Video4linux video0: vivid_parse_dt:cannot find vivid node after kernel optimization
Good afternoon, dear nVidia! Please, could you help me with problem that I obtained during the kernel config optimization. I built my own kernel and now I cannot understand why I lost /dev/video0 device. Boot info:
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.337-dirty (rvp@rvp-pc) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #19 SMP PREEMPT Tue Oct 24 17:54:53 MSK 2023
[    0.000000] Boot CPU: AArch64 Processor [411fd071]
[    0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[    0.000000] OF: fdt: - 80000000 ,  7ee00000
[    0.000000] OF: fdt: - 100000000 ,  7f200000
[    0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[    0.000000] bootconsole [uart8250] enabled
[    0.829931] tegradc tegradc.1: dpd enable lookup fail:-19
[    1.335671] Host read timeout at address 545c00c4
[    1.512482] video4linux video0: vivid_parse_dt:cannot find vivid node
[    1.519771] vivid: error -61 while loading driver
[    2.022472] cgroup: cgroup2: unknown option "nsdelegate"
[    3.026335] proc: unrecognized mount option "hidepid=invisible" or missing value
[    3.686492] proc: unrecognized mount option "hidepid=invisible" or missing value
Dmesg output:
[    1.507534] tegra-vivid-000: using multiplanar format API
[    1.511946] tegra-vivid-000: V4L2 capture device registered as video0
[    1.524505] tegra-vivid: probe of tegra-vivid.0 failed with error -61
My defconfig (I had to remove CONFIG_VIDEO_VIVID because it conflicted with CONFIG_TEGRA_VIVID):
CONFIG_LOCALVERSION_AUTO=y
CONFIG_SYSVIPC=y
CONFIG_POSIX_MQUEUE=y
CONFIG_AUDIT=y
CONFIG_NO_HZ=y
CONFIG_HIGH_RES_TIMERS=y
CONFIG_IRQ_TIME_ACCOUNTING=y
CONFIG_BSD_PROCESS_ACCT=y
CONFIG_BSD_PROCESS_ACCT_V3=y
CONFIG_TASKSTATS=y
CONFIG_TASK_DELAY_ACCT=y
CONFIG_TASK_XACCT=y
CONFIG_TASK_IO_ACCOUNTING=y
CONFIG_IKCONFIG=y
CONFIG_IKCONFIG_PROC=y
CONFIG_LOG_BUF_SHIFT=15
CONFIG_LOG_CPU_MAX_BUF_SHIFT=15
CONFIG_CGROUPS=y
#CONFIG_CGROUP_DEBUG=y
CONFIG_CGROUP_FREEZER=y
CONFIG_CGROUP_PIDS=y
CONFIG_CGROUP_DEVICE=y
CONFIG_CPUSETS=y
CONFIG_CGROUP_CPUACCT=y
CONFIG_MEMCG=y
CONFIG_MEMCG_SWAP=y
CONFIG_BLK_CGROUP=y
CONFIG_CGROUP_SCHED=y
CONFIG_CFS_BANDWIDTH=y
CONFIG_CGROUP_HUGETLB=y
CONFIG_CGROUP_PERF=y
CONFIG_NAMESPACES=y
CONFIG_USER_NS=y
CONFIG_BLK_DEV_INITRD=y
CONFIG_KALLSYMS_ALL=y
CONFIG_EMBEDDED=y
# CONFIG_COMPAT_BRK is not set
CONFIG_PROFILING=y
CONFIG_JUMP_LABEL=y
CONFIG_ARCH_MMAP_RND_COMPAT_BITS=16
CONFIG_MODULES=y
CONFIG_MODULE_UNLOAD=y
CONFIG_MODVERSIONS=y
CONFIG_BLK_DEV_THROTTLING=y
CONFIG_PARTITION_ADVANCED=y
# CONFIG_IOSCHED_DEADLINE is not set
CONFIG_ARCH_TEGRA=y
CONFIG_PCI=y
#CONFIG_PCIEPORTBUS=y
#CONFIG_PCIEASPM_POWERSAVE=y
##CONFIG_PCI_STUB=m
#CONFIG_PCI_IOV=y
CONFIG_PCIE_TEGRA=y
CONFIG_PCIE_DW_EP=y
#CONFIG_PCIE_TEGRA_EP=y
CONFIG_PCI_TEGRA=y
CONFIG_PCI_ENDPOINT=y
#CONFIG_PCI_ENDPOINT_CONFIGFS=y
#CONFIG_PCIE_EPF_NV_TEST=y
#CONFIG_PCIE_EPF_TEGRA_VNET=y
# CONFIG_ARM64_ERRATUM_843419 is not set
CONFIG_SCHED_MC=y
CONFIG_PREEMPT=y
###CONFIG_MEMORY_HOTPLUG=y
###CONFIG_MEMORY_HOTPLUG_DEFAULT_ONLINE=y
###CONFIG_MEMORY_HOTREMOVE=y
CONFIG_HMM_MIRROR=y
CONFIG_KSM=y
CONFIG_TRANSPARENT_HUGEPAGE=y
CONFIG_CMA=y
CONFIG_ZSMALLOC=y
CONFIG_ZONE_DEVICE=y
CONFIG_DEVICE_PRIVATE=y
CONFIG_SECCOMP=y
CONFIG_KEXEC=y
# CONFIG_UNMAP_KERNEL_AT_EL0 is not set
CONFIG_ARMV8_DEPRECATED=y
CONFIG_SWP_EMULATION=y
CONFIG_CP15_BARRIER_EMULATION=y
CONFIG_SETEND_EMULATION=y
CONFIG_ARM64_SW_TTBR0_PAN=y
# CONFIG_ARM64_HW_AFDBM is not set
CONFIG_ARM64_LSE_ATOMICS=y
# CONFIG_ARM64_VHE is not set
CONFIG_RANDOMIZE_BASE=y
# CONFIG_EFI is not set
# CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set
#CONFIG_BINFMT_MISC=m
CONFIG_COMPAT=y
#CONFIG_PM_DEBUG=y
#CONFIG_PM_ADVANCED_DEBUG=y
CONFIG_CPU_IDLE=y
CONFIG_ARM_CPUIDLE=y
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_STAT=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=y
CONFIG_CPU_FREQ_GOV_USERSPACE=y
CONFIG_CPU_FREQ_GOV_ONDEMAND=y
CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
CONFIG_CPU_FREQ_GOV_INTERACTIVE=y
CONFIG_CPU_FREQ_GOV_SCHEDUTIL=y
CONFIG_TASK_WEIGHT=y
CONFIG_NET=y
CONFIG_PACKET=y
CONFIG_UNIX=y
CONFIG_XFRM_USER=y
CONFIG_NET_KEY=y
CONFIG_INET=y
###CONFIG_IP_MULTICAST=y
###CONFIG_IP_ADVANCED_ROUTER=y
###CONFIG_IP_MULTIPLE_TABLES=y
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_IP_PNP_BOOTP=y
#CONFIG_INET_ESP=m
###CONFIG_IPV6_ROUTER_PREF=y
###CONFIG_IPV6_ROUTE_INFO=y
###CONFIG_IPV6_OPTIMISTIC_DAD=y
#CONFIG_INET6_AH=m
#CONFIG_INET6_ESP=m
#CONFIG_INET6_IPCOMP=m
#CONFIG_IPV6_MIP6=m
#CONFIG_INET6_XFRM_MODE_TRANSPORT=m
#CONFIG_INET6_XFRM_MODE_TUNNEL=m
#CONFIG_INET6_XFRM_MODE_BEET=m
#CONFIG_IPV6_SIT=m
#CONFIG_IPV6_TUNNEL=m
###CONFIG_IPV6_MULTIPLE_TABLES=y
# CONFIG_ANDROID_PARANOID_NETWORK is not set
###CONFIG_NETFILTER=y
#CONFIG_NETFILTER_NETLINK_ACCT=m
#CONFIG_NF_CONNTRACK=m
#CONFIG_NF_CONNTRACK_EVENTS=y
#CONFIG_NF_CT_PROTO_DCCP=m
#CONFIG_NF_CT_PROTO_SCTP=m
#CONFIG_NF_CT_PROTO_UDPLITE=m
#CONFIG_NF_CONNTRACK_AMANDA=m
#CONFIG_NF_CONNTRACK_FTP=m
#CONFIG_NF_CONNTRACK_H323=m
#CONFIG_NF_CONNTRACK_IRC=m
#CONFIG_NF_CONNTRACK_NETBIOS_NS=m
#CONFIG_NF_CONNTRACK_PPTP=m
#CONFIG_NF_CONNTRACK_SANE=m
#CONFIG_NF_CONNTRACK_SIP=m
#CONFIG_NF_CONNTRACK_TFTP=m
#CONFIG_NF_CT_NETLINK=m
#CONFIG_NETFILTER_XT_TARGET_CHECKSUM=m
#CONFIG_NETFILTER_XT_TARGET_CLASSIFY=m
#CONFIG_NETFILTER_XT_TARGET_CONNMARK=m
#CONFIG_NETFILTER_XT_TARGET_IDLETIMER=m
#CONFIG_NETFILTER_XT_TARGET_LOG=m
#CONFIG_NETFILTER_XT_TARGET_MARK=m
#CONFIG_NETFILTER_XT_TARGET_NFLOG=m
#CONFIG_NETFILTER_XT_TARGET_NFQUEUE=m
#CONFIG_NETFILTER_XT_TARGET_TPROXY=m
#CONFIG_NETFILTER_XT_TARGET_TRACE=m
#CONFIG_NETFILTER_XT_TARGET_TCPMSS=m
#CONFIG_NETFILTER_XT_MATCH_ADDRTYPE=m
#CONFIG_NETFILTER_XT_MATCH_COMMENT=m
#CONFIG_NETFILTER_XT_MATCH_CONNBYTES=m
#CONFIG_NETFILTER_XT_MATCH_CONNLIMIT=m
#CONFIG_NETFILTER_XT_MATCH_CONNMARK=m
#CONFIG_NETFILTER_XT_MATCH_CONNTRACK=m
#CONFIG_NETFILTER_XT_MATCH_HASHLIMIT=m
#CONFIG_NETFILTER_XT_MATCH_HELPER=m
#CONFIG_NETFILTER_XT_MATCH_IPRANGE=m
#CONFIG_NETFILTER_XT_MATCH_IPVS=m
#CONFIG_NETFILTER_XT_MATCH_LENGTH=m
#CONFIG_NETFILTER_XT_MATCH_LIMIT=m
#CONFIG_NETFILTER_XT_MATCH_MAC=m
#CONFIG_NETFILTER_XT_MATCH_MARK=m
#CONFIG_NETFILTER_XT_MATCH_MULTIPORT=m
#CONFIG_NETFILTER_XT_MATCH_OWNER=m
#CONFIG_NETFILTER_XT_MATCH_POLICY=m
#CONFIG_NETFILTER_XT_MATCH_PHYSDEV=m
#CONFIG_NETFILTER_XT_MATCH_PKTTYPE=m
#CONFIG_NETFILTER_XT_MATCH_QUOTA=m
#CONFIG_NETFILTER_XT_MATCH_QUOTA2=m
#CONFIG_NETFILTER_XT_MATCH_RECENT=m
#CONFIG_NETFILTER_XT_MATCH_SOCKET=m
#CONFIG_NETFILTER_XT_MATCH_STATE=m
#CONFIG_NETFILTER_XT_MATCH_STATISTIC=m
#CONFIG_NETFILTER_XT_MATCH_STRING=m
#CONFIG_NETFILTER_XT_MATCH_TIME=m
#CONFIG_NETFILTER_XT_MATCH_U32=m
#CONFIG_IP_VS=m
CONFIG_IP_VS_PROTO_TCP=y
CONFIG_IP_VS_PROTO_UDP=y
#CONFIG_IP_VS_RR=m
#CONFIG_IP_VS_NFCT=y
#CONFIG_NF_CONNTRACK_IPV4=m
#CONFIG_IP_NF_IPTABLES=m
#CONFIG_IP_NF_MATCH_AH=m
#CONFIG_IP_NF_MATCH_ECN=m
#CONFIG_IP_NF_MATCH_RPFILTER=m
#CONFIG_IP_NF_MATCH_TTL=m
#CONFIG_IP_NF_FILTER=m
#CONFIG_IP_NF_TARGET_REJECT=m
#CONFIG_IP_NF_NAT=m
#CONFIG_IP_NF_TARGET_MASQUERADE=m
#CONFIG_IP_NF_TARGET_REDIRECT=m
#CONFIG_IP_NF_MANGLE=m
#CONFIG_IP_NF_RAW=m
#CONFIG_IP_NF_ARPTABLES=m
#CONFIG_IP_NF_ARPFILTER=m
#CONFIG_IP_NF_ARP_MANGLE=m
#CONFIG_NF_CONNTRACK_IPV6=m
#CONFIG_IP6_NF_IPTABLES=m
#CONFIG_IP6_NF_FILTER=m
#CONFIG_IP6_NF_TARGET_REJECT=m
#CONFIG_IP6_NF_MANGLE=m
#CONFIG_IP6_NF_RAW=m
#CONFIG_IP6_NF_NAT=m
#CONFIG_IP6_NF_TARGET_MASQUERADE=m
#CONFIG_BRIDGE=y
#CONFIG_BRIDGE_VLAN_FILTERING=y
#CONFIG_VLAN_8021Q=m
#CONFIG_VLAN_8021Q_GVRP=y
#CONFIG_VLAN_8021Q_MVRP=y
###CONFIG_NET_SCHED=y
###CONFIG_NET_SCH_HTB=y
###CONFIG_NET_CLS_U32=y
###CONFIG_NET_CLS_CGROUP=y
###CONFIG_NET_EMATCH=y
###CONFIG_NET_EMATCH_U32=y
###CONFIG_NET_CLS_ACT=y
###CONFIG_DNS_RESOLVER=y
###CONFIG_NET_L3_MASTER_DEV=y
###CONFIG_CGROUP_NET_PRIO=y
###CONFIG_BPF_JIT=y
#CONFIG_CAN=m
#CONFIG_CAN_VCAN=m
#CONFIG_CAN_SLCAN=m
#CONFIG_CAN_C_CAN=m
#CONFIG_CAN_CC770=m
#CONFIG_CAN_CC770_ISA=m
#CONFIG_CAN_CC770_PLATFORM=m
#CONFIG_CAN_M_CAN=m
#CONFIG_CAN_SJA1000=m
#CONFIG_CAN_SJA1000_ISA=m
#CONFIG_CAN_SJA1000_PLATFORM=m
#CONFIG_CAN_EMS_PCI=m
#CONFIG_CAN_KVASER_PCI=m
#CONFIG_CAN_PLX_PCI=m
#CONFIG_CAN_SOFTING=m
#CONFIG_CAN_MCP251X=m
#CONFIG_CAN_EMS_USB=m
#CONFIG_CAN_ESD_USB2=m
#CONFIG_CAN_GS_USB=m
#CONFIG_CAN_KVASER_USB=m
#CONFIG_CAN_PEAK_USB=m
#CONFIG_CAN_8DEV_USB=m
#CONFIG_MTTCAN=m
#CONFIG_IRDA=m
###CONFIG_BT=y
###CONFIG_BT_RFCOMM=y
###CONFIG_BT_BNEP=m
###CONFIG_BT_HIDP=y
#### CONFIG_BT_HS is not set
#### CONFIG_BT_LE is not set
###CONFIG_BT_LEDS=y
#### CONFIG_BT_DEBUGFS is not set
###CONFIG_BT_HCIBTUSB=m
###CONFIG_BT_HCIUART=m
###CONFIG_BT_HCIUART_BCSP=y
###CONFIG_BT_HCIUART_ATH3K=y
###CONFIG_BT_HCIUART_LL=y
###CONFIG_BT_HCIUART_INTEL=y
###CONFIG_BT_HCIUART_BCM=y
###CONFIG_BT_HCIUART_QCA=y
###CONFIG_BT_HCIBCM203X=m
###CONFIG_BT_HCIBPA10X=m
###CONFIG_BT_HCIBFUSB=m
###CONFIG_BT_HCIVHCI=m
###CONFIG_BT_MRVL=m
###CONFIG_BT_MRVL_SDIO=m
###CONFIG_BT_ATH3K=m
###CONFIG_AF_RXRPC=m
###CONFIG_CFG80211=m
###CONFIG_MAC80211=m
###CONFIG_MAC80211_RC_MINSTREL_VHT=y
###CONFIG_RFKILL=y
###CONFIG_NET_9P=y
###CONFIG_NET_9P_VIRTIO=y
CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug"
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
CONFIG_FW_LOADER_USER_HELPER_FALLBACK=y
CONFIG_DMA_CMA=y
CONFIG_CMA_SIZE_MBYTES=64
CONFIG_TEGRA_ACONNECT=y
CONFIG_MTD=y
CONFIG_MTD_CMDLINE_PARTS=y
CONFIG_MTD_BLOCK=y
CONFIG_MTD_M25P80=y
CONFIG_MTD_QSPI_FLASH=y
CONFIG_MTD_SPI_NOR=y
#CONFIG_MTD_UBI=m
CONFIG_OF_PLUGIN_MANAGER=y
CONFIG_OF_OVERLAY=y
###CONFIG_ZRAM=m
CONFIG_BLK_DEV_LOOP=y
#CONFIG_BLK_DEV_NBD=m
CONFIG_BLK_DEV_RAM=y
CONFIG_BLK_DEV_RAM_SIZE=8192
CONFIG_VIRTIO_BLK=y
CONFIG_BLK_DEV_NVME=y
CONFIG_SRAM=y
#CONFIG_BLUEDROID_PM=m
#CONFIG_MODS=m
CONFIG_SENSORS_NCT1008=y
CONFIG_SENSORS_PEX9749=y
CONFIG_FAN_THERM_EST=y
#CONFIG_TEGRA_PCIE_EP_MEM=y
CONFIG_NVS_LIGHT=y
CONFIG_NVS_PROXIMITY=y
CONFIG_NVS_TRIGGERED_BUFFER=y
CONFIG_TEGRA_PROFILER=y
# CONFIG_SCSI_PROC_FS is not set
CONFIG_BLK_DEV_SD=y
CONFIG_SCSI_SAS_ATA=y
CONFIG_SCSI_HISI_SAS=y
CONFIG_SCSI_MVSAS=y
CONFIG_SCSI_UFSHCD=y
CONFIG_SCSI_UFSHCD_PLATFORM=y
CONFIG_SCSI_UFSHCD_TEGRA=y
CONFIG_ATA=y
CONFIG_SATA_AHCI=y
CONFIG_SATA_AHCI_PLATFORM=y
CONFIG_AHCI_TEGRA_DOWNSTREAM=y
CONFIG_MD=y
CONFIG_BLK_DEV_DM=y
CONFIG_DM_CRYPT=y
CONFIG_DM_UEVENT=y
CONFIG_NETDEVICES=y
CONFIG_DUMMY=y
#CONFIG_MACVLAN=m
#CONFIG_MACVTAP=m
###CONFIG_IPVLAN=y
###CONFIG_VXLAN=y
###CONFIG_TUN=y
###CONFIG_VETH=m
###CONFIG_VIRTIO_NET=y
###CONFIG_TYPHOON=m
###CONFIG_ET131X=m
###CONFIG_ACENIC=m
###CONFIG_ALTERA_TSE=m
###CONFIG_AQTION=m
###CONFIG_ATL2=m
###CONFIG_ATL1=m
###CONFIG_ATL1E=m
###CONFIG_ATL1C=m
###CONFIG_ALX=m
###CONFIG_MACB=y
#CONFIG_B44=m
#CONFIG_CNIC=m
###CONFIG_TIGON3=y
#CONFIG_BNX2X=m
#CONFIG_BNXT=m
#CONFIG_BNA=m
#CONFIG_THUNDER_NIC_PF=m
#CONFIG_THUNDER_NIC_VF=m
#CONFIG_LIQUIDIO=m
#CONFIG_CHELSIO_T1=m
###CONFIG_CHELSIO_T1_1G=y
#CONFIG_CHELSIO_T3=m
#CONFIG_CHELSIO_T4=m
#CONFIG_CHELSIO_T4VF=m
#CONFIG_ENIC=m
#CONFIG_DL2K=m
#CONFIG_BE2NET=m
#CONFIG_S2IO=m
#CONFIG_VXGE=m
#CONFIG_HP100=m
#CONFIG_E100=m
#CONFIG_E1000=m
###CONFIG_E1000E=y
###CONFIG_IGB=y
###CONFIG_IGBVF=y
#CONFIG_IXGB=m
###CONFIG_IXGBE=y
#CONFIG_IXGBEVF=m
#CONFIG_I40E=m
#CONFIG_I40EVF=m
#CONFIG_FM10K=m
#CONFIG_JME=m
#CONFIG_SKGE=m
#CONFIG_SKGE_DEBUG=y
#CONFIG_SKY2=m
#CONFIG_SKY2_DEBUG=y
#CONFIG_NET_VENDOR_MELLANOX=y
#CONFIG_MLX4_EN=m
# CONFIG_MLX4_DEBUG is not set
#CONFIG_MLX4_CORE=m
###CONFIG_MLX5_CORE=m
###CONFIG_MLX5_CORE_EN=y
###CONFIG_MLX5_CORE_THERMAL=y
###CONFIG_MLX5_MPFS=y
###CONFIG_MLX5_ESWITCH=y
###CONFIG_MLX5_CORE_EN_DCB=y
###CONFIG_MLX5_CORE_IPOIB=y
###CONFIG_MLXSW_CORE=y
###CONFIG_MLXSW_CORE_HWMON=y
###CONFIG_MLXSW_CORE_THERMAL=y
###CONFIG_MLXSW_PCI=m
###CONFIG_MLXSW_I2C=m
###CONFIG_MLXSW_SWITCHIB=m
###CONFIG_MLXSW_SWITCHX2=m
###CONFIG_MLXSW_SPECTRUM=m
###CONFIG_MLXSW_SPECTRUM_DCB=y
###CONFIG_MLXSW_MINIMAL=m
###CONFIG_MLXFW=m
###CONFIG_NATSEMI=m
###CONFIG_NS83820=m
###CONFIG_NFP_NETVF=m
###CONFIG_NFP_NET_DEBUG=y
###CONFIG_NE2K_PCI=m
###CONFIG_FORCEDETH=y
###CONFIG_EQOS=y
###CONFIG_PCIE_TEGRA_VNET=y
###CONFIG_HAMACHI=m
###CONFIG_YELLOWFIN=m
###CONFIG_QLA3XXX=m
###CONFIG_QLCNIC=m
###CONFIG_QLGE=m
###CONFIG_NETXEN_NIC=m
###CONFIG_QED=m
###CONFIG_QEDE=m
###CONFIG_QCA7000=m
###CONFIG_QCOM_EMAC=m
###CONFIG_8139CP=m
###CONFIG_8139TOO=m
###CONFIG_R8169=y
###CONFIG_R8168=y
###CONFIG_SXGBE_ETH=m
###CONFIG_SFC=m
###CONFIG_SMC91X=y
###CONFIG_SMSC911X=y
###CONFIG_STMMAC_ETH=m
###CONFIG_MDIO_BITBANG=y
###CONFIG_BROADCOM_PHY=y
###CONFIG_MARVELL_PHY=y
###CONFIG_MICREL_PHY=y
###CONFIG_REALTEK_PHY=y
CONFIG_PPP=y
CONFIG_PPP_BSDCOMP=y
CONFIG_PPP_DEFLATE=y
CONFIG_PPP_FILTER=y
CONFIG_PPP_MPPE=y
CONFIG_PPPOLAC=y
CONFIG_PPPOPNS=y
CONFIG_PPP_ASYNC=y
CONFIG_PPP_SYNC_TTY=y
###CONFIG_USB_CATC=m
###CONFIG_USB_KAWETH=m
###CONFIG_USB_PEGASUS=m
###CONFIG_USB_RTL8150=m
###CONFIG_USB_RTL8152=y
###CONFIG_USB_LAN78XX=m
###CONFIG_USB_USBNET=y
###CONFIG_USB_NET_DM9601=m
###CONFIG_USB_NET_SR9700=m
###CONFIG_USB_NET_SR9800=m
###CONFIG_USB_NET_SMSC75XX=m
###CONFIG_USB_NET_SMSC95XX=m
###CONFIG_USB_NET_GL620A=m
###CONFIG_USB_NET_PLUSB=m
###CONFIG_USB_NET_MCS7830=m
###CONFIG_USB_NET_RNDIS_HOST=m
###CONFIG_USB_ALI_M5632=y
###CONFIG_USB_AN2720=y
###CONFIG_USB_KC2190=y
###CONFIG_USB_NET_CX82310_ETH=m
###CONFIG_ATH9K=m
###CONFIG_ATH9K_DEBUGFS=y
###CONFIG_ATH9K_STATION_STATISTICS=y
###CONFIG_ATH9K_WOW=y
###CONFIG_ATH9K_CHANNEL_CONTEXT=y
###CONFIG_ATH9K_HTC=m
###CONFIG_ATH9K_HTC_DEBUGFS=y
###CONFIG_CARL9170=m
###CONFIG_CARL9170_DEBUGFS=y
###CONFIG_ATH6KL=m
###CONFIG_ATH6KL_SDIO=m
###CONFIG_ATH6KL_USB=m
###CONFIG_ATH6KL_DEBUG=y
###CONFIG_AR5523=m
###CONFIG_WIL6210=m
#### CONFIG_WIL6210_TRACING is not set
###CONFIG_ATH10K=m
###CONFIG_ATH10K_PCI=m
###CONFIG_ATH10K_AHB=y
###CONFIG_ATH10K_DEBUGFS=y
###CONFIG_WCN36XX=m
###CONFIG_WCN36XX_DEBUGFS=y
###CONFIG_ATMEL=m
###CONFIG_AT76C50X_USB=m
###CONFIG_B43=m
###CONFIG_B43_SDIO=y
###CONFIG_B43LEGACY=m
###CONFIG_IWLWIFI=m
###CONFIG_IWLDVM=m
###CONFIG_IWLMVM=m
###CONFIG_IWLWIFI_DEBUGFS=y
#### CONFIG_IWLWIFI_DEVICE_TRACING is not set
###CONFIG_HERMES=m
###CONFIG_P54_COMMON=m
###CONFIG_P54_USB=m
###CONFIG_P54_PCI=m
###CONFIG_MWIFIEX=m
###CONFIG_MWIFIEX_SDIO=m
###CONFIG_MWIFIEX_PCIE=m
###CONFIG_MWIFIEX_USB=m
###CONFIG_MWL8K=m
###CONFIG_MT7601U=m
###CONFIG_RT2X00=m
###CONFIG_RT2800PCI=m
###CONFIG_RT2500USB=m
###CONFIG_RT73USB=m
###CONFIG_RT2800USB=m
###CONFIG_RT2800USB_RT3573=y
###CONFIG_RT2800USB_RT53XX=y
###CONFIG_RT2800USB_RT55XX=y
###CONFIG_RT2800USB_UNKNOWN=y
###CONFIG_RT2X00_LIB_DEBUGFS=y
###CONFIG_RTL8187=m
###CONFIG_RTL8192CE=m
###CONFIG_RTL8192SE=m
###CONFIG_RTL8192DE=m
###CONFIG_RTL8723AE=m
###CONFIG_RTL8723BE=m
###CONFIG_RTL8188EE=m
###CONFIG_RTL8192EE=m
###CONFIG_RTL8821AE=m
###CONFIG_RTL8192CU=m
###CONFIG_RTL8XXXU=m
###CONFIG_RTL8XXXU_UNTESTED=y
###CONFIG_RSI_91X=m
###CONFIG_CW1200=m
###CONFIG_CW1200_WLAN_SDIO=m
###CONFIG_WL1251=m
###CONFIG_WL1251_SDIO=m
###CONFIG_WL12XX=m
###CONFIG_WL18XX=m
###CONFIG_WLCORE_SDIO=m
###CONFIG_USB_ZD1201=m
###CONFIG_ZD1211RW=m
###CONFIG_BCMDHD=m
###CONFIG_BCMDHD_SDIO=y
###CONFIG_BCMDHD_PCIE=y
###CONFIG_BCM4354=y
###CONFIG_BCMDHD_FW_PATH="/lib/firmware/brcm/fw_bcmdhd.bin"
###CONFIG_BCMDHD_NVRAM_PATH="/lib/firmware/brcm/nvram.txt"
###CONFIG_BCMDHD_HW_OOB=y
###CONFIG_DHD_USE_SCHED_SCAN=y
###CONFIG_BCMDHD_DISABLE_MCC=y
###CONFIG_BCMDHD_PCIE_FW_PATH="/lib/firmware/brcm/fw_bcmdhd_4356.bin"
###CONFIG_BCMDHD_PCIE_NVRAM_PATH="/lib/firmware/brcm/nvram_4356.txt"
###CONFIG_BCMDHD_PCIE_ES4_NVRAM_PATH="/lib/firmware/brcm/nvram_murata_4359_b1_es4.txt"
###CONFIG_RTL8812AU=m
###CONFIG_RTL8814AU=m
###CONFIG_RTL8821AU=m
###CONFIG_RTL8821CU=m
###CONFIG_RTL8822BU=m
###CONFIG_RTL8822CE=m
CONFIG_INPUT_JOYDEV=y
CONFIG_INPUT_EVDEV=y
CONFIG_INPUT_KEYRESET=y
#CONFIG_KEYBOARD_ADP5588=m
#CONFIG_KEYBOARD_ADP5589=m
#CONFIG_KEYBOARD_ATKBD=m
#CONFIG_KEYBOARD_QT1070=m
#CONFIG_KEYBOARD_QT2160=m
#CONFIG_KEYBOARD_LKKBD=m
CONFIG_KEYBOARD_GPIO=y
#CONFIG_KEYBOARD_GPIO_POLLED=m
#CONFIG_KEYBOARD_TCA6416=m
#CONFIG_KEYBOARD_TCA8418=m
#CONFIG_KEYBOARD_MATRIX=m
#CONFIG_KEYBOARD_LM8323=m
#CONFIG_KEYBOARD_LM8333=m
#CONFIG_KEYBOARD_MAX7359=m
#CONFIG_KEYBOARD_MCS=m
#CONFIG_KEYBOARD_MPR121=m
#CONFIG_KEYBOARD_NEWTON=m
#CONFIG_KEYBOARD_TEGRA=m
#CONFIG_KEYBOARD_OPENCORES=m
#CONFIG_KEYBOARD_SAMSUNG=m
#CONFIG_KEYBOARD_STOWAWAY=m
#CONFIG_KEYBOARD_OMAP4=m
#CONFIG_KEYBOARD_XTKBD=m
#CONFIG_KEYBOARD_CAP11XX=m
#CONFIG_KEYBOARD_BCM=m
# CONFIG_MOUSE_PS2 is not set
#CONFIG_MOUSE_SERIAL=m
#CONFIG_MOUSE_APPLETOUCH=m
#CONFIG_MOUSE_BCM5974=m
#CONFIG_MOUSE_CYAPA=m
#CONFIG_MOUSE_VSXXXAA=m
#CONFIG_MOUSE_GPIO=m
#CONFIG_MOUSE_SYNAPTICS_I2C=m
#CONFIG_MOUSE_SYNAPTICS_USB=m
#CONFIG_INPUT_JOYSTICK=y
#CONFIG_JOYSTICK_XPAD=y
#CONFIG_INPUT_TABLET=y
#CONFIG_INPUT_TOUCHSCREEN=y
CONFIG_INPUT_MISC=y
CONFIG_INPUT_KEYCHORD=y
CONFIG_INPUT_UINPUT=y
CONFIG_INPUT_GPIO=y
# CONFIG_SERIO_SERPORT is not set
CONFIG_SERIO_AMBAKMI=y
CONFIG_LEGACY_PTY_COUNT=16
CONFIG_SERIAL_8250=y
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_DW=y
CONFIG_SERIAL_OF_PLATFORM=y
CONFIG_SERIAL_AMBA_PL011=y
CONFIG_SERIAL_AMBA_PL011_CONSOLE=y
CONFIG_SERIAL_TEGRA=y
CONFIG_TEGRA_COMBINED_UART=y
CONFIG_VIRTIO_CONSOLE=y
CONFIG_I2C_CHARDEV=y
CONFIG_I2C_MUX=y
CONFIG_I2C_MUX_GPIO=y
CONFIG_I2C_MUX_PCA954x=y
#CONFIG_I2C_ALI1535=m
#CONFIG_I2C_ALI1563=m
#CONFIG_I2C_ALI15X3=m
#CONFIG_I2C_AMD756=m
#CONFIG_I2C_AMD8111=m
#CONFIG_I2C_I801=m
#CONFIG_I2C_ISCH=m
#CONFIG_I2C_PIIX4=m
#CONFIG_I2C_NFORCE2=m
#CONFIG_I2C_SIS630=m
#CONFIG_I2C_VIAPRO=m
#CONFIG_I2C_CADENCE=m
#CONFIG_I2C_CBUS_GPIO=m
#CONFIG_I2C_DESIGNWARE_PLATFORM=m
#CONFIG_I2C_DESIGNWARE_PCI=m
#CONFIG_I2C_EMEV2=m
#CONFIG_I2C_GPIO=m
#CONFIG_I2C_NOMADIK=m
#CONFIG_I2C_OCORES=m
#CONFIG_I2C_PCA_PLATFORM=m
#CONFIG_I2C_RK3X=m
#CONFIG_I2C_SIMTEC=m
CONFIG_I2C_TEGRA=y
#CONFIG_I2C_TEGRA_SLAVE=m
#CONFIG_I2C_DIOLAN_U2C=m
CONFIG_I2C_TEGRA_CAMRTC=y
#CONFIG_I2C_TEGRA194_SLAVE=m
#CONFIG_I2C_STUB=m
#CONFIG_I2C_SLAVE_EEPROM=m
CONFIG_SPI=y
#CONFIG_SPI_CADENCE=m
#CONFIG_SPI_PXA2XX=m
#CONFIG_SPI_SC18IS602=m
CONFIG_SPI_TEGRA114=y
CONFIG_SPI_TEGRA124_SLAVE=y
CONFIG_QSPI_TEGRA210=y
#CONFIG_SPI_XCOMM=m
#CONFIG_SPI_ZYNQMP_GQSPI=m
#CONFIG_SPI_SPIDEV=m
#CONFIG_SPI_TLE62X0=m
CONFIG_SPMI=y
CONFIG_PINCTRL_SINGLE=y
CONFIG_PINCTRL_MAX77620=y
CONFIG_PINCTRL_TEGRA186_DPAUX=y
CONFIG_PINCTRL_TEGRA194_PEXCLK_PADCTL=y
CONFIG_GPIO_PCA953X=y
CONFIG_GPIO_PCA953X_IRQ=y
CONFIG_GPIO_MAX77620=y
CONFIG_GPIO_TMPM32X_I2C=y
CONFIG_PADCTRL=y
CONFIG_PADCTRL_GENERIC_TEGRA_IO_PAD=y
CONFIG_POWER_OFF_MAX77620=y
CONFIG_POWER_OFF_TMPM32X_I2C=y
CONFIG_BATTERY_BQ27XXX=y
CONFIG_GPIO_TACHOMETER=y
CONFIG_GENERIC_PWM_TACHOMETER=y
CONFIG_PPS=y
#CONFIG_PPS_DEBUG=y
CONFIG_PPS_CLIENT_GPIO=y
CONFIG_THERMAL=y
CONFIG_THERMAL_WRITABLE_TRIPS=y
CONFIG_THERMAL_GOV_POWER_ALLOCATOR=y
CONFIG_THERMAL_EMULATION=y
CONFIG_MAX77620_THERMAL=y
CONFIG_TEGRA_SOCTHERM=y
CONFIG_TEGRA_AOTAG=y
CONFIG_TEGRA_CORE_CAPS=y
CONFIG_TEGRA_DFLL_CAPS=y
CONFIG_PWM_FAN=y
CONFIG_THERMAL_GOV_PID=y
CONFIG_THERMAL_GOV_CONTINUOUS=y
CONFIG_TEGRA_THERMAL_THROTTLE=y
#CONFIG_USERSPACE_THERM_ALERT=m
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_NOWAYOUT=y
CONFIG_MAX77620_WATCHDOG=y
CONFIG_TEGRA21X_WATCHDOG=y
CONFIG_TEGRA18X_WATCHDOG=y
CONFIG_SOFT_PLATFORM_WATCHDOG=y
CONFIG_MFD_MAX77620=y
CONFIG_REGULATOR=y
CONFIG_REGULATOR_FIXED_VOLTAGE=y
CONFIG_REGULATOR_GPIO=y
CONFIG_REGULATOR_MAX77620=y
CONFIG_REGULATOR_PWM=y
CONFIG_REGULATOR_TPS65132=y
CONFIG_REGULATOR_PMIC_OTP=y
CONFIG_MEDIA_SUPPORT=y
CONFIG_MEDIA_CAMERA_SUPPORT=y
CONFIG_MEDIA_CONTROLLER=y
CONFIG_VIDEO_V4L2_SUBDEV_API=y
CONFIG_MEDIA_USB_SUPPORT=y
#CONFIG_USB_VIDEO_CLASS=m
#CONFIG_USB_M5602=m
#CONFIG_USB_STV06XX=m
#CONFIG_USB_GL860=m
#CONFIG_USB_GSPCA_BENQ=m
#CONFIG_USB_GSPCA_CONEX=m
#CONFIG_USB_GSPCA_CPIA1=m
#CONFIG_USB_GSPCA_DTCS033=m
#CONFIG_USB_GSPCA_ETOMS=m
#CONFIG_USB_GSPCA_FINEPIX=m
#CONFIG_USB_GSPCA_JEILINJ=m
#CONFIG_USB_GSPCA_JL2005BCD=m
#CONFIG_USB_GSPCA_KINECT=m
#CONFIG_USB_GSPCA_KONICA=m
#CONFIG_USB_GSPCA_MARS=m
#CONFIG_USB_GSPCA_MR97310A=m
#CONFIG_USB_GSPCA_NW80X=m
#CONFIG_USB_GSPCA_OV519=m
#CONFIG_USB_GSPCA_OV534=m
#CONFIG_USB_GSPCA_OV534_9=m
#CONFIG_USB_GSPCA_PAC207=m
#CONFIG_USB_GSPCA_PAC7302=m
#CONFIG_USB_GSPCA_PAC7311=m
#CONFIG_USB_GSPCA_SE401=m
#CONFIG_USB_GSPCA_SN9C2028=m
#CONFIG_USB_GSPCA_SN9C20X=m
#CONFIG_USB_GSPCA_SONIXB=m
#CONFIG_USB_GSPCA_SONIXJ=m
#CONFIG_USB_GSPCA_SPCA500=m
#CONFIG_USB_GSPCA_SPCA501=m
#CONFIG_USB_GSPCA_SPCA505=m
#CONFIG_USB_GSPCA_SPCA506=m
#CONFIG_USB_GSPCA_SPCA508=m
#CONFIG_USB_GSPCA_SPCA561=m
#CONFIG_USB_GSPCA_SPCA1528=m
#CONFIG_USB_GSPCA_SQ905=m
#CONFIG_USB_GSPCA_SQ905C=m
#CONFIG_USB_GSPCA_SQ930X=m
#CONFIG_USB_GSPCA_STK014=m
#CONFIG_USB_GSPCA_STK1135=m
#CONFIG_USB_GSPCA_STV0680=m
#CONFIG_USB_GSPCA_SUNPLUS=m
#CONFIG_USB_GSPCA_T613=m
#CONFIG_USB_GSPCA_TOPRO=m
#CONFIG_USB_GSPCA_TOUPTEK=m
#CONFIG_USB_GSPCA_TV8532=m
#CONFIG_USB_GSPCA_VC032X=m
#CONFIG_USB_GSPCA_VICAM=m
#CONFIG_USB_GSPCA_XIRLINK_CIT=m
#CONFIG_USB_GSPCA_ZC3XX=m
#CONFIG_USB_PWC=m
#CONFIG_VIDEO_CPIA2=m
#CONFIG_USB_ZR364XX=m
#CONFIG_USB_STKWEBCAM=m
#CONFIG_USB_S2255=m
#CONFIG_VIDEO_USBTV=m
CONFIG_V4L_PLATFORM_DRIVERS=y
CONFIG_V4L_TEST_DRIVERS=y
CONFIG_VIDEO_VIVID=n
CONFIG_VIDEO_CAMERA=y
CONFIG_VIDEO_TEGRA_VIVID=m
# CONFIG_MEDIA_SUBDRV_AUTOSELECT is not set
#CONFIG_VIDEO_IMX185=m
CONFIG_VIDEO_IMX219=y
#CONFIG_VIDEO_IMX477=y
#CONFIG_VIDEO_IMX268=y
#CONFIG_VIDEO_IMX274=m
#CONFIG_VIDEO_IMX318=y
CONFIG_VIDEO_LC898212=y
#CONFIG_VIDEO_OV5693=m
CONFIG_VIDEO_OV9281=y
CONFIG_VIDEO_OV10823=y
CONFIG_VIDEO_OV23850=y
CONFIG_I2C_IOEXPANDER_PCA9570=y
#CONFIG_VIDEO_TC358840=m
CONFIG_VIDEO_LT6911UXC=y
CONFIG_I2C_IOEXPANDER_SER_MAX9295=y
CONFIG_I2C_IOEXPANDER_DESER_MAX9296=y
#CONFIG_VIDEO_IMX390=y
#CONFIG_VIDEO_IMX204=y
# CONFIG_VGA_ARB is not set
CONFIG_DRM=y
#CONFIG_DRM_TEGRA_UDRM=m
CONFIG_FB_MODE_PIXCLOCK_HZ=y
#CONFIG_BACKLIGHT_GENERIC=m
#CONFIG_BACKLIGHT_PWM=y
#CONFIG_BACKLIGHT_LP855X=y
CONFIG_TEGRA_DC=y
CONFIG_TEGRA_GRHOST=y
CONFIG_TEGRA_DSI=y
CONFIG_TEGRA_EDP2LVDS_PS8625=y
CONFIG_TEGRA_HDMI2_0=y
CONFIG_TEGRA_HDMIHDCP=y
CONFIG_TEGRA_DPHDCP=y
CONFIG_TEGRA_CEC_SUPPORT=y
CONFIG_NVMAP_CACHE_MAINT_BY_SET_WAYS=y
CONFIG_FRAMEBUFFER_CONSOLE=y
CONFIG_LOGO=y
#CONFIG_SOUND=y
#CONFIG_SND=y
#CONFIG_SND_DMAENGINE_PCM=y
#CONFIG_SND_ALOOP=m
#CONFIG_SND_AD1889=m
#CONFIG_SND_ATIIXP=m
#CONFIG_SND_ATIIXP_MODEM=m
#CONFIG_SND_AU8810=m
#CONFIG_SND_EMU10K1X=m
#CONFIG_SND_INTEL8X0=m
#CONFIG_SND_INTEL8X0M=m
#CONFIG_SND_MIXART=m
#CONFIG_SND_NM256=m
#CONFIG_SND_TRIDENT=m
#CONFIG_SND_VIRTUOSO=m
#CONFIG_SND_YMFPCI=m
#CONFIG_SND_HDA_INTEL=m
#CONFIG_SND_HDA_CODEC_HDMI=y
#CONFIG_SND_HDA_POWER_SAVE_DEFAULT=1
#CONFIG_SND_HDA_TEGRA=y
#CONFIG_SND_USB_AUDIO=y
#CONFIG_SND_SOC=y
#CONFIG_SND_SOC_TAS2552=y
#CONFIG_SND_SIMPLE_CARD=y
#CONFIG_SND_SOC_TEGRA_T186REF_P4573_ALT=y
#CONFIG_SND_SOC_TEGRA_ALT=y
#CONFIG_DISABLE_ADSP_AUDIO=y
#CONFIG_SND_SOC_TEGRA210_AUDIO_ALT=y
#CONFIG_SND_SOC_TEGRA_T186REF_ALT=y
CONFIG_HIDRAW=y
CONFIG_UHID=y
#CONFIG_HID_ACRUX=y
#CONFIG_HID_ACRUX_FF=y
#CONFIG_HID_APPLE=y
#CONFIG_HID_APPLEIR=m
#CONFIG_HID_AUREAL=m
#CONFIG_HID_BELKIN=m
#CONFIG_HID_BETOP_FF=m
#CONFIG_HID_CHERRY=m
#CONFIG_HID_CHICONY=m
#CONFIG_HID_CORSAIR=m
#CONFIG_HID_PRODIKEYS=y
#CONFIG_HID_CMEDIA=m
#CONFIG_HID_CP2112=m
#CONFIG_HID_CYPRESS=m
#ONFIG_HID_DRAGONRISE=y
#ONFIG_DRAGONRISE_FF=y
#ONFIG_HID_EMS_FF=y
#ONFIG_HID_ELECOM=y
#ONFIG_HID_ELO=m
#ONFIG_HID_EZKEY=m
#ONFIG_HID_GEMBIRD=m
#ONFIG_HID_GFRM=m
#ONFIG_HID_HOLTEK=y
#ONFIG_HID_GT683R=m
#ONFIG_HID_KEYTOUCH=y
#ONFIG_HID_KYE=y
#ONFIG_HID_UCLOGIC=y
#ONFIG_HID_WALTOP=y
#ONFIG_HID_GYRATION=y
#ONFIG_HID_ICADE=m
#ONFIG_HID_TWINHAN=y
#ONFIG_HID_KENSINGTON=m
#ONFIG_HID_LCPOWER=y
#ONFIG_HID_LENOVO=m
#ONFIG_HID_LOGITECH=m
#ONFIG_HID_LOGITECH_DJ=m
#ONFIG_HID_MAGICMOUSE=y
#ONFIG_HID_MICROSOFT=m
#ONFIG_HID_MONTEREY=m
#ONFIG_HID_MULTITOUCH=y
#ONFIG_HID_NTRIG=y
#ONFIG_HID_ORTEK=y
#ONFIG_HID_PANTHERLORD=y
#ONFIG_PANTHERLORD_FF=y
#ONFIG_HID_PENMOUNT=m
#ONFIG_HID_PETALYNX=y
#ONFIG_HID_PICOLCD=y
#ONFIG_HID_PICOLCD_FB=y
#ONFIG_HID_PICOLCD_BACKLIGHT=y
#ONFIG_HID_PLANTRONICS=m
#ONFIG_HID_PRIMAX=y
#ONFIG_HID_ROCCAT=y
#ONFIG_HID_SAITEK=y
#ONFIG_HID_SAMSUNG=y
#ONFIG_HID_SONY=y
#ONFIG_HID_SPEEDLINK=y
#ONFIG_HID_STEELSERIES=m
#ONFIG_HID_SUNPLUS=y
#ONFIG_HID_RMI=m
#ONFIG_HID_GREENASIA=y
#ONFIG_GREENASIA_FF=y
#ONFIG_HID_SMARTJOYPLUS=y
#ONFIG_SMARTJOYPLUS_FF=y
#ONFIG_HID_TIVO=y
#ONFIG_HID_TOPSEED=y
#ONFIG_HID_THINGM=m
#ONFIG_HID_THRUSTMASTER=y
#ONFIG_HID_WACOM=y
#ONFIG_HID_WIIMOTE=y
#ONFIG_HID_XINMO=m
#ONFIG_HID_ZEROPLUS=y
#ONFIG_HID_ZYDACRON=y
#ONFIG_HID_SENSOR_HUB=m
#ONFIG_HID_SENSOR_CUSTOM_SENSOR=m
#ONFIG_HID_SENSOR_ACCEL_3D=m
#ONFIG_HID_SENSOR_GYRO_3D=m
#ONFIG_HID_ALPS=m
#ONFIG_HID_NVIDIA_STAND=m
#ONFIG_HID_SHIELD_REMOTE=m
CONFIG_USB_ANNOUNCE_NEW_DEVICES=y
CONFIG_USB_OTG=y
#CONFIG_USB_MON=m
CONFIG_USB_XHCI_HCD=y
CONFIG_USB_XHCI_PLATFORM=y
CONFIG_USB_XHCI_TEGRA=y
CONFIG_USB_EHCI_HCD=y
CONFIG_USB_OHCI_HCD=y
CONFIG_USB_OHCI_HCD_PLATFORM=y
#CONFIG_USB_ACM=m
#CONFIG_USB_PRINTER=m
#CONFIG_USB_WDM=m
CONFIG_USB_STORAGE=y
#CONFIG_USB_STORAGE_REALTEK=m
#CONFIG_USB_STORAGE_DATAFAB=m
#CONFIG_USB_STORAGE_FREECOM=m
#CONFIG_USB_STORAGE_ISD200=m
#CONFIG_USB_STORAGE_USBAT=m
#CONFIG_USB_STORAGE_SDDR09=m
#CONFIG_USB_STORAGE_SDDR55=m
#CONFIG_USB_STORAGE_JUMPSHOT=m
#CONFIG_USB_STORAGE_ALAUDA=m
#CONFIG_USB_STORAGE_ONETOUCH=m
#CONFIG_USB_STORAGE_KARMA=m
#CONFIG_USB_STORAGE_CYPRESS_ATACB=m
#CONFIG_USB_STORAGE_ENE_UB6250=m
CONFIG_USB_UAS=y
#CONFIG_USB_MDC800=m
#CONFIG_USB_MICROTEK=m
#CONFIG_USB_CHIPIDEA=y
#CONFIG_USB_CHIPIDEA_UDC=y
#CONFIG_USB_ISP1760=y
#CONFIG_USB_SERIAL=y
#CONFIG_USB_SERIAL_CH341=m
#CONFIG_USB_SERIAL_CP210X=m
#CONFIG_USB_SERIAL_FTDI_SIO=m
#CONFIG_USB_SERIAL_PL2303=m
#CONFIG_USB_SERIAL_OPTION=m
#CONFIG_USB_EMI62=m
#CONFIG_USB_EMI26=m
#CONFIG_USB_SEVSEG=m
#CONFIG_USB_RIO500=m
#CONFIG_USB_LCD=m
#CONFIG_USB_CYPRESS_CY7C63=m
#CONFIG_USB_CYTHERM=m
#CONFIG_USB_IDMOUSE=m
#CONFIG_USB_APPLEDISPLAY=m
#CONFIG_USB_LD=m
#CONFIG_USB_TEST=m
#CONFIG_USB_YUREX=m
CONFIG_USB_HSIC_USB3503=y
CONFIG_USB_ULPI=y
CONFIG_USB_GADGET=y
CONFIG_USB_TEGRA_XUDC=y
CONFIG_USB_TEGRA_CD=y
CONFIG_USB_CONFIGFS=y
CONFIG_USB_CONFIGFS_ACM=y
CONFIG_USB_CONFIGFS_NCM=y
CONFIG_USB_CONFIGFS_ECM=y
CONFIG_USB_CONFIGFS_RNDIS=y
CONFIG_USB_CONFIGFS_MASS_STORAGE=y
CONFIG_USB_CONFIGFS_F_FS=y
CONFIG_USB_CONFIGFS_F_MTP=y
CONFIG_USB_CONFIGFS_F_PTP=y
CONFIG_USB_CONFIGFS_F_ACC=y
#CONFIG_USB_CONFIGFS_F_AUDIO_SRC=y
CONFIG_USB_CONFIGFS_UEVENT=y
CONFIG_USB_CONFIGFS_F_UAC1=y
CONFIG_USB_CONFIGFS_F_UAC2=y
CONFIG_USB_CONFIGFS_F_UVC=y
CONFIG_TYPEC_UCSI=y
CONFIG_UCSI_CCG=y
#CONFIG_USB_ULPI_BUS=m
CONFIG_MMC=y
CONFIG_MMC_BLOCK_MINORS=32
CONFIG_MMC_TEST=y
CONFIG_MMC_ARMMMCI=y
CONFIG_MMC_SDHCI=y
CONFIG_MMC_SDHCI_PLTFM=y
CONFIG_MMC_SDHCI_TEGRA=y
#CONFIG_INFINIBAND=m
#CONFIG_INFINIBAND_USER_MAD=y
#CONFIG_INFINIBAND_USER_ACCESS=y
#CONFIG_INFINIBAND_USER_MEM=y
#CONFIG_INFINIBAND_ON_DEMAND_PAGING=y
#CONFIG_INFINIBAND_ADDR_TRANS=y
#CONFIG_INFINIBAND_ADDR_TRANS_CONFIGFS=y
#CONFIG_INFINIBAND_MTHCA=m
#CONFIG_INFINIBAND_MTHCA_DEBUG=y
#CONFIG_MLX4_INFINIBAND=m
#CONFIG_MLX5_INFINIBAND=m
#CONFIG_INFINIBAND_IPOIB=m
#CONFIG_INFINIBAND_IPOIB_CM=y
#CONFIG_INFINIBAND_IPOIB_DEBUG=y
#CONFIG_INFINIBAND_SRP=m
#CONFIG_INFINIBAND_RDMAVT=m
#CONFIG_RDMA_RXE=m
#CONFIG_INFINIBAND_HFI1=m
#CONFIG_MMC_TIFM_SD=m
#CONFIG_MMC_SPI=m
#CONFIG_MMC_CB710=m
#CONFIG_MMC_VIA_SDMMC=m
#CONFIG_MMC_VUB300=m
#CONFIG_MMC_USHC=m
#CONFIG_MMC_USDHI6ROL0=m
#CONFIG_MMC_TOSHIBA_PCI=m
#CONFIG_MMC_MTK=m
CONFIG_MMC_CQ_HCI=y
CONFIG_LEDS_GPIO=y
CONFIG_LEDS_THINE350X=y
CONFIG_LEDS_PWM=y
#CONFIG_LEDS_BD2802=m
CONFIG_LEDS_TRIGGER_THROTTLE=y
CONFIG_SWITCH=y
CONFIG_RTC_CLASS=y
CONFIG_RTC_HCTOSYS_DEVICE="rtc1"
CONFIG_RTC_BACKUP_HCTOSYS_DEVICE="rtc0"
CONFIG_RTC_DRV_MAX77686=y
CONFIG_RTC_DRV_RX8025=y
CONFIG_DMADEVICES=y
CONFIG_TEGRA20_APB_DMA=y
CONFIG_TEGRA210_ADMA=y
CONFIG_DMATEST=y
CONFIG_TEGRA186_GPC_DMA=y
#CONFIG_VFIO=y
#CONFIG_VFIO_PCI=y
#CONFIG_VIRT_DRIVERS=y
#CONFIG_VIRTIO_PCI=y
#CONFIG_VIRTIO_BALLOON=y
#CONFIG_VIRTIO_MMIO=y
#CONFIG_PRISM2_USB=m
#CONFIG_RTL8192U=m
#CONFIG_RTLLIB=m
#CONFIG_RTL8192E=m
#CONFIG_R8712U=m
#CONFIG_R8188EU=m
CONFIG_INA219=y
CONFIG_INA230=y
CONFIG_INA3221=y
CONFIG_STEPPER=y
CONFIG_STEPPER_PCA=y
CONFIG_DENVER_CPU=y
CONFIG_TEGRA_AON=y
CONFIG_TEGRA_18X_SERROR=y
CONFIG_TEGRA_BWMGR=y
CONFIG_TEGRA_CAMERA_RTCPU=y
CONFIG_TEGRA_ISOMGR=y
CONFIG_TEGRA_CENTRAL_ACTMON=y
###CONFIG_TEGRA_NVADSP=m
###CONFIG_TEGRA_NVADSP_ON_SMMU=y
CONFIG_TEGRA_ADSP_DFS=y
CONFIG_COMMON_CLK_MAX77686=y
# CONFIG_COMMON_CLK_XGENE is not set
CONFIG_COMMON_CLK_FREQ_STATS_ACCOUNTING=y
CONFIG_ARM_ARCH_TIMER_VCT_ACCESS=y
CONFIG_ARM_TIMER_SP804=y
CONFIG_CLK_SRC_TEGRA18_TIMER=y
CONFIG_MAILBOX=y
CONFIG_ARM_MHU=y
CONFIG_BCM_PDC_MBOX=y
CONFIG_TEGRA_IOMMU_SMMU=y
CONFIG_ARM_SMMU=y
CONFIG_TEGRA_ARM_SMMU_T19x=y
CONFIG_ARM_SMMU_SUSPEND=y
CONFIG_ARCH_TEGRA_210_SOC=y
CONFIG_TEGRA_210_DVFS=y
CONFIG_TEGRA_KFUSE=y
CONFIG_DEVFREQ_GOV_PERFORMANCE=y
CONFIG_DEVFREQ_GOV_USERSPACE=y
CONFIG_DEVFREQ_GOV_POD_SCALING=y
CONFIG_DEVFREQ_GOV_WMARK_SIMPLE=y
CONFIG_DEVFREQ_GOV_WMARK_ACTIVE=y
CONFIG_EXTCON_GPIO=y
CONFIG_EXTCON_USB_GPIO=y
CONFIG_MEMORY=y
CONFIG_IIO=y
CONFIG_IIO_BUFFER=y
CONFIG_IIO_KFIFO_BUF=y
CONFIG_IIO_TRIGGER=y
CONFIG_PWM=y
CONFIG_PWM_TEGRA=y
CONFIG_PWM_TEGRA_TACHOMETER=y
CONFIG_PWM_TEGRA_PMC_BLINK=y
CONFIG_PWM_TEGRA_DFLL=y
CONFIG_PHY_TEGRA_XUSB=y
CONFIG_TEGRA_P2U=y
#CONFIG_RTK_BTUSB=m
CONFIG_NVPMODEL_EMC=n
#CONFIG_TRUSTY=y
CONFIG_GK20A=y
CONFIG_GK20A_PMU=y
CONFIG_GK20A_DEVFREQ=y
#CONFIG_GK20A_PM_QOS=y
CONFIG_GK20A_RDMA=y
#CONFIG_TEGRA_ACR=y
CONFIG_TEGRA_USE_NA_GPCPLL=y
CONFIG_GK20A_VIDMEM=y
CONFIG_ARM_SCPI_PROTOCOL=y
CONFIG_NV_TEGRA_BPMP=y
CONFIG_EXT3_FS=y
CONFIG_EXT4_FS_POSIX_ACL=y
CONFIG_EXT4_FS_SECURITY=y
###CONFIG_BTRFS_FS=m
###CONFIG_BTRFS_FS_POSIX_ACL=y
CONFIG_FANOTIFY=y
CONFIG_FANOTIFY_ACCESS_PERMISSIONS=y
CONFIG_QUOTA=y
CONFIG_QUOTA_TREE=y
# CONFIG_QFMT_V1 is not set
CONFIG_QFMT_V2=y
CONFIG_QUOTACTL=y
CONFIG_AUTOFS4_FS=y
#CONFIG_FUSE_FS=m
#CONFIG_CUSE=m
#CONFIG_OVERLAY_FS=m
CONFIG_VFAT_FS=y
CONFIG_NTFS_FS=y
CONFIG_NTFS_RW=y
CONFIG_TMPFS=y
CONFIG_TMPFS_POSIX_ACL=y
CONFIG_HUGETLBFS=y
CONFIG_SQUASHFS=y
CONFIG_SQUASHFS_XZ=y
CONFIG_PSTORE=y
CONFIG_PSTORE_CONSOLE=y
CONFIG_PSTORE_RAM=y
CONFIG_NFS_FS=y
CONFIG_ROOT_NFS=y
#CONFIG_NFSD=m
#CONFIG_NFSD_V3=y
#CONFIG_NFSD_V3_ACL=y
#CONFIG_CIFS=m
#CONFIG_9P_FS=y
CONFIG_NLS_CODEPAGE_437=y
CONFIG_NLS_ISO8859_1=y
CONFIG_VIRTUALIZATION=y
CONFIG_PRINTK_TIME=y
#CONFIG_DYNAMIC_DEBUG=y
#CONFIG_DEBUG_INFO=y
#CONFIG_DEBUG_SECTION_MISMATCH=y
# CONFIG_SECTION_MISMATCH_WARN_ONLY is not set
CONFIG_MAGIC_SYSRQ=y
#CONFIG_DEBUG_KMEMLEAK=y
#CONFIG_DEBUG_KMEMLEAK_EARLY_LOG_SIZE=8000
#CONFIG_DEBUG_KMEMLEAK_DEFAULT_OFF=y
#CONFIG_DEBUG_VM=y
CONFIG_LOCKUP_DETECTOR=y
CONFIG_BOOTPARAM_HARDLOCKUP_PANIC=y
CONFIG_BOOTPARAM_SOFTLOCKUP_PANIC=y
# CONFIG_BOOTPARAM_HUNG_TASK_PANIC is not set
CONFIG_WQ_WATCHDOG=y
CONFIG_PANIC_TIMEOUT=5
# CONFIG_SCHED_DEBUG is not set
CONFIG_SCHEDSTATS=y
CONFIG_TIMER_STATS=y
# CONFIG_DEBUG_PREEMPT is not set
CONFIG_FAULT_INJECTION=y
CONFIG_FUNCTION_TRACER=n
# CONFIG_FUNCTION_GRAPH_TRACER is not set
CONFIG_MEMTEST=y
# CONFIG_DEBUG_SET_MODULE_RONX is not set
#CONFIG_SECURITY_PERF_EVENTS_RESTRICT=y
#CONFIG_SECURITY=y
#CONFIG_SECURITY_NETWORK=y
CONFIG_HARDENED_USERCOPY=y
CONFIG_CRYPTO_DH=y
CONFIG_CRYPTO_TEST=n
CONFIG_CRYPTO_CCM=y
CONFIG_CRYPTO_GCM=y
CONFIG_CRYPTO_ECHAINIV=y
CONFIG_CRYPTO_TWOFISH=y
CONFIG_CRYPTO_ANSI_CPRNG=y
CONFIG_TEGRA_CRYPTO_DEV=y
CONFIG_CRYPTO_DEV_TEGRA_SE=y
CONFIG_CRYPTO_DEV_TEGRA_ELLIPTIC_SE=y
CONFIG_CRYPTO_DEV_TEGRA_SE_USE_HOST1X_INTERFACE=y
CONFIG_ARM64_CRYPTO=y
CONFIG_CRYPTO_SHA1_ARM64_CE=y
CONFIG_CRYPTO_SHA2_ARM64_CE=y
CONFIG_CRYPTO_GHASH_ARM64_CE=y
CONFIG_CRYPTO_AES_ARM64_CE_CCM=y
CONFIG_CRYPTO_AES_ARM64_CE_BLK=y
CONFIG_CRYPTO_AES_ARM64_NEON_BLK=y
CONFIG_IRQ_POLL=y
CONFIG_ARCH_TEGRA_18x_SOC=y
CONFIG_ARCH_TEGRA_19x_SOC=y
CONFIG_ARCH_TEGRA_23x_SOC=y
CONFIG_TEGRA_SAFETY=y
CONFIG_VIDEO_LETIM=y
CONFIG_EEPROM_AT24=y
CONFIG_DEBUG_KERNEL=n
CONFIG_HAVE_DEBUG_KMEMLEAK=n
CONFIG_HAVE_DEBUG_BUGVERBOSE=n
CONFIG_DEBUG_BUGVERBOSE=n
CONFIG_DEBUG_RODATA=n
CONFIG_SLUB_DEBUG=n
CONFIG_HAVE_DMA_API_DEBUG=n
CONFIG_SCSI_MVSAS_DEBUG=n
CONFIG_TEGRA_CLK_DEBUG=n
CONFIG_BPMP_DEBUGFS_MOUNT_ON_BOOT=n
CONFIG_BACKLIGHT_LCD_SUPPORT=y
CONFIG_STAGING=y
CONFIG_TRACING_SUPPORT=n
CONFIG_TRACING_EVENTS_GPIO=n
CONFIG_FTRACE=n
CONFIG_HAVE_SYSCALL_TRACEPOINTS=y
CONFIG_TRACE_IRQFLAGS_SUPPORT=n
CONFIG_TEGRA_T19X_GRHOST=y
CONFIG_TEGRA_GRHOST_CAPTURE_SUPPORT=y
CONFIG_TRACE_CLOCK=n
CONFIG_GK20A_CTXSW_TRACE=n
CONFIG_DEBUG_FS=y
CONFIG_ETHERNET=y
CONFIG_NET_VENDOR_REALTEK=y
CONFIG_R8168=y
Please tell me where am I wrong in this defconfig that may cause such a problem?
Here is the problem:
	vivid_node = of_find_node_by_name(NULL, "vivid-driver");
	if (!vivid_node) {
		dev_err(&vfd->dev, "%s:cannot find vivid node\n", __func__);
		return -ENODATA;
It cannot find node vivid-driver. I grepped all over the kernel but never find such letter combination. My dtb working with vanilla kernel but not working after optimization and I cannot understand why…
I need in creating /dev/video0 device but now I have a problem with it );
Full boot log is:
[    0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[    0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[    0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[    0.000000] On node 0 totalpages: 1039872
[    0.000000]   DMA zone: 8192 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 519168 pages, LIFO batch:31
[    0.000000]   Normal zone: 8136 pages used for memmap
[    0.000000]   Normal zone: 520704 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 23 pages/cpu s53592 r8192 d32424 u94208
[    0.000000] pcpu-alloc: s53592 r8192 d32424 u94208 alloc=23*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] CPU features: enabling workaround for ARM erratum 832075
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] CPU features: enabling workaround for Spectre-BHB
[    0.000000] CPU features: enabling workaround for ARM erratum 1742098
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 1023544
[    0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt  earlycon=uart8250,mmio32,0x70006000  root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[    0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[    0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[    0.000000] log_buf_len min size: 32768 bytes
[    0.000000] log_buf_len: 131072 bytes
[    0.000000] early log buf free: 29676(90%)
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Memory: 3582696K/4159488K available (10878K kernel code, 1538K rwdata, 4304K rodata, 2688K init, 582K bss, 101656K reserved, 475136K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0x        (ptrval) - 0x        (ptrval)   ( 10880 KB)
[    0.000000]     .rodata : 0x        (ptrval) - 0x        (ptrval)   (  4352 KB)
[    0.000000]       .init : 0x        (ptrval) - 0x        (ptrval)   (  2688 KB)
[    0.000000]       .data : 0x        (ptrval) - 0x        (ptrval)   (  1539 KB)
[    0.000000]        .bss : 0x        (ptrval) - 0x        (ptrval)   (   583 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf03fc8000   (    63 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc0ff200000   (  4082 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[    0.000000] t210 clock and reset probe
[    0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[    0.000000] clk_cbus_recalc_rate: no gbus parent
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.001478] Console: colour dummy device 80x25
[    0.001487] console [tty0] enabled
[    0.001492] bootconsole [uart8250] disabled
[    0.001520] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[    0.001532] pid_max: default: 32768 minimum: 301
[    0.001632] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.001637] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.002775] sched-energy: CPU device node has no sched-energy-costs
[    0.012172] ASID allocator initialised with 65536 entries
[    0.036096] tegra-id: chipid=22117.
[    0.036105] tegra-id: opt_subrevision=0.
[    0.036124] Tegra Speedo/IDDQ fuse revision 4
[    0.036129] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[    0.036134] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[    0.036205] Tegra: CPU Speedo Value 2102, SoC Speedo Value 1972, GPU Speedo Value 2094
[    0.036208] Tegra: CPU IDDQ Value 2288, SoC IDDQ Value 2492, GPU IDDQ Value 3020
[    0.036231] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[    0.036246] DTS File Name: /home/rvp/work/nvidia/Linux_for_Tegra/source/public/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/lecor.dts
[    0.036252] DTB Build time: Sep 13 2023 11:59:53
[    0.084438] CPU1: Booted secondary processor [411fd071]
[    0.116359] CPU2: Booted secondary processor [411fd071]
[    0.148348] CPU3: Booted secondary processor [411fd071]
[    0.148416] Brought up 4 CPUs
[    0.148423] SMP: Total of 4 processors activated.
[    0.148431] CPU features: detected feature: 32-bit EL0 Support
[    0.148657] CPU: All CPU(s) started at EL2
[    0.148675] alternatives: patching kernel code
[    0.155213] devtmpfs: initialized
[    0.188012] Initilizing CustomIPI irq domain
[    0.188375] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.188393] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.198543] pinctrl core: initialized pinctrl subsystem
[    0.199034] OS set in device tree is not L4T.
[    0.199373] regulator-dummy: no parameters
[    0.199621] Initializing plugin-manager
[    0.199753] Plugin module not found
[    0.199790] Plugin-manager not available
[    0.202477] NET: Registered protocol family 16
[    0.203623] pstore: using zlib compression
[    0.203656] console [pstore-1] enabled
[    0.203660] pstore: Registered ramoops as persistent store backend
[    0.203665] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[    0.220163] cpuidle: using governor menu
[    0.223190] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[    0.224861] vdso: 2 pages (1 code @         (ptrval), 1 data @         (ptrval))
[    0.224882] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.226498] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[    0.228793] Serial: AMBA PL011 UART driver
[    0.229255] tegra_powergate_init: DONE
[    0.229269] DTS File Name: /home/rvp/work/nvidia/Linux_for_Tegra/source/public/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/lecor.dts
[    0.229275] DTB Build time: Sep 13 2023 11:59:53
[    0.231029] Tegra reboot handler registered.
[    0.235101] iommu: Adding device tegra-carveouts to group 0
[    0.235190] platform tegra-carveouts: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.235521] iommu: Adding device smmu_test to group 1
[    0.235571] platform smmu_test: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.236372] mc: mapped MMIO address: 0x        (ptrval) -> 0x70019000
[    0.236426] mc: mapped MMIO address: 0x        (ptrval) -> 0x7001c000
[    0.236481] mc: mapped MMIO address: 0x        (ptrval) -> 0x7001d000
[    0.236490] nv-tegra-mc 70019000.mc: No mssnvlink node
[    0.236506] mc-err: mcerr ops are set to t21x
[    0.246443] iommu: Adding device 70090000.xusb to group 2
[    0.246691] iommu: Adding device 70006000.serial to group 3
[    0.246752] platform 70006000.serial: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.247133] iommu: Adding device 70006040.serial to group 4
[    0.247360] iommu: Adding device 70006200.serial to group 5
[    0.247557] iommu: Adding device sound to group 6
[    0.247600] platform sound: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.248093] iommu: Adding device 7000d400.spi to group 7
[    0.248317] iommu: Adding device 7000d600.spi to group 8
[    0.248714] iommu: Adding device 50000000.host1x to group 9
[    0.248961] iommu: Adding device 54080000.vi to group 10
[    0.249308] iommu: Adding device 54600000.isp to group 11
[    0.249540] iommu: Adding device 54680000.isp to group 12
[    0.249787] iommu: Adding device tegradc.0 to group 13
[    0.249864] platform tegradc.0: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.250371] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[    0.250666] iommu: Adding device tegradc.1 to group 14
[    0.250714] platform tegradc.1: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.251213] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[    0.251412] iommu: Adding device 54340000.vic to group 15
[    0.251592] iommu: Adding device 544c0000.nvenc to group 16
[    0.251770] iommu: Adding device 54500000.tsec to group 17
[    0.251945] iommu: Adding device 54100000.tsecb to group 18
[    0.252120] iommu: Adding device 54480000.nvdec to group 19
[    0.252309] iommu: Adding device 54380000.nvjpg to group 20
[    0.253290] iommu: Adding device 546c0000.i2c to group 21
[    0.253586] iommu: Adding device 57000000.gpu to group 22
[    0.253636] platform 57000000.gpu: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.253671] platform 57000000.gpu: domain=        (ptrval) allocates as[1]=        (ptrval)
[    0.253708] platform 57000000.gpu: domain=        (ptrval) allocates as[2]=        (ptrval)
[    0.253743] platform 57000000.gpu: domain=        (ptrval) allocates as[3]=        (ptrval)
[    0.254564] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[    0.254575] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[    0.254586] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[    0.254591] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[    0.254596] tegra-pmc: ### PMC reset status reg: 0x3
[    0.304591] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.304598] tegra-pmc: Clear bootloader IO dpd settings
[    0.304621] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[    0.304685] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[    0.304952] iommu: Adding device 70012000.se to group 23
[    0.305698] iommu: Adding device 7000c000.i2c to group 24
[    0.305977] iommu: Adding device 7000c400.i2c to group 25
[    0.306253] iommu: Adding device 7000c500.i2c to group 26
[    0.306527] iommu: Adding device 7000c700.i2c to group 27
[    0.306797] iommu: Adding device 7000d000.i2c to group 28
[    0.307096] iommu: Adding device 7000d100.i2c to group 29
[    0.307379] iommu: Adding device sdhci-tegra.3 to group 30
[    0.307430] platform sdhci-tegra.3: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.307852] iommu: Adding device sdhci-tegra.2 to group 31
[    0.307895] platform sdhci-tegra.2: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.308711] iommu: Adding device 700d0000.xudc to group 32
[    0.312485] vdd-ac-bat: 5000 mV
[    0.312859] vdd-5v0-sys: 5000 mV
[    0.313676] vdd-5v0-hdmi: 5000 mV
[    0.314131] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[    0.314412] vdd-1v8-sys: 1800 mV
[    0.314849] vdd-fan: 5000 mV
[    0.315081] vdd-fan: supplied by vdd-5v0-sys
[    0.315376] vdd-usb-vbus: 5000 mV
[    0.315619] vdd-usb-vbus: supplied by vdd-5v0-sys
[    0.315971] vdd-usb-vbus2: 5000 mV
[    0.342309] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.343775] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[    0.344915] GPIO line 6 (system-suspend-gpio) hogged as output/high
[    0.345200] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[    0.352547] eventlib_kernel: keventlib is initialized, test id: 0
[    0.352824] SCSI subsystem initialized
[    0.353007] libata version 3.00 loaded.
[    0.356664] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[    0.360643] vdd-core: 1000 <--> 1162 mV at 1075 mV
[    0.361563] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[    0.364455] vdd-ddr-1v1: 1150 mV
[    0.368442] vdd-pre-reg-1v35: 1350 mV
[    0.372364] vdd-1v8: 1800 mV
[    0.376387] avdd-sys-1v2: 1200 mV
[    0.380363] vdd-pex-1v0: 1050 mV
[    0.381000] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[    0.381497] max77620-ldo3: at 3100 mV
[    0.384372] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[    0.384876] max77620-ldo5: at 3100 mV
[    0.388365] vddio-sdmmc3-ap: 1800 <--> 3300 mV at 2800 mV
[    0.392367] avdd-1v05-pll: 1050 mV
[    0.396366] avdd-io-hdmi-dp: 1050 mV
[    0.398698] GPIO line 505 (spmic-default-output-high) hogged as output/high
[    0.398926] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[    0.399169] max77620 4-003c: max77620 probe successful
[    0.401996] media: Linux media interface: v0.10
[    0.402050] Linux video capture interface: v2.00
[    0.402877] pps_core: LinuxPPS API ver. 1 registered
[    0.402883] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.406306] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[    0.408860] tegra210_dvfs: no clock found for sdmmc2_ddr
[    0.408879] tegra210_dvfs: no clock found for sdmmc4_ddr
[    0.408927] tegra210_dvfs: no clock found for sdmmc1_ddr
[    0.408942] tegra210_dvfs: no clock found for sdmmc3_ddr
[    0.412056] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[    0.413198] vdd-3v3-sys: 3300 mV
[    0.413526] vdd-3v3-sys: supplied by vdd-5v0-sys
[    0.413597] vdd-1v8-sys: supplied by vdd-3v3-sys
[    0.416454] vdd-usb-vbus2: supplied by vdd-3v3-sys
[    0.416903] vdd-3v3-sd: 3300 mV
[    0.417299] vdd-3v3-sd: supplied by vdd-3v3-sys
[    0.417844] avdd-io-edp-1v05: 1050 mV
[    0.418187] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[    0.418313] vdd-usb-hub-en: 5000 mV
[    0.418667] vdd-usb-hub-en: supplied by vdd-1v8-sys
[    0.419630] camchar: rtcpu character device driver loaded
[    0.420271] clocksource: Switched to clocksource arch_sys_counter
[    0.420438] VFS: Disk quotas dquot_6.6.0
[    0.420500] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.420732] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    0.420975] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[    0.420990]  dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[    0.421155] cma: enabled page replacement for spfn=d7000, epfn=f0000
[    0.421159] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[    0.421170] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[    0.421192] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[    0.421197] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[    0.421211] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[    0.421218] nvmap_page_pool_init: Total RAM pages: 1014458
[    0.421223] nvmap_page_pool_init: nvmap page pool size: 126807 pages (495 MB)
[    0.421322] nvmap_background_zero_thread: PP zeroing thread starting.
[    0.421578] misc nvmap: created heap iram base 0x        (ptrval) size (252KiB)
[    0.422308] misc nvmap: created heap vpr base 0x        (ptrval) size (409600KiB)
[    0.429339] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[    0.429724] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[    0.429963] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[    0.430151] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[    0.430316] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[    0.430547] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[    0.430551] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[    0.430672] NET: Registered protocol family 2
[    0.430817] IP idents hash table entries: 65536 (order: 7, 524288 bytes)
[    0.460425] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.460639] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    0.461145] TCP: Hash tables configured (established 32768 bind 32768)
[    0.461289] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    0.461367] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    0.461622] NET: Registered protocol family 1
[    0.462084] RPC: Registered named UNIX socket transport module.
[    0.462090] RPC: Registered udp transport module.
[    0.462094] RPC: Registered tcp transport module.
[    0.462098] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.462110] PCI: CLS 0 bytes, default 64
[    0.462328] Trying to unpack rootfs image as initramfs...
[    0.749566] Freeing initrd memory: 6992K
[    0.758957] host1x 50000000.host1x: initialized
[    0.760615] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.763371] audit: initializing netlink subsys (disabled)
[    0.763471] audit: type=2000 audit(0.759:1): initialized
[    0.764033] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.769871] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.770510] ntfs: driver 2.1.32 [Flags: R/W].
[    0.773486] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.773595] io scheduler noop registered
[    0.773715] io scheduler cfq registered (default)
[    0.775717] gic 702f9000.agic: GIC IRQ controller registered
[    0.778579] iommu: Adding device 702ef000.adsp to group 33
[    0.787150] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[    0.787316] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[    0.787875] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x91e9411
[    0.787882] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[    0.789634] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[    0.789723] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[    0.789804] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[    0.789975] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[    0.790049] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[    0.790143] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[    0.790216] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[    0.790289] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[    0.790366] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[    0.790444] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[    0.796252] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[    0.797854] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[    0.799405] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[    0.800735] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[    0.801072] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[    0.801879] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[    0.802073] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=5250, vi_iso_bw=1029000, max_bw=1029000
[    0.802302] Adding domain tsec-pd to PM domain host1x-pd
[    0.804495] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[    0.805325] tsec 54500000.tsec: initialized
[    0.806767] tsec 54100000.tsecb: initialized
[    0.807423] Adding domain nvdec-pd to PM domain host1x-pd
[    0.810693] nvdec 54480000.nvdec: initialized
[    0.811676] Adding domain vic03-pd to PM domain host1x-pd
[    0.811847] Adding domain msenc-pd to PM domain host1x-pd
[    0.812004] Adding domain nvjpg-pd to PM domain host1x-pd
[    0.816104] falcon 54340000.vic: initialized
[    0.817289] falcon 544c0000.nvenc: initialized
[    0.818519] falcon 54380000.nvjpg: initialized
[    0.822676] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[    0.822722] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[    0.822748] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[    0.822890] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[    0.822990] display board info: id 0x0, fab 0x0
[    0.823009] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[    0.823014] tegra_cec 70015000.tegra_cec: probed
[    0.823057] generic_infoframe_type: 0x87
[    0.823210] tegradc tegradc.0: DT parsed successfully
[    0.823250] tegradc tegradc.0: Display dc.        (ptrval) registered with id=0
[    0.826105] tegradc tegradc.0: probed
[    0.826748] Console: switching to colour frame buffer device 80x30
[    0.826782] tegradc tegradc.0: fb registered
[    0.828066] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[    0.828153] tegradc tegradc.1: No lt-data, using default setting
[    0.828178] tegradc tegradc.1: No hpd-gpio in DT
[    0.828207] tegradc tegradc.1: DT parsed successfully
[    0.828249] tegradc tegradc.1: Display dc.        (ptrval) registered with id=1
[    0.830792] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[    1.337233] tegradc tegradc.1: probed
[    1.337579] tegradc tegradc.1: fb registered
[    1.338397] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[    1.339120] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[    1.339126] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[    1.339413] kfuse 7000fc00.kfuse: initialized
[    1.340370] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[    1.340802] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[    1.340807] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[    1.340816] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[    1.340830] tegradc tegradc.1: blank - powerdown
[    1.340845] Extcon DP: HPD disabled
[    1.340849] hpd: hpd_switch 0
[    1.340853] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[    1.340861] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[    1.340868] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[    1.341151] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[    1.341732] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[    1.341741] vdd-cpu: 708 <--> 1322 mV at 708 mV
[    1.342167] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[    1.343305] vdd-gpu: applied init 1000000uV constraint
[    1.343313] vdd-gpu: 708 <--> 1323 mV at 997 mV
[    1.343648] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[    1.346941] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.347027] No Device Node present for smmu client: serial8250 !!
[    1.347036] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[    1.347074] iommu: Adding device serial8250 to group 35
[    1.349145] console [ttyS0] disabled
[    1.349208] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[    1.359555] console [ttyS0] enabled
[    1.360511] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[    1.360760] serial-tegra 70006200.serial: RX in PIO mode
[    1.360839] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[    1.361601] [drm] Initialized
[    1.362300] nvgpu: 57000000.gpu                       nvgpu_probe:265  [INFO]  platform probe failed
[    1.370907] brd: module loaded
[    1.375440] loop: module loaded
[    1.375995] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.377627] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.379239] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.380849] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.382458] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.384069] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.385688] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.387302] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.388920] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.390535] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.392143] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.393758] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.395371] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.396985] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.398597] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.400204] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.401919] tegra_profiler: version: 1.145, samples/io: 49/28
[    1.402043] tegra_profiler: auth: init
[    1.403260] THERMAL EST: found 2 subdevs
[    1.403268] THERMAL EST num_resources: 0
[    1.403274] [THERMAL EST subdev 0]
[    1.403281] [THERMAL EST subdev 1]
[    1.403696] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[    1.403700] THERMAL EST: thz register success.
[    1.403861] THERMAL EST: end of probe, return err: 0
[    1.404626] sd: No Scsi addr parsed to reserve index
[    1.404660] hisi_sas: driver version v1.6
[    1.410024] PPP generic driver version 2.4.2
[    1.410211] PPP BSD Compression module registered
[    1.410217] PPP Deflate Compression module registered
[    1.410258] PPP MPPE Compression module registered
[    1.410266] NET: Registered protocol family 24
[    1.412115] tegra-xudc-new 700d0000.xudc: device count: 1
[    1.412519] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[    1.413917] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[    1.413928] tegra-xudc-new 700d0000.xudc: vbus state: 0
[    1.414418] tegra-xudc-new 700d0000.xudc: entering ELPG
[    1.414588] mousedev: PS/2 mouse device common for all mice
[    1.414749] tegra-xudc-new 700d0000.xudc: entering ELPG done
[    1.502663] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[    1.505036] rtc rtc1: alarm rtc device
[    1.505055] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[    1.505077] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[    1.505651] i2c /dev entries driver
[    1.525420] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[    1.528085] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[    1.528093] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[    1.528635] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.528653] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[    1.528663] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[    1.528796] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.528806] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[    1.528813] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[    1.528972] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.528984] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[    1.528990] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[    1.529169] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[    1.529983] tegra_aotag tegra-aotag: Registering sensor 0
[    1.530042] tegra_aotag tegra-aotag: Invalid temp readout
[    1.530070] tegra_aotag tegra-aotag: Invalid temp readout
[    1.530087] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[    1.530096] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[    1.530961] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.530979] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[    1.531157] tegra_aotag tegra-aotag: Invalid temp readout
[    1.531192] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[    1.531585] parse_throttle_dt_data: Num cap clks = 6
[    1.531592] parse_throttle_dt_data: clk=cclk_g type=2
[    1.531606] parse_throttle_dt_data: clk=gpu type=4
[    1.531632] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[    1.531650] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[    1.531670] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[    1.531674] parse_throttle_dt_data: clk=emc type=3
[    1.532068] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.532163] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.532481] tegra_throttle_probe: probe successful. #cdevs=4
[    1.533307] FAN dev name: pwm-fan
[    1.533396] FAN:gpio request success.
[    1.533459] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[    1.533753] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[    1.533921] pwm_fan_driver pwm-fan: fan tach request irq success
[    1.533930] pwm_fan_driver pwm-fan: tach period: 1000
[    1.534027] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[    1.534033] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[    1.534039] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[    1.534044] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[    1.534049] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[    1.534054] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[    1.534058] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[    1.534063] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[    1.534068] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[    1.534073] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[    1.535252] device-mapper: uevent: version 1.0.3
[    1.535555] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    1.541555] tegra210-cpufreq cpufreq: probe()...completed
[    1.542202] sdhci: Secure Digital Host Controller Interface driver
[    1.542204] sdhci: Copyright(c) Pierre Ossman
[    1.542206] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.542545] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[    1.546819] sdhci-tegra sdhci-tegra.2: Client registration for eMC Successful
[    1.550859] tegra-se 70012000.se: tegra_se_probe: complete
[    1.551331] hidraw: raw HID events driver (C) Jiri Kosina
[    1.553499] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[    1.553641] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[    1.555169] Initializing XFRM netlink socket
[    1.555381] NET: Registered protocol family 10
[    1.555775] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.556034] NET: Registered protocol family 17
[    1.556043] NET: Registered protocol family 15
[    1.556360] Registered cp15_barrier emulation handler
[    1.556367] Registered setend emulation handler
[    1.557201] registered taskstats version 1
[    1.557626] Adding domain ve2-pd to PM domain host1x-pd
[    1.557870] Adding domain ve-pd to PM domain host1x-pd
[    1.559841] isp 54600000.isp: initialized
[    1.560810] isp 54680000.isp: initialized
[    1.570665] last reset is due to software reset
[    1.570670] KERNEL: PMC reset status reg: 0x3
[    1.570729] BL: PMC reset status reg: 0x3
[    1.570732] BL: PMIC poweroff Event Recorder: 0x0
[    1.572207] clk_cbus_recalc_rate: no gbus parent
[    1.572212] clk_cbus_round_rate: no gbus parent
[    1.572214] clk_cbus_round_rate: no gbus parent
[    1.572221] clk_cbus_recalc_rate: no gbus parent
[    1.572340] clk_cbus_recalc_rate: no gbus parent
[    1.572344] clk_cbus_round_rate: no gbus parent
[    1.572346] clk_cbus_round_rate: no gbus parent
[    1.572351] clk_cbus_recalc_rate: no gbus parent
[    1.573038] tegra_dvfs: GPU-cap: registered
[    1.573090] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[    1.573093] tegra dvfs: vdd-core: nominal 1075mV, offset 1000000uV, step 12500uV, scaling enabled
[    1.573095] tegra dvfs: vdd-gpu: nominal 1048mV, offset 708000uV, step 10000uV, scaling enabled
[    1.574239] tegra_dvfs: vdd-gpu-vts: registered
[    1.574865] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[    1.575568] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[    1.576039] input: gpio-keys as /devices/gpio-keys/input/input0
[    1.578428] nvgpu: 57000000.gpu           gm20b_init_clk_setup_sw:1268 [INFO]  GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[    1.584279] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA 64-bit with 64 bit addr
[    1.588280] mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA 64-bit with 64 bit addr
[    1.609021] tegra_rtc 7000e000.rtc: setting system clock to 2023-10-24 14:57:58 UTC (1698159478)
[    1.609932] vi 54080000.vi: vi_probe: ++
[    1.612405] vi 54080000.vi: initialized
[    1.614404] vi 54080000.vi: subdev nvcsi--4 bound
[    1.614492] vi 54080000.vi: subdev nvcsi--3 bound
[    1.614571] vi 54080000.vi: subdev nvcsi--2 bound
[    1.614650] vi 54080000.vi: subdev nvcsi--1 bound
[    1.615301] Disable partitions left on by BL
[    1.615305]   disb
[    1.615463] bwmgr: missing cdev-type property
[    1.615582] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.615588] DRAM derating cdev registered.
[    1.617670] Freeing unused kernel memory: 2688K
[    1.641301] Root device found: mmcblk0p1
[    1.648779] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    1.653197] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[    1.657409] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[    1.661659] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[    1.665909] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[    1.668276]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9
[    1.734105] tegra-pcie 1003000.pcie: link 0 down, retrying
[    1.846706] Found dev node: /dev/mmcblk0p1
[    1.856296] tegra_cec 70015000.tegra_cec: Can't find physical addresse.
[    1.856301] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[    1.866906] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    1.868707] Rootfs mounted over mmcblk0p1
[    1.884247] Switching from initrd to actual rootfs
[    2.022472] cgroup: cgroup2: unknown option "nsdelegate"
[    2.031096] systemd[1]: systemd 254.5-1-arch running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[    2.031109] systemd[1]: Detected architecture arm64.
[    2.031502] systemd[1]: Warning! Reported kernel version 4.9.337-dirty is older than systemd's required baseline kernel version 4.15. Your mileage may vary.
[    2.033361] systemd[1]: Hostname set to <alarm>.
[    2.047984] systemd[1]: bpf-lsm: BPF LSM hook not enabled in the kernel, BPF LSM not supported
[    2.138291] tegra-pcie 1003000.pcie: link 0 down, retrying
[    2.315554] systemd[1]: /etc/systemd/system/nvs-service.service:38: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    2.319195] systemd[1]: /etc/systemd/system/nvargus-daemon.service:40: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    2.333843] systemd[1]: Queued start job for default target Graphical Interface.
[    2.337754] systemd[1]: Created slice Slice /system/getty.
[    2.338503] systemd[1]: Created slice Slice /system/modprobe.
[    2.339206] systemd[1]: Created slice Slice /system/serial-getty.
[    2.339645] systemd[1]: Created slice User and Session Slice.
[    2.339820] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    2.339985] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    2.340090] systemd[1]: Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
[    2.340183] systemd[1]: Reached target Local Encrypted Volumes.
[    2.340255] systemd[1]: Reached target Local Integrity Protected Volumes.
[    2.340374] systemd[1]: Reached target Path Units.
[    2.340430] systemd[1]: Reached target Remote File Systems.
[    2.340472] systemd[1]: Reached target Slice Units.
[    2.340537] systemd[1]: Reached target Swaps.
[    2.340608] systemd[1]: Reached target Local Verity Protected Volumes.
[    2.340836] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    2.344428] systemd[1]: Listening on Process Core Dump Socket.
[    2.344794] systemd[1]: Listening on Journal Socket (/dev/log).
[    2.345111] systemd[1]: Listening on Journal Socket.
[    2.345497] systemd[1]: Listening on Network Service Netlink Socket.
[    2.345868] systemd[1]: Listening on udev Control Socket.
[    2.346120] systemd[1]: Listening on udev Kernel Socket.
[    2.348007] systemd[1]: Mounting Huge Pages File System...
[    2.350076] systemd[1]: Mounting POSIX Message Queue File System...
[    2.351869] systemd[1]: Mounting Kernel Debug File System...
[    2.352131] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[    2.355082] systemd[1]: Mounting Temporary Directory /tmp...
[    2.355275] systemd[1]: Create List of Static Device Nodes was skipped because of an unmet condition check (ConditionFileNotEmpty=/lib/modules/4.9.337-dirty/modules.devname).
[    2.358019] systemd[1]: Starting Load Kernel Module configfs...
[    2.360673] systemd[1]: Starting Load Kernel Module dm_mod...
[    2.362995] systemd[1]: Starting Load Kernel Module drm...
[    2.365702] systemd[1]: Starting Load Kernel Module fuse...
[    2.368030] systemd[1]: Starting Load Kernel Module loop...
[    2.368803] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    2.368813] systemd[1]: systemd-journald.service: (This warning is only shown for the first unit using IP firewalling.)
[    2.370222] systemd[1]: Starting Journal Service...
[    2.373650] systemd[1]: Starting Load Kernel Modules...
[    2.375743] systemd[1]: Starting Generate network units from Kernel command line...
[    2.375869] systemd[1]: TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/StubPcrKernelImage-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
[    2.378155] systemd[1]: Starting Remount Root and Kernel File Systems...
[    2.380582] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[    2.382902] systemd[1]: Starting Coldplug All udev Devices...
[    2.387739] systemd[1]: Mounted Huge Pages File System.
[    2.388342] systemd[1]: Mounted POSIX Message Queue File System.
[    2.388733] systemd[1]: Mounted Kernel Debug File System.
[    2.389106] systemd[1]: Mounted Temporary Directory /tmp.
[    2.390205] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    2.390678] systemd[1]: Finished Load Kernel Module configfs.
[    2.392410] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[    2.392858] systemd[1]: Finished Load Kernel Module dm_mod.
[    2.394322] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    2.394705] systemd[1]: Finished Load Kernel Module drm.
[    2.395849] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    2.396219] systemd[1]: Finished Load Kernel Module fuse.
[    2.397881] systemd[1]: modprobe@loop.service: Deactivated successfully.
[    2.398248] systemd[1]: Finished Load Kernel Module loop.
[    2.399184] systemd[1]: Finished Load Kernel Modules.
[    2.399875] systemd[1]: Finished Generate network units from Kernel command line.
[    2.400676] systemd[1]: Finished Remount Root and Kernel File Systems.
[    2.401621] systemd[1]: Reached target Preparation for Network.
[    2.401994] systemd[1]: FUSE Control File System was skipped because of an unmet condition check (ConditionPathExists=/sys/fs/fuse/connections).
[    2.403959] systemd[1]: Mounting Kernel Configuration File System...
[    2.406418] systemd[1]: Rebuild Hardware Database was skipped because no trigger condition checks were met.
[    2.409642] systemd-journald[1501]: Collecting audit messages is disabled.
[    2.540333] tegra-pcie 1003000.pcie: link 0 down, retrying
[    2.542398] tegra-pcie 1003000.pcie: link 0 down, ignoring
[    2.556852] systemd[1]: Starting Load/Save OS Random Seed...
[    2.557034] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[    2.559053] systemd[1]: Starting Apply Kernel Variables...
[    2.560798] systemd[1]: Mounted Kernel Configuration File System.
[    2.610369] systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
[    2.612820] systemd[1]: Starting Create System Users...
[    2.619182] systemd[1]: Finished Apply Kernel Variables.
[    2.646437] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[    2.646444] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    2.646448] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[    2.646452] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[    2.646456] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.646476] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[    2.646535] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[    2.646657] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.646753] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[    2.646778] pci 0000:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    2.646811] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit pref]
[    2.646834] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit pref]
[    2.646971] pci 0000:01:00.0: supports D1 D2
[    2.646974] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    2.647091] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    2.647116] pci 0000:00:02.0: BAR 9: assigned [mem 0x20000000-0x200fffff 64bit pref]
[    2.647120] pci 0000:00:02.0: BAR 7: assigned [io  0x1000-0x1fff]
[    2.647126] pci 0000:01:00.0: BAR 4: assigned [mem 0x20000000-0x20003fff 64bit pref]
[    2.647145] pci 0000:01:00.0: BAR 2: assigned [mem 0x20004000-0x20004fff 64bit pref]
[    2.647163] pci 0000:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    2.647171] pci 0000:00:02.0: PCI bridge to [bus 01]
[    2.647175] pci 0000:00:02.0:   bridge window [io  0x1000-0x1fff]
[    2.647182] pci 0000:00:02.0:   bridge window [mem 0x20000000-0x200fffff 64bit pref]
[    2.647345] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[    2.647362] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[    2.678964] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[    2.679116] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e9:fb:54 from device tree
[    2.679894] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[    2.679911] r8168  Copyright (C) 2017  Realtek NIC software team <nicfae@realtek.com>
                This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
                This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[    2.697504] systemd[1]: Finished Create System Users.
[    2.699650] systemd[1]: Starting Create Static Device Nodes in /dev...
[    2.728709] systemd[1]: Started Journal Service.
[    2.774377] systemd-journald[1501]: Received client request to flush runtime journal.
[    2.794671] systemd-journald[1501]: /var/log/journal/b50e63a22b7f423cb41ca0b07c14da26/system.journal: Journal file uses a different sequence number ID, rotating.
[    2.794686] systemd-journald[1501]: Rotating system journal.
[    3.026335] proc: unrecognized mount option "hidepid=invisible" or missing value
[    3.243345] eth0: 0xffffff800a1bd000, 00:04:4b:e9:fb:54, IRQ 407
[    3.350601] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    3.686492] proc: unrecognized mount option "hidepid=invisible" or missing value
[    4.032275] random: crng init done
[    4.154813] using random self ethernet address
[    4.154818] using random host ethernet address
[    4.307907] Mass Storage Function, version: 2009/09/11
[    4.307914] LUN: removable file: (no medium)
[    4.311442] using random self ethernet address
[    4.311447] using random host ethernet address
[    6.429172] r8168: eth0: link up
[    6.430676] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   31.710765] vdd-fan: disabling
[   31.710810] vdd-usb-vbus: disabling
[   31.710843] vdd-usb-vbus2: disabling
[   31.710909] avdd-sys-1v2: disabling
[   31.711935] vddio-sdmmc-ap: disabling
[   31.717659] vddio-sdmmc3-ap: disabling
[   31.718248] vdd-3v3-sd: disabling
[   31.718278] avdd-io-edp-1v05: disabling
[   31.718295] vdd-usb-hub-en: disabling
[   48.407966] systemd-journald[1501]: /var/log/journal/b50e63a22b7f423cb41ca0b07c14da26/user-1000.journal: Journal file uses a different sequence number ID, rotating.
Log when I try to use GPU (camera):
[ 3377.228088] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x38
[ 3377.230121] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x3a
[ 3377.230954] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x3b
[ 3377.231761] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x3c
[ 3377.232632] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x3d
[ 3377.233481] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x3e
[ 3377.234323] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x3f
[ 3402.071785] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x38
[ 3402.073938] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x3a
[ 3402.074792] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x3b
[ 3402.075612] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x3c
[ 3402.076454] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x3d
[ 3402.077291] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x3e
[ 3402.078149] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x3f
You would need to manually enable it in device tree. Please refer to
Vivid virtual driver devicetree - #5 by ShaneCCC
Okay, I’ll try it. But why is everything working with the default kernel and my device tree? I changed only kernel and encounter this problem so I thought that it is the kernel problem that seems logical. I didn’t changed device tree or rootfs.
And also in my sources (kernel 4.9 32.7.4 version) there are no entries of tegra-186-camera-vivid:
  ~/work/Linux_for_Tegra  find . -name "tegra186-camera-vivid"        ✔  rvp@rvp-pc
I found a solution in custom camera driver
