Jetson Nano SD Card Connector is not there
Two years ago I purchased a Jetson Nano. Did not have time
to play with it. Now I am trying to use it. I flashed an SD card as required and went to insert it and there is no SD connector where the documentation states it should be. In the location I see that there is something soldered there about the size of an SD card. It has a QR code with two numbers: 900-13448-0020-000 and SN 1420422037214. The mother board is an Nvidia Corp P3448 and contains a second number:180-13448-DAAA-B01. Help me please!
Jetson Nano SKU you seem to be using is 900-13448-0020-000 which has eMMC fitted. Did you try using this eMMC earlier? Could you send some clear pictures of the module and the carrier board?
