=m
#CONFIG_CAN_M_CAN=m
#CONFIG_CAN_SJA1000=m
#CONFIG_CAN_SJA1000_ISA=m
#CONFIG_CAN_SJA1000_PLATFORM=m
#CONFIG_CAN_EMS_PCI=m
#CONFIG_CAN_KVASER_PCI=m
#CONFIG_CAN_PLX_PCI=m
#CONFIG_CAN_SOFTING=m
#CONFIG_CAN_MCP251X=m
#CONFIG_CAN_EMS_USB=m
#CONFIG_CAN_ESD_USB2=m
#CONFIG_CAN_GS_USB=m
#CONFIG_CAN_KVASER_USB=m
#CONFIG_CAN_PEAK_USB=m
#CONFIG_CAN_8DEV_USB=m
#CONFIG_MTTCAN=m
#CONFIG_IRDA=m
###CONFIG_BT=y
###CONFIG_BT_RFCOMM=y
###CONFIG_BT_BNEP=m
###CONFIG_BT_HIDP=y
#### CONFIG_BT_HS is not set
#### CONFIG_BT_LE is not set
###CONFIG_BT_LEDS=y
#### CONFIG_BT_DEBUGFS is not set
###CONFIG_BT_HCIBTUSB=m
###CONFIG_BT_HCIUART=m
###CONFIG_BT_HCIUART_BCSP=y
###CONFIG_BT_HCIUART_ATH3K=y
###CONFIG_BT_HCIUART_LL=y
###CONFIG_BT_HCIUART_INTEL=y
###CONFIG_BT_HCIUART_BCM=y
###CONFIG_BT_HCIUART_QCA=y
###CONFIG_BT_HCIBCM203X=m
###CONFIG_BT_HCIBPA10X=m
###CONFIG_BT_HCIBFUSB=m
###CONFIG_BT_HCIVHCI=m
###CONFIG_BT_MRVL=m
###CONFIG_BT_MRVL_SDIO=m
###CONFIG_BT_ATH3K=m
###CONFIG_AF_RXRPC=m
###CONFIG_CFG80211=m
###CONFIG_MAC80211=m
###CONFIG_MAC80211_RC_MINSTREL_VHT=y
###CONFIG_RFKILL=y
###CONFIG_NET_9P=y
###CONFIG_NET_9P_VIRTIO=y
CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug"
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
CONFIG_FW_LOADER_USER_HELPER_FALLBACK=y
CONFIG_DMA_CMA=y
CONFIG_CMA_SIZE_MBYTES=64
CONFIG_TEGRA_ACONNECT=y
CONFIG_MTD=y
CONFIG_MTD_CMDLINE_PARTS=y
CONFIG_MTD_BLOCK=y
CONFIG_MTD_M25P80=y
CONFIG_MTD_QSPI_FLASH=y
CONFIG_MTD_SPI_NOR=y
#CONFIG_MTD_UBI=m
CONFIG_OF_PLUGIN_MANAGER=y
CONFIG_OF_OVERLAY=y
###CONFIG_ZRAM=m
CONFIG_BLK_DEV_LOOP=y
#CONFIG_BLK_DEV_NBD=m
CONFIG_BLK_DEV_RAM=y
CONFIG_BLK_DEV_RAM_SIZE=8192
CONFIG_VIRTIO_BLK=y
CONFIG_BLK_DEV_NVME=y
CONFIG_SRAM=y
#CONFIG_BLUEDROID_PM=m
#CONFIG_MODS=m
CONFIG_SENSORS_NCT1008=y
CONFIG_SENSORS_PEX9749=y
CONFIG_FAN_THERM_EST=y
CONFIG_TEGRA_PCIE_EP_MEM=y
CONFIG_NVS_LIGHT=y
CONFIG_NVS_PROXIMITY=y
CONFIG_NVS_TRIGGERED_BUFFER=y
CONFIG_TEGRA_PROFILER=y
# CONFIG_SCSI_PROC_FS is not set
CONFIG_BLK_DEV_SD=y
CONFIG_SCSI_SAS_ATA=y
CONFIG_SCSI_HISI_SAS=y
CONFIG_SCSI_MVSAS=y
CONFIG_SCSI_UFSHCD=y
CONFIG_SCSI_UFSHCD_PLATFORM=y
CONFIG_SCSI_UFSHCD_TEGRA=y
CONFIG_ATA=y
CONFIG_SATA_AHCI=y
CONFIG_SATA_AHCI_PLATFORM=y
CONFIG_AHCI_TEGRA_DOWNSTREAM=y
CONFIG_MD=y
CONFIG_BLK_DEV_DM=y
CONFIG_DM_CRYPT=y
CONFIG_DM_UEVENT=y
CONFIG_NETDEVICES=y
CONFIG_DUMMY=y
#CONFIG_MACVLAN=m
#CONFIG_MACVTAP=m
###CONFIG_IPVLAN=y
###CONFIG_VXLAN=y
###CONFIG_TUN=y
###CONFIG_VETH=m
###CONFIG_VIRTIO_NET=y
###CONFIG_TYPHOON=m
###CONFIG_ET131X=m
###CONFIG_ACENIC=m
###CONFIG_ALTERA_TSE=m
###CONFIG_AQTION=m
###CONFIG_ATL2=m
###CONFIG_ATL1=m
###CONFIG_ATL1E=m
###CONFIG_ATL1C=m
###CONFIG_ALX=m
###CONFIG_MACB=y
#CONFIG_B44=m
#CONFIG_CNIC=m
###CONFIG_TIGON3=y
#CONFIG_BNX2X=m
#CONFIG_BNXT=m
#CONFIG_BNA=m
#CONFIG_THUNDER_NIC_PF=m
#CONFIG_THUNDER_NIC_VF=m
#CONFIG_LIQUIDIO=m
#CONFIG_CHELSIO_T1=m
###CONFIG_CHELSIO_T1_1G=y
#CONFIG_CHELSIO_T3=m
#CONFIG_CHELSIO_T4=m
#CONFIG_CHELSIO_T4VF=m
#CONFIG_ENIC=m
#CONFIG_DL2K=m
#CONFIG_BE2NET=m
#CONFIG_S2IO=m
#CONFIG_VXGE=m
#CONFIG_HP100=m
#CONFIG_E100=m
#CONFIG_E1000=m
###CONFIG_E1000E=y
###CONFIG_IGB=y
###CONFIG_IGBVF=y
#CONFIG_IXGB=m
###CONFIG_IXGBE=y
#CONFIG_IXGBEVF=m
#CONFIG_I40E=m
#CONFIG_I40EVF=m
#CONFIG_FM10K=m
#CONFIG_JME=m
#CONFIG_SKGE=m
#CONFIG_SKGE_DEBUG=y
#CONFIG_SKY2=m
#CONFIG_SKY2_DEBUG=y
#CONFIG_NET_VENDOR_MELLANOX=y
#CONFIG_MLX4_EN=m
# CONFIG_MLX4_DEBUG is not set
#CONFIG_MLX4_CORE=m
###CONFIG_MLX5_CORE=m
###CONFIG_MLX5_CORE_EN=y
###CONFIG_MLX5_CORE_THERMAL=y
###CONFIG_MLX5_MPFS=y
###CONFIG_MLX5_ESWITCH=y
###CONFIG_MLX5_CORE_EN_DCB=y
###CONFIG_MLX5_CORE_IPOIB=y
###CONFIG_MLXSW_CORE=y
###CONFIG_MLXSW_CORE_HWMON=y
###CONFIG_MLXSW_CORE_THERMAL=y
###CONFIG_MLXSW_PCI=m
###CONFIG_MLXSW_I2C=m
###CONFIG_MLXSW_SWITCHIB=m
###CONFIG_MLXSW_SWITCHX2=m
###CONFIG_MLXSW_SPECTRUM=m
###CONFIG_MLXSW_SPECTRUM_DCB=y
###CONFIG_MLXSW_MINIMAL=m
###CONFIG_MLXFW=m
###CONFIG_NATSEMI=m
###CONFIG_NS83820=m
###CONFIG_NFP_NETVF=m
###CONFIG_NFP_NET_DEBUG=y
###CONFIG_NE2K_PCI=m
###CONFIG_FORCEDETH=y
###CONFIG_EQOS=y
###CONFIG_PCIE_TEGRA_VNET=y
###CONFIG_HAMACHI=m
###CONFIG_YELLOWFIN=m
###CONFIG_QLA3XXX=m
###CONFIG_QLCNIC=m
###CONFIG_QLGE=m
###CONFIG_NETXEN_NIC=m
###CONFIG_QED=m
###CONFIG_QEDE=m
###CONFIG_QCA7000=m
###CONFIG_QCOM_EMAC=m
###CONFIG_8139CP=m
###CONFIG_8139TOO=m
###CONFIG_R8169=y
###CONFIG_R8168=y
###CONFIG_SXGBE_ETH=m
###CONFIG_SFC=m
###CONFIG_SMC91X=y
###CONFIG_SMSC911X=y
###CONFIG_STMMAC_ETH=m
###CONFIG_MDIO_BITBANG=y
###CONFIG_BROADCOM_PHY=y
###CONFIG_MARVELL_PHY=y
###CONFIG_MICREL_PHY=y
###CONFIG_REALTEK_PHY=y
CONFIG_PPP=y
CONFIG_PPP_BSDCOMP=y
CONFIG_PPP_DEFLATE=y
CONFIG_PPP_FILTER=y
CONFIG_PPP_MPPE=y
CONFIG_PPPOLAC=y
CONFIG_PPPOPNS=y
CONFIG_PPP_ASYNC=y
CONFIG_PPP_SYNC_TTY=y
###CONFIG_USB_CATC=m
###CONFIG_USB_KAWETH=m
###CONFIG_USB_PEGASUS=m
###CONFIG_USB_RTL8150=m
###CONFIG_USB_RTL8152=y
###CONFIG_USB_LAN78XX=m
###CONFIG_USB_USBNET=y
###CONFIG_USB_NET_DM9601=m
###CONFIG_USB_NET_SR9700=m
###CONFIG_USB_NET_SR9800=m
###CONFIG_USB_NET_SMSC75XX=m
###CONFIG_USB_NET_SMSC95XX=m
###CONFIG_USB_NET_GL620A=m
###CONFIG_USB_NET_PLUSB=m
###CONFIG_USB_NET_MCS7830=m
###CONFIG_USB_NET_RNDIS_HOST=m
###CONFIG_USB_ALI_M5632=y
###CONFIG_USB_AN2720=y
###CONFIG_USB_KC2190=y
###CONFIG_USB_NET_CX82310_ETH=m
###CONFIG_ATH9K=m
###CONFIG_ATH9K_DEBUGFS=y
###CONFIG_ATH9K_STATION_STATISTICS=y
###CONFIG_ATH9K_WOW=y
###CONFIG_ATH9K_CHANNEL_CONTEXT=y
###CONFIG_ATH9K_HTC=m
###CONFIG_ATH9K_HTC_DEBUGFS=y
###CONFIG_CARL9170=m
###CONFIG_CARL9170_DEBUGFS=y
###CONFIG_ATH6KL=m
###CONFIG_ATH6KL_SDIO=m
###CONFIG_ATH6KL_USB=m
###CONFIG_ATH6KL_DEBUG=y
###CONFIG_AR5523=m
###CONFIG_WIL6210=m
#### CONFIG_WIL6210_TRACING is not set
###CONFIG_ATH10K=m
###CONFIG_ATH10K_PCI=m
###CONFIG_ATH10K_AHB=y
###CONFIG_ATH10K_DEBUGFS=y
###CONFIG_WCN36XX=m
###CONFIG_WCN36XX_DEBUGFS=y
###CONFIG_ATMEL=m
###CONFIG_AT76C50X_USB=m
###CONFIG_B43=m
###CONFIG_B43_SDIO=y
###CONFIG_B43LEGACY=m
###CONFIG_IWLWIFI=m
###CONFIG_IWLDVM=m
###CONFIG_IWLMVM=m
###CONFIG_IWLWIFI_DEBUGFS=y
#### CONFIG_IWLWIFI_DEVICE_TRACING is not set
###CONFIG_HERMES=m
###CONFIG_P54_COMMON=m
###CONFIG_P54_USB=m
###CONFIG_P54_PCI=m
###CONFIG_MWIFIEX=m
###CONFIG_MWIFIEX_SDIO=m
###CONFIG_MWIFIEX_PCIE=m
###CONFIG_MWIFIEX_USB=m
###CONFIG_MWL8K=m
###CONFIG_MT7601U=m
###CONFIG_RT2X00=m
###CONFIG_RT2800PCI=m
###CONFIG_RT2500USB=m
###CONFIG_RT73USB=m
###CONFIG_RT2800USB=m
###CONFIG_RT2800USB_RT3573=y
###CONFIG_RT2800USB_RT53XX=y
###CONFIG_RT2800USB_RT55XX=y
###CONFIG_RT2800USB_UNKNOWN=y
###CONFIG_RT2X00_LIB_DEBUGFS=y
###CONFIG_RTL8187=m
###CONFIG_RTL8192CE=m
###CONFIG_RTL8192SE=m
###CONFIG_RTL8192DE=m
###CONFIG_RTL8723AE=m
###CONFIG_RTL8723BE=m
###CONFIG_RTL8188EE=m
###CONFIG_RTL8192EE=m
###CONFIG_RTL8821AE=m
###CONFIG_RTL8192CU=m
###CONFIG_RTL8XXXU=m
###CONFIG_RTL8XXXU_UNTESTED=y
###CONFIG_RSI_91X=m
###CONFIG_CW1200=m
###CONFIG_CW1200_WLAN_SDIO=m
###CONFIG_WL1251=m
###CONFIG_WL1251_SDIO=m
###CONFIG_WL12XX=m
###CONFIG_WL18XX=m
###CONFIG_WLCORE_SDIO=m
###CONFIG_USB_ZD1201=m
###CONFIG_ZD1211RW=m
###CONFIG_BCMDHD=m
###CONFIG_BCMDHD_SDIO=y
###CONFIG_BCMDHD_PCIE=y
###CONFIG_BCM4354=y
###CONFIG_BCMDHD_FW_PATH="/lib/firmware/brcm/fw_bcmdhd.bin"
###CONFIG_BCMDHD_NVRAM_PATH="/lib/firmware/brcm/nvram.txt"
###CONFIG_BCMDHD_HW_OOB=y
###CONFIG_DHD_USE_SCHED_SCAN=y
###CONFIG_BCMDHD_DISABLE_MCC=y
###CONFIG_BCMDHD_PCIE_FW_PATH="/lib/firmware/brcm/fw_bcmdhd_4356.bin"
###CONFIG_BCMDHD_PCIE_NVRAM_PATH="/lib/firmware/brcm/nvram_4356.txt"
###CONFIG_BCMDHD_PCIE_ES4_NVRAM_PATH="/lib/firmware/brcm/nvram_murata_4359_b1_es4.txt"
###CONFIG_RTL8812AU=m
###CONFIG_RTL8814AU=m
###CONFIG_RTL8821AU=m
###CONFIG_RTL8821CU=m
###CONFIG_RTL8822BU=m
###CONFIG_RTL8822CE=m
CONFIG_INPUT_JOYDEV=y
CONFIG_INPUT_EVDEV=y
CONFIG_INPUT_KEYRESET=y
#CONFIG_KEYBOARD_ADP5588=m
#CONFIG_KEYBOARD_ADP5589=m
#CONFIG_KEYBOARD_ATKBD=m
#CONFIG_KEYBOARD_QT1070=m
#CONFIG_KEYBOARD_QT2160=m
#CONFIG_KEYBOARD_LKKBD=m
CONFIG_KEYBOARD_GPIO=y
#CONFIG_KEYBOARD_GPIO_POLLED=m
#CONFIG_KEYBOARD_TCA6416=m
#CONFIG_KEYBOARD_TCA8418=m
#CONFIG_KEYBOARD_MATRIX=m
#CONFIG_KEYBOARD_LM8323=m
#CONFIG_KEYBOARD_LM8333=m
#CONFIG_KEYBOARD_MAX7359=m
#CONFIG_KEYBOARD_MCS=m
#CONFIG_KEYBOARD_MPR121=m
#CONFIG_KEYBOARD_NEWTON=m
#CONFIG_KEYBOARD_TEGRA=m
#CONFIG_KEYBOARD_OPENCORES=m
#CONFIG_KEYBOARD_SAMSUNG=m
#CONFIG_KEYBOARD_STOWAWAY=m
#CONFIG_KEYBOARD_OMAP4=m
#CONFIG_KEYBOARD_XTKBD=m
#CONFIG_KEYBOARD_CAP11XX=m
#CONFIG_KEYBOARD_BCM=m
# CONFIG_MOUSE_PS2 is not set
#CONFIG_MOUSE_SERIAL=m
#CONFIG_MOUSE_APPLETOUCH=m
#CONFIG_MOUSE_BCM5974=m
#CONFIG_MOUSE_CYAPA=m
#CONFIG_MOUSE_VSXXXAA=m
#CONFIG_MOUSE_GPIO=m
#CONFIG_MOUSE_SYNAPTICS_I2C=m
#CONFIG_MOUSE_SYNAPTICS_USB=m
#CONFIG_INPUT_JOYSTICK=y
#CONFIG_JOYSTICK_XPAD=y
#CONFIG_INPUT_TABLET=y
#CONFIG_INPUT_TOUCHSCREEN=y
CONFIG_INPUT_MISC=y
CONFIG_INPUT_KEYCHORD=y
CONFIG_INPUT_UINPUT=y
CONFIG_INPUT_GPIO=y
# CONFIG_SERIO_SERPORT is not set
CONFIG_SERIO_AMBAKMI=y
CONFIG_LEGACY_PTY_COUNT=16
CONFIG_SERIAL_8250=y
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_DW=y
CONFIG_SERIAL_OF_PLATFORM=y
CONFIG_SERIAL_AMBA_PL011=y
CONFIG_SERIAL_AMBA_PL011_CONSOLE=y
CONFIG_SERIAL_TEGRA=y
CONFIG_TEGRA_COMBINED_UART=y
CONFIG_VIRTIO_CONSOLE=y
CONFIG_I2C_CHARDEV=y
CONFIG_I2C_MUX=y
CONFIG_I2C_MUX_GPIO=y
CONFIG_I2C_MUX_PCA954x=y
#CONFIG_I2C_ALI1535=m
#CONFIG_I2C_ALI1563=m
#CONFIG_I2C_ALI15X3=m
#CONFIG_I2C_AMD756=m
#CONFIG_I2C_AMD8111=m
#CONFIG_I2C_I801=m
#CONFIG_I2C_ISCH=m
#CONFIG_I2C_PIIX4=m
#CONFIG_I2C_NFORCE2=m
#CONFIG_I2C_SIS630=m
#CONFIG_I2C_VIAPRO=m
#CONFIG_I2C_CADENCE=m
#CONFIG_I2C_CBUS_GPIO=m
#CONFIG_I2C_DESIGNWARE_PLATFORM=m
#CONFIG_I2C_DESIGNWARE_PCI=m
#CONFIG_I2C_EMEV2=m
#CONFIG_I2C_GPIO=m
#CONFIG_I2C_NOMADIK=m
#CONFIG_I2C_OCORES=m
#CONFIG_I2C_PCA_PLATFORM=m
#CONFIG_I2C_RK3X=m
#CONFIG_I2C_SIMTEC=m
CONFIG_I2C_TEGRA=y
#CONFIG_I2C_TEGRA_SLAVE=m
#CONFIG_I2C_DIOLAN_U2C=m
CONFIG_I2C_TEGRA_CAMRTC=y
#CONFIG_I2C_TEGRA194_SLAVE=m
#CONFIG_I2C_STUB=m
#CONFIG_I2C_SLAVE_EEPROM=m
CONFIG_SPI=y
#CONFIG_SPI_CADENCE=m
#CONFIG_SPI_PXA2XX=m
#CONFIG_SPI_SC18IS602=m
CONFIG_SPI_TEGRA114=y
CONFIG_SPI_TEGRA124_SLAVE=y
CONFIG_QSPI_TEGRA210=y
#CONFIG_SPI_XCOMM=m
#CONFIG_SPI_ZYNQMP_GQSPI=m
#CONFIG_SPI_SPIDEV=m
#CONFIG_SPI_TLE62X0=m
CONFIG_SPMI=y
CONFIG_PINCTRL_SINGLE=y
CONFIG_PINCTRL_MAX77620=y
CONFIG_PINCTRL_TEGRA186_DPAUX=y
CONFIG_PINCTRL_TEGRA194_PEXCLK_PADCTL=y
CONFIG_GPIO_PCA953X=y
CONFIG_GPIO_PCA953X_IRQ=y
CONFIG_GPIO_MAX77620=y
CONFIG_GPIO_TMPM32X_I2C=y
CONFIG_PADCTRL=y
CONFIG_PADCTRL_GENERIC_TEGRA_IO_PAD=y
CONFIG_POWER_OFF_MAX77620=y
CONFIG_POWER_OFF_TMPM32X_I2C=y
CONFIG_BATTERY_BQ27XXX=y
CONFIG_GPIO_TACHOMETER=y
CONFIG_GENERIC_PWM_TACHOMETER=y
CONFIG_PPS=y
#CONFIG_PPS_DEBUG=y
CONFIG_PPS_CLIENT_GPIO=y
CONFIG_THERMAL=y
CONFIG_THERMAL_WRITABLE_TRIPS=y
CONFIG_THERMAL_GOV_POWER_ALLOCATOR=y
CONFIG_THERMAL_EMULATION=y
CONFIG_MAX77620_THERMAL=y
CONFIG_TEGRA_SOCTHERM=y
CONFIG_TEGRA_AOTAG=y
CONFIG_TEGRA_CORE_CAPS=y
CONFIG_TEGRA_DFLL_CAPS=y
CONFIG_PWM_FAN=y
CONFIG_THERMAL_GOV_PID=y
CONFIG_THERMAL_GOV_CONTINUOUS=y
CONFIG_TEGRA_THERMAL_THROTTLE=y
#CONFIG_USERSPACE_THERM_ALERT=m
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_NOWAYOUT=y
CONFIG_MAX77620_WATCHDOG=y
CONFIG_TEGRA21X_WATCHDOG=y
CONFIG_TEGRA18X_WATCHDOG=y
CONFIG_SOFT_PLATFORM_WATCHDOG=y
CONFIG_MFD_MAX77620=y
CONFIG_REGULATOR=y
CONFIG_REGULATOR_FIXED_VOLTAGE=y
CONFIG_REGULATOR_GPIO=y
CONFIG_REGULATOR_MAX77620=y
CONFIG_REGULATOR_PWM=y
CONFIG_REGULATOR_TPS65132=y
CONFIG_REGULATOR_PMIC_OTP=y
CONFIG_MEDIA_SUPPORT=y
CONFIG_MEDIA_CAMERA_SUPPORT=y
CONFIG_MEDIA_CONTROLLER=y
CONFIG_VIDEO_V4L2_SUBDEV_API=y
CONFIG_MEDIA_USB_SUPPORT=y
#CONFIG_USB_VIDEO_CLASS=m
#CONFIG_USB_M5602=m
#CONFIG_USB_STV06XX=m
#CONFIG_USB_GL860=m
#CONFIG_USB_GSPCA_BENQ=m
#CONFIG_USB_GSPCA_CONEX=m
#CONFIG_USB_GSPCA_CPIA1=m
#CONFIG_USB_GSPCA_DTCS033=m
#CONFIG_USB_GSPCA_ETOMS=m
#CONFIG_USB_GSPCA_FINEPIX=m
#CONFIG_USB_GSPCA_JEILINJ=m
#CONFIG_USB_GSPCA_JL2005BCD=m
#CONFIG_USB_GSPCA_KINECT=m
#CONFIG_USB_GSPCA_KONICA=m
#CONFIG_USB_GSPCA_MARS=m
#CONFIG_USB_GSPCA_MR97310A=m
#CONFIG_USB_GSPCA_NW80X=m
#CONFIG_USB_GSPCA_OV519=m
#CONFIG_USB_GSPCA_OV534=m
#CONFIG_USB_GSPCA_OV534_9=m
#CONFIG_USB_GSPCA_PAC207=m
#CONFIG_USB_GSPCA_PAC7302=m
#CONFIG_USB_GSPCA_PAC7311=m
#CONFIG_USB_GSPCA_SE401=m
#CONFIG_USB_GSPCA_SN9C2028=m
#CONFIG_USB_GSPCA_SN9C20X=m
#CONFIG_USB_GSPCA_SONIXB=m
#CONFIG_USB_GSPCA_SONIXJ=m
#CONFIG_USB_GSPCA_SPCA500=m
#CONFIG_USB_GSPCA_SPCA501=m
#CONFIG_USB_GSPCA_SPCA505=m
#CONFIG_USB_GSPCA_SPCA506=m
#CONFIG_USB_GSPCA_SPCA508=m
#CONFIG_USB_GSPCA_SPCA561=m
#CONFIG_USB_GSPCA_SPCA1528=m
#CONFIG_USB_GSPCA_SQ905=m
#CONFIG_USB_GSPCA_SQ905C=m
#CONFIG_USB_GSPCA_SQ930X=m
#CONFIG_USB_GSPCA_STK014=m
#CONFIG_USB_GSPCA_STK1135=m
#CONFIG_USB_GSPCA_STV0680=m
#CONFIG_USB_GSPCA_SUNPLUS=m
#CONFIG_USB_GSPCA_T613=m
#CONFIG_USB_GSPCA_TOPRO=m
#CONFIG_USB_GSPCA_TOUPTEK=m
#CONFIG_USB_GSPCA_TV8532=m
#CONFIG_USB_GSPCA_VC032X=m
#CONFIG_USB_GSPCA_VICAM=m
#CONFIG_USB_GSPCA_XIRLINK_CIT=m
#CONFIG_USB_GSPCA_ZC3XX=m
#CONFIG_USB_PWC=m
#CONFIG_VIDEO_CPIA2=m
#CONFIG_USB_ZR364XX=m
#CONFIG_USB_STKWEBCAM=m
#CONFIG_USB_S2255=m
#CONFIG_VIDEO_USBTV=m
CONFIG_V4L_PLATFORM_DRIVERS=y
CONFIG_V4L_TEST_DRIVERS=y
#CONFIG_VIDEO_VIVID=y
CONFIG_VIDEO_CAMERA=y
CONFIG_VIDEO_TEGRA_VIVID=y
# CONFIG_MEDIA_SUBDRV_AUTOSELECT is not set
#CONFIG_VIDEO_IMX185=m
CONFIG_VIDEO_IMX219=y
CONFIG_VIDEO_IMX477=y
CONFIG_VIDEO_IMX268=y
#CONFIG_VIDEO_IMX274=m
CONFIG_VIDEO_IMX318=y
CONFIG_VIDEO_LC898212=y
#CONFIG_VIDEO_OV5693=m
CONFIG_VIDEO_OV9281=y
CONFIG_VIDEO_OV10823=y
CONFIG_VIDEO_OV23850=y
CONFIG_I2C_IOEXPANDER_PCA9570=y
#CONFIG_VIDEO_TC358840=m
CONFIG_VIDEO_LT6911UXC=y
CONFIG_I2C_IOEXPANDER_SER_MAX9295=y
CONFIG_I2C_IOEXPANDER_DESER_MAX9296=y
CONFIG_VIDEO_IMX390=y
CONFIG_VIDEO_IMX204=y
# CONFIG_VGA_ARB is not set
CONFIG_DRM=y
#CONFIG_DRM_TEGRA_UDRM=m
CONFIG_FB_MODE_PIXCLOCK_HZ=y
#CONFIG_BACKLIGHT_GENERIC=m
CONFIG_BACKLIGHT_PWM=y
CONFIG_BACKLIGHT_LP855X=y
CONFIG_TEGRA_DC=y
CONFIG_TEGRA_GRHOST=y
CONFIG_TEGRA_DSI=y
CONFIG_TEGRA_EDP2LVDS_PS8625=y
CONFIG_TEGRA_HDMI2_0=y
CONFIG_TEGRA_HDMIHDCP=y
CONFIG_TEGRA_DPHDCP=y
CONFIG_TEGRA_CEC_SUPPORT=y
CONFIG_NVMAP_CACHE_MAINT_BY_SET_WAYS=y
CONFIG_FRAMEBUFFER_CONSOLE=y
CONFIG_LOGO=y
CONFIG_SOUND=y
CONFIG_SND=y
CONFIG_SND_DMAENGINE_PCM=y
#CONFIG_SND_ALOOP=m
#CONFIG_SND_AD1889=m
#CONFIG_SND_ATIIXP=m
#CONFIG_SND_ATIIXP_MODEM=m
#CONFIG_SND_AU8810=m
#CONFIG_SND_EMU10K1X=m
#CONFIG_SND_INTEL8X0=m
#CONFIG_SND_INTEL8X0M=m
#CONFIG_SND_MIXART=m
#CONFIG_SND_NM256=m
#CONFIG_SND_TRIDENT=m
#CONFIG_SND_VIRTUOSO=m
#CONFIG_SND_YMFPCI=m
#CONFIG_SND_HDA_INTEL=m
CONFIG_SND_HDA_CODEC_HDMI=y
CONFIG_SND_HDA_POWER_SAVE_DEFAULT=1
CONFIG_SND_HDA_TEGRA=y
CONFIG_SND_USB_AUDIO=y
CONFIG_SND_SOC=y
CONFIG_SND_SOC_TAS2552=y
CONFIG_SND_SIMPLE_CARD=y
CONFIG_SND_SOC_TEGRA_T186REF_P4573_ALT=y
CONFIG_SND_SOC_TEGRA_ALT=y
CONFIG_DISABLE_ADSP_AUDIO=y
CONFIG_SND_SOC_TEGRA210_AUDIO_ALT=y
CONFIG_SND_SOC_TEGRA_T186REF_ALT=y
CONFIG_HIDRAW=y
CONFIG_UHID=y
#CONFIG_HID_ACRUX=y
#CONFIG_HID_ACRUX_FF=y
#CONFIG_HID_APPLE=y
#CONFIG_HID_APPLEIR=m
#CONFIG_HID_AUREAL=m
#CONFIG_HID_BELKIN=m
#CONFIG_HID_BETOP_FF=m
#CONFIG_HID_CHERRY=m
#CONFIG_HID_CHICONY=m
#CONFIG_HID_CORSAIR=m
#CONFIG_HID_PRODIKEYS=y
#CONFIG_HID_CMEDIA=m
#CONFIG_HID_CP2112=m
#CONFIG_HID_CYPRESS=m
#ONFIG_HID_DRAGONRISE=y
#ONFIG_DRAGONRISE_FF=y
#ONFIG_HID_EMS_FF=y
#ONFIG_HID_ELECOM=y
#ONFIG_HID_ELO=m
#ONFIG_HID_EZKEY=m
#ONFIG_HID_GEMBIRD=m
#ONFIG_HID_GFRM=m
#ONFIG_HID_HOLTEK=y
#ONFIG_HID_GT683R=m
#ONFIG_HID_KEYTOUCH=y
#ONFIG_HID_KYE=y
#ONFIG_HID_UCLOGIC=y
#ONFIG_HID_WALTOP=y
#ONFIG_HID_GYRATION=y
#ONFIG_HID_ICADE=m
#ONFIG_HID_TWINHAN=y
#ONFIG_HID_KENSINGTON=m
#ONFIG_HID_LCPOWER=y
#ONFIG_HID_LENOVO=m
#ONFIG_HID_LOGITECH=m
#ONFIG_HID_LOGITECH_DJ=m
#ONFIG_HID_MAGICMOUSE=y
#ONFIG_HID_MICROSOFT=m
#ONFIG_HID_MONTEREY=m
#ONFIG_HID_MULTITOUCH=y
#ONFIG_HID_NTRIG=y
#ONFIG_HID_ORTEK=y
#ONFIG_HID_PANTHERLORD=y
#ONFIG_PANTHERLORD_FF=y
#ONFIG_HID_PENMOUNT=m
#ONFIG_HID_PETALYNX=y
#ONFIG_HID_PICOLCD=y
#ONFIG_HID_PICOLCD_FB=y
#ONFIG_HID_PICOLCD_BACKLIGHT=y
#ONFIG_HID_PLANTRONICS=m
#ONFIG_HID_PRIMAX=y
#ONFIG_HID_ROCCAT=y
#ONFIG_HID_SAITEK=y
#ONFIG_HID_SAMSUNG=y
#ONFIG_HID_SONY=y
#ONFIG_HID_SPEEDLINK=y
#ONFIG_HID_STEELSERIES=m
#ONFIG_HID_SUNPLUS=y
#ONFIG_HID_RMI=m
#ONFIG_HID_GREENASIA=y
#ONFIG_GREENASIA_FF=y
#ONFIG_HID_SMARTJOYPLUS=y
#ONFIG_SMARTJOYPLUS_FF=y
#ONFIG_HID_TIVO=y
#ONFIG_HID_TOPSEED=y
#ONFIG_HID_THINGM=m
#ONFIG_HID_THRUSTMASTER=y
#ONFIG_HID_WACOM=y
#ONFIG_HID_WIIMOTE=y
#ONFIG_HID_XINMO=m
#ONFIG_HID_ZEROPLUS=y
#ONFIG_HID_ZYDACRON=y
#ONFIG_HID_SENSOR_HUB=m
#ONFIG_HID_SENSOR_CUSTOM_SENSOR=m
#ONFIG_HID_SENSOR_ACCEL_3D=m
#ONFIG_HID_SENSOR_GYRO_3D=m
#ONFIG_HID_ALPS=m
#ONFIG_HID_NVIDIA_STAND=m
#ONFIG_HID_SHIELD_REMOTE=m
CONFIG_USB_ANNOUNCE_NEW_DEVICES=y
CONFIG_USB_OTG=y
#CONFIG_USB_MON=m
CONFIG_USB_XHCI_HCD=y
CONFIG_USB_XHCI_PLATFORM=y
CONFIG_USB_XHCI_TEGRA=y
CONFIG_USB_EHCI_HCD=y
CONFIG_USB_OHCI_HCD=y
CONFIG_USB_OHCI_HCD_PLATFORM=y
#CONFIG_USB_ACM=m
#CONFIG_USB_PRINTER=m
#CONFIG_USB_WDM=m
CONFIG_USB_STORAGE=y
#CONFIG_USB_STORAGE_REALTEK=m
#CONFIG_USB_STORAGE_DATAFAB=m
#CONFIG_USB_STORAGE_FREECOM=m
#CONFIG_USB_STORAGE_ISD200=m
#CONFIG_USB_STORAGE_USBAT=m
#CONFIG_USB_STORAGE_SDDR09=m
#CONFIG_USB_STORAGE_SDDR55=m
#CONFIG_USB_STORAGE_JUMPSHOT=m
#CONFIG_USB_STORAGE_ALAUDA=m
#CONFIG_USB_STORAGE_ONETOUCH=m
#CONFIG_USB_STORAGE_KARMA=m
#CONFIG_USB_STORAGE_CYPRESS_ATACB=m
#CONFIG_USB_STORAGE_ENE_UB6250=m
CONFIG_USB_UAS=y
#CONFIG_USB_MDC800=m
#CONFIG_USB_MICROTEK=m
#CONFIG_USB_CHIPIDEA=y
#CONFIG_USB_CHIPIDEA_UDC=y
#CONFIG_USB_ISP1760=y
#CONFIG_USB_SERIAL=y
#CONFIG_USB_SERIAL_CH341=m
#CONFIG_USB_SERIAL_CP210X=m
#CONFIG_USB_SERIAL_FTDI_SIO=m
#CONFIG_USB_SERIAL_PL2303=m
#CONFIG_USB_SERIAL_OPTION=m
#CONFIG_USB_EMI62=m
#CONFIG_USB_EMI26=m
#CONFIG_USB_SEVSEG=m
#CONFIG_USB_RIO500=m
#CONFIG_USB_LCD=m
#CONFIG_USB_CYPRESS_CY7C63=m
#CONFIG_USB_CYTHERM=m
#CONFIG_USB_IDMOUSE=m
#CONFIG_USB_APPLEDISPLAY=m
#CONFIG_USB_LD=m
#CONFIG_USB_TEST=m
#CONFIG_USB_YUREX=m
CONFIG_USB_HSIC_USB3503=y
CONFIG_USB_ULPI=y
CONFIG_USB_GADGET=y
CONFIG_USB_TEGRA_XUDC=y
CONFIG_USB_TEGRA_CD=y
CONFIG_USB_CONFIGFS=y
CONFIG_USB_CONFIGFS_ACM=y
CONFIG_USB_CONFIGFS_NCM=y
CONFIG_USB_CONFIGFS_ECM=y
CONFIG_USB_CONFIGFS_RNDIS=y
CONFIG_USB_CONFIGFS_MASS_STORAGE=y
CONFIG_USB_CONFIGFS_F_FS=y
CONFIG_USB_CONFIGFS_F_MTP=y
CONFIG_USB_CONFIGFS_F_PTP=y
CONFIG_USB_CONFIGFS_F_ACC=y
CONFIG_USB_CONFIGFS_F_AUDIO_SRC=y
CONFIG_USB_CONFIGFS_UEVENT=y
CONFIG_USB_CONFIGFS_F_UAC1=y
CONFIG_USB_CONFIGFS_F_UAC2=y
CONFIG_USB_CONFIGFS_F_UVC=y
CONFIG_TYPEC_UCSI=y
CONFIG_UCSI_CCG=y
#CONFIG_USB_ULPI_BUS=m
CONFIG_MMC=y
CONFIG_MMC_BLOCK_MINORS=32
CONFIG_MMC_TEST=y
CONFIG_MMC_ARMMMCI=y
CONFIG_MMC_SDHCI=y
CONFIG_MMC_SDHCI_PLTFM=y
CONFIG_MMC_SDHCI_TEGRA=y
#CONFIG_INFINIBAND=m
#CONFIG_INFINIBAND_USER_MAD=y
#CONFIG_INFINIBAND_USER_ACCESS=y
#CONFIG_INFINIBAND_USER_MEM=y
#CONFIG_INFINIBAND_ON_DEMAND_PAGING=y
#CONFIG_INFINIBAND_ADDR_TRANS=y
#CONFIG_INFINIBAND_ADDR_TRANS_CONFIGFS=y
#CONFIG_INFINIBAND_MTHCA=m
#CONFIG_INFINIBAND_MTHCA_DEBUG=y
#CONFIG_MLX4_INFINIBAND=m
#CONFIG_MLX5_INFINIBAND=m
#CONFIG_INFINIBAND_IPOIB=m
#CONFIG_INFINIBAND_IPOIB_CM=y
#CONFIG_INFINIBAND_IPOIB_DEBUG=y
#CONFIG_INFINIBAND_SRP=m
#CONFIG_INFINIBAND_RDMAVT=m
#CONFIG_RDMA_RXE=m
#CONFIG_INFINIBAND_HFI1=m
#CONFIG_MMC_TIFM_SD=m
#CONFIG_MMC_SPI=m
#CONFIG_MMC_CB710=m
#CONFIG_MMC_VIA_SDMMC=m
#CONFIG_MMC_VUB300=m
#CONFIG_MMC_USHC=m
#CONFIG_MMC_USDHI6ROL0=m
#CONFIG_MMC_TOSHIBA_PCI=m
#CONFIG_MMC_MTK=m
CONFIG_MMC_CQ_HCI=y
CONFIG_LEDS_GPIO=y
CONFIG_LEDS_THINE350X=y
CONFIG_LEDS_PWM=y
#CONFIG_LEDS_BD2802=m
CONFIG_LEDS_TRIGGER_THROTTLE=y
CONFIG_SWITCH=y
CONFIG_RTC_CLASS=y
CONFIG_RTC_HCTOSYS_DEVICE="rtc1"
CONFIG_RTC_BACKUP_HCTOSYS_DEVICE="rtc0"
CONFIG_RTC_DRV_MAX77686=y
CONFIG_RTC_DRV_RX8025=y
CONFIG_DMADEVICES=y
CONFIG_TEGRA20_APB_DMA=y
CONFIG_TEGRA210_ADMA=y
CONFIG_DMATEST=y
CONFIG_TEGRA186_GPC_DMA=y
CONFIG_VFIO=y
CONFIG_VFIO_PCI=y
CONFIG_VIRT_DRIVERS=y
CONFIG_VIRTIO_PCI=y
CONFIG_VIRTIO_BALLOON=y
CONFIG_VIRTIO_MMIO=y
#CONFIG_PRISM2_USB=m
#CONFIG_RTL8192U=m
#CONFIG_RTLLIB=m
#CONFIG_RTL8192E=m
#CONFIG_R8712U=m
#CONFIG_R8188EU=m
CONFIG_INA219=y
CONFIG_INA230=y
CONFIG_INA3221=y
CONFIG_STEPPER=y
CONFIG_STEPPER_PCA=y
CONFIG_DENVER_CPU=y
CONFIG_TEGRA_AON=y
CONFIG_TEGRA_18X_SERROR=y
CONFIG_TEGRA_BWMGR=y
CONFIG_TEGRA_CAMERA_RTCPU=y
CONFIG_TEGRA_ISOMGR=y
CONFIG_TEGRA_CENTRAL_ACTMON=y
###CONFIG_TEGRA_NVADSP=m
###CONFIG_TEGRA_NVADSP_ON_SMMU=y
CONFIG_TEGRA_ADSP_DFS=y
CONFIG_COMMON_CLK_MAX77686=y
# CONFIG_COMMON_CLK_XGENE is not set
CONFIG_COMMON_CLK_FREQ_STATS_ACCOUNTING=y
CONFIG_ARM_ARCH_TIMER_VCT_ACCESS=y
CONFIG_ARM_TIMER_SP804=y
CONFIG_CLK_SRC_TEGRA18_TIMER=y
CONFIG_MAILBOX=y
CONFIG_ARM_MHU=y
CONFIG_BCM_PDC_MBOX=y
CONFIG_TEGRA_IOMMU_SMMU=y
CONFIG_ARM_SMMU=y
CONFIG_TEGRA_ARM_SMMU_T19x=y
CONFIG_ARM_SMMU_SUSPEND=y
CONFIG_ARCH_TEGRA_210_SOC=y
CONFIG_TEGRA_210_DVFS=y
CONFIG_TEGRA_KFUSE=y
CONFIG_DEVFREQ_GOV_PERFORMANCE=y
CONFIG_DEVFREQ_GOV_USERSPACE=y
CONFIG_DEVFREQ_GOV_POD_SCALING=y
CONFIG_DEVFREQ_GOV_WMARK_SIMPLE=y
CONFIG_DEVFREQ_GOV_WMARK_ACTIVE=y
CONFIG_EXTCON_GPIO=y
CONFIG_EXTCON_USB_GPIO=y
CONFIG_MEMORY=y
CONFIG_IIO=y
CONFIG_IIO_BUFFER=y
CONFIG_IIO_KFIFO_BUF=y
CONFIG_IIO_TRIGGER=y
CONFIG_PWM=y
CONFIG_PWM_TEGRA=y
CONFIG_PWM_TEGRA_TACHOMETER=y
CONFIG_PWM_TEGRA_PMC_BLINK=y
CONFIG_PWM_TEGRA_DFLL=y
CONFIG_PHY_TEGRA_XUSB=y
CONFIG_TEGRA_P2U=y
#CONFIG_RTK_BTUSB=m
CONFIG_NVPMODEL_EMC=y
#CONFIG_TRUSTY=y
###CONFIG_GK20A=m
###CONFIG_GK20A_PMU=y
###CONFIG_GK20A_DEVFREQ=y
###CONFIG_GK20A_RDMA=y
CONFIG_TEGRA_ACR=y
CONFIG_TEGRA_USE_NA_GPCPLL=y
CONFIG_GK20A_VIDMEM=y
CONFIG_ARM_SCPI_PROTOCOL=y
CONFIG_NV_TEGRA_BPMP=y
CONFIG_EXT3_FS=y
CONFIG_EXT4_FS_POSIX_ACL=y
CONFIG_EXT4_FS_SECURITY=y
###CONFIG_BTRFS_FS=m
###CONFIG_BTRFS_FS_POSIX_ACL=y
CONFIG_FANOTIFY=y
CONFIG_FANOTIFY_ACCESS_PERMISSIONS=y
CONFIG_QUOTA=y
CONFIG_QUOTA_TREE=y
# CONFIG_QFMT_V1 is not set
CONFIG_QFMT_V2=y
CONFIG_QUOTACTL=y
CONFIG_AUTOFS4_FS=y
#CONFIG_FUSE_FS=m
#CONFIG_CUSE=m
#CONFIG_OVERLAY_FS=m
CONFIG_VFAT_FS=y
CONFIG_NTFS_FS=y
CONFIG_NTFS_RW=y
CONFIG_TMPFS=y
CONFIG_TMPFS_POSIX_ACL=y
CONFIG_HUGETLBFS=y
CONFIG_SQUASHFS=y
CONFIG_SQUASHFS_XZ=y
CONFIG_PSTORE=y
CONFIG_PSTORE_CONSOLE=y
CONFIG_PSTORE_RAM=y
CONFIG_NFS_FS=y
CONFIG_ROOT_NFS=y
#CONFIG_NFSD=m
#CONFIG_NFSD_V3=y
#CONFIG_NFSD_V3_ACL=y
#CONFIG_CIFS=m
#CONFIG_9P_FS=y
CONFIG_NLS_CODEPAGE_437=y
CONFIG_NLS_ISO8859_1=y
CONFIG_VIRTUALIZATION=y
CONFIG_PRINTK_TIME=y
#CONFIG_DYNAMIC_DEBUG=y
#CONFIG_DEBUG_INFO=y
#CONFIG_DEBUG_SECTION_MISMATCH=y
# CONFIG_SECTION_MISMATCH_WARN_ONLY is not set
CONFIG_MAGIC_SYSRQ=y
#CONFIG_DEBUG_KMEMLEAK=y
#CONFIG_DEBUG_KMEMLEAK_EARLY_LOG_SIZE=8000
#CONFIG_DEBUG_KMEMLEAK_DEFAULT_OFF=y
#CONFIG_DEBUG_VM=y
CONFIG_LOCKUP_DETECTOR=y
CONFIG_BOOTPARAM_HARDLOCKUP_PANIC=y
CONFIG_BOOTPARAM_SOFTLOCKUP_PANIC=y
# CONFIG_BOOTPARAM_HUNG_TASK_PANIC is not set
CONFIG_WQ_WATCHDOG=y
CONFIG_PANIC_TIMEOUT=5
# CONFIG_SCHED_DEBUG is not set
CONFIG_SCHEDSTATS=y
CONFIG_TIMER_STATS=y
# CONFIG_DEBUG_PREEMPT is not set
CONFIG_FAULT_INJECTION=y
CONFIG_FUNCTION_TRACER=y
# CONFIG_FUNCTION_GRAPH_TRACER is not set
CONFIG_MEMTEST=y
# CONFIG_DEBUG_SET_MODULE_RONX is not set
#CONFIG_SECURITY_PERF_EVENTS_RESTRICT=y
#CONFIG_SECURITY=y
#CONFIG_SECURITY_NETWORK=y
CONFIG_HARDENED_USERCOPY=y
CONFIG_CRYPTO_DH=y
CONFIG_CRYPTO_TEST=m
CONFIG_CRYPTO_CCM=y
CONFIG_CRYPTO_GCM=y
CONFIG_CRYPTO_ECHAINIV=y
CONFIG_CRYPTO_TWOFISH=y
CONFIG_CRYPTO_ANSI_CPRNG=y
CONFIG_TEGRA_CRYPTO_DEV=y
CONFIG_CRYPTO_DEV_TEGRA_SE=y
CONFIG_CRYPTO_DEV_TEGRA_ELLIPTIC_SE=y
CONFIG_CRYPTO_DEV_TEGRA_SE_USE_HOST1X_INTERFACE=y
CONFIG_ARM64_CRYPTO=y
CONFIG_CRYPTO_SHA1_ARM64_CE=y
CONFIG_CRYPTO_SHA2_ARM64_CE=y
CONFIG_CRYPTO_GHASH_ARM64_CE=y
CONFIG_CRYPTO_AES_ARM64_CE_CCM=y
CONFIG_CRYPTO_AES_ARM64_CE_BLK=y
CONFIG_CRYPTO_AES_ARM64_NEON_BLK=y
CONFIG_IRQ_POLL=y
CONFIG_ARCH_TEGRA_18x_SOC=y
#CONFIG_ARCH_TEGRA_19x_SOC=y
CONFIG_ARCH_TEGRA_23x_SOC=y
CONFIG_TEGRA_SAFETY=y
CONFIG_VIDEO_LETIM=y
CONFIG_EEPROM_AT24=y
CONFIG_DEBUG_FS=n
CONFIG_DEBUG_KERNEL=n
CONFIG_HAVE_DEBUG_KMEMLEAK=n
CONFIG_HAVE_DEBUG_BUGVERBOSE=n
CONFIG_DEBUG_BUGVERBOSE=n
CONFIG_DEBUG_RODATA=n
CONFIG_SLUB_DEBUG=n
CONFIG_HAVE_DMA_API_DEBUG=n
CONFIG_SCSI_MVSAS_DEBUG=n
CONFIG_TEGRA_CLK_DEBUG=n
CONFIG_BPMP_DEBUGFS_MOUNT_ON_BOOT=n
Why everytime when I try to apply it every configs that I don’t want appears in .config with =y?
I don’t need this options:
CONFIG_DEBUG_FS=n
CONFIG_SLUB_DEBUG=n
But they everytime appears in the .config and CONFIG_DEBUG_FS=y then breaking my building…
How I understood - it is the problem with autoconf.h - I tried to remove this lines from autoconf.h too but it regenerating it and yields in .config then
The problem is not only in autoconf.h and auto.conf - I din’t understand why and when but my .config fully rewriting on each make and I cannot do anything. I tried to rewrite scripts that generating auto.conf and autoconf.h, I tried to export KCONFIG_CONFIG and nothing helped - everytime I try to recompile you kernel it totally ignoring every my efforts to remove some options and crushes my building. Please help me to understand where and why nvidia altered building system of the kernel and how can I remove this options?
I would suggest using tegra_defconfig to build the kernel image to confirm your setting first.
It is building nice - I checked it the first.
