hi, when i run ‘sudo docker pull ultralytics/yolov5:latest’ in my terminnal, the nano aways shun-off.
If someone else have any good idea about this situation , let us know. Thanks very much, in advance.
Could you check if you are running out of storage space?
More, what kind of power supply do you use?
For Nano, please check the below topic for the recommendation of power supply:
Out of the box, the Jetson Nano Developer Kit is configured to accept power via the Micro-USB connector. You’ll need to power the developer kit with a good quality power supply that can deliver 5V⎓2A at the developer kit’s Micro-USB port. Not every power supply rated at “5V⎓2A” will actually do this. The power supply will need to consistently deliver ≥4.75V to avoid brownout condition. Note that some USB cables can lead to additional voltage droop.
See the Jetson Nano Supported Components Lis…
system
closed
October 3, 2021, 7:28am
#5
