I need a portable power supply for Jetson Nano so the first option i thought was using a powerbank. But the one i have now doesn’t work with the Nano (it has 5V 2.1A output at full charge). So i was wondering if you have any suggestion on powerbank options. It would be really great if you can send me specific product names for powerbank and any other suggestions about how to power jetson nano with smt portable.
PSA:
Keep in mind that i have one more device that i need to power portabilly(?) with jetson nano so my powerbank needs to have at least two 5V high amper outputs.
We don’t have experience in using this setup. Would need other users to provide suggestion.
I also cannot give specific advice. I will say though that most of the power supply issues are due to regulation quality. Jetsons need an exceptionally stable power supply. Often the failures are related more to that quality than to total power output ability. This would be especially true if the same power supply powers a motor on a drone. You might consider getting a supply which is a higher voltage, and then a separate quality regulator to 5V. Or if a supply is available already with a high quality regulator, then that should work.
